Home » Eclipse Projects » Standard Widget Toolkit (SWT) » how to embed swt shell into native window
how to embed swt shell into native window [message #504884] Wed, 23 December 2009 05:18 Go to next message
Originally posted by: pg_ltj.hotmail.com
I want to embed swt shell into a native window(e.g win32 window) using
OS.setParent(),but the embeded swt shell works incorrectly when the shell's
parent window resizing/updating.Is there any suggestion or example for
that?
best regads.
Re: how to embed swt shell into native window [message #504894 is a reply to message #504884] Wed, 23 December 2009 06:55 Go to previous messageGo to next message
I think the best way for embedding native windows (on win32 platform)
into SWT is through OLE. Did you look at OLE snippets at
http://www.eclipse.org/swt/snippets/ ?
After embedding native windows, you may need to use X Windows calls to
re-parent such as XReparentWindow().
Re: how to embed swt shell into native window [message #505122 is a reply to message #504894] Sun, 27 December 2009 04:13 Go to previous messageGo to next message
Thanks for your suggestion,but my question is how to embed swt shell into
native windows(on win32 platform) ?
"Praveen" <pinnamur@in.ibm.com> ???? news:hgt0f0$hg$1@build.eclipse.org...
>I think the best way for embedding native windows (on win32 platform) into
Re: how to embed swt shell into native window [message #514948 is a reply to message #504884] Wed, 17 February 2010 05:04 Go to previous messageGo to next message
did you already find a way to embed a SWT Window into a native window (win32 window)?
I need to do it, and have found no Information about it.
Thanks.
Re: how to embed swt shell into native window [message #514975 is a reply to message #514948] Wed, 17 February 2010 06:53 Go to previous messageGo to next message
Long time ago i saw an article about embedding external windows into SWT(not activeX)...
http://lh3.ggpht.com/_3SpBG8kdCvs/S3vWKwm8nfI/AAAAAAAADIE/bdW4-Yftpqg/s800/swtwin.GIF
it uses SWT's win32 wrapper(OS class) to get the handle of the window and add the SWT window as its parent...
The same should be possible from any type of win32 library(C,C++)...
cuz the methods should be same in that language also...
see this link..
http://alexela.javaeye.com/?show_full=true
see section "Control external windows in your SWT application"
get the pdf and study the code...
i think this should help...
The target window which you are talking about,
whats the languge in which it is developed(C++,.net,VB,VC++).???
[Updated on: Wed, 17 February 2010 06:54] by Moderator
Re: how to embed swt shell into native window [message #514986 is a reply to message #514975] Wed, 17 February 2010 07:13 Go to previous messageGo to next message
> SWT(not activeX)...
> it used SWT's win32 wrapper(OS class) to get the handler of the window
I think you can provide the public member Control.handle
as the parent for an externally created window - we use this
to integrate dialogs opened via JNA in C++.
> see this link..
The link to that pdf seems no longer be available.
Greetings from Bremen,
Daniel Krügler
Re: how to embed swt shell into native window [message #514990 is a reply to message #514986] Wed, 17 February 2010 07:45 Go to previous messageGo to next message
I have the PDF but how should i send you...
may be this eml file will help...
copy below (after ---) to a text file and rename it to .eml file..
X-Mozilla-Status: 0001
X-Mozilla-Status2: 00800000
X-Mozilla-Keys:
Message-ID: <4B7BE3CF.9060409@XX.com>
Date: Wed, 17 Feb 2010 18:10:47 +0530
User-Agent: Thunderbird 2.0.0.21 (Windows/20090302)
MIME-Version: 1.0
To: cxvcv@jhj.com
Subject: Emailing: swt_winctrl.pdf
Content-Type: multipart/mixed;
boundary="------------040705040408070203080409"
--------------040705040408070203080409
The message is ready to be sent with the following file or link
swt_winctrl.pdf
Note: To protect against computer viruses, e-mail programs may prevent
sending or receiving certain types of file attachments. Check your
e-mail security settings to determine how attachments are handled.
Content-Type: application/pdf;
name="swt_winctrl.pdf"
Content-Disposition: inline;
filename="swt_winctrl.pdf"
JVBERi0xLjQKJeLjz9MKMSAwIG9iago8PC9QYWdlcyAyIDAgUgovTWV0YWRh dGEgMyAwIFIK
L1R5cGUgL0NhdGFsb2cKPj4KZW5kb2JqCjIgMCBvYmoKPDwvUm90YXRlIDAK L0tpZHMgWzQg
MCBSIDUgMCBSIDYgMCBSXQovQ291bnQgMwovVHlwZSAvUGFnZXMKPj4KZW5k b2JqCjQgMCBv
YmoKPDwvUm90YXRlIDAKL1BhcmVudCAyIDAgUgovUmVzb3VyY2VzIDw8L0V4 dEdTdGF0ZSA3
IDAgUgovRm9udCA4IDAgUgovUHJvY1NldCBbL1BERiAvVGV4dF0KPj4KL01l ZGlhQm94IFsw
IDAgNTk1IDg0Ml0KL0NvbnRlbnRzIDkgMCBSCi9UeXBlIC9QYWdlCj4+CmVu ZG9iago5IDAg
b2JqCjw8L0ZpbHRlciAvRmxhdGVEZWNvZGUKL0xlbmd0aCA2MjU5Cj4+CnN0 cmVhbQpxkvkB
nhpVtc2zm501XQnNfO0ye2/xCX3WYM3BhECB3qHqp0o6OcHEj+WQOn8jjwql 2qU+pQt/Ut9Z
F886KkQnRgkghni9AgEd0sy+OX2VjVELf+sMI3kGcrXccP29RUPAAB2mtxhh 91fVn4k8HQ1A
yRYw3CrKZ1V/9kCOhmRSD96dm17yLB4BHX5nnQru8bTjG7QfqhV/bxpJKZwS uWrQFg7gHeah
oaXhsHnrNRwFob0xVxI3sMfdfJoV6+bNbdKhd+QL6DDGk1LSKqiAEjATAtGY aTtS2yPBxlVB
g0dGct4k4bo3nsPDvYE8QonfyFn4Fq/jaD12SMt/1FoZlRyz8CKPPuX8ExeG Q71AapuHAFFb
pX5mhkcdqk8MTPgX9Aw1vLQ6oU0vZ+daJIuxC3jVIi7rtAz5QTIw7Hu99S0Z r0Mab4oeaDYb
MrCg9EOcZ0vbSuYkbyD4IC+AmehprlBGlD30rU0Cudv9CKYqiyNNUlMyEeRX y0/t9ZNvJM6M
zGcMt4+JCGmYR8CaBX2vyY1YAhNw7IWx9NC0sK6ue+17Ul6oGqJ9YZudNwES w+XMxy6SQ9JP
OdObxRYgZNxTwBmCeRpq54wamLeKRxG610IuIrJXgo7g2ezR01xmUC83SWFY 0h7OuhtFsiZF
VzpUiD8cqfXZqGUOQzHF+A331r65Dtb/HBDr7SvQJUxXUJ9cOFqCI+fhVYlH BHpA9PZmkBbr
Z4BacoWzBrq2Y0CCVFSeDdQyfkrDtsT4BHDRd2o9dM/v0foOYrjetKkoFB4A N8+2lszV6Dzp
YEZ88/9b6kIa3xV7F9T7nxIblNoGFik9bcnoBk7wV04PeTWb7Y4jY20hVFLJ oTq+gsqdzwW/
quGMhB42kl94cdcbtdMc4gQdr9BtEpAuGIZDIojmjVN+El0gze3jqJF222wT aCWpgIbfAsKN
nrGNHN+4v//lz02vrb9QN8g3gncI9ax2748bP0pPSPdOiI0xfx14cYe2YC8U kNLLPA0mL41x
AxHgRmyoC6GBJhv7ekc8L92746dCKhtq8MArP2N91rDVdFLhfvYpKXW74AoQ 3bQfM6V8Prfm
cHEGB9Js8XXTr2sza6GW9+Lp/cBFKL3U3Q7Eo1X6rSmvoF/vqjq/1Y4Q+KTn UghSGFKNKeKX
wIa0LZvtKwvyRW89rL9q4Q3/fxF6G5pGD16epIkEeNIbyDW7iNznt9Q1/X9l Uk6BHUKgtQQn
j/PXtvxb5BYx6R8P7If2wzq2H/R6MxzPpqFjdfd/8RQBaDMrlijgx1rmm8v1 n7rnI0HfqSKs
