Home » Modeling » Epsilon » Problem calling Native java code
Problem calling Native java code [message #506768] Sat, 09 January 2010 14:39 Go to next message
I'm trying to implement a plug-in for epsilon.
In the making, I needed to call a java source code (which was using two JAR files that were added to its build path), using the Native method in epsilon.
For that I followed the next guide: http:// www.eclipse.org/gmt/epsilon/doc/articles/call-java-from-epsi lon/
When I call the Native for the packages, the next error occours:
Internal error: java.lang.NoClassDefFoundError: org/springframework/beans/factory/BeanNameAware
	at java.lang.ClassLoader.defineClass1[Native Method]
	at java.lang.ClassLoader.defineClass[Unknown Source]
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass[DefaultClassLoader.java:183]
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass[ClasspathManager.java:576]
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl[ClasspathManager.java:546]
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl[ClasspathManager.java:477]
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader[ClasspathManager.java:465]
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass[ClasspathManager.java:445]
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass[DefaultClassLoader.java:211]
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass[BundleLoader.java:381]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal[BundleLoader.java:457]
I tried adding the packages that are located in those two JAR files to the exported packages list in the Runtime tab, but it didn't help.
How can I call a java code that uses external JARS, using epsilon's Native method?
Thanks!
Re: Problem calling Native java code [message #506789 is a reply to message #506768] Sun, 10 January 2010 01:38 Go to previous messageGo to next message
Can you please post the entire stack trace?
Re: Problem calling Native java code [message #506790 is a reply to message #506789] Sat, 09 January 2010 21:33 Go to previous messageGo to next message
You've asked for it
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass[BundleLoader.java:410]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass[BundleLoader.java:398]
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass[DefaultClassLoader.java:105]
	at java.lang.ClassLoader.loadClass[Unknown Source]
	at java.lang.ClassLoader.loadClassInternal[Unknown Source]
	at gensets.GensetImplementerFrontend.DisjoinImpl[GensetImplementerFrontend.java:68]
	at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
	at sun.reflect.NativeMethodAccessorImpl.invoke[Unknown Source]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke[Unknown Source]
	at java.lang.reflect.Method.invoke[Unknown Source]
	at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[ReflectionUtil.java:213]
	at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[ReflectionUtil.java:189]
	at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation[PointExecutor.java:173]
	at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointExecutor.java:67]
	at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointExecutor.java:37]
	at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointExecutor.java:123]
	at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[ExecutorFactory.java:185]
	at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execute[StatementBlockExecutor.java:33]
	at org.eclipse.epsilon.ewl.EwlWizard.process[EwlWizard.java:78]
	at org.eclipse.epsilon.ewl.EwlWizardInstance.process[EwlWizardInstance.java:66]
	at org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.execute[ExecuteWizardInstanceCommand.java:42]
	at org.eclipse.emf.workspace.EMFCommandOperation.doExecute[EMFCommandOperation.java:119]
	at org.eclipse.emf.workspace.AbstractEMFOperation.execute[AbstractEMFOperation.java:150]
	at org.eclipse.core.commands.operations.DefaultOperationHistory.execute[DefaultOperationHistory.java:511]
	at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute[WorkspaceCommandStackImpl.java:208]
	at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute[AbstractTransactionalCommandStack.java:165]
	at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute[AbstractTransactionalCommandStack.java:219]
	at org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction.execute[AbstractContributeWizardsAction.java:237]
	at org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$1.widgetSelected[AbstractContributeWizardsAction.java:225]
	at org.eclipse.swt.widgets.TypedListener.handleEvent[TypedListener.java:228]
	at org.eclipse.swt.widgets.EventTable.sendEvent[EventTable.java:84]
	at org.eclipse.swt.widgets.Widget.sendEvent[Widget.java:1003]
