Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] "Copy current change from right to left" doesn't work?
[EMF Compare] "Copy current change from right to left" doesn't work? [message #506112] Wed, 06 January 2010 04:22 Go to next message
I am a new user for EMF compare. I just do a simple test.
Base model is one class.
Then User1 add one attribute: Property1:EInt.
Then I use EMF compare each other, at this time, base model is on left side, and User1 is on right side.
When I click "Copy current change from right to left" button to merge from right to left, it doesn't add same attribute on left model. On left model, just one attribute named as Property1, but has no EInt type!
Is this normal behavior?
B.T.W, if I want to extend "Copy current change from right to left" button action, how to develop? I means what extension point should i extend?
Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #506162 is a reply to message #506112] Wed, 06 January 2010 07:16 Go to previous messageGo to next message
--------------010703020606040502070807
Nope, this is no expected behavior; though we've never experienced this
ourselves and I cannot reproduce your behavior with sample models with
the steps outlined here.
This seems to be fixed with the latest vesion of EMF Compare. Which are
you using?
Extending the merge actions is not possiblve apart from providing your
own mergers. This is done through the extension point
org.eclipse.emf.compare.diff.mergerprovider .
Laurent Goubet
Obeo
esong0317@163.com wrote:
> extend?
> Thanks!
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010703020606040502070807--
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #506413 is a reply to message #506162] Thu, 07 January 2010 08:16 Go to previous messageGo to next message
First thanks for your quick reply.
But actually I meet this merge problem. It is a simple ECore model.
Left is empty class, right is a class with "Property1:EInt", when merge from right to left, left only get Property1 name, no Eint.
I just select two ecore files, and then compare with each other, then that problem happen. I dont know whether my operation is corrent or not.
If possible, I can upload a screenshot. I use eclipse-modeling-galileo-SR1-incubation-win32 package. It seems that EMF compare version is V1.0.1.
Thanks!
[Updated on: Thu, 07 January 2010 08:17] by Moderator
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #506461 is a reply to message #506413] Thu, 07 January 2010 10:39 Go to previous messageGo to next message
--------------070507040604010607070404
The samples I used to try and reproduce are exactly what you describe :
an empty EClass on the left, the same EClass with the addition of an
attribute "property1 : EInt" on the right, then merging from right to left.
This operations yields the expected result of an EClass with "property1
: EInt" on the left after merging. Thus the question I asked : which
version of EMF Compare in which Eclipse are you using?
Laurent Goubet
Obeo
> Hi
> Thanks!
--------------070507040604010607070404--
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #506598 is a reply to message #506461] Fri, 08 January 2010 04:38 Go to previous messageGo to next message
Yes, this is a really strange problem.
Today I download "org.eclipse.emf.compare.examples.standalone" example from CVS repository. and then compile and create a runnable JAR file which name is EMFStandalone.jar.
Now left model is My.ecore as
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="my"
nsURI="http://my/1.0" nsPrefix="my">
<eClassifiers xsi:type="ecore:EClass" name="EClass0"/>
</ecore:EPackage>
Right model is My1.ecore as
<eClassifiers xsi:type="ecore:EClass" name="EClass0">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="EAttribute0" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
</eClassifiers>
</ecore:EPackage>
Then I run command as:
[brucehuang@rat013:/sandbox/bruce/EMF]$ ls
EMFStandalone.jar My1.ecore My.ecore
[brucehuang@rat013:/sandbox/bruce/EMF]$ java -jar EMFStandalone.jar My1.ecore My.ecore
Loading resources.
Matching models.
Differencing models.
Merging difference to args[1].
MatchModel :
<match:MatchModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:match="http://www.eclipse.org/emf/compare/match/1.1">
<matchedElements xsi:type="match:Match2Elements" similarity="1.0">
<subMatchElements xsi:type="match:Match2Elements" similarity="0.8823529411764705">
<leftElement href="My1.ecore#//EClass0"/>
<rightElement href="My.ecore#//EClass0"/>
</subMatchElements>
<leftElement href="My1.ecore#/"/>
<rightElement href="My.ecore#/"/>
</matchedElements>
<unmatchedElements>
<element href="My1.ecore#//EClass0/EAttribute0"/>
</unmatchedElements>
<leftRoots href="My1.ecore#/"/>
<rightRoots href="My.ecore#/"/>
</match:MatchModel>
DiffModel :
<diff:DiffModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.1">
</diff:DiffModel>
saving emfdiff as "result.emfdiff"
Then I see My.ecore again, it has no change as before. I don't change any on "org.eclipse.emf.compare.examples.standalone" source code.
So why? Is there some wrong with source code?
And also I use the above two model to merge using graphics method, it fails as I describe before. Sorry to disturb you.
