Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to set the title's color of a group?
How to set the title's color of a group? [message #507077] Mon, 11 January 2010 13:38 Go to next message
Originally posted by: janila.web.de
I wanted to create a group with black background and white foreground.
Here is a small snippet:
Group group = new Group(parent, SWT.SHADOW_ETCHED_OUT);
group.setText("Test");
group.setForeground(parent.getDisplay().getSystemColor(SWT.C OLOR_WHITE));
group.setBackground(parent.getDisplay().getSystemColor(SWT.C OLOR_BLACK));
However it did not have the wished effect. Background of widget is
black, border is white but title text remains black and is effectively
invisible. I'm using windows.
So, how can I change the title's color of a group object.
Tril
Re: How to set the title's color of a group? [message #507362 is a reply to message #507077] Wed, 13 January 2010 01:37 Go to previous messageGo to next message
Which version of Windows and Eclipse you are using ? When I tried the
snippet on Vista (with Eclipse latest HEAD), I have the background of
the Widget as black, border is white and also, Title appeared in white
(as Foreground is set to White).
The color of the title is changed based upon the Foreground color set to
the Group widget.
Re: How to set the title's color of a group? [message #508133 is a reply to message #507362] Sat, 16 January 2010 07:48 Go to previous messageGo to next message
--------------080603020902070202000405
Am 13.01.2010 07:37, schrieb Praveen:
> the Group widget.
thank you for your answer! Here are my specs:
windows 7 home premium 64 bit
eclipse sdk 3.5.1 M20090917-0800
swt 3.5.1 final release
jre JavaSE-1.6
The example code is attached as well as an image showing that setting
the foreground color of a group to white and background to black makes
the group's title invisible for me.
Since you are observing different things, should I maybe file a bug
report somewhere, or do I still making something wrong?
name="GroupTest.java"
filename="GroupTest.java"
package de.jk.swt.examples;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Shell;
public class GroupTest {
* @param args
Shell shell = new Shell();
shell.setSize(400, 400);
shell.setLayout(new RowLayout());
Display display = shell.getDisplay();
Group group;
// visible title of group
group = new Group(shell, SWT.SHADOW_ETCHED_OUT);
group.setSize(100, 100);
// invisible title of group
group.setForeground(display.getSystemColor(SWT.COLOR_WHITE)) ;
group.setBackground(display.getSystemColor(SWT.COLOR_BLACK)) ;
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep ();
display.dispose ();
Content-Type: image/jpeg;
name="GroupTest.jpg"
filename="GroupTest.jpg"
/9j/4AAQSkZJRgABAQEASABIAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wgAR
CAIwAyADASIAAhEBAxEB/8QAGwABAAMBAQEBAAAAAAAAAAAAAAMEBQIGAQf/ xAAYAQEBAQEB
AAAAAAAAAAAAAAAAAQIDBP/aAAwDAQACEAMQAAAB9XFz8ue/sDUscVZiXumL nVKUl7gklvdU
LEs7hL24HbgduB24HbgduB24HbgduB24HbgduB24HbgduB24HbgduB24Hbgd uB24HbgduB24
HbgduB24HbgduB24HbgduB24HbgduB24HbgduB24HbgduBHPHZSKC7kXVr5w WXmvyadO9nzN
yGT4nP2Po5mhnOOECy9QEncclqRMQphCmEKYQphCmEKYQphCmEKYQphCmEKY QphCmEKYQphC
mEKYQphCmEKYQphCmEKYQphCmEKYQphCmEKYQphCmEKYQphCmEKYQphCmFSz WsnSLpe3z6HH
YPh9ARdnT4Pp8PrnoKnBefPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ABUs1rKQUtbO
azrvyXW4tCjozNGtejzn7Wv1q4l+WJMpcitv5mvnHzQpaBlTfUT2qHytBFmG wzvpoMyQvqIv
OOwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACpZrWU6rz5DVuz5+/daHWTpzK KCtJqfatervV
CeJJchW3x8yzX6ytA55pfI1eMtWxHn3I66zu7LjNS63yjbq0AAAAAAAAAAAA AAVSywfib7AG
+wBvsAb7AG+8+PQPPj0Dz/yvQvPD0Lz309A8+PQPPo9A8+PQMD6u8wRvMH4b 7BG8wfh6Bkah
Xs1rKdUb1RqGWC1bXvRSSQxzRSWKk32op4uiKKSUs0LcRHdrylb538hF3LUd qCQqzfOyKSCY
tgAAAAAAAAAAAAAA+ee9B5tHcVnvygfHTI+H345PvLiz7x841EbixH94scvl dTV+yw4+x39j
SzfYepbd3K+8eml8pdS2a32LHWK3W64eqP719PvpfL+k6+OazWs5v3H2TXnL 2qtxtOZJm1tt
Jn19hWLZ0RgN8V8vcGPoWBi/NsYf3bGPetDAl2hlfdRAUAAAAAAAAAAAAABz 5v0nm7JJ+pd5
gRy5vz5qjKo+j8bUnz845P0f54S2nr+vHaB7X5vDAb48/wDd8YX3cGG3Bhtw Yn3aLj96oyvu
ojLagy49irXm/Seb9JE1mtZzenzEa3Hn7tumyrkllmQG0wrFuqo1JnZZEZts bg3GLsn1UtgA
AAAAAAAAAAAAAAAAAHPm/Sebsu6WbpWBnQDyXrfJH5oAB6TzfpD9UAAAAAAA AAAq2qtnm/Se
b9JZNZpW5e+e0oAAAACOQAAAAAAAAAAAAAAAAAAAAAAc+c9H5xLujn6GoGdA PJet8kfmgAHp
PN+kP1QAAAAAAAAACraq2ec9H530Rn6+PsdeHF35949wWr8tfbD59lAAAAAA AAAAAAAAAAAA
AAAAAAA5876LzyXr1O5QSgPJet8kfmgAHpPN+kP1QAAAAAAAAACtZrJ570GF u1n6+PsdeNoc
e4Ef35HZHzeFPm8K8V0UIdUc9EoAAAAAAAAAAAAAAAAAAAAHPnfReZs1LuPs WBnQCpbGU1Rl
NUZXekAAAAAAAAAAFazTswt/y3qbM/XyNfpxsdVLfHuI1k4xOLr0LOik1lfP NhiS26zMsSW2
dCa7GvlpgTJssyKNhjy1psaNN1m2ItMqJdp57Vq4g7JAAAAAAAAAAAAc+Z9N 5iyzs4u1qBjQ
AAAAAAAAAAAAAACncp2eW9X5L1upn6+Rr75Whx7gAfM3RqR9krykvH3iuPvz 5FjqKwR8T07V
mncKnf3iSXuGREkE9soAAAAAAAAAAAAAAAOfMen8xZY2sXa1AxoAAAAAAAAA AAAAABSu0rPK
eu8h6/UztjI198rQ49wAOcLfqxm2boqcaHyzKafC1a+v8ih9uqzLlj4TYmt8 jNvSc19sQdEq
Hgso+SZz0AAAAAAAAAAAAAc+Y9P5iyxtYu1qBjQAAAAAAAAAAAAAACldpWeT 9f5H12pnbGRr
75Whx7gAc5mlixParKsc1Z0+S2MqWf78jJp6NuzmvofWqs9HksOZmYeu6q2P tcX4oYov2sa5
ZdZ862QAAAAAAAAAAAc+Y9P5iyxtYu1qBjQAAAAAAAAAAAAAACldp2eT9d5H 12pn6+Rr75Wh
x7gAOOxzFOOOJg47HHEw44mAHLocfehF12OfnY44mHHEwi76AAAAAAAAAAAA HPmPT+YssbWL
tagY0AAAAAAAAAAAAAAAp3KdnlPW+S9bqZ+vj7G+Voce4AHGfp1Dnmbgkjlj OPsnwht1rJKA
AAAAAAAAAAAAAAAAAAADnzHp/MWWNrF2tQMaAAAAAAAAAAAAAAAU7lOzyvrP J+s1M/Xx9jfK
0+Q8u06Ak6ATV/tQ0a0I+9fYTvmesaVSGwvHdWVJOq/Z1LT+EnfEiQaMdNdN i3FvM6HU12V9
NRk9mmyvhrMWwaSnVjWZNlbqBJOgE6AToBOgE6AToBOgEvmPQebq5tYm3QY0 AAAAAAAAAAAA
AAAp3KVnlvWeQ9TvNXXyNfXOzHK49okqokohz9PEjQh+Ql+anzVuvV+rasU6 5bkryyV7VO3T
5fyIsqt07jlsVn93RSh01Zkt4ZnegKXN8ZnWiKH28KPVxESURJRElESURJRE lESURJRB5r1X
mLJ9vF2qDGgAAAAAAAAAAAAAAFK7Ss8l6zynr9Zz9fI1987Q49wAFOzmF75H XND5XEscUpLx
FwXIvtmqskHGluGb5lJJBPAAAAAAAAAAAAAAAAAHPmPT+YssbWLtagY0AAAA AAAAAAAAAAAp
XaVnk/X+Q9fqZ2xka++Voce4AA5OnP0+nw+nB247D4Prjo+nJ056AAAAAAAA AAAAAAAAAOfM
en8xZY2sXa1AxoAAAAAAAAAAAAAABSu0rPKeu8j67UztjI198rQ49wAPkEtB NKl84jvqSCny
1RW1zVvnzmtLJ1HzLVulxzGjR7lIft2gfb+HoVcUK+rrsnpNRkzl9mfDUYto 0FejGszLMtoA
AAAAAAHPmPT+Ysn28Tb1AxoAAAAAAAAAAAAAABTuU7PJ+u8j67Uz9fI198rQ 49wAFG3hGzHV
gNabM+JowZ/S6UmdWNLujNHNrPs1PHay4tdUbdWeObBF8mEMdoVpJRW+WlRc WEVVpVaSVEHc
gAAAAAAAA58x6fzFk+3ga2s2VZjVlWFlWFlWFlWFlWFlWFlWFlWFlWFlWFlW FlWFlWFlWFlW
Fmn3VrzfrfJet1M/Xx9jfK0OPcADmlezyX53DFmJJVXubki+WYiSOSzWd9n+ adV7X3JLDNAA
AAAAAAAAAAAAAAAHzA9BAeG+erj3jzD1CvLvUDzHz1A8w9OPMPTjzD048w9O PL/fTjzH30w8
y9MPM/fSjzT0qPNPSjzT0o809KPNPSjzXz0w8/62K/jWBr4+x242hx7gAcYe /TK0Gmir8v8A
NZnzRhOIdGMy7ljsox6XMU+rf0zY9RWdLclSlHofVzGjEUJrfRnRavJT5vor 92flmZDqRrHL
JMZ3y51uZWzW7MazasaUYNWHKX7M52QUAAAAAAAAAAAAAAAAAAAAAB57XyNf twtDj3AA5zdQ
U4NMUft0Z3d4Zkl8ZNu2KPGiKS6M+LVGc0RTi0RnS3BnSXRnx6go/L4p92RR 40RW+WhUjvrM
6W4XO+aRKcegWD7MgAAAAAAAAAAAAAAAAAAAAAADz2vka/bhaHHuAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAB53YyNftwtDj3AA+ZGxWKdmTmOUys/qz0 cp4CeT4PqP6d
gAOR0+fDoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHndjI1+3C0OPcACLH 3S5f3T+FGWG4
V8/VgkqzywE/HX2zOnujM+2y1UlgrW68539q9RoqsNaCpKTIZgAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAADz2vka/bhaHHuAAABVs/RFx1jxpxQ1q0+s2wlnuGnLpR06lavck I7r6RQ7uCvxb
FaSURyAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB57Xx9jtwtDj3AARSwkwAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPPa+PsduFoce4AHGJvIx2xHWPY1I0g zN5Lkw7fNY8u
