Home » Language IDEs » ServerTools (WTP) » JSPs throwing incorrect compiler warnings
JSPs throwing incorrect compiler warnings [message #505263] Mon, 28 December 2009 20:50 Go to next message
I'm seeing problems with the compiler warnings on my Eclipse Galileo JEE
webapp.
Every single jsp is showing the following warnings in the "problems"
tab:
Null pointer access: The variable out can only be null at this
location.
Null pointer access: The variable session can only be null at this
location.
The import javax.servlet is never used.
These errors persist despite complete cleanings of the projects and
servers, and deleting and creating new servers. I'm configured with
Apache Tomcat 6.0 as the server library, and have 6.0.20 installed on
the machine.
Any suggestions, other than just suppressing the warnings?
D
Re: JSPs throwing incorrect compiler warnings [message #505279 is a reply to message #505263] Tue, 29 December 2009 03:53 Go to previous messageGo to next message
could you post the snippet of your JSP which causes the "Null pointer access"
warnings?
Best regards
Wolfgang
Re: JSPs throwing incorrect compiler warnings [message #505301 is a reply to message #505263] Tue, 29 December 2009 07:43 Go to previous messageGo to next message
In article <MPG.25a32a72f515c387989686@news.eclipse.org>,
ns_dkerber@ns_WarrenRogersAssociates.com says...
> webapp.
> tab:
> location.
> location.
> the machine.
> D
This is the entire text of one of my .jsp files. This particular one is
throwing the following (incorrect) errors (I know the line breaks make
it hard to read):
Description Resource Path Location Type
location Logout.jsp /SiteData/WebContent line 12 JSP Problem
The import javax.servlet is never used Logout.jsp
/SiteData/WebContent line 1 JSP Problem
The import javax.servlet.http is never used Logout.jsp
The import javax.servlet.jsp is never used Logout.jsp
<%@ page language="java" contentType="text/html; charset=ISO-8859-1" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;
charset=ISO-8859-1">
<title>Logged out of WRA WebSIRA</title>
</head>
<body BGCOLOR="#000000" TEXT="#FFD700" LINK="#FFFFFF" VLINK="#9F9F9F">
session.invalidate();
<font face="verdana, Arial, Helvetica" size=3>
<b>You have successfully logged out of WRA WebSIRA.</b>
<font size=4>
<br><br><a href="Login.jsp">Log in to WRA WebSIRA
</a>
</font>
</font>
</body>
</html>
Re: JSPs throwing incorrect compiler warnings [message #505407 is a reply to message #505301] Wed, 30 December 2009 07:29 Go to previous messageGo to next message
Hi David,
I think I see the reason: your JSP validation settings are not the default ones,
and you switched some from "ignore" to "warning".
The settings are (either project specific through "Properties" => "Validation"
or global through "Preferences" => "Web" => "JSP files" => "Validation"): Group
"Java", options "Null pointer access" and "Unused import".
By default, the full group "Java" is set to "Ignore".
But it does not make sense that those errors appear. So, maybe someone with
conceptual knowledge of validation can comment on this.
Hope this helps
Wolfgang
Re: JSPs throwing incorrect compiler warnings [message #505421 is a reply to message #505407] Wed, 30 December 2009 08:24 Go to previous message
In article <hhfh31$pdv$1@build.eclipse.org>, wknauf_NO_@_INSIDE_hg-
online.de says...
> Hi David,
But I want it to check MY code in a .jsp, just not the generated, so I
don't want to turn off jsp checking.
Even with that, why does it think "Session" can only be null at some
point? It obviously cannot be null in a jsp, so why does it think it
is? Sounds like a true bug in null checker, wrt .jsp files.
with
Yes, that is the root of my question.
d
Previous Topic:Disable XML Comment Autocompletion
Next Topic:eclipse with glassfish
Current Time: Sat Jul 26 23:43:29 EDT 2025
Powered by FUDForum. Page generated in 0.04216 seconds
