Home » Eclipse Projects » Eclipse Platform » Possible to contribute an "editor factory" for specific resources?
Possible to contribute an "editor factory" for specific resources? [message #507319] Tue, 12 January 2010 17:04 Go to next message
I'm familiar with the org.eclipse.ui.editors extension point for
registering a custom editor to open with a specific file type (or
types). What I need to do is a more complex decision about the type of
editor to open based on the contents of the selected IFile. In other
words, depending on the actual file contents I need to open an
appropriate custom EditorPart (actually, custom FormEditor classes); I
have several such custom editors, each appropriate for different files
based on their contents.
I don't think I can just specify a class attribute for the
org.eclipse.ui.editors extension point, since that EditorPart seems to
be instantiated before I have a chance to get involved in the decision.
Specifying an IEditorLauncher (via the "launcher" extension point
attribute) looks somewhat promising, although the docs for it indicate
it is intended for external editors. Would there be any problems in
using an IEditorLauncher for my purposes (to open an internal editor)?
Would that be a horrible abuse of the launcher attribute?
Are there any other solutions for deciding which editor class to open
based on file contents?
Thanks in advance,
Eric
Re: Possible to contribute an "editor factory" for specific resources? [message #507524 is a reply to message #507319] Wed, 13 January 2010 13:37 Go to previous messageGo to next message
are the file extensions the same? i.e. if they're all .mdl you can use
content type to analyze the file (well, the first 100 bytes) and then
use the content types to pick editors. Content type is to distinguish
between files that have the same file extension.
If you use IEditorLauncher please be sure to conform to the API. But if
you do that, you could use this method (I've seen it used to open a view
for a resource instead of opening an editor).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Possible to contribute an "editor factory" for specific resources? [message #507545 is a reply to message #507524] Wed, 13 January 2010 14:36 Go to previous messageGo to next message
This is actually for Java source files and I need to analyze an unknown
amount of the file contents (because .java files can be so freely
formatted/composed), so I don't think content-types can help in this
case; but please correct me if that analysis is flawed in any way.
The IEditorLauncher interface is so simple that there is really no API
contract; the Javadoc does specifically talk about external editors,
though, which is why I've asked the question (to make sure there is no
implied contract somewhere in the code that uses IEditorLauncher instances).
Eric
Re: Possible to contribute an "editor factory" for specific resources? [message #507556 is a reply to message #507545] Wed, 13 January 2010 15:01 Go to previous messageGo to next message
> instances).
I don't believe so (the API is almost nothing :-). I think it's OK to
use it, although the problem might be how to pick your launcher for
..java vs the actual CompilationUnitEditor.
We use it in the SDK, see the subclasses like
org.eclipse.jdt.internal.ui.jarpackager.OpenJarExportWizardE ditorLauncher
Paul Webster
Re: Possible to contribute an "editor factory" for specific resources? [message #510555 is a reply to message #507319] Wed, 27 January 2010 14:52 Go to previous message
Just wanted to follow-up to say that specifying an IEditorLauncher (via the "launcher" extension point attribute) worked out just fine,in case someone stumbles on this thread in the future...
Previous Topic:Eclipse CVS Client - running in Windows - CVS folder conflict
Next Topic:Eclipse with Java 6
Current Time: Sat Jul 26 20:06:04 EDT 2025
Powered by FUDForum. Page generated in 0.07520 seconds