sOaGjyV7QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAee18jX7cLQ49w CvYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMnQis6z0M6A56AAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAACpZrWU6gn4XsAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAH/8QAMBAAAQMEAQIEBQQDAQEAAAAAAgABAwQSExQRMTMFIDJQ ISI0QGAQFSMw
BiQ1Q0H/2gAIAQEAAQUCb1Rm5Nl+bKCeUGWX53nBhyMsgumJia4rW+VM9zfi 5cuh+CeNnfEy
w/HGPGEeHjciaEWUYNGPHwTPw7Si6uFXCrhVwq4VcKuFXCrhVwq4VcKuFXCr hVwq4VcKuFXC
rhVwq4VcKuFXCrhVwq4VcKuFXCrhVwq4VcKuFXCrhVwq4VcKuFXCrhVwq4Vc KuFXCrhVwq4V
cKuFXCrhVwq4VcKuFXCrhVwq4VcKuFXCrhVwq4VcKuFXCrhVwq4VcKuFXCrh Vwq4VcKuFXCh
FrWjDh4wZmKndnKnYRKEiup+L6ZYwTS0zpgjJuYeY3hlRYAJzpmEBhkF8DGx Uzp5KVkxUxEz
w2OVMI2w34gWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYg WIFiBYgWIFiB
YgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWI FiBYgWIFiBYg
WIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIFiBYgWIEHobo/SOjfENJYzU lsmlYzUDOLix
A9HehhsGwyOOmxQyUzSTDSCz4zxlSi87UTMzULMoqYxPUuB6IXFgdpPw0PQ3 T8iD0N0vZXMu
f0cxFv05/UpBBufiuf05XLfpsxO71cDfh4ehumJmc6UiHTkGRqV2kGiFoIxc Q13zarhBBGcc
LUXEusbRFFI80NKeP9ubCImKagWn8vB3ahEA08ggMb7H4aHobonqXEWrbnaq YnepkeAX5bM9
7VBuMUt4NV8mU0uMpHaYKp3Hde1jZ1uPztESubnOQxbXMewSeoLhjZ2CqPI9 VYgmMiGruWwT
u1Ty8cxFGBXB+Bh6G6LFC6elhc8YXWRiIiINijvemheIYgEcUd5Q07Bgg5jp YY2wxWWCztDE
LPHGTWDdrwCLwxMsUd7QQsNgLHELCMFjwQuTwxCmhieJ4o3LDHx+CB6G6Iop rbKhpWinyNTG
9PFywY5M2OQIIMgwtDO0zxSYSaTNCEzx60+EcjJoJ1gk4e93wz45oppIrZSq Rp5MMsUxlK0h
g8Utkkc0k9MMthxVBU3BPPCxN99JKwNu8rcdbjrcdbjrcdbjrcdbjrcdbjrc dbi3VurdW6t1
bq3VurdW6t1bi3FuO62iW0S2yW0S23W2S2yW2S3HZRVQyJn5QehuiepZmasj d2qY3d6tsQvy
2Zr2qRcY5GlBqyF5CqHxvJxKNUBNvw4xdiFqyJ32h5d+B2hcZanGD1QCTVsZ hJVBE5lYDVXw
2B5eqARztb986rHuL/4QEI/YM6Z/OMrRuEhGzz8O01z5XtmqWW0yiLI2zwhq GM3eyqhflg9D
dE9NG60o79eNiaEGAQYGwhe9MGIIAEcAcvTRuD04OUdIADrx24xuami4147c Y360Vr0sRDqj
mwBZrxrEHOtHa8IOUlHGTa4cffP0qu6TMQFKzxf0crn+hvNyuqtTCrFYjiuW usCwIYOCl+pp
+gehuiJ5mbPO0jPUZLZzpondw5lzXyjBBITws9VmO94CMs8M0px/7mETJM9U 6/2OHInfmoeO
d5ThyyvUjsvDIVQ5GTuwxmzXVLyihI9f75+lV3QjeR9Y1rGtY1rGtY1qmp3j p32aRbFIs9Is
1Is1GhOlMtB1+3uv291+3Ov25ftzrQdaDrQdaDrQdaLrRJaRLUJaprWNaxrW NaxrWNHCQDL9
TT9A9DdPen6VXdpvVVBdTnLMEtMchn+vjcEZJ+LlC1O6t8PVvh6oaemlrPta jtS/U0/QPQ3T
3p+lV3ab1eb/ACD6Dy+B/wDT+1qO1L9TT9A9DdH6DVTFHsyZQl5qWnPFAZHH mPM1Q7QPWSqK
okOqqStEJ5LtiRPVlczuVQFVM4NPNj/+Qk5e0P0qu7Terzf5B9B5fA/+n9rU dqX6mn6B6G6P
0EBBv63ACL2x+lT3qf1+b/IPoPL4H/0/tajtTfVU/QZAYQdiH3p+lT3oPX5v 8g+g8vgf/T+1
n7U/1VP0frT9liK79bjcXKa33R+lR34e55v8g+g8vgf/AE/tZ+3UfV0/R+tP 2vJ8GZctz7m/
So78fd83+QfQeXwP/p/azduq+sp+j9afs+QxYxAWASB7mA3HGSeOTmMSFSRy PLiJYjOMW4H2
t+lQ/E8JMcnmmp451+20S/baJfttEv22iX7bRIaGmjL7Wft1JMdXT9H60/a8 hlaGR7PdH6Vn
rofY6nsP36fo/Wn7XLeXj5vdH6VnroOnsVT2P/an6P1p+zjLn9D+Ecb1EkLD UXgxNUi0zQQ3
YxapefioanYZb+JWUF/BhNmFp3GQZjg+bWZqtgZ57QzNOYucYxyAhyZGaZ4i OXI1mWn+nLY3
P5mi/wBg4A52Jmd4Q7f3D9Kz1UHT2Kq7Dd2n6P1p+15xrBcXqoRTScnGeSM5 44zGqjJtkHDJ
/MZjGMcgyjnjvargdBIMjPVM0u1FjzM5DJceZuHMRP2B+lZ6vD+nsVV9OPdp +j9afs+Z25HX
ZagLDxJFFiE4BOTVHjWbHh/ldmJmFhYqYCJqOO2ONogenud6USbX+IxWy4Pk s/l9gfpW+rw/
p7FVfTj3afo/Wn7Xmd+GGWoMXqKjkTbPDMzU00szVAy1RPIblCMrtM087jkl ekJ5mrBcrIpL
RfngClxcyICe6AiOH2F+lb6vD+nsVV9OPdp+j9afs+fYh4yxppGcgNpAKQBJ 5omWxGrwvyxr
LE4tNE8mUGfJGssaklaJs0azRCOYMbyAyyx8lPCKc2Z8g2OTD94/St9Xh/T2 Kq+nHu0/R+tP
2vM/xYKOxPR8po5GlCKQYZKfJMFGwu8Uztqk8rQGTFTG7DEQmVO5O9DyhpBG eeHMOs7Nq8EV
NIcbQmx6z8YJOHjfLiLAUXP3j9K31eH9PYqr6ce7T9H60/Z8x/ABqSaCarsc KpzPbtpdknaU
8cbVT2HVO1QFU8sR1uOHMWSYpBCIjIDqizPWGMWx80cvM8lSzRtWG8hVB4th wY6omqAqnlhk
rccWYspSljOS0vuH6Vvq8P6exVXYHu0/R+tP2vPaKtZBEEatFYhvVoq1kEQR haKxi0n6WsrW
Voq1uTjGQLRXDK0VayCIIwtFNGLSYxdcNz9w/St9Xh/T2Kq7Dd2n6P1p+z70 /St9Xh/T2Kq7
Dd6n6P1p+z5jKwNgwT1HCKqYRjlyKSosPYWwmquSA7n9qfpW+rw/p7FVdhu9 T9H60/a8+vDx
hiJHSxGoohiGSnCSVoImWvC4DSxjKADH7W/St9Xh/T2Kp7H/ALU/R+tP2fPw VjNw1hMfEmFm
NijEhVsmIfSwkw2k4cPmhY2UjFywf7E3LCLG6tk5JzuDmz2B+lb6vD/T7FU9 j/2p+j9aftP0
8rvw21HxsAnqQFglaRHVxRyGbRgVXELbcSM7BaqG3YC56qMVmawqoGk3Imja e5xkdzUk7hKN
WRqGQpAkmcJBqriaoMh2HdoKnMU07xE85sZVBiO2SaYrzNxWwS2JLnlFg+wf pV+rw/0+xVX0
/wD6wdH60/ZfparVarVanC5ho3tenYlJRsaihxtYjiyBqBzqhecd46rLXa8q L4a/yPSi5aop
6ZnfX4II7Iyp2IxpABNTs0b07Eb0YOzUYMtYeRg12eB5VrtfrMtMVgsfGUra w866eD4Wq1Wq
1Wq1Wq1Wq1Wq1Wq1Wq1OPwrG+bw/0+xVX07d2Bvg/Wn7XmPlgaeQgI5WUs8o NFMWKY5tgTqS
eRyKETJpmlqLb5NTniqG6yOS0X6M/NO+RAT3QOTw+wv0rfV4f6fYqr6ce7T9 H60/Z84z0/Ge
JFLDwBgbFLGBZ4mRVIMLTRu+zBxlDG9QDSjUCTPLEzNNG5BUxyA5iz+xv0rf V4f6fYqr6cO7
T9H60/Z8xDeA00rgUDkpaUyYITaOSmyTBRgDlCZRlSi84UdiKIih4T010b0b OLRu0ksd8bg7
y+xv0rfV4f6fYqr6ce7T9H60/a96fpW+rw/0+xVX0492n6P1p+z5+Uz8t5Lm 5ua79XJmb9Hf
hmflvY36Vvq8P9PsVV9OPdp+j9afteex8aeIudf4YrSaDg8JWsBsUMOIpI71 Y+VonEDgc07c
jg+QW4HE+VoOAwuoInH2B+lb6vD/AE+xVX0492n6P1p+z5iKwdk+HnJkVVa0 UjmpKggllkxR
FWWrda+UnEBqD4zvc9Vwnmew6l2l23GNpScgIsrOztLLKMsdTNK8Jk8UspjI 1RJyE8skbTyE
NJUnUFUSSgTyT5CknYM86aSTLIRMs0rtfUXPL/H9g/St9Xh/p9iquwPdp+j9 aftecKSABeGJ
0dNEajiCIUQiYlFAzMEfJCxM9PBxjiyFTUxjjjePBFzjp7Hhp+cEPICwA8Ub nij4xRsGKO/W
gT08LvjC7G4thE1ijY8EK1oFhYVjcxxhdhjTxi/2L9K31eH+n2Kq7Dd2n6P1 p+z5j5cAGU4y
jkUwzMMOUYpo5TqBp5uTiMohCQZmhntxyNSWlstCdoXxp+gxnhwGgYmKBnGH 2F+lb6qGQAHY
hWxCtiFbEK2IVsQrYhWxCtiFbEK2IVsQrYhWxCtiFbEK2IVsQrYhWxCtiFbE K2IVsQrYhWxC
tiFbEK2IVsQrYhWxCtiFbEKqJYyhbvU/R+tP2fM7sLbQ8bAsiqQFo5WkUlTH FK1dC6Oc2Dbj
aXcB2KXiJ5ZM2y4i9ZEwDLcYVBPER2l7G6rIrx+cVcSuJXEriV5K8leSvJXk ryV5K8leSvJX
kryV5K8lkJZCWQlkJZCWQlkJZCWQlkJZCWQlkJZCWQlkJZCUMZOcI8M/Wn7X mduWCkFheACU
lJGaanBoihAjaAGT00bg8IuY0kILCOJNADC8AOsY5DDILxs8nshByip2darL WZazLWZazLWZ
azLWZazLWZazLWZazLWZazLWZazLWZazLWZazLWZazLWZazLWZazLWZazLWZ azLWZazLWZaz
IIGZM3CfrT9nzHzYE0hxk8zKaaWMYZSxTFPsDtE8olJD/IEvNQ8ck00cDPLm YpuL5+OZHqrj
4jIxUss4O5EdOck+xDI5yVM5DCL1Of58NxQx/wA+1zUNT3VSZnRubwGcjnE8 jzFyUOGW+nBg
OR7ws+YebDjJ0PwhiimwsPyHGzzxi4RvztRuRSe3P1p+159qHjYiTzxMwSBI xSxgWxEykq44
xaYHd6mLjahtzxXtPES2YVnjy5gZgqANPUQi71AWPIDGMoE8koRNnjctmJ4x qAIc8VzVERR7
UDLOzk9QGMpQEhmjIzqQANseYp8hGdi2E0zWvU8KOKJDWCQyTYxeb5gqhNXt kYxI/bn60/Z8
xCxCNMbiUFylpXJhgJo5KYZJQo4wd6d3WkDSa3MZUhNE0Hz63w1Plan4kwJq XhHR8rWd4ypB
OWOImOWnMompAaXA7MVO9usOw9IJR6Qpqf4PTXA8HLhFYeB7NOO8IrHeH5cH zNTfAqMJEJmt
X5DpMiwcLVYQcOZgBxf25+tP2vyJ+tP2vyJ+tP2fyJ+tP2vM78M1VKaerK4T J5Ypf4DmcTas
LHsyOOXkhl+SMr4/xF+tP2fPjhBPFCmCByaKNhII3KKCGNYoWVgr+HE3HHPx MxjZjF28lzOu
Wdc8p3YW/Bn60/a80g3xtSzIYpmRRzOdNEcTSs7mUb8DSyWNTzZxGZmDKMNs myFNMI4pmeWC
V5AhkeI6eYnammaQYZGh4d54hdnmFyH8GfrT9n+l+hVLtTg5ODHzLnfEE977 ocvO62QzxzNI
8kuN2q43lCrGQGrPm2hWzI7hPcT1oMR1gRi03MpVXyPP/Ex/yxnkD8BfrT9r +rXjsZuGsbIU
IGzU0bEdJGUb00bjrx3hAzA8IOsEd2tEtSFm1olqxLXjuOkjINWJxwx3a0Sw jYwMxgDAP4C/
Wn7P9kt2NmlYJM71EBHLTns4GMnqZSkKHiRg4qs7lPGEV2N/qP5NP8JfrT9r zgd4/jT9afte
eMLB/Gn60/Z8xu7BmPiaok5jnMjzmNLlldHL8rTmwHNLsx1MpRSVEzRNNPtF 8BEy4E3Ko/DX
60/a/pEAD9MYOf6iAgP62s34e/Wn7P5E/Wn7XkiJ3/HsFyiGwPIwsP48Hobp +RB6G6IDci/I
A9DdEIMP5D//xAAlEQACAQQCAQUBAQEAAAAAAAAAARECEjFAAzJQECAhMEFg ImH/2gAIAQMB
AT8Bn3T41JEUkU/0VM/g7hz++QQ1/wBH4OSSSfqUfp/kcbbF9qZJx1JVSyvk 42vhlfLxW/As
eicFw3tsSRai1FqLUWIspLKSykspLKSxFiLUWotRai1FOPRKS0gtLXsspxos WBPeYsaLFg4+
2+tJHH29kEEEa7KcaLFg4+3raQQWkEEarwU40Xgpwcfb6VH6OPzUeCnGi8FO Dj7bzwUY0Xgp
wcfb6paG503goxovBTg4+288FGNF4KcHH23ngoxovBTg4+3pJPsiffJJJJJJ JJJJJJJJJI2U
Y0Xgpwcfb0ggj0gXwZ9kEEEEEEEEEEEEEEEEEDXwUY0XgpwcfbeeCjGi8FOD j7bzwUY0Xgpw
cfb3QWyOmCCPWNF4KMaLwU4OPtvPBTjRZTg4+2/YixFiLEWIsRYixFiLEWIs RYixFiLEWIsX
