Home » Language IDEs » ServerTools (WTP) » Catalog URI not getting expanded in exported app
Catalog URI not getting expanded in exported app [message #506207] Wed, 06 January 2010 04:34 Go to next message
Hi all,
I've got an workbench-based application within which I specify a catalog entry for xsd schema validation.
The uri attribute is
platform:/plugin/org.xxx.legacy/schemas/yyy.xsd
When I run this application from within Eclipse, and open the Catalog in the running app, I see that the URI has been expanded, and contains an absolute path reference to the current location of that schema.
However, when I export the app, and then run the app, it can't find the schema, because the URI hasn't been expanded.
Am I doing something wrong?
Ian
Re: Catalog URI not getting expanded in exported app [message #506268 is a reply to message #506207] Wed, 06 January 2010 12:52 Go to previous messageGo to next message
Ian,
How is the entry contributed to the XML Catalog? note that you may need to use the XML Catalog extension point to make the contribution programmatically within your application.
Gabriel.
Re: Catalog URI not getting expanded in exported app [message #506360 is a reply to message #506268] Wed, 06 January 2010 23:46 Go to previous messageGo to next message
Morning Gabriel,
thanks for coming back to me. The entry is contributed to the XML catalog by including it in one of the plugin.xml files (as shown below). As I suggested yesterday, I know the entry is being registered by the application since it appears in the catalog of the running app - it's just that the platform:/ uri isn't being expanded. Thanks in advance for any tips you can offer...
<extension name="create a catalog entry for the schema"
point="org.eclipse.wst.xml.core.catalogContributions">
<catalogContribution>
<public id="http://www.xxx.org/yyy" publicId="http://www.xxx.org/yyy"
uri="platform:/plugin/org.xxx.legacy/schemas/yyy.xsd">
</public>
</catalogContribution>
</extension>
Re: Catalog URI not getting expanded in exported app [message #506547 is a reply to message #506360] Thu, 07 January 2010 12:34 Go to previous messageGo to next message
Ian,
Try making the XML Catalog contribution from the same plug-in that contains the XSD document. With this configuration, you should be able to specify the location to the schema using a path relative to the plug-in root. The extension point would look as follows:
<extension name="create a catalog entry for the schema" point="org.eclipse.wst.xml.core.catalogContributions">
<public id="http://www.xxx.org/yyy" publicId="http://www.xxx.org/yyy" uri="schemas/yyy.xsd" />
</extension>
Gabriel.
Re: Catalog URI not getting expanded in exported app [message #506667 is a reply to message #506547] Fri, 08 January 2010 05:47 Go to previous messageGo to next message
Great,
I'll give that a go.
Ian
Re: Catalog URI not getting expanded in exported app [message #506689 is a reply to message #506547] Fri, 08 January 2010 14:09 Go to previous message
Hi there Gabriel,
your solution worked perfectly, thanks.
Ian Mayo
Previous Topic:Incomplete EAR creation/deloyment
Next Topic:Can I use WTP to deploy a RAP app as a war?
Current Time: Fri Jul 18 12:57:55 EDT 2025
Powered by FUDForum. Page generated in 0.04134 seconds
