Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Ecore diagram with cross-document references
Ecore diagram with cross-document references [message #506525] Thu, 07 January 2010 15:55 Go to next message
I've manually constructed a pair of EMF projects in which one ecore model refers to a class in the other. Both models validate OK in the ecore editor. If I attempt to initialize an ecore_diagram file from the ecore file containing the cross-document reference, EcoreDiagramContentInitializer thows an NPE:
at org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramContentI nitializer.createEClass_1001Children(EcoreDiagramContentInit ializer.java:91)
at org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramContentI nitializer.createNode(EcoreDiagramContentInitializer.java:30 1)
at org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramContentI nitializer.createEPackage_79Children(EcoreDiagramContentInit ializer.java:289)
at org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramContentI nitializer.initDiagramContent(EcoreDiagramContentInitializer .java:83)
at org.eclipse.emf.ecoretools.diagram.edit.commands.InitializeA ndLayoutDiagramCommand.doExecuteWithResult(InitializeAndLayo utDiagramCommand.java:60)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
... 41 more
The resulting diagram is empty.
Should this work? Or is it too bleeding edge?
Paul Allen
Re: Ecore diagram with cross-document references [message #506533 is a reply to message #506525] Thu, 07 January 2010 16:14 Go to previous message
Paul,
It ought to work. Please open a bugzilla with an attachment containing
the projects needed to reproduce this problem. Please add me to the CC
list and I'll see if I can figure out what's going wrong.
> ializer.java:91)
> ializer.java:289)
> ... 41 more
> Paul Allen
Previous Topic:teneo, databinding, model and a treeview
Next Topic:Ecore diagram with cross-document references
Current Time: Fri Jul 25 21:53:11 EDT 2025
Powered by FUDForum. Page generated in 0.03881 seconds
