Home » Modeling » Epsilon » ETL & ATL(Problems with the property ¨"thisModule")
icon7.gif  ETL & ATL [message #505253] Mon, 28 December 2009 18:12 Go to next message
Hello:
I am programming rules with ETL.
I need to be able index like to an operation contextual.
Programming with the language ATL it(he,she) is in use: "thisModule.name_contextual_operation", but the ETL, which is?
Thank you
Re: ETL & ATL [message #505257 is a reply to message #505253] Mon, 28 December 2009 18:18 Go to previous messageGo to next message
In ETL you can define operations with/without a context. Operations with
a context are defined like this:
// Class is the context here
operation Class doSomething() {
and invoked like this:
c.doSomething(); // Provided that that c is an instance of Class
Context-less operations are defined like this:
operation doSomethingElse() {
and called like this:
doSomethingElse();
I hope this helps.
Dimitris
c wrote:
> Hello:
> Thank you
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: ETL & ATL [message #505295 is a reply to message #505257] Tue, 29 December 2009 01:24 Go to previous messageGo to next message
Thank you for answering me.
But my problem is not exactly this.
In ATL I have " helper def: package ........ " and then it writes himself " model <-thisModule.package " and the equivalent one in ETL is: " operation package().... ".
But I do not know call like it is indexed in ETL, that is to say " thisModule.package " says to me that it does not exist.
I want to do " s. Model: = package (); " but me the mistake appears " Property 'Model' not found in object "
Re: ETL & ATL [message #505308 is a reply to message #505295] Tue, 29 December 2009 03:38 Go to previous messageGo to next message
Could you please send me your transformation together with the
metamodels and some sample models so that I can have a closer look at this?
Dimitris
Re: ETL & ATL [message #584058 is a reply to message #505253] Mon, 28 December 2009 18:18 Go to previous messageGo to next message
doSomethingElse();
I hope this helps.
Dimitris
c wrote:
> Hello:
> Thank you
Re: ETL & ATL [message #584093 is a reply to message #505257] Tue, 29 December 2009 01:24 Go to previous messageGo to next message
Re: ETL & ATL [message #584107 is a reply to message #584093] Tue, 29 December 2009 07:58 Go to previous message
Dimitris
Previous Topic:ETL & ATL
Next Topic:ETL property isDerived
Current Time: Sat Jul 26 14:52:08 EDT 2025
Powered by FUDForum. Page generated in 0.07418 seconds
