Home » Archived » Buckminster » Building RCP MailApp example failing under OS X
Building RCP MailApp example failing under OS X [message #507345] Tue, 12 January 2010 22:21 Go to next message
Hi all,
I've spent most of the day trying to figure out the Buckminster RCP builds under Hudson and I keep running into difficulties. Currently, I've simplified things to just trying to get the Mail app examples working. I'm on 3.6M4 w/ latest from update site. I'm trying /org.eclipse.buckminster.tutorial.mailapp.product.feature/ma ilapp.cspex crate.product and this is what I get (looks like a dependency issue Sad):
[start org.eclipse.buckminster.tutorial.mailapp:osgi.bundle$1.0.0#e clipse.build]
[end org.eclipse.buckminster.tutorial.mailapp:osgi.bundle$1.0.0#e clipse.build]
[start org.eclipse.buckminster.tutorial.mailapp:osgi.bundle$1.0.0#s ource.bundle.jar]
[end org.eclipse.buckminster.tutorial.mailapp:osgi.bundle$1.0.0#s ource.bundle.jar]
[start org.eclipse.buckminster.tutorial.mailapp.product.feature:ecl ipse.feature$1.0.0#site.p2]
[end org.eclipse.buckminster.tutorial.mailapp.product.feature:ecl ipse.feature$1.0.0#site.p2]
[start org.eclipse.buckminster.tutorial.mailapp.product.feature:ecl ipse.feature$1.0.0#create.product]
[ant] /Developer/eclipse-buck36/plugins/org.eclipse.equinox.launch er_1.1.0.v20091116.jar
[ant] file:/var/folders/Mz/MzDJm6t-Gr0CdfpHQ42w6E+++TI/-Tmp-/buckm inster/build/org.eclipse.buckminster.tutorial.mailapp.produc t.feature_1.0.0-eclipse.feature/site.p2/
[ant] /var/folders/Mz/MzDJm6t-Gr0CdfpHQ42w6E+++TI/-Tmp-/buckminste r/build/org.eclipse.buckminster.tutorial.mailapp.product.fea ture_1.0.0-eclipse.feature/MailApp
[ant] Cannot complete the install because one or more required items could not be found.
[ant] Software being installed: Mailapp test build 1.0.0 (org.eclipse.buckminster.tutorial.mailapp.product 1.0.0)
[ant] Missing requirement: Equinox Provisioning UI Support 1.1.0.v20091028-1320 (org.eclipse.equinox.p2.ui 1.1.0.v20091028-1320) requires 'bundle org.eclipse.compare 0.0.0' but it could not be found
[ant] Cannot satisfy dependency:
[ant] From: Mailapp test build 1.0.0 (org.eclipse.buckminster.tutorial.mailapp.product 1.0.0)
[ant] To: org.eclipse.buckminster.tutorial.mailapp.product.feature.fea ture.group [1.0.0]
[ant] From: Mailapp Product Feature 1.0.0 (org.eclipse.buckminster.tutorial.mailapp.product.feature.fe ature.group 1.0.0)
[ant] To: org.eclipse.buckminster.tutorial.rcpp2.feature.feature.group [1.0.0]
[ant] From: RCP P2 Feature 1.0.0 (org.eclipse.buckminster.tutorial.rcpp2.feature.feature.grou p 1.0.0)
[ant] To: org.eclipse.equinox.p2.user.ui.feature.group [1.2.0.v20090729-7u7AFm3FbPbJP5rV7cCTt6x]
[ant] From: Equinox p2 Provisioning 1.2.0.v20090729-7u7AFm3FbPbJP5rV7cCTt6x (org.eclipse.equinox.p2.user.ui.feature.group 1.2.0.v20090729-7u7AFm3FbPbJP5rV7cCTt6x)
[ant] To: org.eclipse.equinox.p2.ui [1.1.0.v20091028-1320]
[ant] Application failed, log file location: /Developer/eclipse-buck36/configuration/1263352698641.log
org.eclipse.core.runtime.CoreException: /Volumes/Resources/Developer/workspaces/amp/org.eclipse.buck minster.tutorial.mailapp.product.feature/build/product.ant:2 2: Java returned: 13
/Volumes/Resources/Developer/workspaces/amp/org.eclipse.buck minster.tutorial.mailapp.product.feature/build/product.ant:2 2: Java returned: 13: Java returned: 13
Ideas?
cheers,
Miles
Re: Building RCP MailApp example failing under OS X [message #507346 is a reply to message #507345] Tue, 12 January 2010 22:24 Go to previous messageGo to next message
I get the same dependency issues with the regular export wizard as well.. Sad
Re: Building RCP MailApp example failing under OS X [message #507384 is a reply to message #507345] Wed, 13 January 2010 05:13 Go to previous messageGo to next message
Hi Miles,
For some reason the 'org.eclipse.equinox.p2.ui' bundle fails to find 'org.eclipse.compare'. This leads me to believe
that the 'org.eclipse.compare' is missing in your build. Some feature in the hierarchy should include it but apparently
that isn't so.
My guess would be that p2 has introduces this as a new dependency (requirement, not inclusion) in M4 and that the RCP
feature for M4 is lacking an inclusion of this bundle. I'll have to check to verify this of course (or you could, if you
have the time). Meanwhile, can you please enter a bugzilla for this so that it's not forgotten?
Thomas Hallgren
On 01/13/2010 04:22 AM, Miles Parker wrote:
> Hi all,
> crate.product and this is what I get (looks like a dependency issue :():
> clipse.build]
> clipse.build]
> ource.bundle.jar]
> ource.bundle.jar]
> could not be found.
> ture.group [1.0.0]
> 1.0.0)
> [1.0.0]
> returned: 13
> Ideas?
> cheers,
> Miles
Re: Building RCP MailApp example failing under OS X [message #507865 is a reply to message #507384] Thu, 14 January 2010 17:25 Go to previous message
Thomas Hallgren wrote on Wed, 13 January 2010 05:13
Hi Miles,
that isn't so.
No, it's there...
It looks like ..compare is there...sorry I don't have more time but I've been way too focussed on build issues and I have to get some stuff rolled out. Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=299711.
cheers,
Miles
Previous Topic:Updating a self made eclipse product (site.p2) problem
Next Topic:How to avoid re-execution of eclipse.feature#site.p2?
Current Time: Sat Oct 25 02:41:02 EDT 2025
Powered by FUDForum. Page generated in 0.05104 seconds