px9vJcfbyXH28lx9vJcfb2JwSOc+M4+3kuPt5Lj7eS4+3klSl8/0n//EACYR AAEEAQQBBQEB
AQAAAAAAAAABAhExQAMSEzIhECAiMFBgQXD/2gAIAQIBAT8Bj2wR/wAS8/yM EEEEEEKQpBBH
0+MxBVdPtgj2wQK02jmrtEY9F8oNY+R1+s5iWOcsm9Te43uORxyOORxyuOVx yuOVxyOORxyO
N7je43qI9R1+sesZKWOvBSx1ipnIOvBQdY+vWctBcFBbH17JJJN2OljvC4KW OSFH16xlpZqd
sFLH9h9ZzbNTtgpZqdh9ZzbNTtgpZqdh9ZzbNTtgpZqdh9ZzbNTtgpZqdh9Z zbNTtgpY/sPo
gggggg2m0gggggg2KbFNizBsU41NiitgggggggggRPJqdsFtj0+Q+vSSSSSS SSSSSSSTepvU
3qblN6m5SSSSSSSSSRF8mp2wUsevyH19KR/p8Txhts1O2Clmp2H1nNs1O2Cl mp2H19+1Taor
VRYNptURBUj6W2anbBSzU7D6++SSSSVJ+pLNTt6QQQQQQQQQQR7Us1Ow+vpQ +JKYnK45XHK4
5XHK45XHK45XHK45XHK45XHI45HHI45HHI45Hej6xUJUVfHkVykrGS+saVJN ykrkvr9J9fpP
r9J9fpPr9J9fpPr9JXKv9J//xAA9EAABAwICBwMJCAICAwAAAAABAAIREiED MSIyM0FRcZIQ
E2EgI1BygZGxweEwQEJSYGKh0TSCBHNT8PH/2gAIAQEABj8CDZIsgdzhIUbu MrWCu4KIERMy
plDxWakFEwLK3u/TNkLAACFmeSzPJCHFR+2lRPuVyYhZnKFAUVHskLgswsws wswswswswsws
wswswswswswswswswswswswswswswswswswswswswswswswswswswswswsws wswswswswsws
wswswswswswhZZLJEhzbeKDi5sHfKp3/ABRNTYGd1rs96yTrthu+VIghPAuW i4C0IMZjgg1x
aCdxKqLmRE5qpsEeCoNNXBWcywnNCX4d/FUhzC7hKLnCgAwakHFzADkZVFqs 4WqtVaq1VqrV
WqtVaq1VqrVWqtVaq1VqrVWqtVaq1VqrVWqtVaq1VqrVWqtVaq1VqrVWqtVa q1VqrVWqtVaq
1VqrVWqtVaq1VqrVWqtVaq1VqrVWqtVaq1VqrVWqtVaq1VqrVWqtVaq1Vqod obiOuBAhaL+O
7iq24jgcvYiWO0rLTIqvNpRZuIhGt9RMZtCY1roDdwGacXQ0RSIMo4bMVwG7 wTcQnLwTzJ0g
Qqe9dM60LvbT6oT/ADjtPW5oDvDA8BxlOqfozITmvfVJquAmtkQ3g0Jzi6Zy EZfo4fqQeVJN
vKlxso8nPsir+Fr/AMH9HjslYg0Ic8OyTdFrhBvHJA1A3md6ewhku3woNP8A qFXoZzMXUd3h
ucDMAaywm6LY1hCxHzrzeTN05rRhNLuATMTzdheydoMZmOfuQZo6xMXhMEig Ngp50Q53Dihs
3PBJlzVm2mnhvRaXNExZqwmhzTQ6TKfiENuABx/Rw7Xks1X0qBh7pz/94oQ3 RmJ8U/EGFEcS
rxPNRRozTM70D3N3GG6Sa46JdkJT/NOpbOlyTjS1pb4zKa2LHeqjhRnF+C2L qpilDcSJg5p0
4RAG+dyBYwFpJuXQokTmnFwDnB1Nt6a+izha+/gp7u1xnvRpYCZH4uKEkSfF PD4IE5NhecZT
xvKqdS1lMx9U8DDOiJHioYyrhpZoaOZjNOc5jQRuqQcREjL9CDtPm2XN7IOo Ft25VUirjCIp
aAc7KGgAeCq7ttR3wjh920NOYATAGjQ1fBV0Nq4wqXYeEGzkQE3zWHIy0UQG A1ZyM1R3TKfy
02QNIkCBZENw2Cc4GagsaRnkppExEojusMA56KadVrTIAsFXQ2rjF0WjCZBz FKbojRytkiaG
AZ5LQbh0eGSqOEyRvpTnUtZObhZNZS17BlN1UcNtXGE4UN0ta2f6FHbiBs3e CNPcmtd3hkHJ
x8PqhLpvnVu5LEa4vqPF6uI9sqdKONe7kpcMTO4rJJCwtE31qnXCxD3j7zGl ZOAwzJ3OxJWG
+gxGlpp0DF3jSeb+9Ad5iaxO0v70xsSKbuJvKxHVPk3AOJ4prnS59RyxCFTG iW6070+qXGmG
w8hRSZpiK4gojzgN9KTT4ItccQmQROJ81hxU2OGIsVlAiNG+aMYcExYOjJMd ptaIkB9lNOJk
RpuN/emMbLC38r0GmvIOdnCeXAiXZF0/fpK0WYhHg0rZ4vQVs8XoK2eL0FbP F6Ctni9BWzxe
grZ4nQVs8ToK2eJ0FbPE6CtnidBWzxOgrZ4nQVs8ToK1MToK1MTpK1MTpK1M TpK2eJ0FbPE6
CtnidBWzxOgrZ4nQVs8ToK2eJ0FbPE6Ctli9BWyxegrZYvQVssXoK2WL0FbL F6Ctli9BWyxe
grZ4nQVY9g7XEtOi6lWDz7FaYymLJz24bzT4KYI5qmHcJiymjE8LZoOEx4pz Ju2UXDDdbMOs
msjPeiaXgQTcIPvBMIOGRThpaOaFLHukxIRPBOLQXQJspDC4xNlBDovpRayq YHOvEBMDg6Xb
kXZwnVNEgxGG6pAUv8bZKS12XBTQ/OIi/oBjdxcpke1BxiD959g+alrCQi0i Cmtuqi17YjP/
AOKexx0rZRv8FdNH7h8UI3t7B2ukHSMnSKDgSAN0qqlFkaJ8VA+KqvPrFUNL hvBqJhYYuaMr
om98xUY9ypNceuU12nLctMoglzp8So0uM1Gfeg68gQLoiCZtdxKppgTNjCri 8Qi0NIBzhxVJ
DoiNcquTH5dyLdKDxeULG37inmNfO6jTznXKDrz6xTolpO+SmjSsas8/QGH6 ypM5zZUQd33r
d1fRZN6vosm9X0WQ6vovw9X0WTer6L8PV9Fk3q+iBtYzmmer2DtxKa57wQad yax73AkG0DwQ
qnPhaFiTiPq3CAFer/ZZvjhFoVb8TEF9IloELCLqnl/4oyWJpWvSKLeF06e+ eZ0Zb/SwyBiU
xfRyTnDEe/P8I/hDTdNRvQJ9yY0tMlsl0WWIan8QC0Dfkmvc7FGkZawBUAOG jNSfXWNGBAF1
YYg0cg3ejhtea7miBHgjViYkgjJgBWH3ZxBxlousRtD7DMb+SFNbdLMDwWGZ IbaRR71jju30
nwWEAMRrpA1fQGH6yMEW4rWb7lrN9y1m+5azfctZvuWs33IDGx2MnKQv8vC9 xX+Xh/yv8vD/
AJX+Xh/yv8vD/lBrf+VhkkwFrha4WuFrha4WuFrha4WuFrha4WuFrhawWs33 LWb7lrN9y1m+
5azfctZvuWs33KSRmEz1ewencP1k7kPmnZzuhOYwNDGttMp9ZMQCAWx5GHjY z3Nwxo6AkyjT
lunsPfuxBwobK2v/ACOgf2tr/wAjoH9rC7jExa2uDtNoAt92/wBm/FM9XsHp 3D9ZO5D5+W3/
ALR8D5TfVP3b/ZvxTPV7B21Ck2k6JstcWn8JjdCAJiWavAp+RIfExuUuIN8w FSS0CYiLxxWi
6XVRLlhUtbcaQhOYQKL5IaRaN5CwmVNuJ0807UsJik6KEPww2SKiwpk4jwXN qplYhf3YIFs7
c0x7nMbcg6BPz7Hyb1e70Th+snch8/Lb/wBo+B8pvqn7t/s34pnq9g7YY0NH AfaBxaC4ZGMv
R2H6ydyHz8tv/aPgfKb6p+7f7N+KZ6vYAXt96kGfTmH6ydyHz8tv/aPgfKb6 p+7f7N+KZ6va
F9fIc5t/yhMhgnffL0thesnch8/Lb/2j4Hym+qfu3+zfimer2jyfDsib+lcL 1k7kPn5bf+0f
A+U31T92/wBm/FM9TtHklpyKDRknHwXBMq3Z3Rvn4o1IOabDxTzGeWkrCm/5 kB6Nwj+5PIyg
fPy/Oitv5Tkv8bD9y/xsP3L/ABsP3L/Gw/cv8bD9yDsLDGG4b2/dv9m/FMI/ L2jySYnwTTEO
duPpZnNO5D5+gzzHxTPV7Qs/Jn0szmnch8/QZ5j4pnq9oWfa68WQcC/IcLou pxJgibcbInuy
JbBd4qIcNO+UwtOZ8U+qruzMJrGh9Q3mFhYjg+aYIBGax6Qb6psnVV52qVnu oN54eCcHVat8
s/BNbS7UggRmrA1U+1EecM7zFlgl2G8uB0slJ7ykuOcRCe0sc495eI+awrPi IpabLEJ76Pwi
yw204rIJmIWE1xe1xiwj2r/kVR48oWHyQInuk9zjii++Mk3u3Ylyb2T/AMsD 3p4bnCbaLfem
807kPn6DPMfFM5do+wqpMTFjKbL9bwT203b/ACg6I8EGOOkcrJxOjTnIQezS EwfBd3TumVU7
LlKqbMeIhU1XC1/4UtuMk5lMlviFXJjkVh03a/Jye2mKVO6qmU1hOk7L0E3m nez5+gzzHxTO
XaPLIU948mc7IGp0jfZOf3r9LkqanO5oPJNtygucRBCo7x4EzaP6Qf3j7clB AIUNAHJEkuuZ
hFtyEGNyCJOI88BwV3OOXCyZ5x4oyiE59bjO4qidGur+ZVdRsIjd6CbzTvZ8 /QZ5j4pnLtHl
krSMGsQWtKw6Q2N8g3/hYw85EeKqNZp8DKY3Dim06JWKDSNE0wCm6b5nOhw+ Cw2mrUyg581i
kXI1ZYQqnRVUBLZylN/JBiE6+JTarOfFYbXVS6Y5K2ad3tW0uWzl4Jk1zGj7 96xpOi0/JNc4
yT4R6DbzTuQ+foM8x8Uzl2j7Ce8bExIOSbpt0tW+aeLy3Oyqbkg1z2gnIEp3 nG6OtfJNINQc
YBbdUVCrhN1tG5TmprZSfFd2MRtf5ZRBcBCaam31TOa128M0CZuYsJTdMCrK VIcPZvQe51LT
+ayMvbbxRHeNkZ3yQqxWCbZpo/Nki/cFcgT99bzTuQ+foM8x8Uzl2jyyFrN1 gdXh7UCXNJ3y
36p7+8bpbqfqizvRO5wamvqECNyfcQQRle6b51sgzqfVNxDizF8k+qG30N8b 1tAHGZNKmu28
QnXEF4etfOd3iu9qPL/32pomIMqA8RFJlu5OcMTOc8gqXYw6fqsMWoaNI8VF YgCG6K2oqqqm
lYb5mAQViNtL5WGJFLTvH31vNO5D5+gzzHxTOXaPLN4si7vWv0A6TAg8EygN fV+5Oa6htyLO
uIQeCMR0xmAmlrRpgU3RcnEvw7Yka25Nw2Na4HfUiSWM0ZlrphYThS+RJ0oQ ZSL5X3KcPDrP
CVOIyh3CU/DAAaAdOpajXPtk5YBc4MrzZIWIzvA6MhwTXYZYQd5Nlht7oQ4C TWN6xpcxrmzE
FbRrhWBUTmhhta0g76kSSxmjMtdMLDcKXyJOkqKR7/w8VjO/IbLDAp0jvP3p vNO5D5+gzzHx
TOXaPsMgsgjSM896yCD94yv2aoWSpa2yyCrvVln25BZBZBTAVLhbwMIWFslk sgslQ1tlkFXe
rmjbPNTF/vTeadyHz9BnmPimcu0enG807kPn6DPMfFM5do8su4BPrFVMWYP7 V8J3F2VkTQ60
/wAI6JaRuKpoc7K4Tpwnw20qDhuB4WUd26LaXNOFJEGOfoxvNO5D5+gzzHxT OXaPsC2hsbwm
6IMZJ2jDnfiGahqa85tToYNLNU92Kc1X7hwRpESZPoxvNO9nz9BnmPimcu0f YfucoRu6Oapp
cDPFYctcYFzKux0cJTQAWxuQnNPFLz/smaLpG6VIZuiUa59qtV7Ci4sPgZW+ N8Jk95le6Ot7
0JGJc5AoTn6CbzTvZ8/QZ5j4pnLtHlyTZE6WjnolDW6TZEkutO47loz7RC7t ztLki5xsFLnx
uyWv/CnM7gpdxjR0vgol3uKuXbvwneg4TcwnYYM4gEwq3OIHiFh03Y/J0p7S Ip8ewMpmfFQ3
DkxJFWSqc2n2oMAkni6ERGUzdNjD0iciVIYad90RGQvdMAE1eKp7q28yqjh6 PrJsMmrLSUFm
jNMyrCScgnaGqL6Sd5qzfFNdeHZfcm8072fP0GeY+KZy7R5ZByKcH4hdVwss 3cM806HEEzvt
dZyd5PYWnIqbzxlB8aQ8VBQ0nWM5qq/KbLQxCLjO6DQcjMokl1/FZu96aan6 OV05wc6XeKDZ
JjeVUS7lNkaREiM03Dl0DxVRLuU2UEuiIzWjLeRhb+U2UYOHM56SqfLTlAci 69xEShpOsfzL
Wf1KpoLjORctMUEZQ5A3t4rEhxl6YJIDOB+5N5p3s+foM8x8Uzl2jyzSJMWW IW4j3REea+Sb
Dnm1vN58+CfrCkOvRbwTnmt43aEFMbhzTadFYrTY0mNH6JuljZ592fksMHvN S4pJAPNYsVkj
KrDhS43qEmCLSiB3l28DCdtabVZz4wsNjqpdMcvHsjz0B17OmPimT3kxo58d 6xp1QfkmlxJJ
4iPQbead7Pn6DPMfFM5do+wNOLhx4FN84zSyvmtLEZHiV5tzSPBBrntBOQJT vON0da+SDmy8
Hey6DagHG9JzRPesgXzVcgt8F3cOq5IkgsA3usg4vbByMotDwXDMKsTFtyAL gC7IcfQread7
Pn6DPMfFM5do8stORWIMR7ZdGQmy18xDrZp9L8wYafFGcSHmLgZJrycvBPiN IEZXVJxTMzML
vbTndqxPOE1523qkvl0gyV4otc6ZdVkmtkQP2ouqsdyoECU11Vm7o9Ct5p3s +foM8x8Uzl2j
043mnch8/QZ5j4pnLtH2B8FI8kDiqd/kTu7ZKkehW8072fP0GeY+KZy7R9hT xz7MTVhyyb4W
TKA2GpzobdMBoNKblAEIlAw0kfmCq0YiCnNaGD2JsxIRCIhl925AQByR0Bvu d6ApZ/aEU7lJ
aG+gW8072fP0GeY+KZy7R5Zccgn+Z1YtUr4WQl18kTRlO/gjLaTzVAwnHxg/ 0i+JhU926ucg
g2g1GIWjEzF0NGs1U2FPxWztlM71bDnLfxQNMOLqYRwww5GHHJS7CNVrC6wj ENfmHC6xGuiB
lAUgyEA2miwJifmqWnDkNk6P1QdiuZfhZNAgDiWz/wDEa4DQCZp+qbDsMOky Yt8UHaAGUcU6