qkkYvx8yddyz1YRS6nzmOh3MHtHYyF5EWSfZfgpZnT8hrH+VKs+zHii70pcF RQjxwN9h3N9B
9Ndm+u8pZJx7jTMpPFqjHqtC4CEq0upv8orUNV1KQ6caFmeUlraYG1cNrKWy A9eiCm1A8HGH
at6mBh2u2hjHd/l/AEPQUI+pmVz0NFFYxuW4MrO0t4hBgT8u2ldt1jfMVNul WhxcFrYHGQDO
4gedNXSlmSRyOZ7AoEPhCv7UqBz373dUsVEzfqDaeuHH4+opytWkxiKUHjCx Ngbja+K4tNkQ
rlzTXn72RRglGifkWMwCgbA4yeUN9MxcBrBu9ExRD+7bTOAEShEGqV2cmWdN tnFG+BB7XlFg
+/gCyxL2B+KBO4wWvpXFlkytQKh17Hc7LZHSG3yURPi5/qv7ccUpFi7Y2XC3 jtB+k7cLUjMB
W7i5J5RrJx+kcL2Q3xrmim3lzdf2oB72l7UA+JBsiRmo6L/SzFRdhwQRYJkB wi6Ojn0Qll+v
AVfN4Y6RYOn8LjgQuWvrWE0LSYeGHpnXg50686Nb9uNMkUN9rXLCBpUCIEHt A6KJK4hche3i
vF79Tg3UcqapqegbvJowTAsVvg4xtSBLvBwLe6Rq0GTqWGqNVvV87vPWZtEu 1LhWrSmvfpmf
lEfMwYOM304wbdWwb7mGyJjpi+Vmp6xP5JY0xWoCkzLKaaCqa5P42SPL0wYH 2aS1km0ugk0w
fmRLzrTInZKDxmknTftSysov+Cb0hRrXcWVXP25z3PrPbfXALet/LwRDjmwt CGUczlIko8s0
Z0D69R07o2oTvEFL27KHNZrv8+/MtTyszwmCNUcg9X2LghWKdPtmJr9JfMDh Wc7JSzNRwj6D
z7o8l1TJejizBTtt3TgLiLP0wNhgsyAgcB5LGDXI3IHCSubnSSGXOw+8BBtW 1RCK1L13wzn4
OtSGlCWpNJYS5bPlKPJl397bpL9gsU5iHYrk/VVySkF+X1LycR9upFJ3Zie2 4IiXHCEqRvoV
TuTfi2MnjL8GagSkarm4PEff8qSwzRYN67rVEa+/d06iI2i5fOeUsrlcBLK1 H939dirBjl++
eGKcRzehRdUU3i9IF4p6U4rTxGELrbnQcLwAutqjBT1V3DyJ+ky6rKraEtlH sSO8K56PTB19
8mdrP083bNQC8F2Ut/9tVlA9Bnuq/vTrpgcJL6EEU1vc4UQcOeAoXJZQQ/x3 0BoxCz4nuLCY
6IJ4fJInfdOIhfJdd6wTvmg0aozD4ofbkb8PjxdtnLa2ABHX9GnCuoXt8UJw c145xiYES40m
cvAmPKwgp7rLTd3aDbbvzd/OTuN39v24wYNwesANOyfD1Npt6XYDLeuwdgjC TvP0/E+Uea02
xL9ghyt7WoFMN+lC7Rsqiy+AFfcJ5I374Um+6vsy/hRB09AADzl4TzOCTRa1 utPlyWqbLM6a
+QgT4sEJqRlpCZjLd9GfqbGHREW4XBKx81/yOHIZd5FyhdCFsdF3KhwFgKoL tlClhs5ZsdcY
6642FVqf6ujnd1ZfjTcuhBjJ+Cm1GxisURaZzd4xki2rBpQZqe+qs4T53udY o1ZMH2SD8dhS
X64PiK24ALN59AZAaSDy+0SxhYObbeDHf7QzKok3XSX8A4I2V/hp2XAf/X7R UJL+YnggZQHm
i8BfO7pMUNdDMOudck/njS6dsuMROGk6+g+HnDwIxOOsOIlBWCzRsKctbHT6 6DZ5dmJ9RPQZ
uo7X9PVg0HlBPm2bC3x42YZE4MQTY8oRr9HosJ/tcK+AH1n4wShbe0wh/32N TtrwxmegaHlB
WErlsQ4BEuocbXxF4/SMxsXlnzM5wJwcdLaZp37RtqFxBpm6Z69+dos74AlR Hra5l3gPBrzq
PYyKtp569GvvKS7MLIifLvZsbRCibFIcdeow3CnW6Q/S7ZC3J9LAgHCb/zLl IY2QkRGnO4u+
uuq9LBjNuP8a1zHYdi2XHjr0YO7KeDxMEz5Hgs55tNpn9AX3uX/qutl+m8oi rNVORariI1qz
mQIYdCgM+IkwMIRUJwfBWRg18aEQNR71w7ZXqk2/xsywCmMDS/7WWh/OEjnL iPlefBR2Ac92
atq2Qzl2/HAiwdNIfE4vUqXdZ7oua1rxmxJDxc53IhgKa3eIP5axmNpUHpf/ wZHUa+ZLA5gJ
goMMIqP8V1gZssG6bdI3tHfAVdOYrtJRyLGrafK8ckZvls8nguKI1k3eM/X3 cZdAi/o/Rx7/
pdbvEoa8J1pnq5CdK10hOPjaa/1M2l7Q987z4e004K4+6XUgWE/THpO4BTU/ L9Aj3WkvpEKB
PiiEsSymIBj8gVYbr9FZ4L/kkQKj7xzTD8ugYzJdMYn4RlkLPlf2g0AaLtOq KewUGV9cE4TX
FqP2D0SjN/DwHLAxs8vaY8T+XuD24myHZWkUQ+21gB+PKPGeAIXBmuaQtbgi 0MUC335wAGSM
6ljBsxkq6HMy/ZRTOb2OodlE7lqA7YSHBGSfw7JoSvD7Wbvjk5mqKwYCSrZO FKSNINb/Swq9
OFAqzjwdBk97ihmzLSLhfOJ4YaXEmCWs5wHB6xU2VJ3FFXnLwMEZR/sl4atJ lCxpjw453x3p
8EMnJHVAWlYkPgDScWB9+6lxh0OMDDCpff4637SKMFuESzWlEEGn8BeNPWZL dG3qECfwf7Wa
R7W8nC9GuIvvJoMZffIXXfQX+iESQ8ouYanmqrRQqV5bGIQuh1muKQ3x9htj EPjJW4/0I9Ql
1R9fkwEqsmKtWAgsWWXtaPwOwG55i1Dy6xCZ/refh2ts1brXaPcaOeU8gWF7 MTWEmCcOrU+R
ymbjdaW0BIaMTfIT9pOFndRTawPA/D3w6kEioAYOZK9CVwwXJKmE2BgM97Pt jF1a9E5EHVVQ
39PCxniHh18DOWA8OosQ70JZO5fFdfCA56PqAsfP384cyBG6aypyT/7BDpME Q/3NsBHCjq/7
jlYHkUdlnScUTaqIwqf1MGE1rIGjUNgVsEkHX+xZBLJYmVGI9Rc2Ik+6H/go 8XBaa2z08yD0
dk/k1psoyKfhpI7knYJDBaGJr+3xXkjm0Y2SSl9f2xDzE/iLK9Ph20TM2Aoh uLFXw1Nn19j+
ibCO5u7B/Tm2sbxAJVIT+b9eo87fpqwT6LmVV7v1/oMhZ7Olk9MkD+KgIHl+ 6kqGonAmWjmz
yzmke44rbwVhrk/k157bFVEeqg+P1U/uJRV28gZ465KWMEZJlr5dPkPV2QuK +KlQOanYInky
vfIdcQbaHSJJ+e0HP8w1hXkNxrnVWjEKmcd09HiaWFyfSfBNajUFgb20g22k 8obmAb0MCuqV
tBrz8dv1uZgz8pg2+RSnk8jfxalygRB2+nNi6cqjEnNA7tamNm9bzirchzB7 w3UEmy9i2nsU
fCqUHn9Ak9pIq31Fo/sTjzpZOXWe1FlDuG6T/nsCMxAeeVuY1lk+RnuvS9UY F9cwm1swd957
5kMgoE5VIqQMTxfje+CerrUFqrjHmL9C3kLnoVTWZSL9l8mz6CgFt+dl/9RX LFn5G9O3lUqY
KB3Ge62ev/aAd4dkaz1/2XHVXnI21aDPxD5hSkcB0fgM5gc0U6JkeDw8+JY1 3VjOgW+kqHAe
pJL46tDztsbqri1J2Tw1VQ69NxOQ5JboTUv/UkOwyt+pJgDl/rNTwOXudTcu 0QVkLVfm7Qg8
A9U7JRNCS8gdaM6jovfzaEv3DSsnZsYcWRI/EAnrvM4VYmxpSbz19fjdWTyV umqjPZ57sBu/
97CJaLLO16PVklevyaBTlEQXgnrQGk6zD8GP/EYJhG31ETal+oKR0y3ahNai gzTgwARDPWWb
EbgtwsG2MFdSl8Jx1z7bl0eHTR+o+83XC43d+gESkOrtuDdMFOs3oYOLvnek 3JZhSw26q1/C
ZPe1xDrj4a1W9x3nR8tourP8Lj3TDsOH62APGdTgzHZsg90LMpPX55v5jUve ENYk+8K4ZGVk
2ztDJ49UtPkCO6hzDSXz8eTltUQzxbXYjElMuOhV6KV1g07MnqktCiDIwdJR yEDwG+tVMJ+p
EDm7omKdcyRNaY1UVQsPXzhb3xzg+JsJTY86p54MVwdD1fOxSM/y+/6ws+0v JhgnAEEkD9IA
Urk+GqqkvRS5PQ6BppD8AVmV4Sz3Px32Ashioy+HJAlmFYnKpSbQXJSSdns+ j+0kHd3kwzHN
olsdy62B4EIaAZT0/IAdFYXuuatAti7iXOPUv/5GaII/girLnwhtUbylUk+B MPTE5EQ35SDQ
bfnhDWtXbElaKHoyVMf3SVeyM/6/GUrwaSltm/xsT5hgC6g7ORNmPorU52pk by0O6QisA3sy
kAs5/dQAZ/2Ijg+wB4ZQOHGZUpcXP5GXHnak1Ljg1cwqACZN268POsmWrEVN jbdP+SYOKkGj
qnE7rx4TSdDmvbKyoZyjqDEeQddJfPMwe/CFu682h5YEnHkcZe7ZyScOlRfw KCATH+WCjrDe
8YstVqUkmj14gksL/XtOSTC2115AxWn1VOFV65+ptYgoj08lq8AE5ngIgNdL X2R6Qn0/7QOk
sD4MLuAV/FIs87f5hkNH4ic1CbXtJm/Fb6VvTRj1lndDBl2RrnFPVKmWoOkI 9QUxN3sAmAS2
U3OFY5mWD/cOey39b9ccoQ2tjAIGhbVKOmMvKF3BmW+Zy5cAkIzQE7wjuSgq OfX2lVmBOdTF
V5cQ13Ig2bIoS6G/HXnFjvrxm7BzUiRcfRb4eC20VPlWwwcwgzm63Ta+onJR +79aVOJA8/7R
N9zqDmvUhrDdcdKj3w30YueYuQWGcBEReJ7uEmo6YmvMyCXk6ABssSnGyo9M WI//+jWASkzN
CmvrIDO/z4lZG0mrPpB5N1y7bNXDfXbU1ooo+MGXCqF/igX6sLjWZWCv2Uuh fPVBBhIaFH/R
I6hRdcw7nlLr8ABQ1p6Wj497ixbGdJYN1iz98xUNL0NlRCcRjumWVCITw/2h K2KvB5mzz0Qf
HGul/AOVkvI52Asu5Zv4DxdPe7Jdf9OpXiIqUEi1lQipjPM7YmDlFEbvTmv5 6LxUTnDAb7qZ
nMWJeYdrj9Zp0wJj9qDYULPxtUBQEYoGnYv8i1fwxmqYXdq5Q1NI2yILIfBM NVO8AZv1cqfw
jhhAeOgkCSSy7Z6N/f8bSzi+FHey9CzSEdL6O9WucmgjPcTa3dkTCeCQliSR +crWl+2O5GFq
arhWeQmDO3BKgtE+I0U43pbC2szJrpPHQEGAft9nGmxrftV8bz6AS5VoYLAx ygEUiPruTvb6
pQ7xHAHUJ/MxqmVI3ay0+KHXvi1N7wDlGjIYvtgQfWCUOKZuABWaqzMjiW7z H39cmg1ncy5K
aA7o9Cr2UYiDhB6yK+W/whY3kg24zcz7PDe67qaOFUiAjawjgKuwAWRmlJU+ vPcfKTSkiSj1
hOwf2IjcB317bMd/rTFsQkWpLbaXhzYJbMpCgeG4LyWr3mvew1LrMIAr3Ewv KyGKjzXjqpsq
ONYlH1iFWQKrS7S9irzibGlflxuyn1IgFNQklC3TLvTwXSyRSKN1BzHh7jf3 O345z8OdlkBs
5B/QOAqAULL3sQBIwJZ8Rau7P8LGueaJ6+MBcSxMvT8VakeBfHx2bOaLdUzT RAYMMfBvCIMJ
MRYiEu94z7zvtbaZKdk0IHEyxlQmwAx68nNeb9WAZlWLxPqXiDumYSVYrq1b 0Yt2YOc5/xoE
zeTdRHPZOCFH7I4oHo3Wo1gFQyqngg4mXAmU0rcjnmLr2yVoi+BpxxC1yt4G km1rNsEEea6f
pShWs/mt9DHX/tA2t8jHUZ6HSe71CqCA6Dok8Tc/LLE5ahg8ci9wiPGjLqx/ qVYRBgW3OoKG
