Hi all,
I'm new for using EclipseLink as JPA implementation as I'd like to use JPA 2.0 with latest Spring 3.
I've encountered a weird exception during unit-testing which I cannot figure out why it happens. Please help!!
------- User.java-----------------
@Entity
@Table(name="users")
public class User {
@Id
@Column(name="username")
private String username;
@Column(name="password")
private String password;
@OneToMany(fetch=FetchType.LAZY, mappedBy="fromUser")
@OrderColumn(name="mail_id desc")
private List<UserMail> sentMails;
@OneToMany(fetch=FetchType.LAZY, mappedBy="toUser")
private List<UserMail> receivedMails;
public int hashCode() {
final int prime = 31;
int result = 1;
result = prime * result + ((username == null) ? 0 : username.hashCode());
return result;
public boolean equals(Object obj) {
if (this == obj)
return true;
if (obj == null)
return false;
if (!(obj instanceof User))
return false;
User other = (User) obj;
if (username == null) {
if (other.username != null)
return false;
} else if (!username.equals(other.username))
return false;
return true;
//generated getters and setters
public String getUsername() {
return username;
public void setUsername(String username) {
this.username = username;
public String getPassword() {
return password;
public void setPassword(String password) {
this.password = password;
public List<UserMail> getSentMails() {
return sentMails;
public void setSentMails(List<UserMail> sentMails) {
this.sentMails = sentMails;
public List<UserMail> getReceivedMails() {
return receivedMails;
public void setReceivedMails(List<UserMail> receivedMails) {
this.receivedMails = receivedMails;
-------- Mail.java----------------------------------------
@Entity
@Table(name="mails")
public class Mail {
@Id
@Column(name="mail_id")
private long id;
@Column(name="title")
private String title;
@Column(name="content")
private String content;
@OneToMany(fetch=FetchType.LAZY, mappedBy="mail")
@OrderColumn(name="to_username asc")
private List<UserMail> shipments;
public long getId() {
return id;
public void setId(long id) {
this.id = id;
public String getTitle() {
return title;
public void setTitle(String title) {
this.title = title;
public String getContent() {
return content;
public void setContent(String content) {
this.content = content;
public List<UserMail> getShipments() {
return shipments;
public void setShipments(List<UserMail> shipments) {
this.shipments = shipments;
--------UserMail.java-----------------------------
@Entity
@IdClass(UserMail.Pk.class)
@Table(name="user_mails")
public class UserMail {
public static class Pk implements Serializable {
private static final long serialVersionUID = 7883097744987560068L;
private long mail;
private String fromUser;
private String toUser;
int result = 1;
result = prime * result + ((fromUser == null) ? 0 : fromUser.hashCode());
result = prime * result + (int) (mail ^ (mail >>> 32));
result = prime * result + ((toUser == null) ? 0 : toUser.hashCode());
return result;
if (this == obj)
return true;
if (obj == null)
return false;
if (!(obj instanceof Pk))
return false;
Pk other = (Pk) obj;
if (fromUser == null) {
if (other.fromUser != null)
return false;
} else if (!fromUser.equals(other.fromUser))
return false;
if (mail != other.mail)
return false;
if (toUser == null) {
if (other.toUser != null)
return false;
} else if (!toUser.equals(other.toUser))
return false;
return true;
public long getMail() {
return mail;
public void setMail(long mail) {
this.mail = mail;
public String getFromUser() {
return fromUser;
public void setFromUser(String fromUser) {
this.fromUser = fromUser;
public String getToUser() {
return toUser;
public void setToUser(String toUser) {
this.toUser = toUser;
@Id
@ManyToOne
@JoinColumn(name="mail_id", referencedColumnName="mail_id")
private Mail mail;
@Id
@ManyToOne
@JoinColumn(name="from_username", referencedColumnName="username")
private User fromUser;
@Id
@ManyToOne
@JoinColumn(name="to_username", referencedColumnName="username")
private User toUser;
@Column(name="status")
private int status;
public Mail getMail() {
return mail;
public void setMail(Mail mail) {
this.mail = mail;
public User getFromUser() {
return fromUser;
public void setFromUser(User fromUser) {
public User getToUser() {
return toUser;
public void setToUser(User toUser) {
public int getStatus() {
return status;
public void setStatus(int status) {
this.status = status;
The exception encountered shows as follows:
Exception [EclipseLink-148] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The container policy [IndirectListContainerPolicy(class org.eclipse.persistence.indirection.IndirectList)] is not compatible with transparent indirection.
Mapping: org.eclipse.persistence.mappings.OneToManyMapping[sentMails]
Descriptor: RelationalDescriptor(User --> [DatabaseTable(users)])
Mapping: org.eclipse.persistence.mappings.OneToManyMapping[receivedMails]
Local Exception Stack:
at org.eclipse.persistence.exceptions.DescriptorException.invalidContainerPolicyWithTransparentIndirection(DescriptorException.java:772)
at org.eclipse.persistence.internal.indirection.TransparentIndirectionPolicy.validateContainerPolicy(TransparentIndirectionPolicy.java:521)
at org.eclipse.persistence.mappings.CollectionMapping.validateBeforeInitialization(CollectionMapping.java:2184)
at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5260)
at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3323)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:671)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:633)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:230)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:368)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:151)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:207)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:195)
at org.springframework.orm.jpa.JpaTransactionManager.createEntityManagerForTransaction(JpaTransactionManager.java:400)
at org.springframework.orm.jpa.JpaTransactionManager.doBegin(JpaTransactionManager.java:321)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:371)
at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:336)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:102)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy12.authenticate(Unknown Source)
at test.UserServiceTest.testAuthenticate(UserServiceTest.java:26)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.springframework.test.context.junit4.statements.RunBeforeTestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.java:74)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
at org.springframework.test.context.junit4.statements.RunAfterTestMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java:82)
at org.springframework.test.context.junit4.statements.SpringRepeat.evaluate(SpringRepeat.java:72)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:240)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java:173)
at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:61)
at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70)
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:180)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:46)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
[Updated on: Mon, 28 December 2009 23:55] by Moderator