aYaNzd6YMOL5yJj+Vnh0gTkqpwzMQ0D6psUgGZluX8rNhbVTEXQa2KjxTocy wEaOd+axL4cN
3QmPDZqjf9ybzTvZ8/QZ5j4pnLtH2Bb3bSCZghNnDZo5WyTpY2XZuAuqWNAH gOylwBHArSZh
xO8IQ1s7lDgCOBQnCw4GWjkqqWV8YujosAm9MINaAG5iEXd0yTmac0dDDpOd gmzh4X7bBOIw
2hxzcBdBrRAFgqzhtr/NF1FDeGSDO7bSMhCr7ttfGLrY4fSpOEyc9VV0Nq4w vM92z/RTjMw3
u40quhtXGFsmZzqrY4fSicJuGx5zNKjGof8A6oOobIyMJ0MALsyN6bI1cvuT ead7Pn6DPMfF
M5do8s0mDFliUtxxcRU8/NNpryt5zI+PFPgPiHQQ8+xFwY4nc170wtLw0Rk6 yxQ9+Iamn8Vk
1vdOz/8AJJ/lM0LBtJh1vcsXXaTl5yVSayahncxKkYcAtipHQG7R/NCw2d3n JP7eyO61XTTa
6aKQbZ/lusYxabBNDpnxdPoNvNGtwbzPNbVnUtqzqW1Z1Las6ltWdS2rOpbV nUtqzqW1Z1La
s6ltWdS2rOpbVnUtqzqW1Z1Las6ltWdS2rOpbVnUtqzqW1Z1Las6ltWdS2rO pbVnUtqzqW1Z
1Las6ltWdS2rOpbVnUtqzqW1Z1Las6lDcRpMjI+KZy7R5ZJyCcacTRz0Vqv8 bZIkh1p3cFYE
cwm4bpqdkn0mosEwEHNws/zGEMJ9sQ7pTyGvNGdlXSeEFUDCkfmlOditDQDF nSmvmzsk5tDt
Hei9+EWRCaIOlwHoW2a1Pc5bN3X9Fs3df0Wzd1/RbN3X9Fs3df0Wzd1/RbN3 X9Fs3df0Wzd1
/RbN3X9Fs3df0Wzd1/RbN3X9Fs3df0Wzd1/RbN3X9Fs3df0Wzd1/RbN3X9Fs 3df0Wzd1/RbN
3X9Fs3df0WzPX9Fsz1/RbN3X9Fs3df0WzPX9Fsz1/RbM9f0WzPX9Fsz1/RbM 9f0WzPX9Fsz1
/RVO7R5cHJODnOdUfzFCarW1inRIc6byfgiw1Gc9IqozPrGEc77qjCo0omdc qvSnwcQjDTcQ
dIqgTxznsLb3M6xQmrqKrvPNUnJNfeW5fo0eWadaLLEOHi4joIA0Amw7Eyto Z80+7xSHaUCP
BF/nMQbtG5TBhlwbadHNYoc92qY0cjzWGPOzVm5v9INbXSMhFo5rELXvqm1T NyaX4rgb3ozO
5RU+I/JYnmpnEMRMsQM4ogG1AvdMJ7yJNqbAJ13bTSpEkBYEjF31ClYz63NY AYlosp84+4LT
Tf8AhMpD+7tIpTh3lQw84i6a+XYQI4CZ4JsuNFvwJ7XnGceNITBXSXEtA+d0 G1v7vfo+CgOx
KxElzR/CGm/L/wAfP6Iu7vE765ncnz3r/wAstgoU1gWgU/FPqc+kGwLVBrms zAlNFBp0ZusU
hj7ZTN1hksxKTm3eooxP2+CeG4eIJMm3ihRhui5AdKGZtvTq2uBNLWpoex5J fJsU804lhIWT
q6mwTZNj8pqWJrUzAkekB9gT3ggZoaYvkpLwpY6UGucASnaermmugkHfYfFN E3IkBOg1Fu4K
e8EKmsVcFZ44IaYvkhhTLiiSYAMJkfjyRBxAIzVbdITBjcgwnSKEOzyUvcAg 2sSU54MgIHV3
3QbWJKrDtFbQLUdT+fci9ukBnCDS4AlUB4qG5VQYmFHdvm1rIjuntj80IWJJ yAWzf4/tTnFr
mhpi+9R3T6uFv7TcRoPHMpxDHaPiP7TXFrr/AMKAxzuJCGi4Djayo3xKc0OF Tcxw9IDyy05F
PGJimXRcR/S2jsoOV0+nEdcGAcrog4rqj+IQm4hJ0fAJ5H4gRkEPPPkb7f0m PDnS3LJHDOI+
kiItYIMw8Q2tfh7kXVugiKbLaPm0G1lHevyjcmu7x8AzTZHTLdKoEJkYz9Dl /SxHNdpvEXhU
uxXyczb+k3EL3VNjcFiOdF8o3JoZiGsCKjvCGJ+L1QiBivE8rJrWnfLiV30m eQVDnOcN0xZa
7vYAPl4ot7x9P5U5pxn6WZt/S2jvHK6ca3GozBhU94W3OUJrtLRiPYn+cca+ Vkwd4+W/i3lT
W6N44rbPPuWm4u5wg3usQfuNKp71+UTZaWLiFGMV8HkqWm1p9iD+AgJxLiZP u9ID9SD9SD9S
Dy5VsINIcLE5poGCTIvByWK2oWyVeI5viclAaCBEmUXnCG+IdKHmIJmxcsID J4lYhP4CU1xE
SOM/pMfYBtDBewjemgsZ4CE6G4Zd+KypGG0A7oQc5rZ3EpwY0Tv3lBtGGOAh Ntq5J2k04f4r
q2Sjepe4NHElAhwg5eSbi2az7JJgfogeW5vELTNRkfi3LCn8JM6W5Y0Q2sQH SnVk+10rCO4O
usWnN3ig117k3emYjnu3ZP8AosXzbdLLSWGKW1CAb7kXBopIjWTt5LmmHP8A omuDGzVURWsT
E0opNg75IaNraJebrDuRT+9YhrdpT+P6LHbEVaulO5McBADLrEJyLrIU3hwM fogfZjEGGSSY
hAuEHgnMjVCae7JcRNITBTFTKpTtDE0U0hkaVLg7MLuoNSs0i0pooe6fyo4d 7b1LWPJmKbLC
qDQH53uEZY8Rx3qG4UGqmHHwTBQRUCnih+j4KXNcDNxayo7t0Z1WhVDCfHjv VdJmYg8U5m8C
VPsP6DH2dEGmZ1ioRfxEIAzb9xTSKtGw0iiwFzZ3zKANVv3lVwauae1xqrzl Nz0cocUTBvmJ
t7kbOvvqMoik3/cVkd/4isnZzrlNdB0ctIpzRUJ8ZVJBP+xug6LjxWR6ii0T nOac/eVA/QY+
1NGfgnaGLtJ3XTS0vbh7xARLq8UFt5i5WF3TXtIF7Bd33n7iOHgnUtc10wN/ tWAX4bn4gN3Q
E/TtekU28N6b3mK+741QChXM+KdVq93b5/JYY06zA0c/0WPsJiN36cH2EZ3n 9ODyyQJMLGNc
2EaBWH3MXzlpTg91gXAw0iEO7kumNMFMyFYEWy4p9M1N8E4l5PnPyG4TW4cU HPRMqqQbfkOi
hRSXSblpuqCGBntlGF/xzM1Z+5PbIpaBaN/6PH2Wi0NngOyukVcY8ilrQ0cB 5GX6QH6kHkvm
8Oif09NRUeTYR+nh+pB2vB/Cf1CO0xvM/qH/xAArEAACAgEDAgUEAwEBAAAA AAABEQAhMUFR
YfDxcYGRobEQIFDBYNHhQDD/2gAIAQEAAT8hBoRiwmZyHBnzm2CFEk9oDEAW XMIIz1PgUJLw
ATUyGEDgGYEiXhCaOCWcbDzqGUNN9EGwfxgCW0IyoBTQwAuHZqb8SUt0K8SC hTVdmsJbQkKy
NHE1iAiKAN+AggEqOnp/UAACgqVGCpuM9Mv3gKChfWBvMwW2M7lO5TuU7lO5 TuU7lO5TuU7l
O5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5Tu U7lO5TuU7lO5
TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5TuU7 lO5TuU7lO5Tu
U7lO5TuU7lO5TuU7lO5TuU7lO5TuU7lO5Q8htDsMJCRqERQDJGiAKcWpCcAN jOx1AQXVGiPA
NBK8cIQyKjkKp4rgqMiwQcxwsPiLjJjIg228PAN8iA7CQHUBmIDvygAmE8Pc DEl2FiMOUZIw
8xOI4LQ0V0IIzMKMoYCGFYZ7W84040404040404040404040404040404040 404040404040
404040404040404040404040404040404040404040404040404040404040 404040404040
4040404040404040404040404040404040409h9JnWVPIxRAb2vECAFBBSmM goCgBklRJQWB
sDQsamoBvZihZeohyQBtLQUAnp5mGdPLDA8v9Q3ckrl6mq94c3IswA50EdBX XOYzm5GwMFxV
Gj0m7+CWSxzkQauzYC2b/SxBOoAAEqfpD8CsIRJQTNVCyorYRh/idQWS6qvK LOEH8OD2H0jj
+Rew+k6rvWAjvBRibiMNOGI4DJgLjDTibj6Mbyrxk04oDUYxvE3H0TcQjIBB nn6BYcsDPXHx
MqW3UOICD/DvYfSGMVxKQwUcO0AlThOgY5PQnzi0gA0aQk9pYNVOTEEhAtEA S4hWZaxgnaVb
QFg2LPPtA4Ux/W6MRgMP9wUY9gbwJkUUTMvMGATSFKwJ1JQ6ACzyD10hAFIL JelxRPUEECaF
u5QqtJm/3iHDxSy/xFhJMxLXOGDGKQMBtv8AuAWCIDDk+P8ADvYfSOILASBA d1/cV2yVhGAD
8Q8lgcbYPEyw1YSQVDvANQDKPXcQbQbbVKuEAhZt+GIEZDjWiCdlCj6FBHzA o0vJKI3WcrYh
MkRKJZJKUzdPJoAdnrtBO1lXomkhlsmTx8QIzRoAGcRqKtHpG/BACR6LgQDZ IFIED2IdYD/D
Kx4KKV5IoThAZnjeAYQYLiaslGGPQFEKKrSCZDRquzy/UIZockUL8JRFm1AA TPqVEEUCDtYc
DCQkA7XooR8AGzXn/BPYfSOI7dLK7PMTr2AG8vKUa4LWgFWLAAB8YEjrQEI8 jTIrZHjBDt4M
ReVqCLFvRWz5wGJNET/uFkUV0YW01DMiJ8UeJplhHsgGA2jQNoNS4gjzS88U IkPeN8Fi1tAA
sSoAfGDKtakiDF+itvOAQagAjOppxtCfGRIoAzkzfQdRaBRNSIGFiAgHAUwX rD20jiA8yGDF
iEtK0k80AQQ/7mIxGIxGIxGIxGIxGIxGIxGIxGIxGIxGIxGIxGIxGIxGIxGI xGIxGIxH9PYf
SOIYCFrbxQcUEJpL8YEMaglypY80K3OTSE2IAIPxL/WW1JjkRTGzxjciRX4i VjI9IsEliZke
eZSFG+t4rRR3koVDzcJEUTQviGQApzlqQwrWHdKAMKr/ABGCf5UEfIJBQQ7a aQ1hiEAfn2gl
LGIuNn+wWkkBJOquC1hUVuHeEY0j3waMVK+tW3lBG7GIbFnXU1AAYUtZa7R7 dl8+FQYyxeYA
QMxiZrA12qwgxASNF6XtKfWQaiNAcX+o8KORgf14f9xmRATV0ESgfadMfqdM fqdMfqdMfqdM
fqdMfqdGfqdGfqdGfqdGfqdWfqP0nxG6T4jdB8Trf0Trf1Trf1Trf1Rug+I3 QfEbpPiN0nxG
6T4j9J8R+k+ICEDkdGJ1/wDqdX/qMD6vwnX/AOperOjSdAfqdAfqdAfqEBkY 6NIJclp7D6Rx
AfoBSzfeIRxE1tX9iAIYRG6ENRNluR2jcT2GmUx2YhmHaJWwoDcuPQwRYFsR gR615ZgIecbH
xly+dSdlRJSYS1lQjIIEA1azqoVFgYMCcWAEhVryjBCSAkjd5j5BKNDMyhnp XB5gjiZ4wA5M
NUD5BcMVUTSSH5wFZhS5XlGN4hkDOhJ3oERBAsNqnAMqE2ptVNzQJ3g/DT/v wjBwGIaeANWM
2EIj/nP3uEwmEwmEwmEwn7AccccccMHr80WfZOoEpBoiADkGQCoBmzsuX5IK RbbEHP6QZ03a
HlcwCCIvwgQu/hRy0RPqYlnsPpHEsxTvA84Va4gid41fAgCgpFgAlPDWIH5W sEzmXfTdkT6m
Xldeg90041vbBhcFsS1pnJZmHZ8geclCxwiznPm3CQOof73DkxrUmXQdeU00 LoueZwDXtolj
9wBbC2I2DNQlFwSBuWcT5xyl4QDrAoCfMGCJEORGxu4Am+hDkm2dYB2asleB deUJy9IACo+I
d+cJiCYAXWviE7aZL34twtApbBWGHfnGtzLVN4cALhLEyS5J/AzeRmBBMakB IGn3OEwmGDBM
Jhh+woD9HHHBFZrCsrrMAaD1oBp6iLZ9RC/6oKtL4oCf2o8HqQX/ALUDOqih HBewnS8mYZ7D
6RxAXtgXR6eMBUPADyUnu4vIowAxXeW4NcWNyUq2gDl3EAn0l8G0aDiogpuP w0KTh4pbQcDh
oCZZgDSKShRKCmCDFwISYN7xWJAtoBdUyYTyMYxVh4xglQCAYapAvZoXUNgF ga0yMf3DAnKF
CB28Y/tIEwlviIjqoV8niGuOcQC820zP00HUYRghAoF1lqdKm2ZQDKFevnNX AsCArHxmny2h
gEjxgPdWoA6WoCRu3pz+BkFAiA03f9TuCdwTuCd4TvCdwQmCFgS/pB2uO3x2 +OxwD6YABsmd
pM7CZ2gzsBj/AOBnYDO2mdlM7KZ2UzspnbTOwmdjMA/7k7kneE7wncE7gncE ZrCEAdSp0vJm
Gew+kcfnJOubxihBdjmBLjImswhMKUK8fp5/Q1p00hXqRVGZwS/IvoI8Lj1M j6jhwOKQSgEC
bBP/ADdJxnQ8mYZ7D6Rx+ck67v8A+rj1Db/m6TjOh5Mwz2H0ndZUGQGxtT49 KOxwAk2OB+Ma
WTiWKIIUHN4huUYhMAUAR5zWByM8GqG+agBoMpwkWQrDBelj9xFWoQujrf6h LIksLSg9IgBX
kJz3CFzTkiQhYh1u4aA40iAAjXmWuoDR1WPGBEqTUaUFjOTIAOygFgZmMBhP 8Um6bv8A+rj1
Db/m6TjOl5Mwz2H0gBIGxOLyiH/pnFyMfB9qA0/E3tU6rv8A+rj1Db/m6DjO h5MwwMARoYSE
G4MOPzd7POu7/wDq49Q2/wCbqOM6XkzDM89wYSAI1v8Ax9iC7CU+ZaCX5aXt MFdbf/q49Q2/
5sPRWCujkzDM090YcfYAkEAmcTQHD8rezwV19/8Aq49Q2/5sXVWCuhkzDM89 4YcfY1nUUwkp
RBySnKSYJgNY0ItuHHAJho8NIfYEcW4B5RVPHSJqA6BGtoCoIxlMEFyIY8WQ F+NhEMAYWl/t
x1mdZnWZ1mdZldGFwFvnN/H7qUpSh2tY78P+YgBJwPgwtLH9zMMzT3Rhx9hB JmNGTGCOEPy5
Lh1L/Buh7J0HJmGZ57ox1I/tIkNYCH5enom/4N1PZM9TJmGZp7gwABkgd/qb GAr2hxwMNsTt
RuCWO53IW4ggEj6nEAcCpbx0gCII2Olp1iDcgAGAW28Ao6ATFppeIzHSgmGY 0AZIEmW6/wBg
