Home » Eclipse Projects » EclipseLink » Workbench and Object-relational nested table mappings(Workbench 2.x support for nested tables)
Workbench and Object-relational nested table mappings [message #505089] Sat, 26 December 2009 08:16 Go to next message
I used TopLink many years ago but am new to EclipseLink. I would like to use EclipseLink against a database that uses Oracle Objects and Nested Tables.
Reading the wiki site and using Workbench suggests that
1. Workbench itself does not support Nested tables.
(When I import a table, it replaces the nested data types with VARCHAR2(16)).
http://wiki.eclipse.org/Introduction_to_Object-Relational_Da ta_Type_Mappings_%28ELUG%29#Object-Relational_Data_Type_Nest ed_Table_Mapping
2. There are a number of bugs in the core EclipseLink implementation in respect of nested tables.
It is a goal of 2.x to support Oracle Objects / Nested Tables, or does the community see these as little used edge cases, and hence a low priority?
Just want to get a steer in terms of whether this is something that will get better support in time, and if so when.
Andrew
Re: Workbench and Object-relational nested table mappings [message #505748 is a reply to message #505089] Mon, 04 January 2010 13:40 Go to previous message
Nested tables is a fringe feature, but if you find issues with it, they will be addressed the same as any other bug.
There is little new development being done on nested tables and object-types.
The Mapping Workbench will not have nested table support, and is not undergoing active development in general. Our focus is JPA, and UI focus is integration through IDE's JPA support, such as Eclipse Dali.
Previous Topic:JPA 2.0 BUG
Next Topic:JPA 2.0 and MySQL 5.1 ERROR
Current Time: Sun Jul 27 03:55:08 EDT 2025
Powered by FUDForum. Page generated in 0.03731 seconds
