Home » Modeling » EMF » [EMF databinding] Problems with EMFMapProperty
[EMF databinding] Problems with EMFMapProperty [message #505971] Tue, 05 January 2010 11:48 Go to next message
Originally posted by: Thomas.Kowatsch.ruag.com
Hi all.
I have a problem with a ClassCastException when
EMFMapProperty#doGetMap(Object source) is called.
I tried to track down the problem a bit and found the following:
The doGetMap call in EMFMapProperty is doing the following:
EObject eObj = (EObject)source;
return (Map< ? , ? >)eObj.eGet(eStructuralFeature);
Tracking down the eGet for the related EObject, I found that the
eGet(eStructuralFeature) in the related EOBject calls
eGet(eStructuralFeature, true) and this calls eGet(eStructuralFeature,
true, true). So the coreType parameter for eGet(int featureID, boolean
resolve, boolean coreType) is always true.
The related EObject's eGet(int featureID, boolean resolve, boolean
coreType) method does:
case WhitepagePackage.BLABLA :
if (coreType)
return ((EMap.InternalMapView<PropertyKey, String>)
getUserProperties()).eMap();
else
return getUserProperties();
So the eGet will always return an EMap, which cannot be casted to a
java.util.Map, as it is an EList internally.
In my understanding the doGetMap() should call then the eGet with
coreType to false, to return a java.util.Map.
I know I could create my own IObservableMap without using a EMFProperty
to avoid the problem. I just wanted to know if I'm doing something wrong
or if the problem is related to a bug.
Cheers.
--Thomas
Re: [EMF databinding] Problems with EMFMapProperty [message #505976 is a reply to message #505971] Tue, 05 January 2010 12:04 Go to previous messageGo to next message
I don't have time to wrap my head around it right now - could you file a
bugzilla, ideally with a test case so that I can reproduce the problem
and I take a look tomorrow or on the weekend.
Tom
Am 05.01.10 17:48, schrieb Thomas Kowatsch:
> Hi all.
> if (coreType)
> else
> Cheers.
> --Thomas
Re: [EMF databinding] Problems with EMFMapProperty [message #505981 is a reply to message #505971] Tue, 05 January 2010 12:27 Go to previous messageGo to next message
--------------070802030404090501060309
Thomas,
I think it should be like this:
protected Map< ? , ? > doGetMap(Object source)
return ((EMap< ? , ? >)eObj.eGet(eStructuralFeature)).map();
Thomas Kowatsch wrote:
> Hi all.
> if (coreType)
> else
> EMFProperty to avoid the problem. I just wanted to know if I'm doing
> something wrong or if the problem is related to a bug.
> Cheers.
> --Thomas
<html>
<head>
http-equiv="Content-Type">
</head>
Thomas,<br>
<br>
I think it should be like this:<br>
<blockquote>
Re: [EMF databinding] Problems with EMFMapProperty [message #506001 is a reply to message #505976] Tue, 05 January 2010 13:01 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298886
I have no idea how to create a test case. I check with a colleague
tomorrow and might add one to the bug.
--Thomas
> Tom
>> Hi all.
>> if (coreType)
>> else
>> Cheers.
>> --Thomas
Re: [EMF databinding] Problems with EMFMapProperty [message #506002 is a reply to message #505981] Tue, 05 January 2010 13:03 Go to previous message
Even better then my fix Ed. :-)
You are the expert ...
Ed Merks schrieb:
> Thomas,
>> Hi all.
>> if (coreType)
>> else
>> Cheers.
>> --Thomas
Previous Topic:EMF compare and merge
Next Topic:[teneo] drag and drop in resources
Current Time: Sat Jul 26 08:55:32 EDT 2025
Powered by FUDForum. Page generated in 0.04884 seconds