A2hoVgLiFKIRmGH7VA23zG36vGZ73zJ4hFYOMBWXpLBCIhHDkczQa8rrzAsA AiRoMKahoJVp
VCEoSMLOBAXq4GOrsUjj/Y4wAc5Gms1YJmG7/JiToWHQMz22LA3AEABJZzvx A3ENXX05W8JP
ukMCp07H7g+dfrfspmoGqggACEpJf9V1/E65v+DdJ2Q31cmYZnnujDj7iUCf iNwSzILngX5Q
wCEYt77ecO7hJFjKXybVpF28Jj2hqDYhNCs6+URg49R8QMoBFaHqHZymxfCN yTK35S8aGRYK
GuZhNay9fDmG50EslBBMAk5qDw3BeiYBXXsEzAOAqUGo5SJLJy5p59+a+aiy DEWVn8FdfxPZ
/L8G6LsnU8mYZnnuDDj7roIYTGRAIgkIvYrAxyZZzEBE29RzAYJoJYDZVKsI 3jXoJjdyoq8n
G4PArUvaYjIADBctwpYH2nHECHFYuwKFQrdFhfEDMJqonC8I6jScEEgthCeq rmHg0gToBbQg
0aQoPtL52aF8T2EryPWFgooP6vwV0/E9n8vwbquydTyZhmae6MOPu4kDxGCo FNasU5VAYsOz
RoEv9g5JpGwurX+TM2EFmyrNmDSYbSHOhS94xZBGRBGMhH1leTKM15hKqZBk ZUzhNGUhqtmB
wgwACQCbA0gwp7A7a0s8zxYo5NntiBKyODgkph+SzLFKU4YE6IbpcAU9oVOr Udn+hZg21EnS
hMQADen4H8HdPxOkb/g3Rdk6nkzDM894YcfeRWFxgFztCAgX7X07wORpTe28 FHNuFMGBwBPh
Ahnw764UVcCr8op1d7TwjwwnIuN4WAwG1REICIbL9IWABFlXCEl06HogIkZl KWdoKE6ANaAg
PZZInyhYWCyAbKZSzEhmIf7oXAAo2FPE1kqBbcwKQAiBI2RCUNwzzeKxFV4Q Zyf+26fidI3/
AAbouydTyZhmae6MOPuEhCiRmEDMWbrZmGxICYRDePFKYIINpY90D0DvA28E mHMAKSzovL/U
saDbIOTXtN47jTCxBewMWOylvLhymyg/BrKHUFW9g6gKIuBvSAswEqAGHhV7 S+xJQXVFsPmL
YlkjSOn6pgmCVG/QiAZVdgUNIuAi0xQA2cPxg0QVBEAksRaMCGKuK/2WzaUo Qy7u8cQAfR2H
CScRGSWoKv2E3mj4DhlrEQAkoV4f9t0/E6Rv+DdF2TpeTMMzz3hhx9xM4Cva ZcgGYcAoUUcA
JKhWsa+UVABtm4IUd0dwj1xiAlN7fOvpEKAVuUIHTzUFQYq8xXy2unxmPBlA 81iKUV6mx9o0
S0D4GzMqXoD5gvYLUYMqQABIIDx/caLSgUAQ2SVAyiCw2m8Fj4LA9wqOyKla cyyEKBcHZnKv
yIRVgw3YlCBDngqIf9jokPGZjHuB4JYiSWagW8BQG0seB+1QMM7ZaAA+8Lo5 EKKWm/8A1XT8
TpG/4N0nZOl5MwzNPdGHH3ZlSq2Uw6WKxN2slicvGVKrZQlWPOIeWIQxcq/R CXQ8MTy5JL+Z
UqvCBZFGol4Y+tpNxzUpI9qYtLFQBQA7qNk4k+EAgAVSmI50vNZlSqGihPoa TGYGIDob+ZUq
hxCwQwLJLwxDaDYHkRCYTBMFWP8Aqun4nSN/wbpOydbyZhmae4MOPzd0/E6R v+DdJ2ToeTMM
zz3Bhx91DtxUFQmxkG/QfIwm0jJT68aQyTIdL9pUFcwYPhKJcAoonGTM1BNC zsL5msAtkdAe
8EdMSBogla8wh6rCV5h+Mun4nSN/wbpeydDyZhmae6MOPuIBCNgzVsRgWFai 2gsyAhBAMsxH
/E7wi5yABX7OMXyWIDK1FrD4QSaYAkwqgYBscxP2v8PdPxPZfL8G63sg6PJm GZ57ww4+4lAm
KOr74gBBgBQEBILIAzekogE0A16xgChRfMDEUBZAQdkIT49CBD+Y2RS3NVoR 1XpcJSUqIL+5
aJD0ufmX8fkXlZhoKQVKCPMzmq0F8wgSKjQ0VAmJkA+8JNVd4nZbSi4bpIXj vEbFf4K6fiew
+X4N1vZB0eTMMzT3RmSM7xneM7xneM7xsgAZMvxEJap+UI7G1/sVUFQACPrI LJKuQQveO7FK
aFCDMcxnFihJ+kBSgRLACK2v7EOkCQgMyTEjQSQjOY3E3qw094IdiiI9GkN5 EiCEW4XKSpOz
zDbxAWAs8QZyilH6TE0EbMGM7wK8SyvpCgC9MLjkQHsrAuxAidgejeGWxYWl eUMdyFVLygFL
CcojtzCjRCCjp6Yggpmg1v05jaJADoR6dKUWkkTuO0cQGw8yK2mHmFe1tBoY cmKFaOQENzIW
OIQCexnPXRcQ6SwAgJzjEZ3jO8Z3jO8Z3jO8Z3jO8Z3jO8Z3jO8Z3jO8Z3jO 8M6p13E9p8vw
boOyA9XcwytzPPeGZI0aNGjRSgQIiCHcQLIoBgZMOB1BtrmADH4BkQ1VCrJn TGZY4EFyMRUJ
Dd5aXwv0IL0KUSWkbYtwURK1CbAzPMbbm9xuo9CbGRoMK6hBgaZWW4RoLeF7 QmByUjpVQgnS
iv6VsB5Q9XaYyZqGgeNioyEMjiyJcARyCC7rmONW/wClGg8A5huZcJkpS5TI QDT8ErluEiBP
BwSgCwVsqKAYBqCGWkpVCS1CEr8xwg8mZTItdFiJSmRW8owGQktQBCKAQENb xo0aNGjRo0aN
GjRo0aNDQQdbE9r8vwbquyC+jkw6zNPdGHH3EZQkm5jzZEmb1oHNJAJPd4pw 2limIfxLJSoP
RJieA1g2QMkgh3aXuITU4iVHREp7mDRRa9tahSP8g20IDABshBTwEiB2cXWl x76oAgIZsDTi
E9AC1zpeIHrCzeptiKoZ7QWANW4Uy5xpDg5LAdvNpiAmkqUf9CzBHCaZ8jgm wNt+n4O6fiew
+X4N1XZOp5MwzPPcGHH3GhADAgbSrn6U/RGuALRpmP4HVwQJgBuAJhGM13T6 oPQ8ggPWFEDo
demEFXGIHDT9Yafe7OHTgbcHM0qQpBq+QG5gfSmxDhMSBJ3L+5V+AxvwRD8J dPxPYfL8G6rs
nQ8mYZnnvDDj7hYIowCAXhHkIUdU1ezMsLRAQ8ygaKGBGw2qA0nkBXXMIVFK IAHmBaoNHTSb
qAJBsc6TatzDzf5KhIECsEHTwiNocpoHwSFGK9NoAMl1tAFPIVGUo1CAg/CV qCOKz4/hbp+J
7D5fg3Rdk6nkzDM090Ycfm7p+J1Df8G6LsnU8mYZnnvDDj7wJIA8oMeA4jtf R2Bv9MguwmoY
tfR3Ha1jHPigLDH0GYiAg9IP4W6fiew+X4N0XZOt5MwzNPdGHH3ForM1Cyv8 wUFCKlVj5mUJ
RBXAqAygQLFwz8IkLfxjgAmogowps8pmYSvVm4740CDHuwLMf0Agk9YFNwVk jzEuhMJwkV9h
QaNZggaYQPSleKSxwjIVQR5CYsXUVorFZPj+Bun4ntPl+DdF2TpeTMMzz3hh x9wsMWVEGJO4
AtyvI8Bo/fEzdQ1JKWIq1GAQPVUeyTSItCMWmA3YAOniIDAvEE5BV+/sY3WQ A4BlRGvlYWni
CMgyHA0NQ4CwahYwsEytF3AyxCFkA/P1hCMZAbwPR7GB9aNQJXWkLJGk0KO9 wCAJqIJy0hQS
fR6GLZGEJrTHqHlH3ipUvSyYZs1BhjtXyj/y9ABQUOFAHSAA/wAQBUCCIEkz tdRwCEZILbWZ
Qdd6Srw3ghAHHO7I1t+MCAIyCQz4H7QnBWgTVdP+sTAkDADFBlv9TOUoHETf JhkRIfCHenyv
BVvwhRe8EgT8f+K6fie0+X4N0nZOl5MwzNPdGHH3GxLTnAyH4S0LdH0bQWiE gA9U3mkgP6FB
byBgwhWJiizGFALADHHrCc15AwYhZWBBQzHRoUgiAZjAMbwAJJAKga1NHGlH 4pcGu0BWJkqF
PV4QWWkAx6oHYGgaCBpkMEPulimQwWxtAMAmaaBziE7/AAX7pg0qFa1jYbWI ZnHBVNeMIYK6
gs9sERcAP0fNwEAEYRU14wCAAABoM7zHpYrUJRYLXfoRAYGN0Kj3Jj6RpBjw ngTaj5pRks+J
/wCK6Pie0+X4N0nZOt5MwzNPcGHH3AJYk2xjBFAhGskRhipkzcv2jdIMYS9A FxjARPPmzjwh
4ykaSu2ISGAgJzaLUQhKiNpe7mE9iKVDViCQvMno9NiRrAxQiEGxBIrNOFxx CEjvBqpaw8SG
O05roW17qZKdY3iAxFN0C4UOCCw3uvCOaZ96g4GEVZDo89fwd0fEsVgFQ7js adnTsadjTsad
jTsadjTsadjTsadjTsadjTsadjTsadjTsadjTsadjTsadjTsadjTsadjTsad jTsadjTsadjQ
uM1IScJ0PJmGZ57gw4+45aAyZfBUQ2uFRgp7PmJKAIrzIDLMaKMMJRQCERMQ NBJAzHawSIfF
rYxxgsxZE6QFSAqLgvHjLaAkgKiyUIMRuhgw9oFL8GwfQR3hbQRDgJJhRqBn hMCdCuNHAt0k
gWAeO34SwhLCAsGHAT9EfH4PLLLJJJJJJJJJJJJJJJppppr77rr7777775s5 fLwAMARDM090
YcfcA4GQRES/g48YtubcHKHN35wAaYFoB5yUWEo5YVy2IHDMFWgxTUJqFEgk S3DQgKXni/Fu
YKcUPiAUZUZrA/fPMNyAMASRMFtn6AhVhkL4LqBwaBV3eN35zTfNL0xBNLEP mExQIB1f4UQw
picE4pxTinFOKcU4pxTinFOKcU4pxTinFOKcU4pxTinFOKcU4pxTinFOKcU4 pxTinFNBikzz
3hhx9xCUQWId41awBL1oCWhUJJZ4rWm0JJfDcyy8o38M1DwMBS4ApUgHdwgM EohdhIvmCw3L
0jkJTlhAQC+ep5POu0CmJBCMsirKcKiSAQB0BBEPOmEgEKF4QczCIgADyBVi NEKK1DB1ttBS
UdoQq/T/ACGnGWBVBSB8orVkwdUT3joTkQLSzmEhX0J/hHFx4Cck1UBe8Fhj jGwjVqZNskD5
xLfClgatkCi4M+ZNuaJOC5kDRJOEY+UBOoAmEA7mt4CJUgPA3oLhOUw2gAJ8 Q6GO6ACfh1W1
QDBYGtfAAVCW8CFTd2Fe0uVhWAvFRexmsRZyAQY1RM52w14R9YGpZaAtHnEP kdCFNgVCSCwL
Mocll5hgwUVgVs8obDbRMSouHjGWHYCyQKJJjTiJAKv1pC2IkgaJ2HtKuBAA tdhHhwkMKnmF
+4cSUKjAxa1Pn/4qKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKL65p7ow4+4 kAM0BG4uts/o
6KgADJJ4zDoARtK2JAGEY0q+IjSHIAHB4hKK3gEYFRhnKoltoh8jMBgvLjOS xBARLvWtSrMC
K0QcOeo51PEycwJArSHNQttJkQYUflAoRgEBAiX8SzAQJO8AQQMCOWz0F8w1 WwKbBk1U0gTA
3p/E25VowmAF5DEBAavAY51lujFSx6zDzIQvKZNQj1I0cBkeJAhEywGoWtHy Jyaxo9id4MbU
WWYgXsR6r+HDtNgD5ETGBbPfFPhCBZwj/uhddGQCnK6GBvNSCfiv4iDHgUEE D6xseIEqESgD
coE2RzDxiVbvx+ee8MOPuwMCMfZmpIdNI0yFgkU818KFBwVJNWjii3DsBbVG MyIbHKfvKOQY
AHR5AfvArvTYG36IBgE4FgLKcIkgpLyGPmDF0LrR6QgwwJoi9H7zKCbkCeXz BY+ybkXtMozH
AznR6x0AsUrDznxMNjLEVd7+aDyoMAZ5AZ83H9FqGjThDjjj2fKvKGYB6lhH BIMoZMuuBKbo
na0Fkhj1imYmFuOq+Ym4gOaJecBXBkIcDgWU/eKNJBESrsEvWAaAEAAEC125 IEORgjBX5OGY
FKXW2iJicYFcO9fENpdAg9BBWjA1SYJdsGAQBbVdO0KTaO/YQhCpDWPmUoW2 MaUQ1NQgIHKI
eBJbxNostbE64zCAWkneqj+oFySUOvSBy5EAsBPwEBpDZW464gYVyogD2DJU aZo4PFf1LDLB
6Nh+PzT3Rhx/Is890YcfyLPPcGHH8izT3Rhx9wCFgXAlBGlF6qveBFyzmFVX jiEKgAa4bjBB
JjCyoX3SSm9grlIRIeJBV1UByhQFMUG8fqMM2Dey/wBhigYGUCoQKEIoIHnr /Es894YcfcQC
EQxElMsgHw5mgWbh9od8YQHe8LsqgFGEABoAMeEsUNZybmNhMLKPnNMI2aUZ 50LFxyzDISlK
UTIKNTwbKhCCGUDnw+0UhsLYgxANPMAAwQRxFhbhP8HzT3Rhx91skUMFKHAE eDYIM/PtDJgC
cj8Hj/kwZ0K4T45gqIZoUPYQMA2w8iIaUKwAa6eFe8DeLeWKqwITUAYAQqws vWMlpPywNoOO
4cdxFRd1UXzulCbiBnBZv+kNnRYAB6YveOPQgkukEAz5mEhgTHSh1TGnpKVi Nc8GrrkRg5Ed
LNVh6xPp3AHtawGQKDkyEPYwVhBZDyA+YqxJAV3/AAfPPeGHH/iSIp8CAvOF wEWowHi2aiQw
CT4wiZW2K8YYsaV1aVCpcTAKAtlb7xCwCQXoMQg01RCR1WYACiuVXGcy9Zig /uJcJawqs9Ga
MxVmnuscwlBmS2LEDFVrAYbXKeact2jhDOQGExREZFOaC7W8wHwW1G835OEO CQFuTzftCBko
QQxJ0/1QFQCHXMVGkhAByD2mMogkGxBR/gWee6MOP/EhhSvVIGp6wAgaG5cA ACWAh4QVZjAo
Pq3BZAQ0IDwcpBDKQALQbXlARKTGV7t3CjUFgvndNQvwTJxZ8IfMgcVC9DCQ vklvhAIALDOU
8W4BgoF5zq6gBrciZzrPHclrxlykBIJQAeThGMMlkDaDahA7qJZuZdzMqULd GZP6jwuhxDXQ
G9iW3rMhBgeAHRgnzEk6k5P8Czz3Bhx/6a+97yiHMSIsOCGfeEHLWIWtv9aQ MCIAGOBQ0KDm
EkKs+8AgJ04GEJmzgAJcHAULZAwC+fCW4JwwOnV/SBlkeTBFjJ4n+8XnPKz3 GD0hGIBOS6/h
