Home » Modeling » M2T (model-to-text transformation) » [Xtext] Can a keyword not be generated as a lexer rule ?
[Xtext] Can a keyword not be generated as a lexer rule ? [message #504786] Tue, 22 December 2009 11:31 Go to next message
Hi guys,
Given the following grammar :
grammar org.xtext.example.NonKeywordChar with
org.eclipse.xtext.common.Terminals
generate nonKeywordChar "http://www.xtext.org/example/NonKeywordChar"
AB: name=ID '=' '[' a=INT 'x' b=INT ']';
The following file is correctly parsed :
a = [ 1 x 2 ]
The following is legal but doesn't parse:
x = [ 1 x 2 ]
The 'x' keyword appears in the AB parser rule, therefore 'x' is
generated as a lexer rule.
Therefore, in "x = [ 1 x 2 ]", 'x' is parsed as a token by the 'x'
keyword lexer rule and hence the RULE_ID doesn't match.
I'm aware that it's possible to escape IDs by prepending them with '^'
but the syntax I'm trying to parse is not mine and doesn't allow such
escaping.
Do you see any solution allowing this syntax ?
Cédric
Re: [Xtext] Can a keyword not be generated as a lexer rule ? [message #504828 is a reply to message #504786] Tue, 22 December 2009 15:30 Go to previous messageGo to next message
Hi Cedric,
I'm adding the tmf newsgroup to this reply.
You could introduce a data type rule such as:
MyID: ID | 'x';
and use this one instead of the terminal rule ID. This should solve your
problem.
Sebastian
Cédric Vidal schrieb:
> Hi guys,
> a = [ 1 x 2 ]
> x = [ 1 x 2 ]
> escaping.
> Regards,
> Cédric
Re: [Xtext] Can a keyword not be generated as a lexer rule ? [message #505002 is a reply to message #504828] Thu, 24 December 2009 05:07 Go to previous messageGo to next message
Thanx Sebastian !
I'll try that.
Kind regards,
Cédric
Sebastian Zarnekow a écrit :
> Hi Cedric,
> MyID: ID | 'x';
> problem.
> Regards,
> Sebastian
Re: [Xtext] Can a keyword not be generated as a lexer rule ? [message #505006 is a reply to message #505002] Thu, 24 December 2009 05:28 Go to previous message
It worked ! Thanx.
Cédric Vidal a écrit :
> Thanx Sebastian !
> I'll try that.
> Kind regards,
> Cédric
>> Hi Cedric,
>> MyID: ID | 'x';
>> your problem.
>> Regards,
>> Sebastian
Previous Topic:[XPAND] [XTEND] hot to get the number of parameters for an operation
Next Topic:From generated output how to execute another work flow
Current Time: Tue Sep 16 02:30:02 EDT 2025
Powered by FUDForum. Page generated in 0.03818 seconds
