Home » Eclipse Projects » Remote Application Platform (RAP) » DnD question
DnD question [message #507686] Thu, 14 January 2010 06:42 Go to next message
Is there a way to get information about the keystat while a drop occurs?
I'd like to know wether Shift or Control is pressed, simultaneously.
Niels
Re: DnD question [message #507706 is a reply to message #507686] Thu, 14 January 2010 07:33 Go to previous messageGo to next message
Hi.
The value of "detail" is decided by the modifiers pressed:
DND.DROP_MOVE => no modifier or Shift or Alt + any other modifier
DND.DROP_COPY => Control
DND.DROP_LINK => Alt or Shift + Control
But only if the dragSource and dropTarget both support the operation,
otherwise its DND.DROP_NONE.
Greetings,
Tim
> Regards,
> Niels
Re: DnD question [message #507747 is a reply to message #507706] Thu, 14 January 2010 09:28 Go to previous messageGo to next message
Hmm, somehow it is not working for me. I can see Alt or Control, but never
Shift.
One more question: I'm using a LocalSelectionTransfer to see what kind of
selection is going to be dropped. If the dropTarget component doesn't like
the selection is it possible to programmatically stop the drag event?
Thanks, Niels
"Tim Buschtöns" <tbuschto@eclipsesource.com> schrieb im Newsbeitrag
news:hin2ug$tpu$1@build.eclipse.org...
> Hi.
> Greetings,
> Tim
>> Hi,
>> Regards,
>> Niels
Re: DnD question [message #507777 is a reply to message #507747] Thu, 14 January 2010 05:54 Go to previous messageGo to next message
Ok, I can answer the last question by myself: using event.detail =
DND.DROP_NONE.
But Shift is not working for me...
"Niels Lippke" <niels.lippke@airpas.com> schrieb im Newsbeitrag
news:hin9mi$3vf$1@build.eclipse.org...
> Shift.
> Thanks, Niels
>> Hi.
>> Greetings,
>> Tim
>>> Hi,
>>> Regards,
>>> Niels
Re: DnD question [message #507799 is a reply to message #507747] Thu, 14 January 2010 12:26 Go to previous messageGo to next message
> never Shift.
Well, Shift is the same as no modifier pressed (DND.DROP_MOVE), so there
is no change. So, no, Shift can not be detected.
> of selection is going to be dropped. If the dropTarget component doesn't
> like the selection is it possible to programmatically stop the drag event?
Setting operation to DND.DROP_NONE during dropAccept prevents the drop
event. Does that help?
Greetings,
Tim
> Thanks, Niels
>> Hi.
>> Greetings,
>> Tim
>>> Hi,
>>> occurs? I'd like to know wether Shift or Control is pressed,
>>> simultaneously.
>>> Regards,
>>> Niels
Re: DnD question [message #507800 is a reply to message #507799] Thu, 14 January 2010 12:30 Go to previous message
> event.
Yeah, i meant detail, not operation.
Previous Topic:Browser issue with Composites
Next Topic:widget.upload and RAP 1.3M4
Current Time: Fri Jul 25 21:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.03866 seconds
