Home » Eclipse Projects » Eclipse 4 » Product launch results in error
Product launch results in error [message #498654] Tue, 17 November 2009 16:57 Go to next message
I updated a small example (like the contacts demo) but when I launch the application now, i get an error. Any idea what I'm missing?
Tnx in advance for the answer !
This is the stacktrace:
java.lang.RuntimeException: Application "org.eclipse.e4.workbench.ui.internal.E4Workbench.init" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.e4.ui.workbench.swt.application, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 611)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
at org.eclipse.equinox.launcher.Main.main(Main.java:1339)
Re: Product launch results in error [message #498779 is a reply to message #498654] Wed, 18 November 2009 10:38 Go to previous messageGo to next message
It seems to me you should be using one of org.eclipse.e4.ui.workbench.swt.application, org.eclipse.e4.ui.workbench.swt.E4Application to launch an e4 RCP app (based on an Application.xmi, for example).
PW
Re: Product launch results in error [message #505349 is a reply to message #498779] Tue, 29 December 2009 14:25 Go to previous messageGo to next message
> PW
I am facing the same issue. I am indeed using org.eclipse.e4.ui.workbench.swt.E4Application to
launch the rcp app.
In fact,I created a new project, copied everything from contacts demo project. updated manifest
accordingly and created a new product same as contacts.product. But it still throws the NPE. Badly
missing a silver bullet.
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
Re: Product launch results in error [message #505350 is a reply to message #505349] Tue, 29 December 2009 15:31 Go to previous messageGo to next message
>> PW
> org.eclipse.e4.ui.workbench.swt.E4Application to launch the rcp app.
> project. updated manifest accordingly and created a new product same as
> contacts.product. But it still throws the NPE. Badly missing a silver
> bullet.
Found a solution. Simply add the complete target to the run config. The 'required plugin'
computation is not correct.
Ankur..
Re: Product launch results in error [message #505384 is a reply to message #505350] Tue, 29 December 2009 23:02 Go to previous messageGo to next message
Even I was trying to run a product from M2, but failed.
The e4 examples have a few bugs with e4 1.0 M2 release. Please refer https://bugs.eclipse.org/bugs/show_bug.cgi?id=298011
Re: Product launch results in error [message #506574 is a reply to message #505384] Fri, 08 January 2010 00:55 Go to previous messageGo to next message
Based on my experience some bundles needs to be included manually such as: org.eclipse.equinox.ds
Here the the list of bundles that i have included
org.eclipse.equinox.common,
org.eclipse.core.runtime,
org.eclipse.core.resources,
org.eclipse.core.jobs,
org.eclipse.swt,
org.eclipse.nebula.widgets.gallery,
org.eclipse.core.databinding,
org.eclipse.core.databinding.beans,
org.eclipse.jface,
org.eclipse.jface.databinding,
org.eclipse.e4.ui.services,
org.eclipse.e4.ui.workbench,
org.eclipse.e4.core.services,
org.eclipse.e4.ui.model.workbench,
org.eclipse.e4.ui.bindings;bundle-version="0.9.0",
org.eclipse.e4.ui.workbench.renderers.swt;bundle-version="0.9.1 ",
org.eclipse.e4.ui.workbench.renderers.swt.contributions;bund le-version= "0.9.1",
org.eclipse.e4.ui.workbench.swt;bundle-version="0.9.1",
org.eclipse.e4.xwt;bundle-version="0.9.1",
com.ibm.icu;bundle-version="4.0.1",
org.eclipse.core.databinding.property;bundle-version="1.2.100 ",
org.eclipse.osgi.services;bundle-version="3.2.0",
javax.servlet;bundle-version="2.5.0",
org.eclipse.equinox.ds;bundle-version="1.1.100"
[Updated on: Thu, 07 January 2010 20:02] by Moderator
Re: Product launch results in error [message #566927 is a reply to message #505349] Tue, 29 December 2009 15:31 Go to previous messageGo to next message
>> PW
> bullet.
Ankur..
Re: Product launch results in error [message #566945 is a reply to message #505350] Tue, 29 December 2009 23:02 Go to previous messageGo to next message
Madhu
http://eclipse-info.blogspot.com
Re: Product launch results in error [message #567306 is a reply to message #566945] Fri, 08 January 2010 00:55 Go to previous message
org.eclipse.swt,
org.eclipse.jface,
org.eclipse.equinox.ds;bundle-version="1.1.100",
com.javacraft.properties;bundle-version="1.2.0"
Previous Topic:e4+rcp+create
Next Topic:Rcp + wizard
Current Time: Sun Jul 20 20:46:29 EDT 2025
Powered by FUDForum. Page generated in 0.22641 seconds
