Home » Modeling » EMF » Strange behavior when class with name EPackage is used
Strange behavior when class with name EPackage is used [message #505950] Tue, 05 January 2010 10:50 Go to next message
--------------060107010800050304020203
Hi.
My first strange EMF behavior since ages... ;-)
I am using the EMF version of Galileo 3.5.1.
If you generate from the attached .ecore a normal EMF Editor,
then you can create an XProject containing an XComponent, containing an
XRootPackage.
Then you creat an XSubPackage, and it is NOT shown in the editor, but
exists in the resource:
<xocl:XProject xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xocl="http://www.langlets.org/xocl">
<component>
<rootPackage>
<subPackage/>
</rootPackage>
</component>
</xocl:XProject>
The problem goes away when the package ElocalCore with the classes
ENamedElement and EPackage is removed....
All the best for 2010!
Philipp
Content-Type: text/xml;
name="Xocl.ecore"
Content-Disposition: inline;
filename="Xocl.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="xocl"
nsURI="http://www.langlets.org/xocl" nsPrefix="xocl">
<eAnnotations source="http://www.xocl.org/OCL">
<details key="rootConstraint" value="trg.name='XProject'"/>
</eAnnotations>
<eClassifiers xsi:type="ecore:EClass" name="XNamedElement" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="businessName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="camelCaseLower" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
changeable="false" volatile="true" transient="true" derived="true">
<details key="derive" value="'cclTODO_'.concat(businessName)"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="camelCaseUpper" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
<details key="derive" value="'CCUtodo_'.concat(businessName)"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="XProject" eSuperTypes="#//XNamedElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="implementRootPackage" eType="#//XRootPackage"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="component" upperBound="-1"
eType="#//XComponent" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="knownPackage" upperBound="-1"
eType="#//XPackage"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="XComponent" eSuperTypes="#//XNamedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="domainType" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="domainMiddleName" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EReference" name="rootPackage" upperBound="-1"
eType="#//XRootPackage" containment="true" eOpposite="#//XRootPackage/containingComponent"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="derivedBundleName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
changeable="false" volatile="true" transient="true" derived="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="XPackage" abstract="true" eSuperTypes="#//XNamedElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="subPackage" upperBound="-1"
eType="#//XSubPackage" containment="true" eOpposite="#//XSubPackage/containingPackage"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="derivedPackageName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="derivedNsURI" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="derivedNsPrefix" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="XRootPackage" eSuperTypes="#//XPackage">
<eStructuralFeatures xsi:type="ecore:EReference" name="derivedContainedEPackage"
lowerBound="1" eType="#//ElocalCore/EPackage" changeable="false" volatile="true"
transient="true" derived="true" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="containingComponent" lowerBound="1"
eType="#//XComponent" eOpposite="#//XComponent/rootPackage"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="XSubPackage" eSuperTypes="#//XPackage">
<eStructuralFeatures xsi:type="ecore:EReference" name="derivedEcorePackage" lowerBound="1"
eType="#//ElocalCore/EPackage" changeable="false" volatile="true" transient="true"
derived="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="containingPackage" lowerBound="1"
eType="#//XPackage" eOpposite="#//XPackage/subPackage"/>
</eClassifiers>
<eSubpackages name="ElocalCore" nsURI="http://www.langlets.org/ecore" nsPrefix="ecorelocal">
<eClassifiers xsi:type="ecore:EClass" name="EPackage" eSuperTypes="#//ElocalCore/ENamedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="nsURI" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="nsPrefix" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="eSubpackages" upperBound="-1"
eType="#//ElocalCore/EPackage" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ENamedElement">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
--------------060107010800050304020203--
Re: Strange behavior when class with name EPackage is used [message #506056 is a reply to message #505950] Tue, 05 January 2010 12:20 Go to previous messageGo to next message
--------------050209080409020002000804
Philipp,
How did you implement methods like this in XRootPackageImpl?
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public EPackage getDerivedContainedEPackage() {
// TODO: implement this method to return the 'Derived
Contained EPackage' containment reference
// Ensure that you remove @generated or mark it @generated NOT
throw new UnsupportedOperationException();
Philipp Kutter wrote:
> Hi.
> an XRootPackage.
