update 1.3M4 and UITests Error [message #505816] |
Mon, 04 January 2010 23:16  |
I updated yesterday my framework up to the version 1.3M4 from dec 18.
I got than following error:
"Could not evaluate javascript response:
TypeError: widget is undefined
var req= org .eclipse.swt. request ............."
I found out, that when I set the Ui test attributte "Dorg.eclipse.rwt.enableUITests=true" then the error is fire, when the attribute is false, it work perfect.
I test it with RAP 1.3M3, thart works without errors, as well UI Test is true or false. Only by 1.3M4 come to this error.
do you have any idee?
Thanks a lot.
Maziar
Re: update 1.3M4 and UITests Error [message #505851 is a reply to message #505816] |
Tue, 05 January 2010 06:10  |
Hi Maziar,
I can reproduce the javascript error with the Workbench demo and
-Dorg.eclipse.rwt.enableUITests set to true. Please file a bugzilla to
keep track on this issue.
Best,
Ivan
On 1/5/2010 6:16 AM, Maziar Khodaei wrote:
> Hi
> Thanks a lot.
> Maziar
FUDForum. Page generated in 0.04251 seconds
