| bug 92163 ? [message #50778] | Fri, 22 April 2005 08:05  |  |
| Eclipse User  |  |  |  |  | Any clue what might be the problem here. I'm essentially locked out of using ADJT, and I'm starting to get the shakes.
 thanks!
 -barry
| Re: bug 92163 ? [message #50915 is a reply to message #50805] | Fri, 22 April 2005 11:37  |  |
| Eclipse User  |  |  |  |  | Sian January wrote: > Hi Barry,
 > Would you be able to try this with the latest development build and let
 > us know if you still have the problem?
 Do you mean 1.2.0.20050420095141? If so, that is what I was using.
 -barry
| Re: bug 92163 ? [message #587783 is a reply to message #50778] | Fri, 22 April 2005 08:56  |  |
| Eclipse User  |  |  |  |  | Hi Barry,
 us know if you still have the problem?  The code that appeared to
 produce that exception has been completely overhauled this week so
 hopefully the latest build should fix your problem.  Development builds
 are available from the AJDT download page:
 http://www.eclipse.org/ajdt/download.html
 Sian
 > thanks!
 > -barry
| Re: bug 92163 ? [message #587813 is a reply to message #50805] | Fri, 22 April 2005 11:30  |  |
| Eclipse User  |  |  |  |  | Sian January wrote: > Would you be able to try this with the latest development build and let
 Yes, I'll try and let you know. Thanks.
 -barry
| Re: bug 92163 ? [message #587816 is a reply to message #50805] | Fri, 22 April 2005 11:35  |  |
 This version is for 3.1M6?
 -barry
| Re: bug 92163 ? [message #587824 is a reply to message #50805] | Fri, 22 April 2005 11:37  |  |
 -barry
FUDForum. Page generated in 0.03603 seconds
