Persistence of Multiplicity-Many Reference [message #505613] |
Sun, 03 January 2010 10:09  |
I am generating the Ecore mode from an XSD schema.
If I define my XSD schema as follows:
<xsd:complexType name="MyClass">
<xsd:sequence>
<xsd:element name="dependencies" minOccurs="0" >
<xsd:complexType>
<xsd:sequence>
<xsd:element name="dependency" type="test:Dependency" minOccurs="0" maxOccurs="unbounded" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
This creates an unnnecessary hierarchy in my ecore:
MyClass
dependencies: DependenciesType
DependeniesType
dependency: Dependency
However, this leads to the desired persistence format:
<myClass>
<dependencies>
<dependency name="a"/>
<dependency name="b"/>
</dependencies>
</myClass>
Now, I want to remove the unnecessary hierarchy and still mentain the same persistence as above. I managed to remove the hierarchy by modifying the XSD schema as:
<xsd:sequence>
<xsd:element name="dependencies" type="test:Dependency" minOccurs="0" maxOccurs="unbounded"/>
</xsd:sequence>
</xsd:complexType>
However, the persistence also changes to an undesired one:
<myClass>
</myClass>
I wanted to know if it is possible to remove the unneceesary hieracrchy in the ecore (as in the latter case) and still maintain the persistence in the former case above.
Thanks a lot in advance,
Nidhi
Re: Persistence of Multiplicity-Many Reference [message #505615 is a reply to message #505613] |
Sun, 03 January 2010 11:28   |
Hi Ed,
Thanks a lot for a quick reply.
I went through the bug, but have have couple of questions/confusions:
"If there is a single repeating element, I think it should be possible to avoid
the extra class creation:"
I quiet didn't get this point, how would it be possible to avoid the extra class?
"In XMLHandler (or descendant), I keep a list of "deferredReferences" and a
list<Integer> of deferredLevels in order to process the "extra" wrapper
elements without creating unexistant features. "objects" and "types" must be
handled so that everything looks OK. It is more complex than in XMLSaveImpl,
but only impacts handleFeature and endElement."
Could you please elaborate, I am sorry but I am not very fluent in EMF :( , might
need some more elaboration to get this right.
Also, I tried using ecore:ignore="true" for my anonymous complex type:
<xsd:complexType ecore:ignore="true">
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
However, the ecore generated does still creates an extra class. Am I missing something here.
Best Regards,
Nidhi
Re: Persistence of Multiplicity-Many Reference [message #505621 is a reply to message #505615] |
Sun, 03 January 2010 09:02   |
Nidhi,
Comments below.
Nidhi wrote:
> Hi Ed,
> to avoid
> extra class?
That' exactly your comment: "this creates an unnecessary hierarchy in my
ecore." The intermediate instance object serves only to carry a list
feature and it's the class for that object we want to avoid...
> and a
> must be
> XMLSaveImpl,
> :( , might need some more elaboration to get this right.
If I had more time it would all be committed and I'd not have to explain.
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
You can ignore creating an element, but one you create the element, it's
type must be created.
The best I can do is point you at the bugzilla. It's really quite a
complex problem to solve and it would be eve more complex to try to
explain how to solve it to a relative novice. Sorry.
> Best Regards,
> Nidhi
Re: Persistence of Multiplicity-Many Reference [message #505625 is a reply to message #505622] |
Sun, 03 January 2010 14:34  |
Nidhi,
I don't think the map can cope with omitting intermediate levels of
objects. I don't know much about WTP translators, so I can't comment on
that.
Nidhi wrote:
> Nevermind Ed :),
> I did get a hang of the solution being discussed in the reported bug
> after having a closer look at it.
> I'll look for forward to the resolution, however, as of now am I
> correct to say that there can be 2 alternatives:
> 1. Use OPTION_XML_MAP to customize my serialization..
> OR
> 2. Use WTP Translators..
> Do you feel that either of them would be a good workaround?
> Best Regards,
> Nidhi
FUDForum. Page generated in 0.04729 seconds
