Home » Modeling » Epsilon » Composing Epsilon tools?(e.g how to compose ETL+EVL into one tool)
Composing Epsilon tools? [message #505563] Fri, 01 January 2010 12:54 Go to next message
Is there any way to programmatically execute an E_L module on a model?
The motivation is to compose several Epsilon tools into one tool. For example: create an EVL tool that first transforms the model into another model (using ETL) and then validates the result.
Is it possible to do this in any of the E_L languages?
Is it possible in a more "low level" way, via Java?
Does it require a new EOL sub-language?
Thanks !
Re: Composing Epsilon tools? [message #505564 is a reply to message #505563] Fri, 01 January 2010 13:00 Go to previous messageGo to next message
You can use either the ANT tasks
(http://eclipse.org/gmt/epsilon/doc/workflow) or plain Java (see
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.examples.standalone)
to do this.
Dimitris
> Thanks !
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Composing Epsilon tools? [message #505582 is a reply to message #505564] Sat, 02 January 2010 05:54 Go to previous messageGo to next message
Hi Dimitrios,
Thanks for the prompt response.
I looked at the example and it seems to fit what I need. However, I was thinking maybe of another approach for this:
Is it possible in Epsilon (and if not - is it worthy in your opinion?) to exploit the "Model!Type" syntax for composition?
For example, is it possible to write something along the following to implicitly invoke an ETL module?
-- in some EVL module, for example
context ETL("UML2Graph") ! Node {
The semantics is that instead of applying the constraint on instances of types in the model (e.g UML14!Class), it would be applied on instances of Graph!Node which are obtained by a transformation defined in the ETL module "UML2Graph".
Does such thing exist?
If not, do you think its worth to implement such a "hack"? How would I go about this? (suppose I create some class that implements IModel and executes the ETL module -- where would I "stitch" that into Epsilon's execution engine?)
[Updated on: Sat, 02 January 2010 07:40] by Moderator
Re: Composing Epsilon tools? [message #505592 is a reply to message #505582] Sat, 02 January 2010 10:55 Go to previous messageGo to next message
Hi Itamar,
There is nothing like this at the moment in Epsilon (and I must admit I
haven't come across anything similar elsewhere). What would be the
benefit of this approach vs. the workflow?
Dimitris
Itamar wrote:
> Hi Dimitrios,
> context ETL("UML2Graph",UML14!Class) ! Node {
> UML14!Class, it would be applied on instances of Graph!Node which are
> execution engine?)
Re: Composing Epsilon tools? [message #506104 is a reply to message #505592] Wed, 06 January 2010 03:02 Go to previous messageGo to next message
I have to admit I haven't thoroughly investigated the workflow alternative, and I see it's quite powerful. The differences I can see so far are:
* it can be easier to define validation rules that use a transformation of the model (virtually, all you need to do is just declare that instead of operating on model A, you operate on "a transformation of A")
* it can be easier to run such EVLs -- just like any other EVLs, and not like ANT scripts
However, I do admit I might be missing a simple (or even simpler) alternative using workflows. I will check that, and post again.
Re: Composing Epsilon tools? [message #584226 is a reply to message #505564] Sat, 02 January 2010 05:54 Go to previous messageGo to next message
Hi Dimitrios,
The semantics is that instead of applying the constraint on instances of UML14!Class, it would be applied on instances of Graph!Node which are obtained by a transformation defined in the ETL module "UML2Graph".
Re: Composing Epsilon tools? [message #584262 is a reply to message #584226] Sat, 02 January 2010 10:55 Go to previous messageGo to next message
Hi Itamar,
Dimitris
Itamar wrote:
> Hi Dimitrios,
> execution engine?)
Re: Composing Epsilon tools? [message #584392 is a reply to message #505592] Wed, 06 January 2010 03:02 Go to previous message
Previous Topic:[EUGENIA] Different types of diagrams like UML2 Tools
Next Topic:Performing validation whenever a diagram is saved
Current Time: Wed Jul 23 19:11:21 EDT 2025
Powered by FUDForum. Page generated in 0.06112 seconds