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #506809 is a reply to message #506598] Sun, 10 January 2010 09:09 Go to previous messageGo to next message
I am using EMF Compare 1.1.0 v200912150654, and then it seems that "copy current change from right to left" button works, but when it fails to save. And one nullPointer exception is caught. I report one bug 299214.
And before I use EMF compare 1.0.1 v200909161031.
Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #506979 is a reply to message #506598] Mon, 11 January 2010 10:40 Go to previous messageGo to next message
--------------030106070207050700030803
Hi Bruce,
IIRC, the standalone example does not save any model after merging
operations took place. You have to save the merged model yourself.
Laurent Goubet
Obeo
Bruce wrote:
> </ecore:EPackage>
> </eClassifiers>
> </ecore:EPackage>
> [mailto:brucehuang@rat013:/sandbox/bruce/EMF]$ ls
> [mailto:brucehuang@rat013:/sandbox/bruce/EMF]$ java -jar
> EMFStandalone.jar My1.ecore My.ecore Loading resources.
> Matching models.
> MatchModel :
> </subMatchElements>
> </matchedElements>
> <unmatchedElements>
> </match:MatchModel>
> DiffModel :
> </diff:DiffModel>
--------------030106070207050700030803--
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #507000 is a reply to message #506809] Mon, 11 January 2010 06:32 Go to previous messageGo to next message
--------------090406080905020603030907
Hi Bruce,
This had been previously identified and the fix is already commited.
This failure will disappear from the next build onward.
Laurent Goubet
Obeo
Bruce wrote:
> Thanks!
--------------090406080905020603030907--
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #507721 is a reply to message #507000] Thu, 14 January 2010 08:27 Go to previous messageGo to next message
Hi Laurent ,
Thanks for your great help.
B.T.W, it seems that EMF Compare 1.0.0 has "Draft Graphical Modelers Integration " feature from http://wiki.eclipse.org/EMF_Compare_1.0.0_New_And_Noteworthy #Draft_Graphical_Modelers_Integration.
But when I compare two *.ecorediag file each other, no Graphical Compare window appear, so what is wrong with it? Is this feature unavailable currently?
And also if I use Topcased Plugins to create two UML models, and two responding *.umldia file, is it possible to compare two *.umldia file in Graphical Window way?
Thanks very much!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #507745 is a reply to message #507721] Thu, 14 January 2010 04:26 Go to previous messageGo to next message
Hi Bruce,
the graphical modelers integration feature is not provided as built plugins
and is only available through CVS right now.
Once built and installed it should work with any GMF based diagram model, as
such it should work with EcoreDiag (like in the demo) but not with Topcased
ones as topcased is not based on GMF.
Cédric
Bruce wrote:
> Hi Laurent ,
> currently?
> Thanks very much!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621967 is a reply to message #506162] Thu, 07 January 2010 08:16 Go to previous messageGo to next message
Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621968 is a reply to message #621967] Thu, 07 January 2010 10:39 Go to previous messageGo to next message
Laurent Goubet
Obeo
> Hi
> Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621974 is a reply to message #506461] Fri, 08 January 2010 04:38 Go to previous messageGo to next message
</ecore:EPackage>
</eClassifiers>
</ecore:EPackage>
[mailto:brucehuang@rat013:/sandbox/bruce/EMF]$ java -jar EMFStandalone.jar My1.ecore My.ecore
Loading resources.
Matching models.
MatchModel :
</subMatchElements>
</matchedElements>
<unmatchedElements>
</match:MatchModel>
DiffModel :
</diff:DiffModel>
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621977 is a reply to message #621974] Sun, 10 January 2010 09:09 Go to previous messageGo to next message
Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621984 is a reply to message #621974] Mon, 11 January 2010 10:40 Go to previous messageGo to next message
Hi Bruce,
Laurent Goubet
Obeo
Bruce wrote:
> </ecore:EPackage>
> </eClassifiers>
> </ecore:EPackage>
> Matching models.
> MatchModel :
> </subMatchElements>
> </matchedElements>
> <unmatchedElements>
> </match:MatchModel>
> DiffModel :
> </diff:DiffModel>
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621986 is a reply to message #621977] Mon, 11 January 2010 11:18 Go to previous messageGo to next message
Hi Bruce,
Laurent Goubet
Obeo
Bruce wrote:
> Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621998 is a reply to message #621986] Thu, 14 January 2010 08:27 Go to previous messageGo to next message
Hi Laurent ,
Thanks very much!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #622000 is a reply to message #507721] Thu, 14 January 2010 09:25 Go to previous message
Hi Bruce,
Cédric
Bruce wrote:
> Hi Laurent ,
> currently?
> Thanks very much!
Previous Topic:[MWE] MWE project evolution?
Next Topic:[EMF Compare] array as eattribute value
Current Time: Sat Oct 25 02:58:58 EDT 2025
Powered by FUDForum. Page generated in 0.10419 seconds
