Home » Language IDEs » ServerTools (WTP) » jsdt content assistence in object literals
jsdt content assistence in object literals [message #507662] Wed, 13 January 2010 23:56 Go to next message
I observed a strange behaviour of the content assistance of the jsdt
editor. Could someone please help with this?
If I use the editor in conjunction with object literals
assigned to variables, everything works as expected.
The "type" of an object (i.e. its members) is derived
even if I the type of a variable is only known across
multiple assignments as shown in the example below:
var a = {
foo : function() {
this.name; // works
var b = {
other : a,
foo : function() {
this.name; // works
// works:
// jsdt derives the "type" of
// "other" and suggests "name".
// It "follows" the "assignment" "other : a"
// and thus knows the "type" of "a"
this.other.name;
However, this does not seem to work with the following
example using nested object literals:
var root = {
c : {
foo : function() {
this.name; // works
d : {
other : root.c, // works
foo : function() {
this.name; // works
// !! does not work !!
// jsdt does not supply any suggestions
// for "other" in this case.
// ("No Default Proposals")
this.other.name;
My first assumption was, that jsdt is unable to "follow" the
"assignments" within the object literal, because the object is not
complete at the time of editing. However, content assist seems
to work when I try to auto-complete the "root." at "other : root.c".
I am currently using:
JavaScript Developer Tools
Version: 1.1.2.v200908101420-77-FGCCcNBC-BhLcE_Pm
Build id: 20090917225226
Thanks a lot for any feedback.
Kind regards
Harald
jsdt content assistance and object members (was: jsdt content assistence in object literals) [message #507713 is a reply to message #507662] Thu, 14 January 2010 02:54 Go to previous messageGo to next message
Hello again,
more investigation seems to indicate that the problem is
not (exclusively) related to the use of object lieterals.
See examples below.
jsdt makes correct suggestions for all examples given
in the sample code, except for the expression
"this.s.a" within function "foo2".
var x = {
x1 : {
a : "a",
b : "b"
x.x1; // okay
var y = x;
y.x1; // okay
y.x1.a; // okay
y.x1.b; // okay
var z = x.x1;
z.a; // okay
z.b; // okay
var l = {
r : x,
foo1 : function() {
this.r.x1; // okay
s : x.x1, // okay
foo2 : function() {
* does not work
* i.e. typing "this.s. Control-Space" does
* not make any proposals
this.s.a;
t : {
u : {
m : 3
foo3 : function() {
this.t; // okay
this.t.u; // okay
this.t.u.m; // okay
Re: jsdt content assistance and object members [message #508426 is a reply to message #507713] Mon, 18 January 2010 13:11 Go to previous messageGo to next message
On 1/14/2010 7:53 AM, Harald Finster wrote:
> Hello again,
> See examples below.
> var x = {
> x1 : {
> a : "a",
> b : "b"
> x.x1; // okay
> var y = x;
> y.x1; // okay
> y.x1.a; // okay
> y.x1.b; // okay
> var z = x.x1;
> z.a; // okay
> z.b; // okay
> var l = {
> r : x,
> foo1 : function() {
> this.r.x1; // okay
> s : x.x1, // okay
> foo2 : function() {
> * does not work
> this.s.a;
> t : {
> u : {
> m : 3
> foo3 : function() {
> this.t; // okay
> this.t.u; // okay
> this.t.u.m; // okay
This sounds like a bug. Please report it at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing&component=wst.jsdt
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: jsdt content assistance and object members [message #508585 is a reply to message #508426] Tue, 19 January 2010 09:45 Go to previous message
thanks for your reply!
okay, I reported this bug (or you could say "missing feature")
and submitted a possible fix.
Kind regards
Harald
Previous Topic:JSP editor absent after installing JEE Dev Tools
Next Topic:Use Eclipse as Standard HTML-Editor
Current Time: Mon Oct 27 06:41:25 EDT 2025
Powered by FUDForum. Page generated in 0.05094 seconds
