Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Layout Problems
Layout Problems [message #505300] Tue, 29 December 2009 07:31 Go to next message
I have problems with getting the size and the location of layout widget for example a Canvas. The layout which I'm using is GridLayout and I need the height and the width of the canvas but I can't get them.
The result of calling the method getSize is 0 - width , 0- height.
My question is how can I get the size of a canvas when I'm using layouts?
Re: Layout Problems [message #505650 is a reply to message #505300] Sun, 03 January 2010 21:06 Go to previous messageGo to next message
I found a way to get the size of Canvas positioned with layout. In a paint listener I can get the bounds of the widget. But I don't like this method because I can't use the size parameters before the widget is painted.
How can I get the size of a Canvas without a paint listener?
Re: Layout Problems [message #505717 is a reply to message #505650] Mon, 04 January 2010 11:25 Go to previous message
A Control's size is 0,0 until it has been set, either by you (eg.- with
Control.setSize(...)), or by a layout. Once it has been set then
Control.getSize() should always work. Are you asking it for its size before
it has been laid out? If so, maybe
Control.computeSize(SWT.DEFAULT,SWT.DEFAULT) is what you want (in which case
the default answer for Canvas is 64x64)?
Grant
"Jordan Borisov" <xstream9014@gmail.com> wrote in message
news:hhs3vu$5n0$1@build.eclipse.org...
painted.
Previous Topic:[Linux/GTK Q] How are the arrow keys, pgup/pgdn, & bksp read differently than other keys?
Next Topic:Reparenting shell problem
Current Time: Tue Jul 22 03:43:25 EDT 2025
Powered by FUDForum. Page generated in 0.09069 seconds
