How to contribute a IDE project to Eclipse [message #505375] |
Tue, 29 December 2009 18:22  |
We have a IDE (SwixEditor) for visually laying out swing forms persisted in XML. This project is based on EMF / GEF. This tool is used by several enterprises and individuals.
We want to opensource this project and contribute it as an IDE project similar to VE. Whats the process of doing so. Please advise. You can also send me an email at sanjeevk [AT] invivosoft [DOT] com.
More information on this product can be accessed from http://www.invivosoft.com/swixeditor
Best regards
Sanjeev Kumar
Invivo Software.
Re: How to contribute a IDE project to Eclipse [message #506075 is a reply to message #505797] |
Tue, 05 January 2010 20:34   |
Could you look at the XWT Designer, which is incubated in e4? It seems your
editor is much close to this one.
> e. Our customers found this equivalant and better than Microsoft XAML
> editor.
I suppose you mean XAML pad, which is in fact a XML text editor, or
Expression Blend, which is much rich and powerful commercial tools?
Best regards
Yves YANG
"Sanjeev" <sanjeevk@invivosoft.com> wrote in message
news:hhuhb4$1m2$1@build.eclipse.org...
> Hi Yves,
> Thanks for the reply. You asked
>>>1. What's the syntax or grammar of XML?
> The XML is based on swixml, an open source engine for representing Swing
> UI in xml (www.swixml.org).
> However, the SwixEditor is independent of the underlying XML schema. It
> can support any XML schema. Supporting a custom schema is as simple as
> adding required annotations to the schema and generating the EMF model
> code.
>>>2. Benefits to Eclipse community
> a. Declarative UI persistance for any XML schema definition.
> b. Robust implementation of Jigloo FormLayout layout manager (in addition
> to other layout managers)
> c. A complex reference implementation of WYSIWYG editor using GEF/EMF
> platforms.
> d. Advance concepts such as visual inheritance using EObject model.
> editor.
>>>Is XML open source...license details
> Out of box, SwixEditor supports swixml (http://www.swixml.org) an open
> source engine for representing swing UI. SwiXml is available under an
> Apache-style open source license.
> However, as I mentioned earlier, swixeditor is designed to support any xml
> schema representation.
> Please let me know if you need any further information.
> Thanks
> Sanjeev Kumar
Re: How to contribute a IDE project to Eclipse [message #617603 is a reply to message #505460] |
Tue, 05 January 2010 00:05  |
Hi Yves,
You asked
The XML is based on swixml, an open source engine for representing Swing UI in xml (www.swixml.org).
However, the SwixEditor is independent of the underlying XML schema. It can support any XML schema. Supporting a custom schema is as simple as adding required annotations to the schema and generating the EMF model code.
b. Robust implementation of Jigloo FormLayout layout manager (in addition to other layout managers)
c. A complex reference implementation of WYSIWYG editor using GEF/EMF platforms.
e. Our customers found this equivalant and better than Microsoft XAML editor.
Out of box, SwixEditor supports swixml (http://www.swixml.org) an open source engine for representing swing UI. SwiXml is available under an Apache-style open source license.
However, as I mentioned earlier, swixeditor is designed to support any xml schema representation.
Sanjeev Kumar
Re: How to contribute a IDE project to Eclipse [message #618348 is a reply to message #617603] |
> editor.
Best regards
Yves YANG
> Hi Yves,
> code.
> platforms.
> editor.
> Thanks
> Sanjeev Kumar
FUDForum. Page generated in 0.04524 seconds
