| relative path for web app [message #505190] |
Mon, 28 December 2009 03:45  |
I am developing a web application in jsp with Eclipse 3.2 WTP all-in-one, Tomcat 5.5 (I followed tutorial on eclipsetotale.com) .
I would like to place an image in the application but I can not give the path relative to my application to find the file. Jpg.
The folder of Eclipse and 'installed in c: \ eclipse while the project in c: \ workspace \ ProgettoBeta \
I created a folder for the images in c: \ workspace \ ProgettoBeta \ images \ with a file inside logo.jpg
the path in the code and check that 'this
". / ProgettoBeta / images / Logo.jpg"
When I try to load the application and found the error 'The following
Code:
java.io.FileNotFoundException: C:\eclipse\.\ProgettoBeta\images\Logo.jpg (The system cannot
find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:70)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:161)
at java.net.URL.openStream(URL.java:1010)
at com.itextpdf.text.Image.getInstance(Unknown Source)
at org.me.betaLib.GeneraPdf.creaPdf(GeneraPdf.java:47)
at org.me.betaLib.Controller.doGet(Controller.java:62)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection
(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:619)
From what i read the source path is 'C: \ eclipse instead of' the project folder and this puts me in error.
how can I resolve the situation?
| Re: relative path for web app [message #505701 is a reply to message #505190] |
Mon, 04 January 2010 05:12  |
Simone wrote:
> Hello, I am developing a web application in jsp with Eclipse 3.2 WTP
> path relative to my application to find the file. Jpg. The folder of
> images \ with a file inside logo.jpg the path in the code and check that
> 'this
> When I try to load the application and found the error 'The following Code:
> C:\eclipse\.\ProgettoBeta\images\Logo.jpg (The system cannot find the
> path specified)
> (The system cannot
> at
> sun.net.www.protocol.file.FileURLConnection.connect(FileURLC onnection.java:70)
> at
> sun.net.www.protocol.file.FileURLConnection.getInputStream(F ileURLConnection.java:161)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:174)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:874)
> at
> org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection
> at
> org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
> at
> org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
> at
> org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689)
> Thanks
There is no guarantee as to what folder "." will refer to in a servlet
container, such as Tomcat. It's not clear what GeneraPdf.creaPdf() or
Image.getInstance() will use as the algorithm for resolving a relative
image URL, so it is hard to say much more than using "." isn't going to
work. I wouldn't be surprised if your options are limited and you have
to specify something absolute. If you put the image under a
"WebContent\images" folder of the project, then it should be accessible
via the served webapp using the URL
"http://localhost:<port>/ProgettoBeta/images/Logo.jpg".
Larry
FUDForum. Page generated in 0.03494 seconds