g+7ok881xaVtbp86iG/8kl30HhkzFRqB1Kkbaty5J+yr4gjqWmAeVPwT0NlO 7Q/4vZ268RiT
AVy51Msg0cS1EIvrujjqclfJzW/YJ5ygZ+mHbOBiuaobkUscTByxmQ2+4tDD SJ3UNCh0YfSF
NJVZKRggZp0A23yDoyVPIjQH3XV/JzQt7vQg6+1BqTq2WWJKxB14B3WlKWfH uhjcjPTZjG/I
lJjyOFWuu312VVF3joD41LyLCM2LEtTaabMad5DbNdr6Wp7M39wop9e7zqSm LC3exsNkSOyl
Bu20cV7QjJcwkzxRSNn2GgeBbOKrCdthx462lYkUymhxWZyLAloOJCyBAric DrCnF8R2hnPQ
TPZ1EpTDwDOAKN/ZkJ2pBt/IJooAPP73kDq1T6d9u6APun0iYbh2itkkHVB3 TtqUHqAq19eH
3ZYt5QrrSglkzWWnQyhJFUhQ5z/FLNj3YmMCHZp4LO7tyXgrHahDMLtKbogh hxSC5KEFr5B5
IUAD/S34fWyTwS6qJnsPoIQsyczHH7t+SlpdQDl29yDLr7J/KKJR1j6wa/4i KxLnsWla1CVF
oRaMzWOjrr1xobCXfmYcq7uFPTTKjl89OkFNXmx2OHzmhicq4KU/1w710oRZ vn7qh2VVJOVg
+OFMQnkSPRjRYR5/BPAVSlfmKSCae9pNLo+W78oVSgyUOEwgzI/RtF1etXpE y23fXAzwVPVv
0q2VGg5vbGtFttUJUIzgGwyiajTsR1V6jowJ5vnIGZzdKZlu0ES9vHzkM2dw T7oioo9x5sXv
4/xlW9A5YgnTf/evmSdHeNLdyTl84e/RQXtgzdquLI6BAMWgkT1QYCaT7y0J hRpE3i26imC0
9rv58ZKhfEI6a/I3h4yDHaz6wcoVNOLjg9/YMfbGDqSb4friwUEONC7mVErO 4bqgtUXZe1IU
3dLRq9dUg8WyFhHC9oQghFh5R8YXla4jmftMEtqGQwkrIqlnPc7xYtWQ9Fra 2rSLRNxBrEJL
ag+P/wlu2yTN8HuSy9vjrgmomt5IdP68rMFCo20E6YioZAER067s9X7JAWtp BrF7jfBEgZtS
ygtr9+Phsx0rABtMV9NOkIjjWfH82hTveayFhdvbz2QP1FL3oc/gClZQC2f5 bLtaCzwE4jCA
oejr9kBoilptOHQwIrKFCYmhfOvrtiCFgCJtmrVsGZV4497CRNLt1S0dgM53 CmVuZHN0cmVh
bQplbmRvYmoKMTAgMCBvYmoKNjI1OQplbmRvYmoKMTEgMCBvYmoKPDwvVHlw ZSAvRXh0R1N0
YXRlCi9PUE0gMQo+PgplbmRvYmoKMTIgMCBvYmoKPDwvTGFzdENoYXIgMjQK L0Jhc2VGb250
IC9HTVRYU1UrVGltZXNOZXdSb21hbgovU3VidHlwZSAvVHJ1ZVR5cGUKL1dp ZHRocyBbNTAw
IDQ0NCAyNTAgNjExIDI3OCA0NDQgNDQ0IDUwMCA1MDAgNTAwIDM4OSA1NTYg Mzg5IDUwMCAy
NTAgNTAwIDI3OCA1MDAgMzMzIDI3OCA2NjcgMjUwIDUwMCAyNzhdCi9Gb250 RGVzY3JpcHRv
ciAxMyAwIFIKL0VuY29kaW5nIDE0IDAgUgovVHlwZSAvRm9udAovRmlyc3RD aGFyIDEKPj4K
ZW5kb2JqCjEzIDAgb2JqCjw8L0ZvbnROYW1lIC9HTVRYU1UrVGltZXNOZXdS b21hbgovU3Rl
bVYgOTkKL0ZvbnRGaWxlMiAxNSAwIFIKL0FzY2VudCA2OTQKL0ZsYWdzIDQK L0Rlc2NlbnQg
LTIxNQovSXRhbGljQW5nbGUgMAovTWlzc2luZ1dpZHRoIDc3NwovRm9udEJC b3ggWy0xNzQg
LTIxNSA2NjEgNjk0XQovVHlwZSAvRm9udERlc2NyaXB0b3IKL0NhcEhlaWdo dCA2OTQKPj4K
ZW5kb2JqCjE2IDAgb2JqCjw8L0xhc3RDaGFyIDQKL0Jhc2VGb250IC9NRURM TVMrVGltZXNO
ZXdSb21hbgovU3VidHlwZSAvVHJ1ZVR5cGUKL1dpZHRocyBbMjUwIDUwMCA1 MDAgNTAwXQov
Rm9udERlc2NyaXB0b3IgMTcgMCBSCi9FbmNvZGluZyAxOCAwIFIKL1R5cGUg L0ZvbnQKL0Zp
cnN0Q2hhciAxCj4+CmVuZG9iagoxNyAwIG9iago8PC9Gb250TmFtZSAvTUVE TE1TK1RpbWVz
TmV3Um9tYW4KL1N0ZW1WIDk1Ci9Gb250RmlsZTIgMTkgMCBSCi9Bc2NlbnQg Njc1Ci9GbGFn
cyA0Ci9EZXNjZW50IC0xMQovSXRhbGljQW5nbGUgMAovTWlzc2luZ1dpZHRo IDc3NwovRm9u
dEJCb3ggWzAgLTExIDYzOCA2NzVdCi9UeXBlIC9Gb250RGVzY3JpcHRvcgov Q2FwSGVpZ2h0
IDY3NQo+PgplbmRvYmoKMjAgMCBvYmoKPDwvTGFzdENoYXIgMjEKL0Jhc2VG b250IC9MV1dI
S0MrVGltZXNOZXdSb21hbgovU3VidHlwZSAvVHJ1ZVR5cGUKL1dpZHRocyBb NzIyIDUwMCA1
NTYgMzMzIDQ0NCAyNzggMjUwIDQ0NCA1MDAgNTAwIDcyMiAyNzggNTU2IDM4 OSA1MDAgNTU2
IDU1NiAxMDAwIDY2NyA1NTYgNDQ0XQovRm9udERlc2NyaXB0b3IgMjEgMCBS Ci9FbmNvZGlu
ZyAyMiAwIFIKL1R5cGUgL0ZvbnQKL0ZpcnN0Q2hhciAxCj4+CmVuZG9iagoy MSAwIG9iago8
PC9Gb250TmFtZSAvTFdXSEtDK1RpbWVzTmV3Um9tYW4KL1N0ZW1WIDE0OAov Rm9udEZpbGUy
IDIzIDAgUgovQXNjZW50IDY3NwovRmxhZ3MgNAovRGVzY2VudCAtMjE1Ci9J dGFsaWNBbmds
ZSAwCi9NaXNzaW5nV2lkdGggNzc3Ci9Gb250QkJveCBbMCAtMjE1IDk5MSA2 NzddCi9UeXBl
IC9Gb250RGVzY3JpcHRvcgovQ2FwSGVpZ2h0IDY3Nwo+PgplbmRvYmoKMjQg MCBvYmoKPDwv
TGFzdENoYXIgMjMKL0Jhc2VGb250IC9ZQldCSkQrQXJpYWwKL1N1YnR5cGUg L1RydWVUeXBl
Ci9XaWR0aHMgWzMzMyA3NzggNjExIDU1NiA1NTYgMzMzIDI3OCA2MTEgNjEx IDI3OCA2Njcg
NjExIDMzMyAzMzMgNjY3IDI3OCA3MjIgNTU2IDU1NiA1NTYgODg5IDYxMSA3 MjJdCi9Gb250
RGVzY3JpcHRvciAyNSAwIFIKL0VuY29kaW5nIDI2IDAgUgovVHlwZSAvRm9u dAovRmlyc3RD
aGFyIDEKPj4KZW5kb2JqCjI1IDAgb2JqCjw8L0ZvbnROYW1lIC9ZQldCSkQr QXJpYWwKL1N0
ZW1WIDEyMwovRm9udEZpbGUyIDI3IDAgUgovQXNjZW50IDcyOAovRmxhZ3Mg NAovRGVzY2Vu
dCAtMjAxCi9JdGFsaWNBbmdsZSAwCi9NaXNzaW5nV2lkdGggNzUwCi9Gb250 QkJveCBbMCAt
MjAxIDgyNCA3MjhdCi9UeXBlIC9Gb250RGVzY3JpcHRvcgovQ2FwSGVpZ2h0 IDcyOAo+Pgpl
bmRvYmoKMjggMCBvYmoKPDwvTGFzdENoYXIgNTgKL0Jhc2VGb250IC9LRk9B TlQrQXJpYWwK
L1N1YnR5cGUgL1RydWVUeXBlCi9XaWR0aHMgWzI3OCA2NjcgNTU2IDIyMiA1 NTYgMjc4IDIy
MiA1NTYgNTU2IDU1NiAzMzMgNTAwIDcyMiA1MDAgNTU2IDU1NiA1NTYgNTU2 IDcyMiAyNzgg
ODMzIDU1NiAyNzggNzIyIDU1NiAzMzMgNzIyIDYxMSA2NjcgNzIyIDUwMCAz MzMgNTAwIDI3
OCA1MDAgNTAwIDc3OCAyNzggMzMzIDc3OCA1MDAgNTU2IDU1NiAyNzggOTQ0 IDY2NyA2Njcg
NzIyIDU1NiA1NTYgNTAwIDI3OCA1NTYgNjExIDEwMDAgMjIyIDIyMiAyNzhd Ci9Gb250RGVz
Y3JpcHRvciAyOSAwIFIKL0VuY29kaW5nIDMwIDAgUgovVHlwZSAvRm9udAov Rmlyc3RDaGFy
IDEKPj4KZW5kb2JqCjI5IDAgb2JqCjw8L0ZvbnROYW1lIC9LRk9BTlQrQXJp YWwKL1N0ZW1W
IDEzOQovRm9udEZpbGUyIDMxIDAgUgovQXNjZW50IDcyOAovRmxhZ3MgNAov RGVzY2VudCAt
MjEwCi9JdGFsaWNBbmdsZSAwCi9NaXNzaW5nV2lkdGggNzUwCi9Gb250QkJv eCBbLTQ1IC0y
MTAgOTMyIDcyOF0KL1R5cGUgL0ZvbnREZXNjcmlwdG9yCi9DYXBIZWlnaHQg NzI4Cj4+CmVu
ZG9iagozMiAwIG9iago8PC9MYXN0Q2hhciAyNQovQmFzZUZvbnQgL01GWk1S UitBcmlhbAov
U3VidHlwZSAvVHJ1ZVR5cGUKL1dpZHRocyBbNzc4IDY2NyAyNzggNTU2IDMz MyA2NjcgNTU2
IDM4OSA2MTEgMzMzIDYxMSA1NTYgNjExIDYxMSAyNzggMjc4IDI3OCA1NTYg NjExIDg4OSA2
MTEgNTU2IDI3OCAzMzMgNTU2XQovRm9udERlc2NyaXB0b3IgMzMgMCBSCi9F bmNvZGluZyAz
NCAwIFIKL1R5cGUgL0ZvbnQKL0ZpcnN0Q2hhciAxCj4+CmVuZG9iagozMyAw IG9iago8PC9G
b250TmFtZSAvTUZaTVJSK0FyaWFsCi9TdGVtViAxMzAKL0ZvbnRGaWxlMiAz NSAwIFIKL0Fz
Y2VudCA3MjgKL0ZsYWdzIDQKL0Rlc2NlbnQgLTIxMAovSXRhbGljQW5nbGUg MAovTWlzc2lu
Z1dpZHRoIDc1MAovRm9udEJCb3ggWy03OCAtMjEwIDg2OCA3MjhdCi9UeXBl IC9Gb250RGVz
Y3JpcHRvcgovQ2FwSGVpZ2h0IDcyOAo+PgplbmRvYmoKNyAwIG9iago8PC9S NyAxMSAwIFIK
Pj4KZW5kb2JqCjggMCBvYmoKPDwvUjE4IDMyIDAgUgovUjE2IDI4IDAgUgov UjE0IDI0IDAg
UgovUjEyIDIwIDAgUgovUjggMTIgMCBSCi9SMTAgMTYgMCBSCj4+CmVuZG9i ago1IDAgb2Jq
Cjw8L1JvdGF0ZSAwCi9QYXJlbnQgMiAwIFIKL1Jlc291cmNlcyA8PC9FeHRH U3RhdGUgMzYg
MCBSCi9Gb250IDM3IDAgUgovUHJvY1NldCBbL1BERiAvVGV4dF0KPj4KL01l ZGlhQm94IFsw
IDAgNTk1IDg0Ml0KL0NvbnRlbnRzIDM4IDAgUgovVHlwZSAvUGFnZQo+Pgpl bmRvYmoKMzgg
MCBvYmoKPDwvRmlsdGVyIC9GbGF0ZURlY29kZQovTGVuZ3RoIDQ4NTUKPj4K c3RyZWFtCqWb
rrn7nSLX+pQiz1L4rNSmZt3z5pEpk7zmlZz4WJTD2TgA1wYvVl0M8O19z017 Kn53RmzqOZbo
j78L0m0JmVAn8psMQQZvqg3elJMtzMFWhV8+OwmGiKxnxa+4nK/0r/IO8PzL 6mIVLV/cuytF
8fqOI/cQ/HjgOMy/RtPdAJprZhnPxf6DTM6raooxPZDpVE3bT7v2sYhwQ0Id 5ENhOBLVOfQX
em7Jf00hUpGmpudPfZemAtpgQsuAkbf3olKTKcnBBm8u6varQpc/cotJmwW0 D/WviwVy6hqe
XEisRU1z6Ae6uWMSAHIgGb+Iu/gaYnndWvJTmrsF/nPMrh72yFcqmjJ5Xs6V t0mBnO6mUXBU
