Re: Repo deleted files not shown as incoming change [message #505184 is a reply to message #504933] |
Mon, 28 December 2009 07:08   |
Hello David,
You created defects about this or similar problems (and I also created
corresponding defects for Team Component). Unfortunately, these problems are
not always reproducible and so it's hard to fix them, so we can only wait
when Team will fix them. As a workaround I can propose you to switch to
Incoming/Outgoing mode or does the problem also occur in this mode?
> Happened again.
> Eclipse Galileo SR1 EE, subversive and SVNKit (all latest as of today).
> I checked out some projects.
> I changed a few files locally.
> Many files were changed (deleted actually) in the repository.
> When syncing, I see:
> - files that I changed and are unchanged on server
> - files new on server (one file actually)
> - files that are changed both locally and on server
> - files deleted on server are not shown, they should be visible in
> incoming mode, with a blue arrow and a minus sign on it, right?
> egards,
> David
FUDForum. Page generated in 0.04607 seconds