	at org.eclipse.swt.widgets.Widget.sendEvent[Widget.java:1027]
	at org.eclipse.swt.widgets.Widget.sendEvent[Widget.java:1012]
	at org.eclipse.swt.widgets.Widget.notifyListeners[Widget.java:770]
	at org.eclipse.jface.action.ActionContributionItem$9.handleEvent[ActionContributionItem.java:1284]
	at org.eclipse.swt.widgets.Display.runDeferredEvents[Display.java:3880]
	at org.eclipse.swt.widgets.Display.readAndDispatch[Display.java:3473]
	at org.eclipse.ui.internal.Workbench.runEventLoop[Workbench.java:2405]
	at org.eclipse.ui.internal.Workbench.runUI[Workbench.java:2369]
	at org.eclipse.ui.internal.Workbench.access$4[Workbench.java:2221]
	at org.eclipse.ui.internal.Workbench$5.run[Workbench.java:500]
	at org.eclipse.core.databinding.observable.Realm.runWithDefault[Realm.java:332]
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench[Workbench.java:493]
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench[PlatformUI.java:149]
	at org.eclipse.ui.internal.ide.application.IDEApplication.start[IDEApplication.java:113]
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run[EclipseAppHandle.java:194]
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication[EclipseAppLauncher.java:110]
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start[EclipseAppLauncher.java:79]
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run[EclipseStarter.java:368]
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run[EclipseStarter.java:179]
	at org.eclipse.equinox.launcher.Main.invokeFramework[Main.java:559]
	at org.eclipse.equinox.launcher.Main.basicRun[Main.java:514]
	at org.eclipse.equinox.launcher.Main.run[Main.java:1311]
	at org.eclipse.equinox.launcher.Main.main[Main.java:1287]
Caused by: java.lang.ClassNotFoundException: org.springframework.beans.factory.BeanNameAware
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal[BundleLoader.java:494]
	... 89 more
 (34:19)
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:183)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:576)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:546)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:477)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:465)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:445)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:211)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:381)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:457)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
	at java.lang.ClassLoader.loadClassInternal(Unknown Source)
	at gensets.GensetImplementerFrontend.DisjoinImpl(GensetImplementerFrontend.java:68)
	at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(ReflectionUtil.java:213)
	at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(ReflectionUtil.java:189)
	at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation(PointExecutor.java:173)
	at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointExecutor.java:67)
	at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointExecutor.java:37)
	at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointExecutor.java:123)
	at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(ExecutorFactory.java:185)
	at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execute(StatementBlockExecutor.java:33)
	at org.eclipse.epsilon.ewl.EwlWizard.process(EwlWizard.java:78)
	at org.eclipse.epsilon.ewl.EwlWizardInstance.process(EwlWizardInstance.java:66)
	at org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.execute(ExecuteWizardInstanceCommand.java:42)
	at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
	at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
	at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:511)
	at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
	at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
	at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
	at org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction.execute(AbstractContributeWizardsAction.java:237)
	at org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$1.widgetSelected(AbstractContributeWizardsAction.java:225)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770)
	at org.eclipse.jface.action.ActionContributionItem$9.handleEvent(ActionContributionItem.java:1284)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: Problem calling Native java code [message #506794 is a reply to message #506790] Sun, 10 January 2010 04:58 Go to previous messageGo to next message
Can you instantiate this class from the Java code of your plugin? If
not, you may want to turn your jars into plugins (as per
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tools/project_wizards/plugin_from_archive s.htm)
and then add them as dependencies to your existing plugin.