q4nGWp9nrMX7skaBFgeSIyOIen5v0xsBoMsS2ws9sYFl17joqWkscM9sTaM2 NHnn5mJ/MHYi
pLf2AgAwfkJ2g9wfROeQeQTghf//mXHRhm7izYolz4k8aVmxXBzCF5gS0Iim Hixjp8za305o
EZLF9pVZSyrhKKjdxRk4IWizwXOkewvaGrNCVqNqVw7azLp6o53ybYJ43aEM E/nY8stiHEYn
Gz4tX8GioBCHYIYiYk3OFgF8lfKSqUXIC80NWDHkJ0v9TgZgwa816JlR+SzD xXC+yGAfDW7D
g9uTbQJDUI8umAoLqwMIEtd7Z3ivzOo7OoP+xYkq94qMWNaVncKZfIr2EFq/ hMAGYn7MfFZN
9Nlwp4Ar3ysK30VX+eps0gn5DBZqPxgtN8kX8P+Pm+7/5pg1weYhJcZRPWFv V85f9jRblSHw
Fo6wB0BdectkwctdnJ60oqmzPELR1PN2YxWSbMTkBxJ6lyNQt4ORvxRpiDFd EImljh5eMPZA
+f9NvF1yyOgKoS7myqilbo7Gq7+f7kvsMT5jtOc4XtBbUPDQBabZJdXIXmfX 7WVeqMut+gz+
OQypzTJt377rs6E4pRAZ377VHERT/1yjOm8XnNUueW2fIKKZZbsPSFl+7F59 dtT/9Epyinie
M73lHW18O0NbwIuYxHiD/j4MWgK20/4/HP5aVm5F6sO8THPEFm5mQPbUMCi1 UYzYayITk0C6
7AdN5e7tGGGRUafEtZFpS8G0Cj4pvM8wD/dsqtBXDfxkMBLYs7lh+dGmntF8 fpeBfkJ5z6rr
gOaO5qyw8CldQo/9AVFB6qVrX2moOX/5A3aq0wqjwJsdRgdXJ5FYo2ebvXIW pgr/aZqssF2V
wC0P5M3L1EPP7e2KcnHe3vZYgGkyuqLs1M0eyAQiHuhSo0w/x3xNOFfUyZmI 3PgEN5FGslJm
5sjzhh3LsghCAAmFn0BPv2HJ83zaylhYKUQvedD7YzMvJ7Twl3fO4Wx7Ljov mivNL220V3Ht
2Q6nTiRMiUB2uqaI2JrmujW6fuXT8giWTnAK8YP7YkUTJ2MOtBHnpWt2Dl/A aUAhxJ+NSX1A
GkM50mzth2Yq2SpbKsfXbmA3DT3bF8z8oIE7rmxyghNccXxtJLfTgvN2qJd1 kMPUZ4y3Lcje
ol4JCSpgU1Ed/QeXEUCLqWA7r7zVnPMPTxcvZD7nKG/azjrpEo9P/XQqSkql YyBbr8Qr3jaj
lIfPkOJYvOqRb/g0ZPnynbFw08aa/2ihfUetHSL2qhEVh43Y17mGKSIsT6MF kImoY/s7cci9
tIYTkexlXK5cJrySLbldplEPHfZ3kJueFpq2l1kIs/Y3lBLgZefNWWHjh9H2 mgWYBMyXb7LM
eiJ09nMsXKn0yOnih9Q83EItgue1jJJyCiaKk7rjs3P2R917DWYatqDVohj/ k2mZFyI9qMi3
iUN7Jj0DyHZe7XxqRFu1co93GFTJz71xAqmh5AGoHgwzcm5Dfe2FP0X2ZdMn KQOViaf7N163
q47AYQID4T5aFCAf2ls6k0xnCwHpsX2IxWWH9fqhzGdEnOOLI//102K1e0Vw +zJn1812WtVJ
QtfdIbRJWzLUNUGR0V9ABk+f8cxODL0nFodTJhywcStn4WHuXRjDgfh3AFZC 6g4hks1NAXVW
k+2cfEo0036ST3tKRmvJgKOcDQERYa5CnFWpQIi7etTNgw5pAbFM/RC0ZKcj J3Z0PqNP/A27
qQ9J0bIT6kW8o4s/8wTxGsdu5CeKpQY4dg9c4aAIxXdf/tf4Z4zp5dJ3zQLt 7mhQg+guMhTk
ftM/X18zB/OUwKtEaMJVgWfMVjcDF0BCvUlVb35vl9ItYb3gBSTbFM1PHH59 I7fu9XaKFYc0
UVlGw2N18Pha6bCgPJmES8QBCimb2v+bcAmOsHwVzNzriyxHlJjzx0LlOxb1 7+eW/6soXb7o
3De8nMesdbSdBL4UTPdcY+LZxEgpVazG4XI/SOrcuVDFHT/5msXpLeZopghv jRsNl7UecfMB
KtLL4WdBr8h0rGhfkvKUWm3alPgWZDPmP5wU7gWz/9YjAoIyynDABxvvPXh+ HI6uUQBTt6hh
YBf7N+o3mqADJWUSOF8xumFQTz483SsJuY+fzwwu3HhvpgbDW97PgyoaJHkc TxsbsRiVupvr
+1AozkS7kjyRUWtDEYNEuUqmwkNGObCJNYJ8YlhiL77hxd5db9NUEi4vMChf 34hZlgNejO0+
9j/09wX1MDqx2ifEDHr+MLkn1OgNJEO9KcCTwtt0iiB+A97//+2+EuGxwduX SaE61KX5htsu
NUmG4e44I4sfg5DriHaHgpgv07ek7H5hF+xVBEmxsXC/Ycm/rOsvrDPRPzgb 6aWsbjJ+m5YR
OJYpwmuBrihCSXFxheGeer2SbfBgdxVQwBUwpO35i9hoZTDBcyklWxnM+YNG N2gkrzIvnn/m
lKUNzbsGJTK30c7SIndmioErsmzTSKU1IFCR45LmHnJ8Muu6FKYndpK1s8p3 Kq+fgCZdhONj
tN0xGTfWD54WeS5ke/5THgDdiOCvoX7rftCPn01HLU2aqJYpQRo5QHUI0SiB rag6MExhvET4
/7z1eTyZreU5Q/MCK/4vTcxlzP1wsZdb2NppW+QGgkIXycNcAoi9pWfeQQ+i nD72/JQNh0d3
dyLUBUu2gtFdAcuUmZlsaGxcn6WG1h3VB1PsfPqRgBFtuOai7jLo6o7iFmQa pyhjAWtgrUkQ
jgkbSDA0MZMPivnlDqZIEdw/iWI7vj8Qhz1FUEjyVhaLZe0nPF496h+LiaP5 jbJRp+E2JBUN
GZExYUODjHjeVxgiVB+kQ+0HwRI0NkoRmaNp+5tDvVClE9ixZcikpYxte5nh OQj1BDXVcxLh
hAIY1MjbRzKn/TFomdHM2VQLCZmeoH2ouEphh8ZgB0iRm/IUrFUobnKCPkOx 04e0YR0zK211
g7h1bCmGfIe2LCE8hOxeIkgG32NxOz+bx1U9eft7HiI+dr7ejV7DtSTL7PrB h2SwAvXf32v4
urxPTlHRxXqUDlTeM0G1HbE6qwEdoBWEOAokfpvAeI0lYx2Dri+6sJeL9jP7 dKfILV2PioxA
1l1o8CJ4xYUdYz2l3d0Ez18NcZtIqoN4xUuc1328w5xvieF6r5c/pK9HvsTm H2CbNOnXGZCW
i1cTY/6iQTRbpeoVWpqH/2uQt26HILNCtRhL/lVhDonoM7NkJgxzytN9iLAZ VjwrazihDqKA
Ol0sd3hj2iG49UVe06gxJhK9rf9/DvFIgi3nuaHn6p7MQ+8XFdQIGwBdOkl7 1zJNB7tv+o5d
gXGJmZ3Ki3QCh3VTq5wgg0BN4PMx4ozESb6kuLwhgGkxL7pv+576d7OzTkJg b20kA2ynIWZk
VBzhXinBWgIcet64T9mkCFKDezEAFmMwTtI4nzSvJL+rKGjgEMRhlnAD+Y12 AynvFlW25s2n
YlUkpACiid4CVZvJfOxpavs2tDes1br0IKqDN+0+7WZRPokbIbr8ZIrSb1T1 G7IFO6NzBrc4
/rKusj8pEa95Op1x6fqnLExCxAnZzh9BEiV9oibbiGnQeapQLiA//W8C1rKq rUiFSW02PKeo
1OXLs9OksZKoL8gB7UxZfkFOhYLEaCY+4jsxT+05biH0v3dWcjjXA/LUCNSH sHkpC6x47ePW
Bzgsuq6jAbOhW3qMGYdNpVBO654xFVG5S9pijI+rKcxc/PMPURSMgjqSgscq 5df5Z1CC/c/Q
pgQ629yEAlmqrN+aCOmcKSxsAD33A673JMRUVD4UZAOqVt531JUatIS5IGsg s4vAdMmeCxvz
MUf31oSWf9BQ1DhqcFlz8H+mWJoKu9zAvG9SywA6iyJY+BG3/Q7ChmTnv23N sNEBZUt+My/e
Wjy0AKhlzrO411ToA3nzjtisS6zELhRwfDZ4mGLor9gu6JQLZ0PEYRDvW+lC 9OusW0YdZi5G
DEQCwjhDj1M2fv9tgxgxOiVHmpGCmsIQVd2yMEXuVDDByfDO/UjQu0jQZd/q uOhn0QbZ1Bza
EKIU+x/qDelhcM5TJsAYLb5WESZnS0BfKXdsUU0Y07Zq/hnuBPXuKjiQj+Bm aIbBKn1j1L36
b2INEIqSKVBlvgj+N02n8Qo8EyOJxvuSasXT2avRoOogaI5JhId69jfmC83b 61ym4hL/oYfJ
1hagbAq+QU/OOlql7LdUqMA8ZSDZpnOcQ5oy/p0LVBH0Ss9Wg5cB5FhpygDw LYRJLHrfW3hu
XFC5mXzT1EQw9YvyoMkVFYnAuROG7WY+fhEgajmWzdtH3r7T9df1LnNtN6ws FSTRnWf+aUkd
rHiUZ9iYtpQ8Ue3sI9/MyCsCTPAIwcaYkpcVNGvs9wXDSEc4VDgwK61CIN65 0GmlrEC7D45Y
9f/mOUFTFbuhtZbtAD64cG5hhWULdmSmGc/XUzGd7+HeZJodHuEk8YP4PxWp RLGn3yx4PaSO
00XbliNP6PjDLcCvLmMtesaVpSs4DXb6SE0P+rzWfe46cgm98zZh83HtQhmf hYnOI7G4HKbN
tul8u2v9kByB1Kbqp7NRknkOF20tlfl6bMMObWsgFbXqXOfbtL9N+Cegizdo 9bNhUuYVftjY
YJCjf9/rt/RVJg1U88zohpN9BzWHasY+uMXdfo7HaOX2S+aGQOA8z8oRpEb1 oSCABtJEUohV
JoMmQS2MOPgP2BO3psaS7UCC4hlN7sbySWwGZqhwmsQBdtNpBb383WAEZ7lP RlC2Ed+uwHLG
jSVGTOwRtZbOyb9eVkKF4i8UgGrEDM6SN29JAz69xyoOav5mQ356Cc0xFadW sLS6GC3F+zBj
Kmq9+mBvc6TDvwlIDqjQQ5WrnTpLXD+1qVukwa7kODjEDc/tIkf/jgpXG9rE EBlgqRSBA6od
vPxuWDv2nihNPAozrIXbrataVyqhKmFOnYfdiY+DV59h9ZrQQlWMUYTmMdv+ X2CLXdyuVIqV
mXaPvaUMEeHTZ2Gzvu/3sJWy1zkLR3IQjAfp3HQs57E7J1n/KPu2pp7QA2zZ v5kbdniyT4HW
/VYLTzBwidpl6axDkwxM4aZBvdK6Q+1a5Gl1pNNH/JZM8rRKLIxy45kQgU3a h7mR0YisYpK9
nRQcvZq92a3GKOvkDvyUF5D9SjJJ3YfBa606fyFvjPSCOvrAXF1wrlURKlvp bYxJx9oNVwKI
Aw+t/Jr3piKTOX2quZB0hnnz4SdGo6hoWFLsnOO+rrwdt/m9DRDk01HbW37w nhtQ15OrSq79
lAw1tA3GlFlOm5hXdIjwhpU1n13e/A88F8p7+hk2AfAcrwZbCYti6EGJ4t9Z SMZy80N8h1hJ
PDgfPnFDlA9QdepGwB412wjoEJz780qzPJ6tORFDr/s8+MEiwcLXGb2eG+SP d38GGp+dwsa2
E9yDfwU89ewrH8/34RnLFvcMz/rB8mbR8kyjc0vnNWr0wqE9qM1DNgKPaqnx vHPy0afx6qKY
WIV7M1PILYD7eo2aroqVJsd5DdXGClq6tjjerGlrC+3desGWLl2MDyGk3xg+ A9WqOtlN9C9Z
L5BFmf8+QW3B+0BfQb8pDuItClHiysXy5DGJAhBPe6IBVfWOLYyOt61TQX0F rCxZcSoa1H6q
4J7nbGpeX+I47urxPqm/LeOM1PScBxfI2LFP+QgTw3t6RytW94rpqgPH0wUr ayXx5yib74O9
3P9S6MOtpnAydG1kur6ZFBsk1WXPIE0ggc8iFEZFAUwygS585CE3e+ltEU6g OjuQNpgPLgj9
I/8b2zM9g0juv1dWkTfQbqwnZ5P3ZTcQyFNdNDUQngXIQJu+L7bsnsBhnzWR Iq1Fkluf9j91
