Home » Eclipse Projects » EclipseLink » Unexpected entity version number
Unexpected entity version number [message #507187] Tue, 12 January 2010 02:26 Go to next message
I wrote several test for JPA (eclipselink 2.0) scenarios like concurrent update with optimistic locking.
I use DerbyDB and DBUnit to initialize a database before each test.
 @Before
    public void setUp() throws MalformedURLException, DataSetException, DatabaseUnitException, SQLException {
        FlatXmlDataSetBuilder builder = new FlatXmlDataSetBuilder();
        builder.setColumnSensing(true);
        dataset = builder.build(new File(initDataSourceFile));
        //Clean and initialize database
        DatabaseOperation.CLEAN_INSERT.execute(connection, dataset);
        EntityManagerFactory emFactory = Persistence.createEntityManagerFactory(testPUName, properties);
        testEm = emFactory.createEntityManager();
        logger.log(Level.INFO, "+++ Test begin");
There are two test methods that use two entity managers (testEm created in setUp and additional one created in the test method) to simulate concurrent update operations:
@Test
    public void concurrentUpdate() {
        EntityManagerFactory emf = Persistence.createEntityManagerFactory(testPUName, properties);
        EntityManager concurrentTestEm = emf.createEntityManager();
        Query firstQuery = testEm.createNamedQuery("Student.getByID");
        firstQuery.setParameter("id", 2);
        Query secondQuery = concurrentTestEm.createNamedQuery("Student.getByID");
        secondQuery.setParameter("id", 2);
        Student student, student2;
        //Start two transaction, each on different entity manager
        try {
            testEm.getTransaction().begin();
            concurrentTestEm.getTransaction().begin();
            student = (Student) firstQuery.getSingleResult();
            student.setImie("Wiesław");
            student2 = (Student) secondQuery.getSingleResult();
            student2.setImie("Kacper");
            testEm.getTransaction().commit();
            //the following operation should fail
            concurrentTestEm.getTransaction().commit();
            //Error, concurrent update was possible
            fail("Concurrent update was possible");
        } catch (javax.persistence.RollbackException ex) {
            //Oczekujemy javax.persistence.OptimisticLockException opakowany w {@link javax.persistence.RollbackException}
            Throwable cause = ex.getCause();
            if ((cause != null) && (cause instanceof javax.persistence.OptimisticLockException)) {
                logger.log(Level.INFO, "**** OK - Expected optimistic lock exception occured");
            } else {
                logger.log(Level.WARNING, "Błąd", ex);
                fail("Unexpected exception, should be javax.persistence.OptimisticLockException");
        } finally {
            concurrentTestEm.close();
        //Dump DB
        dumpDb=true;
    @Test
    public void concurrentDeleteAndUpdate() {
        secondQuery.setParameter("id", 3);
        try {
            testEm.remove(student);
            //Concurrent update exception is thrown during commit. It was not expected here.
            //Student entity version is 2, but should be 1
            //When concurrentUpdate() test is commented, this will fail
            //Running test in debug mode and setting breakpoint in concurrenUpdate,
            //will cause this test to fail
            } else {
        } finally {
        //Dump DB
        dumpDb=true;
And the problem is with the concurrentDeleteAndUpdate test method. This test method succeedes but should fail. If you look carefully you will find that there is no concurrent update. I changed secondQuery id parameter to 3 intentionally to show this unexpected for me behaviour. firstQuery.getSingleResult returns student entity with version set to 2, but should be 1.
  1. When I run test suite in debug mode and set breakpoint in concurrentUpdate and then continue the test, the concurrentDeleteAndUpdate fails (student version is 1)
  2. If I comment the first test method (concurrentUpdate) concurrentDeleteAndUpdate fails (as expected).
What is wrong with my test methods? You can download maven project with these tests from:
http://zskl.zsk.p.lodz.pl/~mkwapisz/jpatest/entitytest.zip
Thanks in advance for your help
Marcin Kwapisz
icon8.gif  Re: Unexpected entity version number [message #507297 is a reply to message #507187] Tue, 12 January 2010 15:03 Go to previous messageGo to next message
I have run these tests against OpenJPA 2.0.0-m3 and everything works perfectly. So the only conclusions are:
  1. there is a bug in eclipselink
  2. something is wrong with my eclipselink configuration
Marcin Kwapisz
Re: Unexpected entity version number [message #507501 is a reply to message #507187] Wed, 13 January 2010 12:12 Go to previous messageGo to next message
I dont see any problems with the tests directly, can you post the logs from running them both? This will show the EclipseLink build/version being used as well as the SQL it is issuing which can show if the version field is being used in the updates or not. Be sure to set the eclipselink.logging.level property to FINE or FINEST to see the sql getting used.
Best Regards,
Chris
Re: Unexpected entity version number [message #507593 is a reply to message #507501] Wed, 13 January 2010 19:14 Go to previous messageGo to next message
You can download the test project using the link from my first post. This is maven project so there should be no problems with running the test suite. You can check configuration and dependency versions in pom.xml and of course try to reproduce the problem. Uncomment the first line of JPATest.setUpClass to run the test using in-memory database.
There is another very interesting thing. I have run the test suite in debug mode. When a breakpoint is set within the try block of the first test method (concurrentUpdate) and then the test is continued, the second test method (concurrentUpdateAndDelete) works as expected (query reads Student entity with version 1).
