Home » Eclipse Projects » Subversive » Clicked Update, got Merge
Clicked Update, got Merge [message #504791] Tue, 22 December 2009 12:18 Go to next message
Hi!
Is this a bug? I searched bugzilla, but found nothing like this.
In Synchronize, Incoming mode, I clicked the "Update All Incoming Changes" button and a dialog popped up:
(from memory, I did not save it)
Are you sure you want to merge these 52 items?
Why did the "update" turn into a "merge" ?
David
PS: Using latest Eclipse JEE and subversive/svnkit.
Re: Clicked Update, got Merge [message #504865 is a reply to message #504791] Tue, 22 December 2009 22:24 Go to previous messageGo to next message
I work with CVS, not SVN, but in CVS too if you update from the
synchronize view, and if merges can be done automatically, they are
done. If not, a dialog will show (after the update process) saying that
there are changes in conflict that you have to merge manually.
Mauro.
Re: Clicked Update, got Merge [message #504866 is a reply to message #504865] Wed, 23 December 2009 03:44 Go to previous messageGo to next message
In my case the question popped up right at beginning.
And I had no conflicts.
[Updated on: Tue, 22 December 2009 22:45] by Moderator
Re: Clicked Update, got Merge [message #504868 is a reply to message #504866] Wed, 23 December 2009 03:52 Go to previous messageGo to next message
Maybe the implementation is different, however the concept is the same:
if you have changes in conflict and you click "update incoming changes",
if the implementation can merge it will do. Maybe Subversive just alerts
you before doing that.
Mauro.
Re: Clicked Update, got Merge [message #504873 is a reply to message #504868] Wed, 23 December 2009 04:38 Go to previous messageGo to next message
As I said, I had no conflicts. Let's wait for some SVN guy to look into it...
[Updated on: Tue, 22 December 2009 23:39] by Moderator
Re: Clicked Update, got Merge [message #505173 is a reply to message #504791] Mon, 28 December 2009 01:22 Go to previous messageGo to next message
Hello David,
This is terminology of Team Component and that's their dialog.
> Hi!
> Regards,
> David
Re: Clicked Update, got Merge [message #505180 is a reply to message #505173] Mon, 28 December 2009 06:40 Go to previous message
David, from the other side I agree with you that it's not clear why you see
notes about merge when you make update action and so I created a defect for
Team component about it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298570 Note that you can add
yourself to CC to track bug activity.
> Hello David,
Previous Topic:snv direct use
Next Topic:Right bar in compare does not work same as in editor
Current Time: Sun Jul 27 10:06:47 EDT 2025
Powered by FUDForum. Page generated in 0.10528 seconds