K8PKG5IX5OI6w73zOYQ+ztIutKmZQDG9T1kks67f0wF20tbM6v8R9dUsUQPa xFpm2Ac7H3iy
2Mze81CEqJO15zlJBqbFaGBQMUkcT1r4Bk3G9Buyv0B4gc0TCfI+H08/DPK4 TQL6dO0Srt8l
YMIv8GPU2gaW+TKGtcyTrQ3IiR0HCT7gzDp0zaA1bd1li4+cjKHNAAwzzCPX 9xgL1nBNcyBq
C/IF1i6Qy0VxRVjZtVhoVVugRSarob96IG51AZt5utRYQkfLcg/bCPzCZP8R 1lUKZW5kc3Ry
ZWFtCmVuZG9iagozOSAwIG9iago0ODU1CmVuZG9iago0MCAwIG9iago8PC9M YXN0Q2hhciA1
MAovQmFzZUZvbnQgL0ZPUktFVitDb3VyaWVyTmV3Ci9TdWJ0eXBlIC9UcnVl VHlwZQovV2lk
dGhzIFs2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAg NjAwIDYwMCA2
MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYw MCA2MDAgNjAw
IDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAg NjAwIDYwMCA2
MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwXQov Rm9udERlc2Ny
aXB0b3IgNDEgMCBSCi9FbmNvZGluZyA0MiAwIFIKL1R5cGUgL0ZvbnQKL0Zp cnN0Q2hhciAx
Cj4+CmVuZG9iago0MSAwIG9iago8PC9Gb250TmFtZSAvRk9SS0VWK0NvdXJp ZXJOZXcKL1N0
ZW1WIDg4Ci9Gb250RmlsZTIgNDMgMCBSCi9Bc2NlbnQgNjMzCi9GbGFncyA0 Ci9EZXNjZW50
IC0xODgKL0l0YWxpY0FuZ2xlIDAKL01pc3NpbmdXaWR0aCA2MDAKL0ZvbnRC Qm94IFswIC0x
ODggNTkzIDYzM10KL1R5cGUgL0ZvbnREZXNjcmlwdG9yCi9DYXBIZWlnaHQg NjMzCj4+CmVu
ZG9iago0NCAwIG9iago8PC9MYXN0Q2hhciAxOQovQmFzZUZvbnQgL1hHUUZE RytDb3VyaWVy
TmV3Ci9TdWJ0eXBlIC9UcnVlVHlwZQovV2lkdGhzIFs2MDAgNjAwIDYwMCA2 MDAgNjAwIDYw
MCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAw IDYwMCA2MDBd
Ci9Gb250RGVzY3JpcHRvciA0NSAwIFIKL0VuY29kaW5nIDQ2IDAgUgovVHlw ZSAvRm9udAov
Rmlyc3RDaGFyIDEKPj4KZW5kb2JqCjQ1IDAgb2JqCjw8L0ZvbnROYW1lIC9Y R1FGREcrQ291
cmllck5ldwovU3RlbVYgOTEKL0ZvbnRGaWxlMiA0NyAwIFIKL0FzY2VudCA2 MzMKL0ZsYWdz
IDQKL0Rlc2NlbnQgLTIwOAovSXRhbGljQW5nbGUgMAovTWlzc2luZ1dpZHRo IDYwMAovRm9u
dEJCb3ggWy0xMCAtMjA4IDYxMyA2MzNdCi9UeXBlIC9Gb250RGVzY3JpcHRv cgovQ2FwSGVp
Z2h0IDYzMwo+PgplbmRvYmoKNDggMCBvYmoKPDwvTGFzdENoYXIgMjQKL0Jh c2VGb250IC9H
TVRYU1UrQ291cmllck5ldwovU3VidHlwZSAvVHJ1ZVR5cGUKL1dpZHRocyBb NjAwIDYwMCA2
IDYwMCA2MDAgNjAwIDYwMCA2MDAgNjAwIDYwMCA2MDBdCi9Gb250RGVzY3Jp cHRvciA0OSAw
IFIKL0VuY29kaW5nIDUwIDAgUgovVHlwZSAvRm9udAovRmlyc3RDaGFyIDEK Pj4KZW5kb2Jq
CjQ5IDAgb2JqCjw8L0ZvbnROYW1lIC9HTVRYU1UrQ291cmllck5ldwovU3Rl bVYgMTA1Ci9G
b250RmlsZTIgNTEgMCBSCi9Bc2NlbnQgNjMzCi9GbGFncyA0Ci9EZXNjZW50 IC0yNzMKL0l0
YWxpY0FuZ2xlIDAKL01pc3NpbmdXaWR0aCA2MDAKL0ZvbnRCQm94IFstNjcg LTI3MyA3MDIg
NjMzXQovVHlwZSAvRm9udERlc2NyaXB0b3IKL0NhcEhlaWdodCA2MzMKPj4K ZW5kb2JqCjUy
IDAgb2JqCjw8L1N1cHBsZW1lbnQgMAovT3JkZXJpbmcgKHKkXyML7Z71MGf4 S+rtKQovUmVn
aXN0cnkgKGSpXgIGKQo+PgplbmRvYmoKNTMgMCBvYmoKPDwvRGVzY2VuZGFu dEZvbnRzIFs1
NCAwIFJdCi9CYXNlRm9udCAvUUVFQk9DK1RUNTRBQjBFRDN0Q0lELVdpbkNo YXJTZXRGRkZG
LUgKL1N1YnR5cGUgL1R5cGUwCi9Ub1VuaWNvZGUgNTUgMCBSCi9FbmNvZGlu ZyAvSWRlbnRp
dHktSAovVHlwZSAvRm9udAo+PgplbmRvYmoKNTQgMCBvYmoKPDwvQmFzZUZv bnQgL1FFRUJP
QytUVDU0QUIwRUQzdENJRAovU3VidHlwZSAvQ0lERm9udFR5cGUyCi9DSURT eXN0ZW1JbmZv
IDUyIDAgUgovRFcgMTAwMAovRm9udERlc2NyaXB0b3IgNTYgMCBSCi9UeXBl IC9Gb250Cj4+
CmVuZG9iago1NiAwIG9iago8PC9Gb250TmFtZSAvUUVFQk9DK1RUNTRBQjBF RDN0Q0lECi9T
dGVtViAxNDkKL0ZvbnRGaWxlMiA1NyAwIFIKL0FzY2VudCA4NTkKL0ZsYWdz IDUKL0F2Z1dp
ZHRoIDEwMDAKL0Rlc2NlbnQgLTEzNgovSXRhbGljQW5nbGUgMAovQ0lEU2V0 IDU4IDAgUgov
TWlzc2luZ1dpZHRoIDEwMDAKL01heFdpZHRoIDEwMDAKL0ZvbnRCQm94IFsw IC0xMzYgMTAw
MCA4NTldCi9UeXBlIC9Gb250RGVzY3JpcHRvcgovQ2FwSGVpZ2h0IDg1OQo+ PgplbmRvYmoK
MzYgMCBvYmoKPDwvUjcgMTEgMCBSCj4+CmVuZG9iagozNyAwIG9iago8PC9S MzIgNTMgMCBS
Ci9SMjkgNDggMCBSCi9SMTYgMjggMCBSCi9SMjcgNDQgMCBSCi9SMTQgMjQg MCBSCi9SMjUg
NDAgMCBSCi9SOCAxMiAwIFIKL1IxMCAxNiAwIFIKPj4KZW5kb2JqCjYgMCBv YmoKPDwvUm90
YXRlIDAKL1BhcmVudCAyIDAgUgovUmVzb3VyY2VzIDw8L0V4dEdTdGF0ZSA1 OSAwIFIKL0Zv
bnQgNjAgMCBSCi9YT2JqZWN0IDYxIDAgUgovUHJvY1NldCBbL1BERiAvSW1h Z2VDIC9UZXh0
XQo+PgovTWVkaWFCb3ggWzAgMCA1OTUgODQyXQovQ29udGVudHMgNjIgMCBS Ci9UeXBlIC9Q
YWdlCj4+CmVuZG9iago2MiAwIG9iago8PC9GaWx0ZXIgL0ZsYXRlRGVjb2Rl Ci9MZW5ndGgg
MjAxOAo+PgpzdHJlYW0KuJy0MKk57nno5Dl55WenlAbRiwbV9LRjesiquvjk Iz+7QziWIItc
ay2E1a9JHde7fsmrGILPQRO/gjsEx96zNqGGt2n+IyTm2TcVL9QNW2lmcSdW Wxo4QyBDxM9a
ThRfOftUXNCXH714o/TYCXz8nVE2yA4zpw4r6YpStXnDA4ZuFXgSUGh1GwiI tBFa3wkFZEUU
ONcy/Fi1tCbKLSUA/FkRVKfhYNRgp6Kwr5rekOiSYi60S3GlBSxgBImuEcUa rDR+aMmmByxq
V+ollI2nA+AzFBCCTzytBHjMwdUwZ81MSjXYM4IEWmUGfMiDsjgv4vcZodWQ RBadS3UFrpcR
VC1bH7vJXxOWWsfmG8lXWdv/+EUYawHVHaWvOgs8qj87AXh1NXV42b+PSSzS 7ryuTrtWjDTP
TNQe6JEEl0dcExrhoVv25FVqXWKq78bv5sNFK1ERtVzX1kUdehkJjEyn2dbM iyrLCSEq6Sta
qfaBqBtsqMQ1gV1E0W2lb8vaxa18e/CS+4EZZ6a9f+DZBqDfQ48sont96tQc RjavWZyIDP46
SkI6wDVgYLaIfEUzVV1zMjWa64E0cp/nFPltVGHQeohqYgF/XgM3M75EtmF8 LEMETNGWQk19
9zEpFbrLypx4Tq8qm8WVH3hJzhd1F91DrGASXYAS5pKK/LtFhYQaFdC/x2QA StlVvWyaQ46a
Wg7w7067rJVACsGvLfxApStUKPybCINvOJRsx5E71+uRiRm2TzIZP17DhXey ZcOAxht5bO5J
Dng+aDh7Z8xvtP7a7zLpUM1qIK71RpgV00N47Mq90FeH9IJL3hvimC+8v8bH BeVWChybKjX6
zNnFNhdbvuBtN9HQ3kPhH/CvT/m3y3NGvH5hFIBtbBa83mmGQePBLp5n86CH 7IokKO6der4u
cAasMt6zEensUuqbdoNt6EAmz64KPx1crf7DYo4CF7CpSbGK/E6oJI4spe25 VL+xkb6JVmQp
DyMSIozGSTg8AdfboncnssMdI32AZ3j1HD876IdoSkAtAMEfPw56XJb2AJGI itOIldYIXxuE
VyTxdne8faJk7MnAxMTBu9CrgTPekhTvWpy1eH2eeMgyqi8/qZx7aINFiQzJ XFQa/7NI5rAj
rHSwlLZpKSUzup8J5T0KLgXKMuiGjKe4kGWt8Tobcy4swhet54qo7jbinq2U TnfehcerAE1/
bLUOyVD1QEFSmFB0IKMmU4PH3vY5VF99RD39FxoUmOCf8auZxwNA/9zeXKut foPb70wx2LG3
A56WQcoJ3CQPnLef+vnS8KxzCOxRtwUSG11ed+GfnYltrXjFsJNqvrpKL3yX AKTduxlI99FV
GwIWUDFU6PAgRgTRw1w7gfASh9xiQyhiiBtANVTP6iyeAhat0jAiggyL4bsh o5HDLall9fhl
cM9exxY52OwpQFQOQxBHCvEau4PavHXozP456Ql7cin61vERrJ6x83YbjVzU p0nyw/dhKk0K
wljn3rQRNtZ9I2iYChq4sw7gSQ/wtjXfl2Xl5z9Fmey/25SKQGs2mSRbbosN 8B0meyi0ubA2
M+VEv6N7q4ROmQm2FxmiIiui/e3qAUzlMAbK73G8cRaFijSOd9EP3uAuhhXs wtp7tJcUWXrL
FnuiIn/paUqIyatRrpxdvK8ZbWS9h4YNZlMUj187A7+teEvydpHHeFRQJDTI vpy9jA3ooyPE
dtBIJWZXXwo35Y5MFkcArIbd5eAHEHDGMoalK2JUOYDHwtiPIXKD6W4TaS6W YKF5RQkv/E1O
uRS8ukuIqfxW993Mbp9K97jZspNK0LUhsQRxTEBBCt2XJ/3tpkV5d5M41qfD G/WKxUnRT0rF
ZPXqeejcpKyQ/8ep1RCnVv+GUJuNqx2H/4112STfeXodX/M8cof79NDM0eZL rb4xV3kZ5ty0
R/duQmgbr4p8PiHyS8GG//s32NeKoovdtC7QXb8h7a22880CUSrRne8Spg/N +cda1/fdvHkW
UCa7Zm6QtKNFI0myqukWT0zmisYAyAs2+v6dO5TYuUjjx/rsebjcHTrST2sj QWmf9l7cyRzH
MZRCLw2sNxRxiPosYeEZmmjbhtaSTvLIxmyjo5TphXgcX5cI/6DqeYiaIJP1 0Fh5kd+Reh+D
wQHJLLB5DwjuBHvgDpHCOyjzFyIAMn2srdVZhP8elip8ovjR0NfIwW9cCG5O rGvMExJpoiJq
X5tC25kr8UPib2OsKrhwonyWisCso4cYs7RGnkEPz+Xa4cmSWPr/DnaJRQ+t K7Pur67IvRnR