Wee6MOPvHcISQPH8bzT3Rhx97ZmJEUm/43nnvDDj7kOgiBvFuSvgYdsAQGxA gg4b098wEwig
4AduPaEyJVXnWAVWKCdt3lFhGiyTV68+UIYFWyDG2sPw0tka7R2FECUDL3ht MigwA40hg7Ik
MrOFnmESLECopjIf3P1gRmYNYLnGF/Ds090Ycf8AiNIHEzQz9CAI40Mw8/qQ CEQwYrI6KH2B
JAFQr+H557ww4/kWae6MOPsVjtBuH8eAAFnpErvmHH2CkIG0B/HvYfSOP5F7 D6RxBFBorb+Q
+w+kcQmbNxl3/If/2gAMAwEAAgADAAAAEFkHBCmhTDDDDDDDDDDDDDDDDDDD DDDDDDDDDDDD
DDDDDDDDDDDD9NC3I++5NWZfffffffffffffffffffffffffffffffffffff fexMMNMPPPOM
PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPK41ECmH8IDKsPMPNNPPPP PPPPPPPPPPPP
PPPPPPPPPPPPPPPPPPzym+uDvKBNhFoZnHPPPPPPPPPPPPPMM8888/8AvXnn HPfTjzHBD9Kl
/JQCQiB4yywRTzzzzzzzzzzzzzw/m3dZfntczRPZzMQS29n/AGFOusM8scsM Mcu888888888
8888889oHSUA7nTjjjDTwgiCwB/S4y/w0480888888888888888888889JAA AAAAAAAAAAAA
AABJ0EMcMc8888c8888888888888888888vpAAAAAAAAAAAAAAAAFqNf4hU8 w08888888888
888888888888rKAAAAAAAAAAAAAAAAHgMU8pUsMuc8888888888888888888 889JAAAAAQAA
AAAAAAAAFhBX4XHPAGHTcWYx/wDrNPPPPPPPPPPPPLCAAAAAAAAAAAAAAAAA qAFPDKlqNtho
5m0PDDPPPPPPPPPPPPPPgAAAAAAAAAAAAAAAAFCMFPPOulUOsLHhEPPNPPPP PPPPPPPPPPgA
AAAAAAAAAAAAAAAFoMFPPMjBRqtZzFREPudPPPPPPPPPPPPPgAAAAAAAAAAA AAAAAEqAFPPH
HLDLPHDPDPLPPPPPPPPPPPPPPPgAAAAAAAAAAAAAAAAACDFPPECKLLOPNPPP PPPPPPPPPPPP
PPPPAAAAAAAAAAAAAAAAAAADHf8A+mlp8ILKnGrDXH3XPvz/AP8A/wD/AP8A /wD4gAAAAAAA
AAAAAAAAAawDfzxsdA2yLQNYQ0444y6z/wA88888889gAAAAAAAAAAAAAAAA WrAU88c0Q440
7js88888888888888888+AAAAAAAAAAAAAAAAAUowU884800888884888888 8888888888+A
AAAAAAAAAAAAAAAAWAwU88tTUwMXUDqiV8zx15/288888888+oAAAAAAAAAA AAAAAACoQU88
MUN1suISMUceuMeceM88888888sjDDDDDDDDPPPPPPPPOMMU88w+YI4gUC44 84w8w848www0
8888cfxxRBBBBhBxhDzzzzTrMU88kW0EMouGs1o0AA6tE+HPU/y8888MMMMM MMMMMMMMMMMM
McEU88MMsscMMMMsMsMc8ccMdcPM888888888888888888888888AU888888 888888888888
888888888888888888888888888888wU88EWkQ0Q48808888888888888888 888888888888
88888888wU88/wC1zhkbWMHLuOPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPA FPPPLDdpPRlG
GDLPHPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPDFPPPPPPLLPLLPPPPPPPPPP PPPPPPPPPPPP
PPPPPPPPPPPPPPPDFPPDvOfqHDPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP PPPPPAFPNPPP
PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPLFPHPPPPPPPPPPPPP PPPPPPPPPPPP
PPPPPPPPPPPPPPPPPPPPPPwPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP PPPPPPPPPPPP
/8QAIREAAwEAAgICAwEAAAAAAAAAAAERMUBhECFBUCAwUXH/2gAIAQMBAT8Q FL4pf4KvrElB
le/B3kREREREQiIRERERERERERERERERERERERERERERERERERERERERERER EREREQsF7IT6
9YIjH9F5iz61YLfmDPkIl8+FyqioqKioqKiCCCCoqKXxH5WeA/4p/Dl4EXz+ FGyl80TExPyI
ruJHyY26b3DIWH8A0eIpy8DyrH/I6DrOs6ToOo6jqOo6TpOs6zqOgcMMBYNS obIbIoaFeTgw
4ODIQ/SZebjhWPFqJTxOW8McF4YNfPqkEESEC42Bqj4Poh6jNRMXtw7tH+xX fZ/ocK0/2OFv
F2M+DoZmv6h6eI2M+DoZmv6oycPYx4Ohma/n2fJ2LIMb2UY+BsY8HQzNedsY 8HQzNedsY8HQ
zNRueS0vhOnpDTUq8X1CwwXo9OAcAKJmPB0Himo1SCDBCBn6JjumQhPCCCCC SCCPCCCCCCCC
BFGPB0F9TX9XribGPB0MzXnbGPB0MzX8GhoiCfAzR7EDQ0mQJT14onSlG/1b GPB0MzX8kVrC
3jbDqSoqKioqKioqKioqKioqKioZRmZrz+s6zrOs6zrOs6zrOs6zpOk6zrOs 6zrEklEa/s+f
C/StIfPJ1408Tla/Za/jPK+q1/BqRF2iaeevqdfybb3z8fU6/Za/Za/ZOI+y WfZf/8QAIhEA
AwABAwUBAQEAAAAAAAAAAAERMUBRYRAgIUFQMHHw/9oACAECAQE/EMqQhCHl kcfMbdE92Vbn
jcrKyspWUTZWVlZWVlZWVlZWVlZWVlZWVlZWVlZWVlZWVlZWVlZWVlZWVlZW VlY8k+i8ibYw
777ffTPyHkQ1yNfi9HGRlFFbFbFbFbHAcBWxWxWxGTteRT30OetXkISsdIQS EEITpBhh1cH4
DzJZLSh5drwZx5Ex8Bu/nNBgE2SZynIcxyHOc5ynKcpynOc5yHMcxzjLlM48 iVGyIRlanAZ9
DiM4xeWtdkZ9DkjIYxu9I21eRnoculj6pOcFFCZOladaiFqtClRFlGMa6f0Q hCEGour6LzoM
Rl0OIzGP8VBz1pMBl0OIyGP8oPR4DLocRkMffwYQhNobuei6PH74DLocRkMe uwGXQ4jIY+55
1GAy6HEZjGKu79Dbr/32ZOVRMa6Z6TTkTMDcvx/5IZdDgLMYxOFlFFDeljd5 GwnKKKKEnDK+
xtdeTnN1m0N3koooosoosc0MuhxEmMf4smBHeRyvH+30eAy6HEZDHrsBl0OI yGPtfRLYaaz0
nT31TlRqKnkrcahrVKJ+OAy6HEZDH3ey/hW5W5RW5yFGfxxCOyMrYrYrYrYr YrYrYrYrYrYr
YjIyMjFcGQx93vqyWVS3hjhEtJynKcpynKcpynKcpynKcpznOc5znOc4226z H3ey9nrp7H3v
JDwYHNIHX5UG2Z48anHpU5jpN2ozz2jcpqcf0sfbOr+Vj7E4UdyeBq9fXx8f 5r4+P6WPvny8
f0vAP6Tz9L//xAArEAEBAAIBAwIFAwUBAAAAAAABEQAhMUFRYXHwgZGhwfEQ IFBAYLHR4TD/
2gAIAQEAAT8Qn1B7ATuPdxXVo0QWSAPliBQsJKhWdUxcJEb5PZgYiMleaU+m 8FQXaXluTx3x
kGCiqHOIm6pV3CdPjm4+Bp6vGTwslO+KbeGuqsQ5Wol5w4Jra7f6wY+uEeR7 P9sFEjd3cZsQ
8ZHa3/Snc8YsRaYkpVxeHvM03j1RFA8Wzzio1tnYDAcOuIp2yvL67wIgRJHC bhccCTV2MQJJ
92F6wKOV3o5Kz1xMpSVA2+ADJiDgUgKpJHnlqQyBSwlecr0rpOMQj4e/Xhz8 Xz8Xz8Xz8Xz8
Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8 Xz8Xz8Xz8Xz8
Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8Xz8XweCjbcAKz6uCEAqq6w+vbkFw88YnEkbV HMb0w70IcQor
bZHEOFDgp4u8CVUFBEcnPnFpIKqsDIEtnN7QG86dOE7PZgdxua1ZZRzSXnXW cmFkGVGCgB04
mqAkKWEF3vCStiRyB3njACkwsHA4lUlHpfGCoaYO1pviieo4RtPNIapvjNvf SdqWS4q0FhAz
kU+uDBlSQfDcFZjBragi2KO/Ge3c9u57dz27nt3Pbue3c9u57dz27nt3Pbue 3c9u57dz27nt
3Pbue3c9u57dz27nt3Pbue3c9u57dz27nt3Pbue3c9u57dz27nt3Pbue3c9u 57dz27nt3Pbu
e3c9u57dz27nt3Pbue3c9u57dz27nt3Pbue3c9u57dz27nt3Pbue3c9u57dz 27nt3Pbue3c9
u57dz27nt3Pbue3c9u57dz27nt39C484kNILC5pvaTFgVoQwI9KdctY9axB0 JKGWN4AUA4EO
LSPwynC6MbsQVYto3EdSHUzyEqLzC9suTQpzEmNV0UEkOkdFv7YwpgJyOkGi t4bMDBjAQVgg
WjXdzlmhC9lQo275suumb4LdEKupivIObO5BJDx2gB8MBR6ELBNCSIR67cLC FS2EERwBw9M4
01ThbhOEi5A420bXUaJRANFBkcdWREadaGCn3IKDTF+ZInhzU41DNDG3zHfn G6jkgIb3yqq7
8a6v9nFx5zen6z+4C484YhQ0i43PfBN/fPz2S0L2uE8+o6DAFETuZ0he1zSu o53giURPGCKA
pyXDFIJIC8WDPVxVnnQj0wawM53mm6u9/T8tgtdAEVmKAq6wopShy12cNb41 zikI1XSSjejl
8nBCI0v9nlx5HzZTW/PBS0hYUKPl6vLgNYJVwbGjdQd+px5NUtceVylnlwqp J6dgR7MPhrFZ
6ZNrwGRnTVNod5vx4MuDAim9BIZsVhGFPEJNEWIYIpXsfXDHoHAdibA4NcBj wlychzB24Nwu
1j4B7dhwUb+JdFmgaIieMRE9ImgcjSdTeU7ZvykRJghvEG2rreM1lihD3s30 MdwBR60r1YKe
qZ6sRfLzbNOkvnLNnE1qSJpBrRrAQFLVtCOtfThr1TrNXpSmAfHev7OLjznw pyOfUhrzw7Y6
IiuES6dj431zX1+Egk65E39JvAL6DNoWjc5nedNU+NKTq7WGHJg0aoYxrYW3 xMU61FRVSGka
aV1oxfkAFMujuwurkxPFWEiVAsZF+GGhshFe1JeX64F6/wBgWToed4rB7m2E TVeOfg6zVnhw
2MMJcII78YMruDANW+FjkCUaYE1+oOeROuNFyH6B0detHiYEWUiF8p284c0i j1qC7O14x9nD
kSwmcu4+OMu3PH1ZRJo0Xwa3l5qHloioo74+OLdOBYORa0j06Zto8hQyGVu5 J1w0Ga5CQxKb
exJlrJ+0qBwE0PqzjcnSsUUdulPOWKw5gexPQb4dmAYjoJE7JzyJ4uCEz+gk 2oBTl1lpPMbJ
ZGn1Nf2KXHnPnASNyjsdNu7vvjlQUAqTmIunyMqzXEJO15mWLU3A5jhvnOIj xw+BihlDqQiM
VJqYptQFqIjAl0YvSWwKpFHoovHfAzyeGXEYrgoAIJvQxJ/ljJJhovCpSeOM 2/FERaiSpeji
wCwRPciXbjSoGA69HoaNHYziglJ6Ab+OCDeRhd0Tmq3GhRbR5btzPGBZ8Qmd kSM3zgUL4Ae5
DXX64AQOOBxGKmjBFqAIjYkjvAlAvTHTPka10wINTTCJrlNL1w5AiWm4XWru ZC9xz2BlJ0yX
JiWPKkwayDG+pR784MnQQENAZSY/D4QfJc/HAAADQHT+tuS655s82ebPNnmz zZ5s82ebPNnm
zzZ5jPNnmzzZ5s82ebPNnmzzZ5s8xnmzzZ5s82eYzzZ5s82ebPNnmwD1/UuP Of0w9GIkwkW0
EHXG8BdqmOqE6NF00+hkR8LCROjrTfPOpkAB7NoTetQ/zcWKCg2F1VtfnkX0 NBOQGorOF1bg
SHnd4g7g0m02wN9aAVUdKrCMnwmXmAIHsM1aFO3XNh6V6uQ3N9B+WHzoDg+L FO8uMMbQUdoN
zhHz5zl/OYAClpBHTWzrjEXAGBIQRu1Sccbx6DgZGgaSNROJj2nRsEgkgNDB CsxtpIrGagAe
N7Xxknz2WDtbycuTvNqOFOwGGik5uMlbdNoBFtBC7FR6DEpyVrSBBOiy71lT rS6tk8Ubu6+q
jj1LMqCcGdW4vh2BDyaBvE3oLlziBiBskrp1usRtSMLjTpy7m/POLroFKAEj TypHpgyDIwH4
veKDuqbwZx2caAnQssaL5/rXRhfxVV4xAtH0UEh/9yxYsWLFnz7duFckUqv1 09NX/h6UKBIm
XLk9PAoaxsfkfl+kBMrDACBRKP6CgjcIseP9i9Wvb8oFedYfMmbwIxHSPZOm ESfoXHnPicso
KMRnZR3wYwBLUCXns3x74jZgK0gruifOYkoTqNEAtafvzHGdb0QD1i5dNnQA ipbzp8alw70Z
7tUp3KPSFLlIuw4xmzpxjeZJkfHBXXkL0uIpNw0uqALx80yjPE+kPPyxsAhM Lg25PryU3gVQ
pFQFDsCnC7yNh5pRKOKyOtipq3q7x8ZC0w2wIPIR04RqKwqhYecVU5qRy2Cw Rp0jzh9glPwQ
p16PG4bwAnc7EvN0ievFzcDqkcW6T43JCn1IVCJdtelmHT7AWVwF9cNlttNA AIXUT6Y0QJST
QTdNnFlOmcZm5qSyDaKa84K1CG0oilcEV4D0/r3G4G2ltwhuPyzzPzkfAcdh gNaooWR2ZcuX
