Home » Archived » Service Component Architecture (SCA) Tools » simple example wont work with 1.5.1 - help required(The endpoint reference (EPR) for the Operation not found is)
icon9.gif  simple example wont work with 1.5.1 - help required [message #506772] Sat, 09 January 2010 10:22 Go to next message
tried afresh - coming back after a gap
downloaded tuscany 1.5.1 and stored in file system. created eclipse user lib to inlcude all the tuscany /lib jars
created a very simple hello world app and keep getting the same error
Starting ...
09-Jan-2010 19:30:52 org.apache.tuscany.sca.node.impl.NodeImpl <init>
INFO: Creating node: scaTest.composite
09-Jan-2010 19:30:52 org.apache.tuscany.sca.node.impl.NodeImpl configureNode
INFO: Loading contribution: file:/C:/Users/will/eclipseWorkspace/scaTest/bin/
09-Jan-2010 19:30:53 org.apache.tuscany.sca.node.impl.NodeImpl start
INFO: Starting node: scaTest.composite
09-Jan-2010 19:30:54 org.apache.tuscany.sca.http.jetty.JettyServer addServletMapping
INFO: Added Servlet mapping: http://MONSTER-PC:8085/HelloWorldService
wills test ready for big business !!!
- The endpoint reference (EPR) for the Operation not found is /HelloWorldService and the WSA Action = null
org.apache.axis2.AxisFault: The endpoint reference (EPR) for the Operation not found is /HelloWorldService and the WSA Action = null
at org.apache.axis2.engine.DispatchPhase.checkPostConditions(Di spatchPhase.java:89)
at org.apache.axis2.engine.Phase.invoke(Phase.java:333)
at org.apache.axis2.engine.AxisEngine.invoke(AxisEngine.java:26 4)
at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:1 63)
at org.apache.axis2.transport.http.util.RESTUtil.invokeAxisEngi ne(RESTUtil.java:136)
at org.apache.axis2.transport.http.util.RESTUtil.processURLRequ est(RESTUtil.java:130)
at org.apache.axis2.transport.http.AxisServlet$RestRequestProce ssor.processURLRequest(AxisServlet.java:829)
at org.apache.axis2.transport.http.AxisServlet.doGet(AxisServle t.java:255)
at org.apache.tuscany.sca.binding.ws.axis2.Axis2ServiceServlet. doGet(Axis2ServiceServlet.java:321)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:487)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:362)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:726)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:139)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComple te(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:395)
at org.apache.tuscany.sca.core.work.Work.run(Work.java:63)
at org.apache.tuscany.sca.core.work.ThreadPoolWorkManager$Decor atingWork.run(ThreadPoolWorkManager.java:215)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
basically i have a client that launches the embedded tuscany web service
import org.apache.tuscany.sca.host.embedded.SCADomain;
public class Launch
* @param args
public static void main(String[] args) throws Exception
System.out.println("Starting ...");
SCADomain scaDomain = SCADomain.newInstance("scaTest.composite");
System.out.println("wills test ready for big business !!!");
System.in.read();
System.out.println("Stopping ...");
scaDomain.close();
System.out.println();
I then have a simple interface class
import org.osoa.sca.annotations.Service;
@Service (HelloWorldService.class)
public class HelloWorldImpl implements HelloWorldService
public HelloWorldImpl ()
public String sayHello ()
return "hello William";
and a simple componnt that implements
import org.osoa.sca.annotations.Remotable;
@Remotable
public interface HelloWorldService
String sayHello ();
lastly my composite file (tried various varitions on this and essentially net out to same error ) - tried service at top level and child withiun the component, one trying the sca:interface declarition, etc
current config looks like this
<sca:composite xmlns:sca="http://www.osoa.org/xmlns/sca/1.0" name="scaTest" targetNamespace="http://eclipse.org/scaTest/src/scaTest">
<sca:component name="HelloWorld">
<sca:implementation.java class="scaTest.HelloWorldImpl"/>
<sca:service name="HelloWorldService" promote="HelloWorld/HelloWorldService">
<sca:binding.ws uri="http://localhost:8085/HelloWorldService"/>
</sca:service>
</sca:component>
</sca:composite>
so why cant axis find my service - there appears to be no dispatching of the web service.