M3T9NChzVsVN5BYVLtYPKie7dSwE+2duoGVtlAqGyLrQUvqiPnnzs9IsGftD sMI0UcSsLpxL
sqKpBr32VJxP5X3Ec1OMaOR8mUt8C11OXGDDFewGifyixoZD9EvkeEgpODLk J9KbqLdRbGXM
t43OiK/qRagEgr7efxSB/HyeFcsIpIIo0SfJUTPB8+UfI18Ca/qfHSSLGlRl yI8zaHP9xiCZ
F92Mg2385xnCgxUigyjrf8AqYRzSXHQdaVodD25NCUkoXQXbQEmMDHPFF31k BXxB1OttIvFV
qdEFd1g2w6zRJPmH6GIilRrwU36lJ4xYG9vRD0tDg1ui8Krxsnv2W+ekn5ce aJjPKhtJZaWz
/dbA2vCwfAv6EtkqpWuKlK7OXawUcbHkxTiKh74nQfEpxjEKZW5kc3RyZWFt CmVuZG9iago2
MyAwIG9iagoyMDE4CmVuZG9iago2NCAwIG9iago8PC9Db2xvclNwYWNlIC9E ZXZpY2VSR0IK
L1N1YnR5cGUgL0ltYWdlCi9GaWx0ZXIgL0ZsYXRlRGVjb2RlCi9EZWNvZGVQ YXJtcyA8PC9D
b2xvcnMgMwovQ29sdW1ucyA3NjkKL1ByZWRpY3RvciAxNQo+PgovTGVuZ3Ro IDEwOTE0Nwov
V2lkdGggNzY5Ci9IZWlnaHQgNTA2Ci9CaXRzUGVyQ29tcG9uZW50IDgKPj4K c3RyZWFtChtj
eotKrxhWAShOWe5vM7s0vXZi3ncKXUiXPMheN0e9xUOpOwSy2E93eY5afs3+ BJiGvPPgrVBT
CfjkNUmmA3xDM+p3KIV5TBJ4Ju8BySYgdGvsAeP9M+VtS51RCPHH0mp54z1F BV8J/LlwimQe
5SdHiaog+dc7JFa75RqYGDLhPzRyJ4MmS0cL6W9A1G2OIh95vC7vZ/Q2TSO7 xtC3UuDMEgIh
sJ3r9CA6VWMuV2ipRzwEWJnERVg+gEEojAVstouEVRkiVTh/e8g765Ei8oJt sYWA2QrXgRy9
BQ5uGqY3jYPjLnI3Y9KIRlztxVm4jKMFyx4XejSJ9gEO181ZFsF5BM9HBGQp hgdnGmOs5T8V
8XyVh5xbzD09AxxJntVkhcnW4hTqj5OkRIe3mjZK0t6W2GgsddC9E9hBsvhS bUBaF6c8RMVv
BzB698YNwPldLpIlg4ynSs5dIr6iKTwXlU8La12f3ikUC2E9p2NEfLntLuIO xbPXjQqR3g9V
1PmR/kAxv2L/SNM6IApcX0rRsQwDFzr2t/he34uYmx9x+4isxwQtLiOH1a80 gLzSXToyJxfB
RIp+TM7Rksep09GDP6hIaPk3MuQBoRo9ZcF3Pof7V371fBK7iCTXLWq74SyJ qHlv0Yr9Idoc
Jsx66KX8tLOk0Fi3GyBfU/VRd5+EafbCF1miQ8ixmPC5J4wLtXv+Lpkq5Td8 tZGUWd+EXkJt
N66hVxNstUt6XAxPHBxSSpmsGDVJe56etrpE/nUhVp53FzkS/dKxJxgpHDe5 nsUOSZldcBEe
w1QTciZuIYSGLJmB21x8i1vczqwlLKYFbGT9a1gWaju+0UVf/e27pYAOvkm7 K6iKnuhUBAyB
sl7zZBpzUGeJzQ2b0yInP1IUEoooUMDEOzre+ibp5Rnb59QiPTt6faI1DUo7 cUWiwfDEG1ww
p1XijtaDDqUCbIgTIf79KqivsKhZoKmvmD6VrLL3yRLPBOtu2rY+W2ytGvwG 6VZVUhEdNix9
q3sEBscjhAVjtP9+PQ88dIcxoajHa3gLAZ32RDvnVamVVOb9oGiqhlA4YFJv Y0QEJAvulULc
Wn4UVfo5gexDGVAqv/WqVJ0f5HQnPA12zUX/xRqPMQh1gqFZDQ2gXMAKBxr/ ejKWQTtIAbxy
aqbMY7R1K+BIp/I4P5ODsNPGumgOMqtmeMf6YHC4yshRAqtxUzx1D9jhqKDr /ZmGXKBQ4o2W
SB2P8xdu2wvKQOWBOCm1QaYgm00yOrFqEOY9Ij0roQzCN52HTRpXDl+FVFp0 BmPRQ7HMB3/5
aW9SJDMjasDjOF6KUJAQ244ZHa8rYUy+NB9n3iIO82BnVv9roet8E/PoAONe 1DKlB9muNucY
GidxMkwdUetE1+BcLX1VPIATeq7XRb9UnBGg6BRKKj8hX4Gndrz690LZ5Z5L LE+cpu0kRZ9L
7EEmqeRDNYyKoSbuiDfd6/Goxhjp46ZZ85NoPL9m8y9ISp/A8KJ3L3YlQAp7 n1q8e1Og349R
U6GNx8uBjvLnXnjBxUwwLIkI56KEVUbwOI9hCcCAzVKbsMGeb44Tvhw91KJN h4fFnadV9klO
ipLUcc71mamx4Sl7pjSH0huAS6KW3ZcoqitwvskvkqI1XQsiAih/gLGas+YP I4xsOY3ilSO4
H1zEu6QQfQbee3SAEJvRsMaSn+pNtZqs0k9qQPiENh/90AwzXES5vve60SSQ d5uOnmZE8rgL
zsblsGMvVG+51bnmd0feExtebqqlBvsOGpMpnpufqUd4UqGHz2KK0geGzaem aOhzYugv57n7
gqzGC1U+598FgU6mN2qMK3AgwkF7WE138CjaR6EihuSRcvnGw7hq/81O6xBD gcxH0I9BiROG
Hdzqug1oiiUmZAEPOGtaeq+o1h0/qtxPN3SnhaMKnFECuEM02Dg9RRteadiL 9h66QFHQblCS
yuEUNwdZsoIrltEFx5xr3dNvHQaOu8gsK/Pf1pfGwHQoGEAlCPDJErhTQEHc NSc5Rwm6xWM7
8vFTJAt+/Qi807LERi/v63eMUEDScuphhCfLoslwB3Sd9S3hj6Tu2fwqxtDF A4lEbHfi8N3z
aTxQLp+BO07w4hHD8xdhKKGkG750o+WABkigKgIALvCbuNW9LlAQTagklfS9 s6D5C2X0WN6N
mOzve+AQRnAsuD8ywz/5L+hRIqKsmEqOFcTAvNieAJ3rK3xMK3dTYxOz5Hw5 XPUqyNZnSc44
lOAacBXPPEywWPGoBmlHMtLHaaDRAdunZBvGsg0ktou9apPwbfhuFp5kihk2 fMt4t/5m8MyS
Qy1o74SWRLfDvpQJ0KKXkW/VyeQGE0oXKqiSymOUZ4eItBi9BKidV94Ep1ff vWfOXQmbxs96
psNvv6gfrLopWlU2L39T6vToeQ9b71itWccba0rneGWrTIe9IKBKRQEeBtbX /dvZJBZygQVR
Ix9T/l6H4r05Vn+XLH9u7eZ+OtkQqm8ACqi1buQ5O/I0Y9TUZC9daMNasMPU vy9SeJXihP43
t9g/V2mCn52NzHcmjcMnEemoQGLEBKL5Hnvm/q/hw8KVxoA8m7u9eIq0AuNF 8ijDwsjXSyCK
EPD0dMSa2zsJH25WeRhx3c/W3K6ITynlLaV1X6Juib91XrTUPClEzMPZZHTU odYS1R2jw/L1
2Ic0ihyh21OZFpVhtd3xyekcdr04kf3RWpHY56yfe6Uw/Xb5CmkpqGeRi1Jk LT4FnNdV3Swo
KyWL1cAhjabqXIcGZeOAoX/fPmWIbx/4pjgLv6tPajjNCel8rpbSA58SkeTZ VYsMh19BjYU7
isAMePSVInpVSLgn5DBxtMO+ErJwK4WTwxY5qI2v2KHq2PuKsrF9+R7CUlK6 OGTReT+yxT1D
Np8UDm7tUHZleT3uw7VoDzCt9D7lMAQzB0dAslfzacb5Y2aubTvRGwxoP9Tt HMNJfcebFSqP
LcJM2CWYvsmWCfgy/ETV8IlKqO7JzUmHd5hotR5nJR0oRdBACBninfjzXVjI OQrvtulFTBX+
HFhRtGXHbAyfW+fwn6Xlikk1MwJVL0lKxudI7B00PYCycLS4olxbpZTVUcmZ urEYcxpOE6WT
yqAKQ5J9EeOtsvrkK/EYSUSN7tWGSZEGUrcd9MXPTldFp9YWrsVwbD0jel7B HPS4npwWfO4d
Ey0qhDI1dtlt6O3dwiTR1QDIhyVKcoMqWeC5mTqw/gopNJFhbtpDCrYU7ZHp y2wDW2Vaka3L
5qd/bq4MjgxGgpOUloJEqUZmZ9bdTKB5pjUbXvf9JpDOkmzvK65MWBGoJg+E CtQfikS/kQXs
RkLmgkE8r36CoCd0YPR04J/sad+U03briQQBnDxjX2fcJXFmwjxsAzITzEGO Jx7ToDHKOqhB
TfYf88xAf99wBnj7S6HyuiyKxG5emfjbRMSeayQVFVKVdlllH480jCtDhEbn 14EqjaAWlDkZ
KIlBPMWaNV75FH2vMML88j2Cu3R4a0ZxmgliGDEH4iMtCMkQ+328uzhv/Hvp Y+br2RKK58Su
P3AMSQsTd6t5hI2z4f2O1uIBdnb8R8rT1U2jao7CQM1cY/5MC9v6KEJo+J4e 95SKGYiWoJke
iCkFGJ+De6+HU1PdAywYiViIvfiMuGJWav4jH8WjNWqr5Dn2L689qDvWGLpe pE0sjvVbBlxF
SBFDZN4WuvKj8lfJrCJWgYzi/IoJr2ju1t/nOs2jcWdf1LaJw4+v0KXnXOO/ 2yD6Va/PVTP1
aliOAvpXnCjRnBDqX4WXXtOS+to4dW8p3qQNkkkLPtwi29d2NP37TfkyRWu2 EB+LlzkLQnfj
d9ponwam+06xncmQqoH4eUniT1B5IJQww+snlBfLIz0YqPsZGKKRN20KDbLa JZrkOrrykfJs
jdLrDnDyjMhfsjODQnBI11DbR9DEHW8Ap78Ubt+fdRdJng+i9OoVt52w3ZKV BPLPjYnjOy30
rQ1e8ggvuRAm+Sm9HRLaVcVhWWRb4WZmSZLoQT30AFAfcYxn+B29C6MVUm8o oLh5TzeAXdDB
VwrdFPILsByfhQtimU5IXxChyZL679XZxlbjrON9dcVeu35mg7aeC3MNjv0i ykvUuHod6bEH
+yQn4++pduu9SA9sCHp9Y06dgoJr9YPkHufKux1/m9PRKScI/aP7mQ/zAAgx 060xMlQbQUcp
0ZYbF4ONbLQs+JYu7+8a24/uCP/6jB6gRgLgKed95ELQS+RRtk64y3bBMfZ7 j8/45X9xaZCh
P2VIofv9+g7ejsX1VTU8glyUWFSrNp+N6JUUkWgiGcx4PJeS3fPv8jb8jkXP iLGGlAbV0pR4
QDkUqN1VeBjLgE5zBJGwwtbaKSDdt/uiHrosklyqgk7yDVOBTkou2V0nbAsl iaISADA9SCtC
6w/4Ni58rdy/Pqle/cpFg8KNAnW4FGCrXf5EssWklLJ5RfRBhCOdGXYllTEd b6FnZlBIPPba
Y6aLF4DZYj8saEueG++VSNZXIFQAYIz84HH92WHodbkTOHfz4zZgH9l8ECIM LxkC5EvkXt/M
TwJ+7yYWHNYRjGa33zUWT6QaqP30vriB2SAn/AryOqnXC2y5bqyGprO/LNT+ 0aFA1k5Ixt0j
TFGsEpgqv4fm51cLnTUhOANcTqlvDGBF7t9fQIoMTTq7CNxsuAWtMHgxkPsB DmXzn/1F2lFk
Mb1K7yayvolZ/XD/nXIIMyspBiWEOwNUC6cd5F9CxNQjdYzKHDaQEhn2NPx+ 0mKv2sAR0VAd
H9VAktM1nWYPOOk6356+Gd87n5vNp+39rp6eWh2OXkNY7ySfkC/Y+2dYsmzs HUmt7W+czOWd
cT3JDDD5SLfthj+A0V8oPU+C5kyAAV2CeWoCMdebuUBT+OJRWK/ZUloqGr// ohAy/nIKN5WU
s/CF0z2Jr/S59lgVhj7nUak+z2gp+4r5FGp8jkb0MU5AC4ERQVphfnyixbO1 vV7p20NCY6/O
kvBYT49OFpD0FrwRM5NpTE7+dHxJW4um0oN/1ooANqc9V8Dduuh6YqoQ5MoV BjbikOvd/DdD
F83LUc1mCzq1ME4qPWLuXw/i8ghCbHmY67RoutYZQjveejUbTO6XsmQklcvA z/SuUoxxVS/R
