Home » Modeling » EMF » [CDO] 3.0 Standalone (spring wired) server and client example
[CDO] 3.0 Standalone (spring wired) server and client example [message #507536] Wed, 13 January 2010 14:16 Go to next message
Please have a look at the following example http://wiki.eclipse.org/CDO_Spring
I want to run a CDO server inside a J2EE web application, without the OSGI container.
Eike, can you help me out with replacing the TCP transport with JVM transport?
Thanks in advance,
Assen
Re: [CDO] 3.0 Standalone (spring wired) server and client example [message #507679 is a reply to message #507536] Thu, 14 January 2010 06:04 Go to previous message
Hi Assen,
Normally that's quite simple: You prepare your IManagedConatiner with
JVM factories instead of TCP factories (see JVMUtil.prepareContainer).
I'm confused by your xml example. You seem to create the acceptor and
connector beans explicitely:
<bean id="accpetor" class="org.eclipse.net4j.internal.tcp.TCPAcceptor" init-method="activate" destroy-method="deactivate">
<property name="address" value="localhost"/>
<property name="port" value="2036"/>
<property name="selector">
<bean id="selector" class="org.eclipse.net4j.internal.tcp.TCPSelector" init-method="activate" destroy-method="deactivate"/>
</property>
<property name="config" ref="serverConfig"/>
</bean>
<bean id="connector" class="org.eclipse.net4j.internal.tcp.TCPClientConnector">
<property name="host" value="localhost"/>
<property name="selector" ref="selector"/>
<property name="config" ref="clientConfig"/>
</bean>
Why do you need the factories then?
Cheers
/Eike
Assen Sharlandjiev schrieb:
> OSGI container.
> transport?
> Thanks in advance,
> Assen
Previous Topic:childen of a resource
Next Topic:editor code usage
Current Time: Thu Jul 24 22:14:31 EDT 2025
Powered by FUDForum. Page generated in 0.06808 seconds
