Home » Modeling » EMF » Re: JMerger Example and Standalone Use
Re: JMerger Example and Standalone Use [message #507566] Wed, 13 January 2010 15:39 Go to next message
I'm cross posting this to the EMF newsgroup, as JMerger lives within EMF.
Ed, we await your wise response.
Paul
vvernon wrote:
> Hello,
> I am new to JMerger. I saw I nice example of using the now deprecated
> version (org.eclipse.emf.codegen.jmerge.JMerger) on:
> http://www.ibm.com/developerworks/library/os-ecemf3/
> But I need an example for the newer version
> (org.eclipse.emf.codegen.merge.java.JMerger). Are there any available?
> Also I am trying to understand if the newer JMerger can be used outside
> the Eclipse/EMF environment. I tried with the deprecated version but I
> ran into many dependency issues. After I finally got all the jars I
> needed to run JMerger it appeared that a NullPointerException indicated
> that some deep environment dependency on Eclipse prevented reuse outside.
> Thanks for your help!
Re: JMerger Example and Standalone Use [message #507574 is a reply to message #507566] Wed, 13 January 2010 16:02 Go to previous messageGo to next message
Comments below.
I hope this one counts. :-P
> Paul
> vvernon wrote:
>> Hello,
The org.eclipse.emf.examples.jet.article2.codege example is updated to
use the non-deprecated merger.
>> outside the Eclipse/EMF environment.
I think the one that uses the AST facade, the default, does work stand
alone because it's JDT dependencies also work stand alone.
>> I tried with the deprecated version but I ran into many dependency
>> issues.
Yes, JDT's JDOM doesn't work stand alone.
>> After I finally got all the jars I needed to run JMerger it appeared
>> that a NullPointerException indicated that some deep environment
Yes, I think so. But I seem to recall that the AST-based version did
work stand alone.
Re: JMerger Example and Standalone Use [message #507613 is a reply to message #507574] Wed, 13 January 2010 23:43 Go to previous messageGo to next message
Ed,
Thanks for your help, but I can't find what you referenced. I grep'd and googled for: org.eclipse.emf.examples.jet.article2.codegen
I did find a CodeGen class, but it uses the deprecated JMerger, and it deals with JET output, not generated Java sources.
Can you provide a bit more context for me? Where would I find the example you are referencing?
Thanks!
Re: JMerger Example and Standalone Use [message #507703 is a reply to message #507613] Thu, 14 January 2010 02:34 Go to previous messageGo to next message
--------------050905050901040805020502
If it's not available as an installable example or as part of the
article (though it's the source for it), then you can get it straight
from CVS:
http://wiki.eclipse.org/EMF/Getting_Source
vvernon wrote:
> Ed,
> Thanks!
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
from CVS:<br>
<blockquote><a href="http://wiki.eclipse.org/EMF/Getting_Source">http://wiki.eclipse.org/EMF/Getting_Source</a><br>
</blockquote>
<br>
vvernon wrote:
<blockquote cite="mid:him7ea$joc$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks!
<br>
</blockquote>
</body>
</html>
--------------050905050901040805020502--
Re: JMerger Example and Standalone Use [message #507880 is a reply to message #507703] Thu, 14 January 2010 19:37 Go to previous messageGo to next message
Ed,
Thanks, I think I found the article:
http://www.eclipse.org/articles/Article-JET2/jet_tutorial2.h tml
This is still based on the deprecated version. But at least now I see how to provide missing pieces that were probably causing the NPE before. I will give it a shot.
If you know for sure that a more recent article exists that documents the newer JMerger please point me to the URL.
Thanks!
Re: JMerger Example and Standalone Use [message #507895 is a reply to message #507880] Thu, 14 January 2010 20:23 Go to previous message
I think only the code in CVS was updated to fix the deprecation warnings...
vvernon wrote:
> Ed,
> Thanks!
Previous Topic:instanceof for (dynamic) EObject
Next Topic:Teneo: create table fails without any warning message
Current Time: Sat Jul 26 20:56:45 EDT 2025
Powered by FUDForum. Page generated in 0.03671 seconds
