Home » Eclipse Projects » Rich Client Platform (RCP) » Product export problem
Product export problem [message #506825] Sun, 10 January 2010 15:52 Go to next message
I can't export a RCP product I took back.
Here is the log I get at each time I try to export :
D:\dev\workspace-3.5-RCP-xxxxx\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\package.or g.eclipse.pde.container.feature.win32.win32.x86.xml:90: The following error occurred while executing this line:
D:\dev\workspace-3.5-RCP-xxxxx\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\package.or g.eclipse.pde.container.feature.win32.win32.x86.xml:1024: The following error occurred while executing this line:
D:\Program Files\eclipse-3.5-rcp-xxxxx\configuration\org.eclipse.osgi\b undles\314\1\bundlefile\scripts\genericTargets.xml:268: A Problem occured while running the director.
at org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:508)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:418)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:105)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor106.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
................... etc
at org.eclipse.pde.internal.core.exports.ProductExportOperation .run(ProductExportOperation.java:105)
Caused by: D:\dev\workspace-3.5-RCP-xxxxx\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\package.or g.eclipse.pde.container.feature.win32.win32.x86.xml:1024: The following error occurred while executing this line:
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
... 25 more
Caused by: D:\Program Files\eclipse-3.5-rcp-xxxxx\configuration\org.eclipse.osgi\b undles\314\1\bundlefile\scripts\genericTargets.xml:268: A Problem occured while running the director.
at org.apache.tools.ant.taskdefs.Exit.execute(Exit.java:142)
... 38 more
--- Nested Exception ---
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .runScript(FeatureExportOperation.java:422)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .doExport(FeatureExportOperation.java:286)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
... 38 more
I've tried a hundred of times to export that product without any success. I can launch the product into Eclipse anyway.
I don't know how to get more information about the problem.
How can I make to detect the source of the problem ?
Thanks in advance for your help.
Laurent
Re: Product export problem [message #507327 is a reply to message #506825] Tue, 12 January 2010 17:58 Go to previous message
I solved my pb...
If I uncheck the "Generate metadata repository" it's ok.
Well, I had already tried to uncheck that option before but the export hadn't worked anyway, certainly because of something else.
Ok, that option must not be checked, but why ?...
Previous Topic:Advice Requested: RCP versus SWT/JFace for PIM Application
Next Topic:How to specify default fonts in an RCP app
Current Time: Sun Jul 27 18:17:54 EDT 2025
Powered by FUDForum. Page generated in 0.04354 seconds
