gmf diagram file stops writing to model xml file (diagram is a RCP app and also Eclipse plugin) [message #507045] |
Mon, 11 January 2010 14:19  |
A quick summary...
For my gmf based diagram editor, I have created an RCP application and eclipse plugins.
The diagram file is separate from the backing domain model file.
My users are expected to edit the diagram file either through the RCP app or they can install eclipse plugins to work on the diagram.
Here is the weirdness.....
It works 90% of the time. i.e I can edit the diagram file in RCP app, then close the RCP app and edit the file in Eclipse with appropriate plugins.
But after 15 or 20 edits, the Eclipse plugin based editor stops writing to the backing domain model file. Every time I open the diagram file, it shows that the file is dirty and needs to be saved (since the nodes I created exist in the diagram file but not in the model file....and I assume the view is created in sync with diagram and model files).
The RCP app keeps on working as expected. Everything created through the diagram file is written to the backing model file.
Re: gmf diagram file stops writing to model xml file (diagram is a RCP app and also Eclipse plugin) [message #507305 is a reply to message #507045] |
Tue, 12 January 2010 16:30  |
so at this point I an hoping someone will find this useful.....
The problem is not between the RCP and plugin version. The problem is how the diagram file is opened.
In the RCP version, since there is no project explorer, the only way to open the file is through "File->Open" menu.
In the Eclipse plugin version, I could open the diagram file either using the "File->Open" or simply double clicking on the file through project explorer view.
If the diagram file is opened using the "File->Open" sequence, then everything works. If it is opened by double clicking the diagram file, it somehow seems to get "disconnected" from the backing model file and does not write to it.
Now I am 125% sure that this was not happening in previous versions of GMF (I just upgraded to 2.2, hence all this). I have my diagram editor running in the previous version and everything works irrespective of how the diagram file is opened.
[Updated on: Tue, 12 January 2010 17:00] by Moderator
FUDForum. Page generated in 0.09390 seconds