2010-01-14 00:43:51 pl.lodz.p.ck.egzaminy.entities.JPATest setUp
INFO: +++ Początek testu
[EL Fine]: 2010-01-14 00:43:51.609--ServerSession(2456372)--Connection(3075861)--T hread(Thread[main,5,main])--SELECT TS_ID, WD_NAZWA, CZ_IMIE, ADR_EMAIL, WERSJA, CZ_NAZWISKO, AL_ALBUM FROM TESTDB.STUDENT WHERE (TS_ID = ?)
bind => [2]
bind => [2]
[EL Fine]: 2010-01-14 00:43:51.609--ClientSession(10808772)--Connection(3075861)-- Thread(Thread[main,5,main])--UPDATE TESTDB.STUDENT SET CZ_IMIE = ?, WERSJA = ? WHERE ((TS_ID = ?) AND (WERSJA = ?))
bind => [Wiesław, 2, 2, 1]
[EL Fine]: 2010-01-14 00:43:51.609--ClientSession(23398687)--Connection(3075861)-- Thread(Thread[main,5,main])--UPDATE TESTDB.STUDENT SET CZ_IMIE = ?, WERSJA = ? WHERE ((TS_ID = ?) AND (WERSJA = ?))
bind => [Kacper, 2, 2, 1]
[EL Warning]: 2010-01-14 00:43:51.609--UnitOfWork(9089012)--Thread(Thread[main,5,main ])--Exception [EclipseLink-5006] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.OptimisticLockException
Exception Description: The object [pl.lodz.p.ck.egzaminy.entities.Student[id=2, ver=2]] cannot be updated because it has changed or been deleted since it was last read.
Class> pl.lodz.p.ck.egzaminy.entities.Student Primary Key> [2]
[EL Warning]: 2010-01-14 00:43:51.609--UnitOfWork(9089012)--Thread(Thread[main,5,main ])--javax.persistence.OptimisticLockException: Exception [EclipseLink-5006] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.OptimisticLockException
2010-01-14 00:43:51 pl.lodz.p.ck.egzaminy.entities.StudentTest concurrentUpdate
INFO: **** OK - Expected optimistic lock exception occured
2010-01-14 00:43:51 pl.lodz.p.ck.egzaminy.entities.JPATest tearDown
INFO: +++ Koniec testu
[EL Fine]: 2010-01-14 00:43:51.625--ServerSession(2456372)--Connection(3075861)--T hread(Thread[main,5,main])--SELECT TS_ID, WD_NAZWA, CZ_IMIE, ADR_EMAIL, WERSJA, CZ_NAZWISKO, AL_ALBUM FROM TESTDB.STUDENT WHERE (TS_ID = ?)
bind => [2]
2010-01-14 00:43:51 pl.lodz.p.ck.egzaminy.entities.StudentTest concurrentUpdateAndDelete
INFO: pl.lodz.p.ck.egzaminy.entities.Student[id=2, ver=2]
bind => [3]
INFO: pl.lodz.p.ck.egzaminy.entities.Student[id=3, ver=1]
[EL Fine]: 2010-01-14 00:43:51.625--ClientSession(12090673)--Connection(3075861)-- Thread(Thread[main,5,main])--DELETE FROM TESTDB.STUDENT WHERE ((TS_ID = ?) AND (WERSJA = ?))
bind => [2, 2]
[EL Warning]: 2010-01-14 00:43:51.625--UnitOfWork(3023915)--Thread(Thread[main,5,main ])--Exception [EclipseLink-5003] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.OptimisticLockException
Exception Description: The object [pl.lodz.p.ck.egzaminy.entities.Student[id=2, ver=2]] cannot be deleted because it has changed or been deleted since it was last read.
[EL Warning]: 2010-01-14 00:43:51.625--UnitOfWork(3023915)--Thread(Thread[main,5,main ])--javax.persistence.OptimisticLockException: Exception [EclipseLink-5003] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.OptimisticLockException
Re: Unexpected entity version number [message #507719 is a reply to message #507593] Thu, 14 January 2010 08:22 Go to previous messageGo to next message
I find it odd that the logs are showing the update statements from the first method using the same connection - this might explain why the delete fails. If they are appart of the same transaction, then when the second statement fails it will rollback the version number change. What I don't understand is how, since the code should be starting two distinct transactions. Can you change the logging to finest? This should show the transaction begin/end in the logs.
Best Regards,
Chris
Re: Unexpected entity version number [message #507936 is a reply to message #507719] Fri, 15 January 2010 04:07 Go to previous messageGo to next message
I think I have found the "problem". It is not a bug, it is a feature of jpa2 called second level cache. See chapter 3.7 of the JSR317 spec. Setting shared-cache-mode to "none" fo persistence unit solves the unexpected entity version number problem. The default value for eclipselink must be "all", I think.
Marcin Kwapisz
Re: Unexpected entity version number [message #508007 is a reply to message #507936] Fri, 15 January 2010 09:44 Go to previous messageGo to next message
Ah, I didn't notice your setup/tear down methods using a connection directly. Yes, JPA providers are allowed to use a second level cache, and EclipseLink has always done so - JPA2 just added api allowing standard configuration. Because your tests clear out the database between tests, you might also close the EntityManagers and factories, clearing out the cache. In production, a second level cache can greatly increases performance,but it all depends on how often changes are made outside of the application.
EclipseLink offers a number of other features to help reduce having problems with stale data in such as invalidation and cache coordination.
Best Regards,
Chris
Re: Unexpected entity version number [message #508178 is a reply to message #508007] Sun, 17 January 2010 05:03 Go to previous message
There is EntityManagerFactory#getCache()#evictAll() method that can be called in the setUp method.
Marcin Kwapisz
Previous Topic:Cascade.Persist problems
Next Topic:FileNotFoundException: tempToDelete.xml (Access is denied)
Current Time: Wed Jul 23 20:37:14 EDT 2025
Powered by FUDForum. Page generated in 0.08268 seconds