Llxcf/EH+C5ByhhgyZMmTLrfFhc3QyoRs9UxkE0nCl6eEy81gYydF9M4BUGS kTew8XOBSfUc
b1yFyGQhcXdxpaXTxlaJW3hvj4cYkVB2Z8QHzFAvynyx1L0/QuPOfNUQFrWo nRNaIaO2B5xA
DA9Q0UNay0pgFIjbsGrLjOLLv0Yqptupki7iWS9VFfnjqqzARREakLsLvJGn rJZOJTScvfEN
tUQ0IqDvl5udj0f5SA95gaBq6Tgdo8WYhgYcR6mtdbb1uIvy3KoAh05hzQEz i2gFRXQG3odj
KmHoe0trto2184uQUIwbRIvQmH4CDQ1yQxrrjpMgQoi9Zs2nxlwHzkZC8ger 13d494kyVbTc
bZVnTHCmSkCKKK7uhbu5QLCRFGyiY8jGZJJUhU4DqtC4nVS4AIQs5dJmxGD2 448boWYqb2Un
JqM7hcDjuAURYKAU6SdJjVRcHkgoVDWr0O39fzZ9F/w5KcRTOkm075R7Icgh eF5mX9i4/vDG
LFjjgxyOUy/oMn6RJPCENUVGg93TC8DrocC3RbXlxBKEnq4NW+d8Sg1Dh5f0 YdwONp03G1yO
I1S2UqANy2H6VfR/oXHnP6ZNsUsqojggG0vG8gWmOiQJxR9DxcWIyK0xr1CF 7a65t2bDIbEb
Ly9dTECgU5BcoAPkZqwnYa3IFzSpt1gWxNgLEtKpVHrAxbcKCggSAIAS8nrh xu4iO4HWSiu7
xkXVMHtqQa8p88XOYmtwVkPfcnTHVS8zw4mjaL8DjK+S3JrT0C7MvHRzUPgA Eoi0WqG+HeXj
smZ1DbbS347wqTBEIgOWhRdzZ7KPPQ8c5PlwmAuEz83Y62AnBdBh/XtWmxJU aEic89MNCHeH
FZNtV51rhCiA+2vEoOuj4uSvlN0hkI4ug5PQiSC2STrbaeZzgioCnPdehJxH mXeacH1L7vL+
IGneEXVSGo+I1xryigG+hJEeXbf9fzZ9H/w5Rpoo2h0T8s9+ffPfn3z35989 uffPbn3z2Z98
T7TQI5dOKZCuMtjL4ymVauYWiAeq5f2X1xf2X1z3N98p77657e++Ae++uAey +uewvvnsL757
i++ewvvgfsvrgHtvrgfvvrnBe484F7T657s++e3Pvnvz7578++e/PvgK7kZ0 1t6W/oV9H+hc
ecn6QvH6T9Z+s/Sfsn7J+syZP4Hmz6H/AIc+ZzAKF9gBpxHK9KJp2hBEHUt1 lb7CoJryObq5
HufLI9nyyPc+WEABJRoaBputs1hAhHQBVpQsZ+lYUTnfN4Lpxev63bsN1RhR SsGa5/puf9Ba
+j/QuPOTL+25cuX9L+l/jebPof8Ah/eo6/1vArn/AEFr6P8AQuPORBSKUHIN PEhAEbtRUnFc
m8hxQiWUuStI3c64gBtdaUHHMXECoW7k3qoV4enTEB8YmOkEvHlMVZJqJmgL Is6Sdbi2BvE7
Qqahp7zvjghVEYhh0EdFb470SOljQCaH4DsuNLtQGidBheuM0HxU6BREcaJO uUXpVAgj5EXg
OOEyt5cIIEm2i0Hk7JXr4AiiHgho75wKuE9n0G1CmyfLeGutK5zitx71+vNG y7J9HjLVafqC
QPhH4/xHNn0X/D+/R1/ruBUOuC+j/QuPCYEIiaTDZQ0GXwMh2yHbIdv0h2yH bIdsh+ypfZ1H
NOz4ZMn6iFALthz/ABHNnuXZwT91HX+u4FIiYr6PAQNEAj6YdTVgk+ZnJ+y5 f5Xmzf2mnDP3
Udf63gVxZInosvo8+o7e/e8/7C9cOBWBSzrwh639emJHzsojTU6t+B5wjKeq gHjW/wCV5sND
3RyC/dHX+t4Fb4TB+OX0eeHz3zrr5DznJ+qCI8OGwFgcAYIBQjwmDMoCtbD0 /lObBS928k/3
J1/reBW+Iwfhl9HldS3377ZGieD1zk/ZpKEpGeuUQjCtcBXjUuV4m7fh0MDR AKWqWtRi66OS
gBgB4OjeTRSFxUrVUndy4iGj7u52nyw/BO5F0Sr8zNiSKr2liaseLzkjNrZA G11zqGRLGne0
PO/4zmxHY0viOUrRXjCHb6v95Dt9X+8h2+r/AHkO31f7yHb6v95Oz6v94K0N BHtzLApzIuuM
/OP95+cf7z84/wB5+cf7z84/3ho0IAYNabpkes6/0yJRJcdUtlmX0eR0/fv5 5e6+T1zk/Yaa
afRMrqRtketj0Bf5Xmz2fhx1v4QI7uS+jzyOe/v3rOmngJ1xclOy/tWorNmg ef8AB/K82ew8
OO/wkGe1Yvo8+q7e/e8/7C9cZlGd6s8T9bmrEsdOccbq8jB7SXTNmRFg67TS 7A5yBqsZFV+I
AzBjcQipUUO1S2POa3FXrSGksmKzZF56RGtSOnuYv5EtJ0AWpy3xiZATxsEW R26vGeNpr0KD
zpkdsdNgtcilaJb88AGsSEGg5iV8HxjAtQJ+F45dHTzkiIihdANmdXGEYPK4 dIV2vmZo3QiR
SgUdiU454oXXEkI0qPOR09XHAvNWIQBvPx5xZTiAErV0Bm9vjCAalRuJXa2L 2MnWrpCHdbam
mVykQwKmI2zjduDczxmOnVvO6Jg5ia9XvXn5HOGEENROkxImG5b2pKNcVot3 Me2ig6bWxnkX
XI9VmToKka6gPDgEL1Xh6D6vwyjiQBK64A64gISHQTiQn9TzZ77y/hYHuizf R59R39+9Z/zE
65yfsn6asWFgq+mKSFSQDCrVhpamsGWyvEFgudeuGx7OQIiiBDJvXDzhAbsU FQomtcmItaAG
VYVBKe6YpOCkAokTfUTtDnKLUsLVDgpyaliOKCI8iogk5uzDYWBXN64C/THI gqSvoBxC8CaQ
NFE43zuM4wChI2GUUVNaPZrnHJolQoxlN+pkH8UCNi9DQGTF8yytRTgCVoJB brHhuAoQWJz0
emMyfoEIYk9OucuZspOp9Mozi7mI5SHJz+s/Sf1nNnvvL+FUS1fW5fR59R29 +95/2F65yfu5
x9TKdR6OGW61gukJPBd84tpTEE1DU0rgHeGAXOB33Oqy3zcBKSDvprIdVcq1 tDzqjtDfZLMW
mBCyhXobEJ6dcWJRdKpJZGkvFxE3L4jVvPcFieJit65EH4Ob4DYRfQwR4d1G 54sVOcCNJgAO
hoXsrVOuB+KbK7Vd+q4tCGhQqebhAKheMSDbESmCDOxbR5xUBNApuqd4zUzo j3Sw4kDqvX1u
TSFNck6i/P21ip3IWUtUdXQF433/AIHmz2Xl/CqBf1zL6PI6XPfOuvkPOcn7 tWLaBLo7HOGg
ntIh3BRrkhra8MQR34GBwAHc+TKlzYYQ25rpr4MYDMD0s0HAm94jxIIB2hwn cTs8YYR6pdpp
sdl053g3cacngnAUl0o6cSMGWyOAU87nR4yBLCGjVWNIqAKy9Zl2+GBNwgie k65uiGOn3Hm0
l4cG3ENfsWS+cJ4TcmDYPXKKm7Os9T3zdlUhQvS+MCbkpNG1Jw6aLvrmoNuY lF1J/u9cEkSL
rED0FfnhH9Vuk03KanP8FzZ7Ly/hWEv65l9HldS3377ZGieD1zk/fNzobEXc ZwecCSAQ0Hx9
xx3ycRihURnDlHjOdSyyIxo7NmKIKekiWvwwC0N/2DXxy2V6XgLQcPPbEgtx Yru6prnAlloi
CWPLgeXA6U2SmLbEurnKgEQ6vVeMSyE8gihXlnTCn00ciaXW648YiUni0eRv b4wLeSkVZoPG
NxHD39hbXxjWDYmbQ2RNzCCG2b3gkbcGHiInuN6vTvgoEEaiMAXSvA4KPJY5 Bbydc2JZAFsK
vpOvk74k12Sywxp4cGYATinAXl8f1nNnsvL+FYS/qmX0eR0579+uXuvk9c5P 3GwQBFjOZ1zm
uiFIGARHfNhCBjwgVDmYBEVypxrD1Autu2eU5aL4xsNcXvSgPKdM2l4EtkgB z3U6TE6j7bld
mj0HB8dqO5LzAAENrtWvQ1gS36xCgcQRXha8prJgQAQA2JVLTtC6uIb9yAEG m7RtXrgVAYG8
QSw6yLrnLCHi3AUU1T882A1TNLWOxRuiTWSYBIFE5+af84iI3rEF0KDnnNKj SqpICMYsbLDI
YYPt6yHF6i3xmuMQNjkFL1tnhzT7C0W/G8O/VhuCGmQp90cFb+DmgpupW+xi zfa3qygMdUC4
Et7RtyRGuV5Kduh9cTCA1lSFNrum+0v9ZzZ7Ly/hWEv6zl9Hnkc9/fvWRong J1zk/co9Ecej
nesZnmoyVsQUEum3UtpIeCAnLq4PGUCnDoJZAa64vXHqBrZ0DF6XphOIErY6 qCaN847QSBIq
FXoF24rIosxLv3FyWXesnhLtEFNaiRoTfJHHuKloxCagq6uPNhAQBQVC14b8 YNlvq264eR1P
JvecHSOk96gyhfRoJdNFMWDnyMFum9aBrnYNJENGZiAOE+JMVxgE/KILdkIz 441u4wl6BhDm
uKNfpfNNHdIZ9O6kAQJ4N9MOw69NqEMKT1uTA8WcSCFExga87yZ5DsIDWxJu TduLVGqi9EFf
HfNX7BGCCFQWvBvxisKbVtV0c9D64CQoKNqB+JPjhdU8DhKmNGta/qebPZeX 8Kw9/Vcvo8+q
7e/e8/7i9c5P3IBEEeRzZ37dMuTVs5o+TDApVOLs7TpenGQZNN0y42JqQdtO rtvmYCAEeRy8
Me04tZxoRDjSbMFGBqr60rmhpmhMMc2G5caaExwcH69ABFFTznRAwSNzFNta ademIknkAXGl
A3/IEOG9CBGhxMd6/eHzd8ULfgjDKWpaCRJpNmEyFBXXypXKDswmGbXx1cdg mOOhm4gNVkEU
+B8sTTNHEGUHpYfI/qebPZeX8Kwf/Xcvo8+q7+/es/5Cdc5P5rmz2Xl/CsH/ ANZy+jz6jt79
7z/sL1zk/cbTMEywswAHSAwp2APXZvRM1wUw5JQXq5PLjBEyArb2HkbP940m SVTCjUmBFw2k
bKg/LBhotJZrkK3G+O8wQwa1QhNI2Ot+sw0KVOoOmzwONYICucajoXW5uOv4 vmz2Xl/DMC63
0eeFz3zzvIec5P3IwARHhMHOychs4v1wdTFyoOmakI2gSFE2a4wecIaQWErA L6AYNagBLGlX
geyYUSC8dXzcQAknRRL8tY+99IEGgOg6rhiGYVVVVcuUspe36xZS9v4bmz2X l/DeK+30eV1O
ft7+GRong9c5P3akWFhy4QyKWd/PyCfDCPhgeDBuOs1juZqMvcyyrlUqlGze nUfXFzZCNJ2R
vuh88es0etdKQ1zZ8cYzNqrsiEni/DBM1GgCs3Zr5YyKOotqbaad2fHAE4Pt 1KpCU9fGI7po
svIXdBxxj4vSbK3VW+c9MbugMe7SU41vrrKvMBQdNhsc9sqUC2mHhp1nXjEs NJIbWkKOvB2P
GAZLN48UDejofHCAqdGjuIPiP84CWyNkX4zr/A82ey8v4axX2+jyOnPfv1y9 18nrn0GeR888
j555HzzyPnnkfPDrlIdAcudptbegzbNKc0OhZelo7Zxj5yC0FOjp/jeHYawx djAMe+GU/Qrz
xsJhxgpDB6G8HEGSbAXheEb5Mrlikq0JrZ1jWzJKoSKAC9DfOEMTgQBYIYvZ j4xPoDhudgmn
TnAslCgg6BtZPXWLdFhLIRHZN89saswkNckQ0nzzhA5eBSIqS7NacpKhwCCz Tx3y3EoNEY8E
dcbzyPnj2NLvLORGdSjxBy2YwRpUV201L1OmcJTFtAbYTmSdMNwI8huSuRzM E81hwOC+T8s2
tB8FW3wnQ5x7qAZNNDelLwdrhI1kiewiNy8dsXKSxzAGlyjH/UEFJUOQV3er KvsiqgBQKMbN
4oRFpnEeN84jpJUOboNdLcB5+OxlVegHX/LrNNe6ASOrk30yo1oeIEPYfLqY iGyXXrAYb5dH
XPI+eeR888j555HzzyPnnkfPPI+eeR888j555HzzyPnnkfPPI+eeR888j555 Hzyht88a3X83
8JY1xtFR68uROO+eRz39+9Z4HgPObB4z0c9HPRz0c9H54KkBHUecZJGYdwJ9 fhjzYMUS2Hfy
/NxzA1BURZz685MnAo6E1Vh4rjsLvdMf9lNpPXJvVtBSEXsmjwYOaBUOiFvL vr2O2ArRIikD
RHoiZEFkWihFXXWsXU1reonqTJdXE8qjR1c5LkNmxpVebswhsEFJKL2aU+OB DZzFZQj00o96
5F6ODLzV7qMyTtqX5ETwusNcDbj6q8rgJSbZSqujmPwxpKo7YLfevOBQnIt1 BG06Tqay8RAt
CGk+C+uA7ISUSgnWv0zSyteCAQDg0cYFoiiQIQeigGG4di7KADUb/u98Z3Ih aJeDrD5ZUaBg
z6T4vzyLVRCdB6YS2ltKIqj32uLH8KRahRB6ejjzKCnsR2BMIMgJ3JRHVqu+ uOhrRs6TR0hi
NWmCUCOTrPGejno56Pzz0c9HPRz0c9HPRz0c9HPRz0c9HPRz0cpcfPKDPzYJ /CEK2h78k8XG
fVdvfvef9xeucn7hvKF4ho+eNWDZAtloHnXTfVWAiWS6vRQ6up3rDo4xHnUh U1p9YzBliEM3
kiQXk6XbMj5UIgdzGu8POFBym03ijE6U+Tm1y0FnhFq6WDWkmBFsTugMLzVe nTE7UExCC94o
Bau7MI7WVSUHiJ2A65cEvSCxiJ1d3P8AJr9PNwnh5ma93zGClsbFu6mMFUAu CvwnXGEVxPVi
KHcdmfIj2pddf7vXHITLKzYDwN/xmnWyYLSlYydf4Lmz2Xl/C2Ff1zL6PPqO /v3rP+QnXOT9
yEVAOVwcBLGHQseWfTGC1KLmWdW961kTswxRSq8Dp7OWpXbxhrHOcCIrCC73 rJ1bQRJzA6yD
FxBaEaC1MI2UDJLtt7/LH6wVKLoHiE9dY1pcBwtYBOVUMQgDiw7QfAxZlQqt ktluD11nA9Y3
fTLNLgsgXXxM1uDSiUPpB88R5SDECoOsN6wCwCtZ/B82ey8v4Wwr+qZfR59R 29+95/0F65yf
uvHTJjEjhs2qAjoaFfTpz23AcDoiuu7bjONVFCmKhOuTWIsaN8AYepU68GFF 3sAVdcyvOKUN
