XsdEcoreBuilder producing an illegal Java package name [message #506257] |
Wed, 06 January 2010 12:22  |
Given a schema with the following namespace URI:
http://www.new.HelloWorld.com/int/2010-01-06/12345
XsdEcoreBuilder (EMF 2.4.2) produces an EPackage with name:
com.world.hello.new.int._2010._01._06._12345
It's done a pretty good job of cleansing the name, but has crucially failed to eliminate the inclusion of Java reserved words 'new' and 'int' therefore making the resulting Java package name illegal.
If I import the same XSD via the UI, using the 'New EMF Project' wizard, it additionally suffixes each reserved word with an underscore, thus producing a legal name:
com.world.hello.new_.int_._2010._01._06._12345
Is there a reason for the inconsistency? This sound like a bug in XsdEcoreBuilder to me (or the NameMangler class that it calls). I've not yet located the source that's responsible for the mapping when invoked via the UI.
Ben.
Re: XsdEcoreBuilder producing an illegal Java package name [message #506267 is a reply to message #506257] |
Wed, 06 January 2010 12:49  |
--------------090904050904070200060004
Ben,
The package name produced by the XSDEcoreBuilder isn't even a valid
EPackage name. ModelImporter deals with that like this:
protected void adjustEPackage(Monitor monitor, EPackage ePackage)
EPackageImportInfo ePackageInfo = getEPackageImportInfo(ePackage);
String name = ePackage.getName();
if (name == null)
name = "null";
int index = name.lastIndexOf(".");
if (index != -1)
String basePackage = ePackageInfo.getBasePackage();
String namePackage = name.substring(0, index);
name = name.substring(index + 1);
if (basePackage != null && !namePackage.startsWith(basePackage))
namePackage = basePackage + "." + namePackage;
StringBuffer basePackageName = new StringBuffer();
for (StringTokenizer stringTokenizer = new
StringTokenizer(namePackage, "."); stringTokenizer.hasMoreTokens(); )
String packageName = stringTokenizer.nextToken();
basePackageName.append(CodeGenUtil.safeName(packageName));
if (stringTokenizer.hasMoreTokens())
basePackageName.append('.');
ePackageInfo.setBasePackage(basePackageName.toString());
ePackage.setName(name);
So it's important that the raw converters convey the fully qualified
package name via the EPackage's name, even though that form is invalid
according to Ecore's constraints. The importer then uses utilities like
CodeGenUtil.safeName(packageName) to make sure that there are no
collisions with Java keywords.
So it's working as designed, because builders don't have access to
CodGenUtil. You could of course specialize the validName method to
mangle keywords...
> invoked via the UI.
> Cheers,
> Ben.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Ben,<br>
<br>
EPackage name. ModelImporter deals with that like this:<small><br>
</small>
<blockquote><small> protected void adjustEPackage(Monitor monitor,
EPackage ePackage)</small><br>
<small> {</small><br>
<small> EPackageImportInfo ePackageInfo =
getEPackageImportInfo(ePackage);</small><br>
<br>
<small> String name = ePackage.getName();</small><br>
<small> if (name == null)</small><br>
<small> name = "null";</small><br>
<small> }</small><br>
<small> int index = name.lastIndexOf(".");</small><br>
<small> if (index != -1)</small><br>
<small> String basePackage = ePackageInfo.getBasePackage();</small><br>
<small> String namePackage = name.substring(0, index);</small><br>
<small> name = name.substring(index + 1);</small><br>
<small> </small><br>
<small> if (basePackage != null &&
!namePackage.startsWith(basePackage))</small><br>
<small> namePackage = basePackage + "." + namePackage;</small><br>
<br>
<small> StringBuffer basePackageName = new StringBuffer();</small><br>
<small> for (StringTokenizer stringTokenizer = new
StringTokenizer(namePackage, "."); stringTokenizer.hasMoreTokens(); )</small><br>
<small> String packageName = stringTokenizer.nextToken();</small><br>
<small>
basePackageName.append(CodeGenUtil.safeName(packageName));</small ><br>
<small> if (stringTokenizer.hasMoreTokens())</small><br>
<small> basePackageName.append('.');</small><br>
<br>
<small> ePackageInfo.setBasePackage(basePackageName.toString());</small ><br>
<small> ePackage.setName(name);</small><br>
</blockquote>
like CodeGenUtil.safeName(packageName) to make sure that there are no
collisions with Java keywords.<br>
<br>
mangle keywords...<br>
<br>
<br>
Ben Tenne wrote:
<blockquote cite="mid:hi2gta$kpj$1@build.eclipse.org" type="cite">Given
<br>
<br>
<a class="moz-txt-link-freetext" href="http://www.new.HelloWorld.com/int/2010-01-06/12345">http://www.new.HelloWorld.com/int/2010-01-06/12345</a>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
invoked via the UI.
<br>
<br>
<br>
Ben.
<br>
</blockquote>
</body>
</html>
--------------090904050904070200060004--
FUDForum. Page generated in 0.03244 seconds