> <component>
> <rootPackage>
> <subPackage/>
> </rootPackage>
> </component>
> </xocl:XProject>
> Philipp
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Philipp,<br>
<br>
How did you implement methods like this in XRootPackageImpl?<br>
<blockquote>&nbsp;&nbsp;&nbsp; /**<br>
&nbsp;&nbsp;&nbsp; &nbsp;* &lt;!-- begin-user-doc --&gt;<br>
&nbsp;&nbsp;&nbsp; &nbsp;* &lt;!-- end-user-doc --&gt;<br>
&nbsp;&nbsp;&nbsp; &nbsp;* @generated<br>
&nbsp;&nbsp;&nbsp; &nbsp;*/<br>
&nbsp;&nbsp;&nbsp; public EPackage getDerivedContainedEPackage() {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; // TODO: implement this method to return the 'Derived Contained
EPackage' containment reference<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; // Ensure that you remove @generated or mark it @generated NOT<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; throw new UnsupportedOperationException();<br>
&nbsp;&nbsp;&nbsp; }<br>
</blockquote>
<br>
<br>
<blockquote cite="mid:hhvn66$qam$1@build.eclipse.org" type="cite">Hi.
<br>
<br>
<br>
<br>
<br>
<br>
XRootPackage.
<br>
<br>
<br>
<br>
&lt;?xml version="1.0" encoding="UTF-8"?&gt;
<br>
&lt;xocl:XProject xmi:version="2.0" xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xocl=<a class="moz-txt-link-rfc2396E" href="http://www.langlets.org/xocl">"http://www.langlets.org/xocl"</a>&gt;
<br>
&nbsp; &lt;component&gt;
<br>
&nbsp;&nbsp;&nbsp; &lt;rootPackage&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;subPackage/&gt;
<br>
&nbsp;&nbsp;&nbsp; &lt;/rootPackage&gt;
<br>
&nbsp; &lt;/component&gt;
<br>
&lt;/xocl:XProject&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Philipp
<br>
</blockquote>
</body>
</html>
--------------050209080409020002000804--
Re: Strange behavior when class with name EPackage is used [message #506815 is a reply to message #506056] Sun, 10 January 2010 10:18 Go to previous message
Ed.
As below. And of course the error went away, once I implemented it...
Regards, Philipp
* @OCL let res:Tuple(name:String)=Tuple{name='EdAnswer'} in res
* @templateTag GGFT01
EClass eClass = (XoclPackage.Literals.XROOT_PACKAGE);
EStructuralFeature eFeature =
XoclPackage.Literals.XROOT_PACKAGE__DERIVED_CONTAINED_EPACKA GE;
if (derivedContainedEPackageDeriveOCL == null) {
Helper helper = OCL_ENV.createOCLHelper();
helper.setAttributeContext(eClass, eFeature);
String derive = XoclEmfUtil.findDeriveAnnotationText(eFeature,
eClass());
try {
derivedContainedEPackageDeriveOCL = helper.createQuery(derive);
} catch (ParserException e) {
return null;
} finally {
XoclErrorHandler.handleQueryProblems(XoclPackage.PLUGIN_ID,
derive, helper.getProblems(), eClass, eFeature);
Query query = OCL_ENV.createQuery(derivedContainedEPackageDeriveOCL);
try {
XoclErrorHandler.enterContext(XoclPackage.PLUGIN_ID, query);
XoclEvaluator xoclEval = new XoclEvaluator(this, cachedValues);
EPackage result = (EPackage) xoclEval.evaluateElement(eFeature,
query);
if (result instanceof BasicEObjectImpl) {
((BasicEObjectImpl) result)
.eBasicSetContainer(
this,
InternalEObject.EOPPOSITE_FEATURE_BASE
- XoclPackage.XROOT_PACKAGE__DERIVED_CONTAINED_EPACKAGE,
null);
return result;
} catch (Throwable e) {
XoclErrorHandler.handleException(e);
return null;
} finally {
XoclErrorHandler.leaveContext();
Ed Merks wrote:
> Philipp,
> * @generated
>> Hi.
>> an XRootPackage.
>> <?xml version="1.0" encoding="UTF-8"?>
>> <component>
>> <rootPackage>
>> <subPackage/>
>> </rootPackage>
>> </component>
>> </xocl:XProject>
>> Philipp
Previous Topic:Resource URIs for FeatureMaps
Next Topic:Re: Cross Document References persistence with Translator
Current Time: Wed Jul 23 20:21:50 EDT 2025
Powered by FUDForum. Page generated in 0.28820 seconds