t8yCAits2vzKsn78k1ROJ46o9AWiGFeicpab10iMrnzoB8C/4fRwHCHJ5r9o gstSRKZUZQZI
TQqt+94NCH2U2ZIX+5IsNPei1FpBzbrjCY+Mttt9+p2tvYC8WdUXs7Kb6Gyz SaTzhiSg5yPi
nFoCM9oOCsxz5Cpnny9F8sdwCjctLfpvr1Vvr+WYc8RPzj0wZLrivJj3gCKk ZzlFbu6xWoD3
569jDXP1YRy5mZDxGZ7CaJJ+qrPU/3lJuPqwrg6wKtL/Tart2EhEFNWLXRB+ TNramMWn0Tnk
x1yolnUJy2v94oHPHjMewVDJVvXRHjl/TR9Yc+KP/Bah4nlpu1X44WU1Sxrx dkO9Cfg/se+X
ZCUOVSaFRp+CrFSikYMDSzwsle0y9d8l1PlTVcKgMTyAD7ckh7zYp34K6+pu 9wj0proSKHEK
UWgUhCkplitJqirhtg+d0NpJ9he+Mo4G2TGJHyIkRpEuRYnxfal/0xcyHGhF mnVG2puzgPFy
OlUo1Qi+ZrL8i1raFtkud59KaI64x7tzFxC104QnDeMV+8fNzzUXK770Xkpu JJ5vXUbyWznK
lpGHk2iQIEahOye1Ch6O3wBHx4ZqzkvV0BHl14oFqRsio4IDq8zKjJ9FFE3F 9ddEBsxJ3YvW
ZWZm00X7v6ksLsXRkEJUt1xmOrMVAo3ubT5BaSP8EgarCMayjRMYqRTP956U 3ZK2sms1W3zX
eUBAf20Nh1eYX3BgSsJ1Y3waodDAYZaneb5X8FLrxC615fhg3ImVpUfb1354 Tr8H5/DEj6zr
czag95Gd6UBiQlLp7kxC0fmLpS6aTg8mjdcXfHBmJsBuKeeO+5+wVzhiIye1 DlcZCtyOuRJF
If6gZc14B8npge7o0XT7ImOYbhCuDQ/KRw6CJ8tZUpxMcjFc5yHE3N4JhO1c EtqqGFSD79Xf
gqBFFdbqLyEsz+cTORPFL+v9YL0qAlO5daiLXcIXJtnxe0V/8XsyXVa3WnkZ 2HiKCUVBqS5G
MRh2y2QE3WtsQ7J4ReoA9LcnQNTpAexB0SJRgefAKjgNFjP4P0eYBa1TKBeM ew+o1QfBnuGA
IIh0tLYFJECadcanmGjVNl2AKZKdZozt76GMvF7akmWhiH/BsKRu6ulU2dJz wf3kaH+oewzG
Qq8oYRhEXDb6aKWIGTHJaZlGQnYDJNpWoTcw1hH/l9uUKgbvSsop7pbSK4oz oIMmtczZcBAv
HFPIVemRY9CWfdyIaAUK2qhepCO2HRgQmZT3mxBnifXpehsxsuw5QMwYSBCB 2c4bnAL8TI6F
4IzlT4WcU5CnbOuC1Yv+PR5q1g4ZyD4VaIbN9QtZLKI/8tH5gFQi9dVSzlaC o1g8OV2/NJEb
q6rUs3COrmj3VUPBnlk9Hz9f3guThL8NULHY9Cw2t7x4D7fYSl9glKoi7FJ3 FHAGZSGS5wUv
NE9ZkzwJYCjZTYKtmGiWP0eYNT1//e2Zw/MKQvmSfMolY8JqWuB5smyAD63c DxD40ZD3l+NI
oWAcG31rbl2EVlEVnjXNgkYBANKczgbNFYFcXPmr9f2OWBJPZMPm7uFs9tTS 0iwfvMp365Rd
if40PjqYB1FvrwMj3CHU5cIAu/I8eFKjIbA0/g5EZ4vCGziBhMd21fZILINB CjKVxy0A9lQU
CCitlv7M+9OVIrd1aXyHn4zB0vA3NHaLzbILZNukPbPEShKJ2+Rofrme4l3v 7GbbCo8tSe1P
0Hf+Izg0HCkvMp6uSDTyK/5JEFTatkW4GcjsRgmaJ+liK6J/7dhhAZCSVzMm WpQ2a1ZNUMQq
ZSg+cWpDaIlT99Yaa4FFfGg6xhVEvPN0sWJGlQj6SvpbkjjXd04d3TNAWcdf vp0JHM4uVnm+
D8jqEDgaKYUgDG8t/KuSrs+rGv1W+n5npvdYjxcS/ew/c/q+9G14O7v7dWg/ iCFAM8dBzW1n
kzV/sO3AbIjhHSnRPuRt3Yk5DBPsrDlSTUcB9USuAHh9kh95AIHpLudrjkHe 4svAtt0xPQ6z
6yIU20xglyvXIk2GOlJdaxyxH2f5jDq6OrD9rQTDKAnrnkULg11z45CC0EUj QvPjmqSXBXsU
ZRQ1vUwPMhurjTlDm14F3jCU1XU72+RuQ4G8lFnTrM3uei1UNt0kqQLmaJ8r CtQSQ3+yycLp
W/bQyeic3279P2eKt1zxtMnCxX6dZFip4l84BKsRX2AZD0bZPTrAvo558lWB obPdl4essYcd
re6DsoSOCOlivzrBFeROAGdvFVu0nQqjLGSQY9ryWGCDE5cWeShN+NHyc4qd C3ReKKqHxyUD
sxfS49Px4SsNYtRBo7YLA0FZjLiuR7y0AT73UEiPeN/9xh+u/n+lymW9SlYv NOzX+ITVNdcE
Q802t6UU0V5TtB3DAya14BmI/6DgFiz9M6j9uBhzxz6NQmkcogZSyFc1Dpe3 YjR9LvEYXg+r
sDmADPO/wjsMVcAb0OJt7r5hD9oKAff7zF5jPPHy4CzZB7t9kPsl4rT0qEUo l7r9zEKHmUq8
fb32l7aX9C1xDQnW4Lhd49IZqMN/JtNP1Rw41f0MMaTgvjy3uuuknfhZ6fCF DQmBEvFlZWQB
mj5u5ryFidV87aLi7jXTNWjbF7mFUstDaVdBHae1R5P8nTFd5OsciWxehMn3 6BwFT/RDr+3t
V0D6jQCRfIWvsO+1Mn/KcZwbY78PiDSLVc6N5HjLlSkDAQH1qEXJyskJLWP2 2GKVA7IDxwip
uVbDBtZs8a3Ic8FB1G5Q0wntxeux2UIqdf5nI+z7uFhQY9JXWHcqMZ/wND9n AcJcg2BmTI/B
+hwK9s2KYY7bMipvjT9owAipJ7YZ3Sl4UK/M2CFqy/VYVVnp0MEzoIAbY8Uo V8S0LuhSpiEq
Ddj065Q31qoaaPIWkjzjLcXl/H58Cc3HArR91Nw2VNwg0bv0gC9BrqJtgC8/ OlK1+CQ+AdLq
F3RJElx6LbOKzdkStF558IAgBoXF+LYAJzz5nVoQ/3FVSJX8hSF652Y7VCaf jCNr/W+d/62x
A/nYf/CWC8l7BtD+hIAqgfmd1GuRIXCbnKazNgYt/zLc67fcvu4yT5tCPq0X TgDTn1iWcsp3
fsSst209AVTToKGg6vbNgGNE8U4jDK1d2dSclRaLBdYGvmHyLB0N0KFfyJL8 MI/l+389sC5p
ORFotxt9Rz4+7XlNAd7nyOHjDBeroPz4fytX39S8ZN7SwTYZBd/5ebJNSuy2 QRD2H3Qb6Qi7
rdlBTyPkek5F43jChclgAwfgQmENeOY83Q/Uo8f68Pmtp2GSVXmG110W8NQ8 EohOX6nlcg1T
AjddrSVhFP8PcHq+vikqQ7cPtnsi7qfUZ6uGguOHCwVlAvAIJJuXVTkWnpEs 0iOoT4fYz8k1
Ej/desqfc6kFMszmFCZ2qHIN9zL0vI+EEYYHWizuCvB0u5kM6BEfClyigjLk Ka31XFG9rdWh
R+KYEiRxKGxQWaKIh3EK6Zrjf4lcjD2IfL9dJxzPH+NpyYXO5yz7GZ5R7GK/ //vmnBjBThhu
BBmDI1w2PM1oquSxsueKISEbOuShXKm4EgFSglBiQubuqNLBpYQb33dnmGgQ 2Dy2hvL0qguB
uqLS1ZhUL/gD7/VTCnBi9JlcSZl3qyRybyMr0jpV7x0fgF6IDUjx4tiN25vL bHzs2cEcpegT
QwHna16DEHupla43OxfeMEoVJXJmNgFS/p0DWf9boA7/W9M8FEtQN4ZTxaY8 AXdznAnxI00M
FGduwCAXZesBqWGxAO/cdtoxee8gHlmefqgKSF22d5pyoiNzperdOSBYFYFV njud6Axq3Nul
hOghHKRfw7cBfa80ljlhgsBSqE7zCa0HTllucnCxgXIjOQkJjsogjHw+Z9BS bGBd5zd9WqYh
PZr9lomg3sZ7KGoM529VoaL+3OYrCd7nAb8arXLy7kJNFgIyvfWZ2xX9C9wE uktDCEOeFYJz
N8rp6GOpKJ6H7YaRWcoQk7m1eTntT2j0qPB9F7DTJUtrlmYh7rtnvjCtqTh6 hCDgh/jPsdUy
45S4RW7Ug7PTWZCrmaV4usAsjKTf6v84MHne3DUBaNOyjg22CgWtK6a2kJue W2OoW50WMzpY
QYkIJFdjZM+AAMPkAlL3ObfZuG46YoF8txlC64rr7BbXX7M4Aehz4MC3Yl6M Jez0gNt6DxAx
zmqa9gK6JLLBL8mUfz7XIF/yTk6gSi5HQIH7ze6/MxMxwQrzluo3mr3S24om bhWpRcGYZoJv
mM8ryEgCeyqKE1CNoxhI/P+37yrp35r+HVqPwlMKnG/oc07hLCqgwlQdikTY JC0r/vSseBqd
OZbe4lSPcAfw08Erhe/2gKhX2dJtxFqqltdZslYTRfKn2oxBV5gOvgdgObhl uwtW8hdToHRX
Q8vP3C37xCEbkMhIDjqYO9PULqpTKM7RP7hp5NdBGl4o+aOM/jzEw911yZ8q 1TQyO13i63dp
ykInzA4VK2RGzQkCwbKDFdHCuZpd/NnSkBoY6Xa19dSejSa8we1X4XH1KvlL XjBmN+i3WRMy
LksGbcpe7g55UhB8dTy/vCTks0tmcFgDjp+zCvlKkdqXHUXOgnmDwA960cMi eQeFhwyebcYw
K/W1i/k3p3v9jssBggMdO0a6wznpgaPKyW4obO5GzhzWJQnapJQtnhWsO1sl /WqhzlfrI2Qk
PClzg+q662oisAsNFyEfGAFbcX+RsmLXQtc5XofprKc/BiG+RQIeemVNmNH4 Qe9gXgvHufrR
OeWg9Mpen3eMRB1qnWFhYfkDYQANiaC7VGtxMsLwIR/bqbYv7gPgcI4xy9dD tqq3rO5ZMY6P
wNJovGELLfEftuHIUlHA3V9EMlSU9vToXOfbPrlq71iEkd+rv2U6+Q2N3bJM J09ZqF+7TCEM
HibUg4sr1eM0INpYHTJOPx7HSVqoamquPdCkIphFjaFB63RT64z2Bvur/xN1 KZPyPLdOlqOn
AQUyF0sXc49uVT7wYNn2IzomajNVfB0UlWs1cO5Z+yKFoDwk3zU8VgRsWGgZ MEVjpwgxSQrm
zoxnVNM8Bym0PveIRrRh452yAUrfqslvlrfLXqdFDRd5HkZOOFtL9nAO+Cn5 Gokp2W61hZFv
Ubs/Gim9Rc9ZXjnQDWeAd0ySpqyouEScKCpdLl9mF6FDo2Z0k7tNwFlz1gGR Kn9fs6b0Ra0j
BGTMeHiy3aO92QEnKZc2KI1FsXEVOMZ1FZsWdz3mrZPTLLGN0cIqVaVhiqKA 9p0fjCZacIJP
i+OLI0ITPnSBT0jhtlp4hGNFihrD9HgW6Sasjvuulw/YgY4a3s9+ZMjJP6dk njqViY32CxzV
Om1mlovp1/LO+dufdMiIOWMWeGc1WvAKMU7bqWX3lBcqnjh8S6BVdQbIp9W5 HzhS00/vm4U1
NFXJJolwbEaGjxvZUWL0rJRV2rxyPtyDEzV0WSz0tWV++WzjCJpY+2h3oBoA Tu18ZcUhbx3/
4RNMTtABVNbaxwIR0byOkKm1oXrJUPYmDfMHvYNLY2kWdX+WFMG9SZHlJKc8 k610UN+vFdP2
lMsznPnNh/dAO0OnOsXMxVotwK6IQxdhShhmsxgwS/lIhUWaJPiXT6L7FwVB 4rP7ilA8+jXq
aw1C3XtwhJ7MidVLI+H7Rl3IObvgcr0lVj4we3OnCWg1PfjSAl4gRr+3TBDY ojqhf+Fgv+a4
fe8OAPY922vxsjR3xY8qhHDLs+P/Afjw1ShTpGX5VcOXcNXYDVES7ujMZYls zAXmTE/0Rebq
VDn/iD3zp22YACy2aHaL6yil6OaX8ipZAgIffJ8+PfOIiI09Bjtwoms/VRUM j9KvlGecS0l5
ZZmOZ+0OutvBsMtyxRz/k4cPp/UE0+9UU3RqlqWdmy/R63SFmSUXjrArGup1 hZlQRpqt4V3B
