IWAB0014E Unexpected exception occurred. [message #506458] |
Thu, 07 January 2010 10:24  |
Hi All
I created a dynamic webproject, and then tryed to create a webservices client, i am getting the following error
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.Stub2Be anCommand.execute(Stub2BeanCommand.java:121)
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientC odeGenOperation$ClientWSModifyOperation.execute(ClientCodeGe nOperation.java:110)
at org.eclipse.jst.ws.internal.axis.consumption.ui.task.ClientC odeGenOperation.execute(ClientCodeGenOperation.java:61)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:154)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:136)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:813)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
could you please tell me what this error is and how to fix this error
Anbu
[Updated on: Thu, 07 January 2010 10:36] by Moderator
FUDForum. Page generated in 0.04730 seconds
