Home » Modeling » GMF (Graphical Modeling Framework) » Integrate own Gef in GMF
Integrate own Gef in GMF [message #504692] Mon, 21 December 2009 22:48 Go to next message
I extended the gef framework for my own behaviors and now i have the problem to integrate it in gmf. How can i set the required references of gmf to my gef? Is it possible to do this so easy as i thougth?
I downloaded the sources of gef and generate a my.gef plugin. It seems to be working.
I downloaded the gmf sources too, because i need to update the dependancies. Instead of org.eclipse.gef i am using my.gef.
Is there something where i can get the sources for the GMF Project. I downloaded it from the CVS but i can´t compile it. I want to switch the org.eclipse.gef dependancies with my.my.gef.
Now a important question. What are the steps to generate the gmf plugins. I only need to update my.gef on org.eclipse.gmf.ui.diagrams (+.properties), org.eclipse.[something].gef. Do i need to generate the whole GMF Source Project as a new Plugin or just the 3 Projects?
Thomas
[Updated on: Wed, 23 December 2009 03:43] by Moderator
Re: Integrate own Gef in GMF [message #505658 is a reply to message #504692] Mon, 04 January 2010 04:12 Go to previous messageGo to next message
Is Feature Patch a solution for this? Fragments do not work for this, but Fragments are not "definded" to replace Plugins.
The only "do not make a heavy change of gmf and gef solution" is a feature patch.
But is this true, its just a self study????
Re: Integrate own Gef in GMF [message #505684 is a reply to message #505658] Mon, 04 January 2010 09:00 Go to previous messageGo to next message
Thomas,
Your problem description is very vague, including the one you cross
posted to the newcomers newsgroup. Fragments are not intended for
injecting your extensions into a base framework. If you extend GEF then
you'll need to extend the GMF classes where your want your classes to be
used instead of the basic GEF ones.
> feature patch.
> Thanks
Re: Integrate own Gef in GMF [message #505744 is a reply to message #505684] Mon, 04 January 2010 13:22 Go to previous messageGo to next message
I know, but have you ever seen the overhead changing every gmf class which depends on gef? It should be exist a better solution. I tried it but, puh....after 1 minute i stopped because of nonsense!
Yes this is because of i don´t have the time right now.
Re: Integrate own Gef in GMF [message #505755 is a reply to message #505744] Mon, 04 January 2010 13:56 Go to previous messageGo to next message
Thomas,
It remains unclear what specific problem you're trying to solve. I
don't imagine you've changed every GEF class nor that you will have to
change every GMF class that depends on GEF. It's unlikely you'll get
help unless you're more specific.
Re: Integrate own Gef in GMF [message #505848 is a reply to message #505755] Tue, 05 January 2010 05:51 Go to previous message
Ok, i solved it with a friend. We imported the plugins as source code build a new version (Plugin and feature) changed the depandancies of GEF and GMF in the plugin.xml. It worked.
Doesn´t though eclipse is that good to handle it that easy....
Sorry that i was annoying.
Thomas
Previous Topic:markerNavigationProviders extension point problem...
Next Topic:Connection moves diagram on click
Current Time: Fri Jul 25 23:33:26 EDT 2025
Powered by FUDForum. Page generated in 0.03725 seconds
