Home » Eclipse Projects » Eclipse 4 » ECommandService in Workbench.init() is null
ECommandService in Workbench.init() is null [message #502449] Tue, 08 December 2009 05:24 Go to next message
i made an application oriented on the contacts demo. Just a window with a part containing a TableViewer and an exit command. But when i try to start the application i get a NullPointerException at line 313 in the Workbench.init(). This means that the ECommandService is null when trying to define a category:
ECommandService cs = (ECommandService) workbenchContext.get(ECommandService.class.getName());
Category cat = cs.defineCategory(MApplication.class.getName(), "Application Category", null);
I also tried the e4 tuorial from Lars Vogel and get the same error but the contacts demo works great. Maybe somebody can help me on that. Thanks in advance.
I'm using Eclipse 3.6M3 with e4M2 as target platform.
jens
Re: ECommandService in Workbench.init() is null [message #502452 is a reply to message #502449] Tue, 08 December 2009 05:36 Go to previous messageGo to next message
Are you sure the equinox.ds stuff is part of your launch config? The
problem with ds is that no plugin has a dependency on it and so you need
to add it manually to the launch.
We discussed in our last e4 call a better error handling to help users
find the problem.
Tom
jens schrieb:
> Hello,
> Thanks in advance.
> jens
Re: ECommandService in Workbench.init() is null [message #502456 is a reply to message #502452] Tue, 08 December 2009 06:12 Go to previous messageGo to next message
That solved the problem Surprised Thanks for your fast reply.
Jens Keller
Re: ECommandService in Workbench.init() is null [message #507619 is a reply to message #502449] Wed, 13 January 2010 19:52 Go to previous messageGo to next message
>> Thanks in advance.
>> jens
Hi Jens,
my blog entry / tutorial was a little outdated. I updated the tutorial
to the Eclipse e4 milestone from 15.01.2010 (coming Friday):
http://www.vogella.de/articles/EclipseE4/article.html
Cheers, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: ECommandService in Workbench.init() is null [message #507631 is a reply to message #507619] Thu, 14 January 2010 03:08 Go to previous messageGo to next message
Thanks for this update and also your other excellent tutorials. They helped me a lot working with Eclipse RCP.
Jens Keller
Re: ECommandService in Workbench.init() is null [message #507829 is a reply to message #507631] Thu, 14 January 2010 14:58 Go to previous message
Hello Jens,
I'm happy to hear this. Smile Cheers, Lars
Re: ECommandService in Workbench.init() is null [message #565563 is a reply to message #502452] Tue, 08 December 2009 06:12 Go to previous message
That solved the problem :o Thanks for your fast reply.
Jens Keller
Previous Topic:RCP ERROR
Next Topic:ECommandService in Workbench.init() is null
Current Time: Sat Jul 26 01:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.28444 seconds