4Qa67fx2x5JC+uEB0KH1wOUsxGEEW9Aw9CHvYSs9tIRrVlVawGiCNINHDrl/ kxv54C5wAqWT
hMQvcZ1D3PJ64Lu5pzCrzIGu+CWKMJolk6whnNMmixBrZC8S3+E5s9l5fwti X9cy+jyOnz3z
rr5DznJ/Nc2ey8v4UhL+qZfR5XUt9++2Rong9c5P37+jnaMv+MTZTqSUwKw7 OdfokQ74ay4P
wMgjsOf859Pg8fogAoLwd8nn4XjHpwlRsnwwCSiUf0DoKq4HReBRP8/rf4Hm z2Xl/C2Jf1HL
6PI6c9+/XL3Xyeucn7mGIxoWC4mSGy/NbH+MAAIBDFUO8VVLHu5+mABp2MNR Z5xVLrYY88Hx
9ccaqoUtHl6Yz/VcJCa8YCLKaqyv0zlDMRbflHV84Yylmhs/GDfREQHnNzCp qN7jlmJBqMIR
0hsccVtwOSnOFm028nROXjONAkYPTHNZIIVrViujWzjFqJ3p1SvnEtVVdT2+ preIpQYJvaUK
a6b+X7Lly5cuXL+ty/0XNnsvL+FcS/qOX0eeRz39+9ZGieAnXOT91a6ZKwK5 qHyRp4x4+c++
IwBHzKBO7Z6ZfE58C3vnub+mV7PoChRp/jHIN2cXymnrlDZoaKeMPWMaZEGh 6dLvkepjBCq7
eH+DCcguqgUgiheKXIwXZHRC7ZLUXxc5w9qx0jt0v0m8rM8gXXLeIn+u2JOG QxqbHOhnw9Mb
YAovRdDshWmhMN/vXdw6o1ojkMNIgk8qTjh+TLuRqIB1Srrknpm9EAtH44Gs rEQowNUDRvaG
br0NyIoOO4Ly95u6E11CI2Leu9YkfUBq81nDh0bhDFm+yEN55oXpMdERVoNE Jz1POa5kUhLc
RGlH4c5DkmwhYmwbOOzgE7BUAi+EOXLgqQcfTo0lkkeDnEbKlojVS0u9LkMs VQcqewa18MLB
mEFHZGI6j1zQ2oJTCqgi8cU9cGloKAwTsQQ3zy4FhrujU6G6rXV7Y4KGbxO9 iy2G3p/Q82ey
8v4Vx7+q5fR59V29+95/3F65yfuAggjpHJmOcQccJr0zgywtT8HYcYuq5GRI 8bxr0w+XTkGS
sCvn9OICpeoHJwOhyMFptmsGVg3IAh6AQTu98D8MIB2R05s9rQx5TUOOmVQx Ok8OeZ0w9LhK
u01iVscEJIogYY1zijlUiI8ilR846mQJlaVqM4O2KVBmxA2GuuV13wAb1gXm gtwexQtAQMi0
ygE4kXL7F9ARqibFVndwjwigZhIgju98VILl9BOi8azWeD2FdDWi79cTJzSa qVs50b8YvZ+a
7VNLM74xgQBBHAnXpxMSOqDJOwEj55IlKE4kYsmA3gQEDxw584AsN5+6uta2 r8cs1AKi7bQq
7tyDbkJPUpfli6tY5PZShvpiYyFDbuaCrvGnr6TREE+C/wBDzZ7by/hXD/6r l9Hn1Xf371n/
ACE65yfuE8IUpDT88V3Ix7sxGm+R9CF4hblrFeh2aY0k3jfW4i2FVDq9OOLg PcsBs2SXuo6c
FxPJBOFAUXWut8ZzoSczsB0naHNusTBlR0ZtIRulYB3hKYIwxtWAR4LxgsXl pDaWuw6JQOLk
NmNk2CeAbV6Y0WEyVYinKSY4OvxCivYWnPbCPAQm0KCLoDXC9MNPnX+jBi9a ZLAbhKO+pg7I
68Ba3bpDR0ZqL6CKCRe6ffH8GmsWxYaWcfwXPg9juzo23WikvqZ7Q++ewPvn tD757Q++e0Pv
ntD757Q++e0PvntD757Q++e0PvntD757Q++e0PvntD757Q++e0PvntD757Q+ +e0PvntD757Q
++e0PvntD757Q++e0PvntD757Q++e0PvntD757Q++e0PvntD757Q++LqKGCM 6HsL+k30WfUd
vfvef9heucn7iIMI6By5Ee75g4ocvwzdcYl8iD2mnvxlOOSvKf7eTGGM10ko zs5VMBQtYeXz
LOuUWfqDI33nMw9wrNiBorzfhgPoEgmpWl9ZN5X3rpiXWHVOyPCYBhjUYAPM qmCxpsQm/qAc
9c63b0TE3DEEuG8qMTnbdQubQoBDQ6b5OmCUWXsEux2Pg4kXpDCWs0PL11/C Cpm2BRixMW/0
5Xb0Fz5v9FJBBAQggwgwwwwwgQgHkH9Ahhhhgo5xx5555544iTn74SUEFKLp 9XEI9s8L5553
kPOcn7j3NI4R5MCtookODbB6zxiTLRqcthPl6uXvjrcFUchQvpzHHrBFWxIk GuBmO8lABKqT
RHuYx6udPKP5AOuAiwbkxIu9IaWaM7EK6h0ICTqjnJ67zVWt2pe7zrHqaxiQ UKohy5NRwTHd
COdSvgTHLFYXC2dB8WtcYExTz1kl32mrLMesECHARnxmMXBBg0qnVhPi/wBT f/NKY6ExQ/wc
22222222222222220tlkQYIBldTn377ZGieD1zk/cFgJxGNX45Xxlucy7J8u nqugt5k6vQwj
XU71hWXSdnVQ/R33HAmwWVwWCgoj2u3EH4gonIxkPJ8ckFRqB51Cd666jjdB YketaSgFDi7M
g2DAblMIFgjjRu1odYnHoPkHGryZBLQ40tJdgWHGBvn9WIYa44TbzNZcAyiq hQQI9Xy4vKJb
JQPLyI7ibymAeUYTCVvKrvwwrw+HpiEidry+oUwChYFCIo8aImJKdCQhISt9 Xnpkznbc4VgD
qjN3rhixxtDyDZFNXpxj2Gc9Slgjomq85dfSAYGwAeUbo2ZywqYCmuoDqGjW AgZRCXWSzIvO
uO2LRJHEvSSPcgPGDKi1kcOpdGD8JiRqjQ4iHMNo6dXpSDKObB5R1XTZA6bq JkqopaESOofi
50uUwTXoiczry5eLgxd0NGScPxYZJAVcmySo2b45vOGo10gAAAEkmVVvSyOy Jsje/O4+Revg
upNlvz5w2I+dUoVeeY8h0yZ+lLayUDV1W6DWP2V0TUF9VrriYMIB+NAAo6VF Be1i4HRBNeI6
+cUxjEuwQ763fIlyUs6ACxlYQ0vV85BJSpPMNJDTrXK3nqOnYNmx63xh11bU 0Sn139fbJH6C
KCmaFu+qzX/jHbI7ZHbI7ZHbI7ZHbI7ZHbI7ZHbI7ZHbI7ZHbI7ZHbI7ZHbI 7ZHbI7ZHbI7Z
HbI7ZHbI7ZHbI7ZHbI7ZHbI7ZHbI7ZD9I6fv38866+T1zk/czQBVWAYCQbgo dK9riA0fM73P
hvW8JX9hAcT6ONiiL0Y45TqysPm6xizUgVDSgG54uEEeDBFRz626RIJTnrLr nGQbHGhilQQ9
cXCi12H2HV4wYxAJjEo+nnPQFl5bPnGOExhQ3TY/PWPFNBkdF32OljzM3jUl qNSNs2fB7YbU
KZUq7FHjouOmMC4CC/Cl7ZXvwbKm0RrZxXxnPzTu/jx0wVnMF5Z8jrEAtBfb n4ecbUNtbEp8
U3OcOJddFs7DnqoY+cOmt+RKPIuevYOjoeeUya7qstvBEuFfhK8jY/R+T2w6 xIvY7mwEdoGt
OEg+DUvVEa9lyG4au2sPSvfEXMhuw5uBWaU7hWyNPLXoOQQwFPWjbpN9euK3 xotkGbQwch1z
jB4CvPVA11UMYiKRrQWH+aUm8RBDQiGaMd66OVJ0DQAFK6I9FwSCXfhSjhAj WwNnCB8IvS5C
3JW0Kxym7txh91bSaNC65QQyIOLVVALdmiylmIwD78AQZ5KfMx5iBG4Uvqb/ AI/yOe/v3rOg
ngPOcn7iXqyHokc0UDAhxmwe28lJuFiVOzy+pgsTBFxFr1uX5YJiW4dlBJzy XeVrpGsVdJm9
YLgkCKILXVfxX0MtdQpIBEdEOgZz9BnTQpgS0EKrLkbLainDr0S0zJXB04rW KhCcOucRt0Wi
EI+RfVgdDwcIugSX4HAFGXQ2XvncARFUaRNutXXrrAFUHyj0QI76HCdsgxoG lpvwEanz3hDq
WGlHI4HFYQxW1rBBYh8XFIwDRXzbrdEG+M0dqTac8hFdvnElo1gHUiqmg45M PDDZoAGnUHAw
5H8p1gGUeOWsIhbINahwF1DBlonQwdEFk6KMXHIDioJbTNFwADqcB0gBgrV8 SaDWg5KyyvGO
ySbSBkcG7xfOOzaLptTs89mPEqIhIGkHgDa4Ii97AoBNV4ymVQmAYHHWF9Hb LLPDi5OB0nN4
9cHE0U9EdqLLweJg0WNBgAJt0NWa4zdi4RmsARadby5AlxCIA8QAkgTjbnPi 1Ca5C/T4MNhp
HWFs6WsqlzbGtwxFSBwSOp0wIAOqAIjlesdXphwt4waGgEgHpinUUc10vwE9 XEzLkAIQD4de
VfT+P+q7e/e8/wC4vXOT+4vqO/v3rP8AmJ1zk/uL6jt797z/ALC9c5P7i8Ln v796zrr5DznJ
+5nABSoaPXHMCa0LDo0nIcGXDEI3vKzghXLpO8Gj14l5g73J4w6ckE0sO3Vh 1xyYiCXDc9Wz
xcACXSA2CIrzvXIOsOyqERoG1E1wb0m8SaEQVCGHmj5OF3dVBNjbxpK4siqa gsBoeTn+0q6l
vv32yNE8HrnJ+5GJCIlEx4AbWhyJ0HTeSRiOovLE566yvGrt7xJd+ecZxVKJ 3QI4wqytHQTs
+GWyo3Y5RKzw4DyQIrQEE7Qc3urUGNUgHSPGBhiJgq6Izl4cQVILVE6Txnz+ Hc7ztkLUyC3q
6yHTJqde3X4ftWLD0BuWPbSOMRqIK08Pox+WbowlVKMT5mLQzkQHxf7Hjp+/ fzy918nrnJ+7
lSxcknImU34QKhBrmwdUFcA5Oqb0HGwJz8WOpBSFdDOF8tecILkkcW9kt+uO +kI6JH4KY9M3
g2RRqj26ZBxR5cQQUp0ANaWqgQS8lCJoWti3pMkUeQ0bAvHQvXJxlUaAAjk9 iHrjtqwWRs4R
204kW4oTjAAvHJ7uRBBgPQkIrkobXN8vRydUUqOw51wluEDLIKumqk3gpCaS Ac0NyALR3cj3
0QHsEhg1amIQwpk0RQJs+uVgOhKR6h8C+cZoxyQEM8hfjeuX5AIJAvM9eTj4 f2P5HPf371ka
J4DznJ/4oQmF0V8bwBwRsOdWc9r98J1cPY7UyP0rvWoT0MXOvwZ5Kxopo23Q 4TGAg0lDd1eo
YEdpTdGht6GPWYt0KKF4mxyPM84ouo0UDyBncDzlEsjTpSouh8ecHeHLGwsa Jqtda5sE4GbJ
aaOaSOwGueKk0DFXuOPlfRzrJqhQ6rMYUWdk32xgymNicSE8pyA49zk0DnYD 20p56ZdABaB4
N13dwJM6780xOpty8IM4MJjy4pbHERHZbktMYe6WAKa8Ewk15SAhZXe6FO8w AIBcAGVFOXkX
J/pYaVHwRX0w+s7lFgHqUY/2F9R29+95/wBxeucn/iCKxIxmK8aUoVbdud88 7yxoIUXxXb8c
N46YmlH124JsUCC8iKD1FjDAznEmJDgTRqdMPxOwAAphQ1HGL8VwC02FLXLZ 0xMlwpkTuE0s
31xMPKBIImhD/bi+IgCg8APxuWaggDUjapTrLleIbOBBNRjNPGuMOpIzhCB5 C8Tl74ACIBDH
vXa/TpMmMBBmwm3LYznjNWHAcHSIeN031uTjMCwAgYChQDg7GAxS8qgBsBhp U0a1hswJ1yHF
FiKxamBgDFEOgaHcOiHjGwvagIoUzYM4y6FBWciB4qvjj9qDyBip5VX+wvqO /v3rP+QnXOT/
ANPFcmml3tqyy4PBxp2XnOThGzCyA0LUqbIlCV5boza9cACUebe3fNbiGCAE JAd8njjAQUGz
RFkoKj894U35WBNIETujhxJMGojpKOhfVlyEBlUPiVsvqPOTd5AgyKTs7Pjc 9bHRrdaaslmd
36xZ91MJIh0yqWCCDV8zcw0G7/ZP1Hb373n/AHF65yfvZFER0VHh/dMmTJky ZMmTJkyf2VHS
57+/esvdfIec5P3PGFxVjUV/58P7brqW+/fbI0Tweucn7vPsYwaMXYVEJ1Qo 6Cj2cD6IBJBN
JdaI6Y7DCAYN6Lrg+GLuiBIKOFUAGPOL93Mot2Izo0cONbyU4gY7Qa10mAw1 EOVi0XyNOsU9
luuhUaICdab1dZWxpMSRYusVh2wYkBGJIBqsilnOPZCEEt4RdiPRg3VUd2Za DgVtFL4AHxnX
CoDAFB3ddgKdef7Ojp+/fzy918nrnJ++ZMUVAyKdWcvnJhX7pCXYihkyYrMC IlEwBVCBK+DW
TJ+jCeCgCC1D4h/Z/kc9/fvWeB4DznJ/cX1Xb373n/cXrnJ+yqyhAHIGu1nw /t52crAawyXK
tAP0zk/Yzf0hAq1ddVb/AG+XHnJ/cZcec+EOQkMUCW9f7iLjzkwAQhUpevBr j+4f/9k=
--------------080603020902070202000405--
Re: How to set the title's color of a group? [message #508404 is a reply to message #508133] Mon, 18 January 2010 06:34 Go to previous message
I see the text foreground remain black on Vista and Windows 7, but it
changes on Windows 2000 (haven't tried XP). Yes, please log a report with
swt at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT
so that this will be investigated.
Grant
"Jan Keller" <janila@web.de> wrote in message
news:hiscjd$l3d$1@build.eclipse.org...
> > the Group widget.
> jre JavaSE-1.6
Previous Topic:SWT Table with different sized rows and wrapped text
Next Topic:problem with virtual table
Current Time: Thu Jul 24 22:52:49 EDT 2025
Powered by FUDForum. Page generated in 0.18252 seconds
