Home » Eclipse Projects » GEF » CompoundDirectedGraph layout problem
CompoundDirectedGraph layout problem [message #505893] Tue, 05 January 2010 09:17 Go to next message
In org.eclipse.gef.examples.flow example there is a class GraphLayoutManager,
Using the same principle of adding nodes and sub graps i have created a flow chart solution,
everything is fine ,but for certain types of diagram the layout fails...
http://lh3.ggpht.com/_3SpBG8kdCvs/S0NHXrPdVlI/AAAAAAAADE0/DKRSmRcQmk0/s800/untitled.GIF
http://lh3.ggpht.com/_3SpBG8kdCvs/S0NHXuVJdgI/AAAAAAAADE4/UDLRizk_ylY/s800/untitled1.GIF
as in the image shown above the subgrapf does not resize according to children...
am i doing somthing wrong or is it an issue...
[Updated on: Wed, 13 January 2010 06:29] by Moderator
Re: CompoundDirectedGraph layout problem [message #506335 is a reply to message #505893] Wed, 06 January 2010 23:29 Go to previous messageGo to next message
Apart from this...
-Are there any other graph layout liberaries appart from zest?
-Are there any routers available appart from the SPR,FR,MR
routers available?
Thanks in advance.
Re: CompoundDirectedGraph layout problem [message #507400 is a reply to message #506335] Wed, 13 January 2010 06:30 Go to previous messageGo to next message
Help Needed Pls....
Re: CompoundDirectedGraph layout problem [message #510294 is a reply to message #507400] Wed, 27 January 2010 02:19 Go to previous messageGo to next message
I have logged a bug against the same...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=300025
Pls help....
Re: CompoundDirectedGraph layout problem [message #510908 is a reply to message #510294] Fri, 29 January 2010 01:35 Go to previous messageGo to next message
The same issue can be reproduced in org.eclipse.gef.examples.flow example..
http://lh4.ggpht.com/_3SpBG8kdCvs/S2J_dNQ9yUI/AAAAAAAADGk/BLpj5dhupCU/s800/flowError.GIF
The .flow file has been attached in the bug..
https://bugs.eclipse.org/bugs/attachment.cgi?id=156483
You can open this file using the flow example editor and see the bug.
Re: CompoundDirectedGraph layout problem [message #513217 is a reply to message #510908] Tue, 09 February 2010 07:02 Go to previous messageGo to next message
More then 4000 views and not one comment!!! Rolling Eyes
Re: CompoundDirectedGraph layout problem [message #629099 is a reply to message #513217] Mon, 27 September 2010 04:23 Go to previous message
No Progress on this issue..https://bugs.eclipse.org/bugs/show_bug.cgi?id=300025
can anybody suggest somthing for this issue...
Previous Topic:unnecessary command creations during DND
Next Topic:IOOBE while dragging bendpoint
Current Time: Fri Jul 25 06:19:56 EDT 2025
Powered by FUDForum. Page generated in 0.05392 seconds