Dimitris
On 10/01/2010 02:33, Barak wrote:
> You've asked for it
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass[DefaultClassLoader.java:183]
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass[ClasspathManager.java:576]
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl[ClasspathManager.java:546]
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl[ClasspathManager.java:477]
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader[ClasspathManager.java:465]
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass[ClasspathManager.java:445]
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass[DefaultClassLoader.java:211]
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass [BundleLoader.java:381]
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal[BundleLoader.java:457]
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass[Bund leLoader.java:410]
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass[Bund leLoader.java:398]
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass[DefaultClassLoader.java:105]
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> gensets.GensetImplementerFrontend.DisjoinImpl[GensetImplemen terFrontend.java:68]
> at
> org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:213]
> at
> org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:189]
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on[PointExecutor.java:173]
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:67]
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:37]
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:123]
> at
> org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[E xecutorFactory.java:185]
> at
> org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te[StatementBlockExecutor.java:33]
> at
> at
> org.eclipse.epsilon.ewl.EwlWizardInstance.process[EwlWizardI nstance.java:66]
> at
> org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.exe cute[ExecuteWizardInstanceCommand.java:42]
> at
> org.eclipse.emf.workspace.EMFCommandOperation.doExecute[EMFC ommandOperation.java:119]
> at
> org.eclipse.emf.workspace.AbstractEMFOperation.execute[Abstr actEMFOperation.java:150]
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .execute[DefaultOperationHistory.java:511]
> at
> org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doE xecute[WorkspaceCommandStackImpl.java:208]
> at
> org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute[AbstractTransactionalCommandStack.java:165]
> at
> org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute[AbstractTransactionalCommandStack.java:219]
> at
> org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction. execute[AbstractContributeWizardsAction.java:237]
> at
> org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$ 1.widgetSelected[AbstractContributeWizardsAction.java:225]
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent[TypedListe ner.java:228]
> at org.eclipse.swt.widgets.EventTable.sendEvent[EventTable.java :84]
> at org.eclipse.swt.widgets.Widget.notifyListeners[Widget.java:7 70]
> at
> org.eclipse.jface.action.ActionContributionItem$9.handleEven t[ActionContributionItem.java:1284]
> at org.eclipse.swt.widgets.Display.runDeferredEvents[Display.ja va:3880]
> at org.eclipse.swt.widgets.Display.readAndDispatch[Display.java :3473]
> at org.eclipse.ui.internal.Workbench.runEventLoop[Workbench.jav a:2405]
> at org.eclipse.ui.internal.Workbench.access$4[Workbench.java:22 21]
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault [Realm.java:332]
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench[Work bench.java:493]
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench[PlatformUI.j ava:149]
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start [IDEApplication.java:113]
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run[Eclips eAppHandle.java:194]
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication[EclipseAppLauncher.java:110]
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start[EclipseAppLauncher.java:79]
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run[EclipseS tarter.java:368]
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run[EclipseS tarter.java:179]
> at org.eclipse.equinox.launcher.Main.invokeFramework[Main.java: 559]
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal[BundleLoader.java:494]
> at
> at
> at
> ... 89 more
> (34:19)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> gensets.GensetImplementerFrontend.DisjoinImpl(GensetImplemen terFrontend.java:68)
> at
> org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:213)
> at
> org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:189)
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:173)
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:67)
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:37)
> at
> org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:123)
> at
> org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:185)
> at
> org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
> at
> at
> org.eclipse.epsilon.ewl.EwlWizardInstance.process(EwlWizardI nstance.java:66)
> at
> org.eclipse.epsilon.ewl.emf.ExecuteWizardInstanceCommand.exe cute(ExecuteWizardInstanceCommand.java:42)
> at
> org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFC ommandOperation.java:119)
> at
> org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:150)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
> at
> org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doE xecute(WorkspaceCommandStackImpl.java:208)
> at
> org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:165)
> at
> org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:219)
> at
> org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction. execute(AbstractContributeWizardsAction.java:237)
> at
> org.eclipse.epsilon.ewl.emf.AbstractContributeWizardsAction$ 1.widgetSelected(AbstractContributeWizardsAction.java:225)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
> at
> org.eclipse.jface.action.ActionContributionItem$9.handleEven t(ActionContributionItem.java:1284)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Re: Problem calling Native java code [message #507140 is a reply to message #506794] Mon, 11 January 2010 23:55 Go to previous messageGo to next message
Thanks!
I'll try it.
Re: Problem calling Native java code [message #584649 is a reply to message #506794] Mon, 11 January 2010 23:55 Go to previous message
Thanks!
I'll try it.
Previous Topic:Namespace reference
Next Topic:Incorrect access to model in ubuntu
Current Time: Fri Jul 25 20:41:41 EDT 2025
Powered by FUDForum. Page generated in 0.04384 seconds
