Home » Eclipse Projects » Rich Client Platform (RCP) » Always meet bundle missing problem while exporting RCP(Export RCP problem)
Always meet bundle missing problem while exporting RCP [message #504670] |
Mon, 21 December 2009 17:04  |
Dear All,
I configured all the necessary plugins in a feature, then I added this feature to my product file.
This product works very well in debug mode(by clicking "Launch an Eclipse application in Debug mode" in the product editor). But when I'm trying to export it. I always meet the error of "Cannot complete the install because one or more required items could not be found."
I tried many times, and the missing plugins were different each time. I'm really confused about this. I read some articles about how to export an RCP application, and followed the guides. But just failed.
BTW, I can export this RCP based on Eclipse 3.4, after upgrading to Eclipse 3.5, and fixed some errors in feature.xml, I met this crazy problem.
Can anyone help me out? Any suggestions are welcome. Thanks so much.
Re: Always meet bundle missing problem while exporting RCP [message #505097 is a reply to message #504670] |
Sat, 26 December 2009 14:02   |
Hi Li,
does the description here work for you:
http://www.vogella.de/articles/RichClientPlatform/article.ht ml
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
On 21.12.2009 14:04, Li Junhong wrote:
> Dear All,
> problem.
Re: Always meet bundle missing problem while exporting RCP [message #505155 is a reply to message #505097] |
Sun, 27 December 2009 21:31   |
Hi Lars,
Thanks so much for your kindly help.
Actually, when I exported the rcp, I checked on the option of "Generate metadata repository", if I did this, the exporting process failed, but if I check it off, I could export it successfully.
At the end, I had to check off this option to make sure I can export my RCP.
Do you happen to know what's the difference between the above two ways?
Anyway, I can export it now, thanks again.
Li
Re: Always meet bundle missing problem while exporting RCP [message #505234 is a reply to message #505155] |
Mon, 28 December 2009 14:41   |
Good to hear that the export worked.
AFAIK if you check the option a p2 enabled directory will be created so
that you could use the update manager to install new versions of your
RCP application.
Best regards, Lars
On 27.12.2009 18:31, Li Junhong wrote:
> Hi Lars,
> RCP.
> Li
Re: Always meet bundle missing problem while exporting RCP [message #505262 is a reply to message #505234] |
Mon, 28 December 2009 20:13  |
Hi Lars,
I agreed with you so much! If check the option, there will be a p2 enabled directory in the exported directory, and the RCP can use the update manager function directly.
For now, if I want to use the update manager, I have to write some code to enable it. Anyway, I have done this already. Thanks!
Best regards, Li
Current Time: Sat Jul 26 11:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.09707 seconds