What did i do wrong ?
Re: simple example wont work with 1.5.1 - help required [message #506811 is a reply to message #506772] Sun, 10 January 2010 09:58 Go to previous messageGo to next message
okay - think i've managed to sort myself (mostly ) out.
the web service was generated - and pointing my browser at it didnt do any good as it wasnt a soap message generated.
downloaded soapUI and point at the wsdl and i got the service work.
in passing is their an equivelent to @Local as opposed to @Remotable. That is if you want to build a reference to a local component - i got more errors until i added the @remotable to the referenced interface.
or do all sca interfaces have to be marked @remotable?
Re: simple example wont work with 1.5.1 - help required [message #506955 is a reply to message #506772] Mon, 11 January 2010 09:06 Go to previous messageGo to next message
Hi William,
My answers below.
> Quote:
>> Starting ...
>> configureNode
>> addServletMapping
>> t.java:255)
>> .java:487)
>> er.java:362)
>> er.java:181)
>> er.java:726)
>> er.java:139)
>> n.java:505)
>> dPoint.java:395)
>> wn Source)
> Quote:
>> public class Launch {
>> * @param args
>> public static void main(String[] args) throws Exception {
>> System.in.read();
>> scaDomain.close();
Seems OK.
> Quote:
> Quote:
>> @Remotable
>> public interface HelloWorldService {
>> String sayHello ();
Both seem correct.
> Quote:
>> <?xml version="1.0" encoding="UTF-8"?>
>> </sca:service>
>> </sca:component>
>> </sca:composite>
It seems, and I cannot believe it, that the SCA builder does not show an
error with such a composite.
You set the promote on a component service.
The right way to promote a service, is to declare it in the component,
declare another in the composite and make it promote the first one.
Here is one exemple of your composite with a correct promotion:
> <sca:service name="visibleService" promote="HelloWorld/HelloWorldService" />
> <sca:implementation.java class="scaTest.HelloWorldImpl" />
> <sca:service name="HelloWorldService">
> <sca:binding.ws uri="http://localhost:8085/HelloWorldService" />
> </sca:service>
> </sca:component>
> </sca:composite>
Once it is promoted, the service can be exposed correctly.
Vincent.
Re: simple example wont work with 1.5.1 - help required [message #506956 is a reply to message #506811] Mon, 11 January 2010 09:07 Go to previous message
Hi William,
To check if a web service is correctly deployed with a Web browser, go
to the WSDL address. Generally <ws url>?wsdl
No.
Just those that can be invoked remotly.
Vincent.
Re: simple example wont work with 1.5.1 - help required [message #576804 is a reply to message #506772] Sun, 10 January 2010 09:58 Go to previous message
Re: simple example wont work with 1.5.1 - help required [message #576819 is a reply to message #506772] Mon, 11 January 2010 09:06 Go to previous message
Hi William,
My answers below.
> Quote:
>> Starting ...
>> configureNode
>> addServletMapping
>> t.java:255)
>> .java:487)
>> er.java:362)
>> er.java:181)
>> er.java:726)
>> er.java:139)
>> n.java:505)
>> dPoint.java:395)
>> wn Source)
> Quote:
>> * @param args
>> System.in.read();
>> scaDomain.close();
Seems OK.
> Quote:
> Quote:
>> @Remotable
>> String sayHello ();
Both seem correct.
> Quote:
>> </sca:service>
>> </sca:component>
>> </sca:composite>
> </sca:service>
> </sca:component>
> </sca:composite>
Vincent.
Re: simple example wont work with 1.5.1 - help required [message #576832 is a reply to message #576804] Mon, 11 January 2010 09:07 Go to previous message
Hi William,
No.
Vincent.
Previous Topic:simple example wont work with 1.5.1 - help required
Next Topic:ecore model (ws-policy)-> is it in SCA prj ?
Current Time: Sat Jul 19 10:33:23 EDT 2025
Powered by FUDForum. Page generated in 0.04483 seconds
