Home » Eclipse Projects » Eclipse 4 » XWT + DataBinding +DataContext +Replace
XWT + DataBinding +DataContext +Replace [message #505197] Mon, 28 December 2009 09:21 Go to next message
Problem
In my java code, I have the following
oC = (Control) XWT.load(parent, url, loadModel("SG.xml"));
System.out.println ( XWT.getDataContext(oC)) ;
I would like to refresh the TableViewer with the contents of SGNew.xml in
the runtime.
Since I didn't see setDataContext such as
XWT.setDataContext(oC,loadModel("SGNew.xml")),
I tried setting the input of TableViewer with the result of
loadModel("SGNew.xml"), obviously it threw the following error
"org.eclipse.core.runtime.AssertionFailedException: assertion failed: This
content provider only works with input of type IObservableList"
What is the best way to proceed ?
Best Regards,
Walter G. Prabhakar.
Re: XWT + DataBinding +DataContext +Replace [message #505211 is a reply to message #505197] Mon, 28 December 2009 10:59 Go to previous message
The error message states that you are using the wrong data provider.
There is a xml data provider (..e4.xwt.xml) to be used for xml data.
Though, I am not sure how mature the data provider is.
In your binding declaration you will have to use xpath expressions, e.g.:
{Binding path=//users/@name}
Afaik, you can only set the data context once, prior to loading the UI.
Re: XWT + DataBinding +DataContext +Replace [message #505235 is a reply to message #505197] Sun, 27 December 2009 23:45 Go to previous message
"Walter Prabhakar" <kwchess@gmail.com> wrote in message
news:hhaeth$s4v$1@build.eclipse.org...
> Problem
> the runtime.
You can always to get the file content, create a IObservableList to pass and
then pass it to TableViewer. But you need to know data binding framework.
The simple way is just to reload the XWT resource to recreate UI with new
data context.
Best regards
yves
> Best Regards,
Re: XWT + DataBinding +DataContext +Replace [message #505236 is a reply to message #505211] Sun, 27 December 2009 23:48 Go to previous message
By now, It is a POC. We need to develop more tests. Particuliarly, the xpath
expression may have a problem with some special characters.
yves
"Erdal Karaca" <erdal.karaca.de@googlemail.com> wrote in message
news:hhakli$evi$1@build.eclipse.org...
Re: XWT + DataBinding +DataContext +Replace [message #566789 is a reply to message #505197] Mon, 28 December 2009 10:59 Go to previous message
Re: XWT + DataBinding +DataContext +Replace [message #566799 is a reply to message #505197] Sun, 27 December 2009 23:45 Go to previous message
> Problem
> the runtime.
data context.
Best regards
yves
> Best Regards,
Re: XWT + DataBinding +DataContext +Replace [message #566823 is a reply to message #505211] Sun, 27 December 2009 23:48 Go to previous message
yves
Previous Topic:XWT + DataBinding +DataContext +Replace
Next Topic:Product launch results in error
Current Time: Wed Jul 23 08:13:56 EDT 2025
Powered by FUDForum. Page generated in 0.05225 seconds