ky0n8WDpnduKbQTNt4IgsLWp+WYTlCDDgfoVpeOC0kkmTwwMEEhmetTnfTZP p3mi98jg/bX3
eSted51DR+1hmpN3r1FfsNxQXY5qUQTe3tvc6kg9FpEuTyvDeDThdy3HsgwC OOMkrjuSsZCK
9NFwobK/c6Ee2H6rniJulVc7hszVFTw3GHAqKKSyyeEdt7AdmDAsn494C+US XjwghYuJcWKa
cbuggDPZ1u/vIeeWTUyKjoRCgd/cEgZmL3kDHu+yNPrDFjdLIWcHIN3mHH8A XyxQWffkXuDx
7l/kHNJr56i29raHGMSQ2bQKdZIJPkDDN/B6PfV2cqTgBs8RdPzl4JDggNCx IIREGERwYDgj
w3GcVgbe7H12L0dhjPTZYcki8ajDAcEs63LnwECwTyyuOhMKvwrSIYRaE7xC JfYY5QYbfdd/
g2r2W/zIsXWvdnjUkKdXQo8NCTcWGsbXszwXteuNZCDeja4tEnMARBsqBfXn S71MrzdqB7Ql
uQxfqMtHAcfSYNZ4OqvNFH9YgB5NILdGKKdEm9XajA7bsq0M+34h73YKIFTv /Hp+V1tRXWZB
OESRctXi5HNKCKwmdqCGRfZQQTv8wFnzri0//cZrKixt5AVUzw5+9kBHpdd/ QTZG2S4rEVcM
neYyqTiAmTt136n18yC6yoXJXaF1FQjfKF0vRqAijBGhKIQB17LNCZsgCr+m MBik4lwTSLMs
b3iRe66F7eEG3bgYNNqZ5KnlpRwyaqfm5UNvmUMFB0dj0J6BAKdog8s/g3L/ eqtCXgjrCqOf
uA9PoMai6OWT5r4BXJRPHy83pDWWThu7dSGYaHrRa2XkCrBSjXudLVN+FpWX 2KcLYTbf7495
H4ZEP7IIkEssVQJFCMrgi+uVI/dVQ6T4My5Qm1mQu1YdqhdqimlK1Fv5C/f3 wROG11NZ4pol
0qjUMHmrWviqybnIgpCdNflT9ViG4d21kqSEwc5NLkCCE30CN78bI33PUBDN JmS7mfqypXWs
k6efgh8n3u9yViApiUeQaEDgfnOIzpdB0uciRyIswLDydXjUCkzgCeSUqXZy I6H/QpJ2gdRV
XRaaFEqRfaykPxwKdH7+SNMexqE9IMowZ6bITWUkO/+4ZUQPZyizFvJQrtRz +W1+90nnuaql
E4106U+qgutmx+fR032dqh72K1LNAJ3NjyHhmWSLHhNfjVZf5+u9zfwesdbc xxI5WvrC6ZNO
ToMttQtJFMnPAPDoiNLLiuBN6EmSZemVk81d62mqyOi0pGhKki9PRZVTwkz9 qi7NPCd3xFhK
hzemW90QOmufvWh8BSth1GQuNNs3+d0GPiRFsKq+5Zy0rJTpScZ3acNsZa85 ShKaJg0g5lZe
kQszRGzD3T21cLdXmQSBnUGngBjNJudp6KFGpbJmUjyCzQbHUgHsNYHKKGgc yfcRT0gfmr7T
uuf0t4liGTvr7evLtz35RkY16uPEZnO/fS8b7Uq1fyHLpWiyPO5k+4xWobxE iCGxQ/fyBQTA
F29ZVA+C8ZPCfkf/he0v0CtbSqp9J/rL7jmKgZdjr01rgeLfwu3T+SJ0xaEq nca/rJPc6uMY
dlOEifVxxpz9rlRqeMdhy/y2DZxQY7qZss80p+AtZCK37VVvmeXM1iqTxdNY FFIBX3l/7nob
+YmG8BpLAoMDEJjLFGesO3+UCqZguUF8u6UjUIzPs047gywdeSx6DrJnyEFo iaoj1Kh/21jx
JprwFCgl4CZZ29mPHZqZogR+1jEW7K0BiNfHA6HIFkE7zPVzj3iBY7vfCLNA +SEVlR1FUOzg
01o5x8j3Kupxx4TZZ31TIOyt8xu2L+L5K544P/HPC2RoQ8U/O+oMGCjBE1IY tUyYAmedSXOK
LadiQh9t4S3R7z019+V+1PX+CMtnCRL7yC/OjzAM+EUPzSv/Jj4EWaMdB2JL gqwEfOvdUrXl
yLjhoZkYtKfw9sPRBOYfnp1SdFL0siEjSXbaeT6kl0Q01FLx8+TalKFgDGdT DpS5tWrZB/38
v81k9Md7U5Q612VS5s4ob1K1JAwtRBBoMriwF4f2O1jde4R9bWsVNWxZ1F8o 6Ei1hQIz+VjE
ANWItVEKu51gL4M8WYJnMXZCrp9CkHOf2Xbos7z0kgaq8M2rP10Oxs1l0tCZ g7qqSaJBGjwj
wH8by625Jo03fRnI1xuRkzcvy1LpVdlP+T7mpkXixOBVj6DoCN5EeW2hUNtr OnP3OwdN9ezR
IHFx0NjCuvqZWm6HYHDOkj04Y1ZAwSA701NZZmM8HzjZlepDb2rCUvUtdVCB LidB4VzxVBNd
qHlJJ/s1ddS0f/MX/OnZTwN3DTcSMN1JTPF6qL8NFasyFYXQqHWSwG2QtI+y d91o6Q3aqQh1
3NI534l3EVvOhxuEd2bRayU/Y94cTsU+L/2acbYhsDcPWzaDaH9bIACcS0QR wH0dUegjpQED
IZH8LpkCWhTBF6mlcS7/yZDKO4ALgtJ7nsVgFwThOcndNHeBLzIyZbROdvb5 JjOvdMXOZWox
s/aIuHkW+xxblYZ9XfpXg88/susHWPYOxRcibtXPA3oRHU3jNPBdiStOLBce K7dJQX2DSAC4
egUjZwwNR8g2KXZCyKWt3HJMN2rvAfkJwwaFHAzsFhwCqo59YuD0bnsem8Af Ycvf9S/lZk9A
dtoTGPl8zBycIIeHOXkEwSU/oD941vz/qFJWNjztSSyA+mqgr3Y+VI07x7je nBr1lX66ouAf
FwNQHuDaLw2zMtdSagW1rxOUt7VfWEooq56yMVSuVtgVq9AObKV3LAnGOdQ+ ZaD9UEqMNvyv
2WBP393SOqdYZNx4RgrRkVMSKr8pujUqWWRyIht3tsHBkjcDLBHmTaKwyyxT CEagKKjFrAJv
KbvHULz5zoDDoOeYZTPq+CyAr051JKqJhmmEWErP39rZE9GUHcux+wjp7B2E l0dpPUS1ll63
09njHkWNcj5QLA14TlE11X3BSCf/wGBNIwFa2ki6av33Py5FrpS4CvNRIEsO zU/0/hJ4dqJ7
e9s7uz+9BAfuQwlWHc040JLn52yPUftt7OSRPGRXGNT7KGsgKktdJ4xiCHAz hV2mcvonEwQq
sTF6/6asBX9P0IjyQDye+iMfNE4v8iXBDGN8HguGLdJ/x9AB4rK+BB63Zgtv D9R0735HFkby
cGALaSqDs6/2hoSxUVkrdEr4eWH2pC2u1YpaTHVDSu8QVG6xyk5W7+bmyCRL //ie9zeO9dVv
QftR25GJna7ZaVHz3iEYdR1Eb+vOPA6/tLWvok5SHa1idWzvm1ieI24VOupc VkFPu3lxXhko
IOIRebuce9rVXTVs4LcPZkdyk0yYpRY1zU6MLTvERbCPvbU6bTtfeqI3FxRa 2J3BJ6ZSrNsS
hLF9JcAfT89vKSv5JcTrE4Ja+YoYDTCATKG2PTJ2djaQw1L86wJRQN6pqrf/ YzCX8EQjCXeJ
TW2BCVzKcrT1tRCn6jQ8B4KKORGezsvYWplcngocLbUETaPZZzDVmmGZw0Ht W4q95gyQkEnl
E/eSEXuJOI5GfiVvs8XzQBR9kcelohcu0zQHp4M9Vx3vAahKKXkr+31NW4uZ lUmC/lm0kN3u
Efb/Zz1nIFC9suRR63rRyH3bjXv7AsJ2onfn97CFW0vcmMepacu1iCr2XBbp dskc9lczp5N+
GghFuQPdUyxq8I3Su71kClllYXGuMi+vp9oL97jG6jtOf4XR9FOpygvsw/mT SqX4GbfQltRl
rmS679kZ803Ffa7sF6Lh3duTaXNUVncf3DES9dJSVDv+IXsqrBfiUPoo63hO g5kYkSQBEY14
Ik+nojAPpPtRrDGKroskPIivzn52cCBja0eextpoyROMsPDCpiDcXCNyFjlK 37sGkzf/ToTa
JahEZCoTJMysBdA5peSYIXCKtEXnAPtWOa95SN3GinqbzsLR2EE+1lQyZ+1i YuHhKe0ssjZJ
mNmQxP3lys+ueX/5lksYT1aaTJwznsv2IJGa+8mUSADT3vf95yUTAlVa5JNT 4xvvk+b/10sw
Lem6yk+BMZHGhIoKeZ/F2ori0cmn5TmkpkSnvSC+b26qMGKY0rXitIghg4y9 G+HcFQfc6e0j
+f3tDzB4ku/5nbokr7mVNrmjxUg9a3X0uRjrgqaMrRyyzr6RsGiISB4AjnsD bnY/Gz94ZXzJ
cO6bhzbxom9W1sYRlZG3QNJRUFkrRd0EmzjVwuWDV7xP7Qjztd9lnN4Jzegi 1uJ4ePu6fkgm
sE3So0U79MuZ7RUd3yM4MopoNNTqK1U7mJ5tIavVEdz0xtr+h/8M114r674F +Ol3tous691+
JL3Lg5RX9zVQDe1+JzcXAUpv2E8yXAGYG815x62hrFF4joxZ2wQ0MKZIsR6t Lan4lHzH7gSP
r1SEBd7MuoCkXJgG9RW990Rp2euqnSp8EIXbxDecNipCcDHHNsVn9XdzZ7xF wVKeLemESX6U
Be2EJ+usK10Xlzm+3clsfl1u1RaCTWoG7CY3ix6cH8TaiUX7g1gfFxjJrlu+ pK3mfWT4DElY
bzYa2yP+jFNEEJYEmilePwLkItQBq0ArckniEfIMGUjM6fbpI5mVR0Cij3VY LDlNdRWoB24i
aTmYRealnivMBjtTT3C2VhHnmfWUn/0Dr5D3ujRCnrdJDkjmsas8t80YdE+s tFI8/4pv+1r4
huUTkRyNxVhzSXtJQlEhrqPzR8C4KhIi/qrWMlqMLBI+V+Ybl18L7Hc4Kh/v kNqpl0Wc8jrp
LaYHTf6WHqv+11JwDz9AUI90bgQG1eacIKUV1R5LNOR5hQLR6OWngERgXYHq 7bovomFRjw/G
oBiQEvFCmgbipVQpmKT5kFnduxfyeCudWls4t7pQgy4/bTb5JIi3srMjjKQC P9/UME+exsSk
HRjo7yp7SdukucrzAj1o7Q5xB/JpSVbNHZSN89fnZ/44wBRnmlGrRzNDQ9kf iwhtIj+Qb16a
35TqJ4is0vK8Z0RHsvHuhuTsJViCC/eG0FHc+9vZkWcpmn60DdJS7dTw/GOn aLoFSgwYfhje
erUjGqUymniodOCyLROh8zA3WTjuOLaSJGRonhTlMxeLzhqTX67o0MKTtNho ALZnZxPCDtAM
SwQYE/EoL0gS5Svj1AF2gpOqoxbw+lcKkcNPXevlWP5WmruZcYApdbBn9qF2 CeGCwIJsudpM
b8OKvQBlGGzTcKlI++amPDxMgbCijx3YDUe8vW7rvs/zxiw0KS2f2zwgn2Yf KbnkIE2BEDQ1
aunplTDubdlM7FcBqHSVqZTNfyFNKuKt9q8vr3USK3q7sHwa/yAkPc+qYiBh N5+4IPne99jF
bcwwXZ+K9QhbOOisUzkwPsDIpWs8lJuezfsUAO0IYXW/P16XyD0KjFF9LvTm 8O+M/xXl0Y9N
dAp2EQ0KicjPnaQ302NHvfgmvK+gL4tuYaZA15Dla4xjeXTFqyLLT9J6Xw5Y FeeTW0LuQyDQ
XSzxqE5geiF72o/ZfyyXAdeu8YBMvZC+UqofCtUDxXLI8J4ql0lwkSCVYZT+ k9Lab5VmnZIZ
0x9QflMlRaUHw2j+8SnMoEqAR7ztrFvf6flA86RhKEwYQiCm3W55qhdFFq5y Sqvml08Phd49
qdNL00fSPXeBE10GpX6hAIQSeeZQLS1ci//jDIJITIqE/lvv4B31zK5W7WBD UV1IDhFYahWO
MZxUfCBY5OEkoEk78wWtj60FCKhkMBKpkfASWb6+bbi4eUqzGy56IejBaZ0Z lXKOMsLdx6b/
xKHWJb7L1szAXFm69s2pmvNwnV5/PBrgqpfomb3ipqECuXGyNsFOeNbkeyCQ LckDcsj4XUKr
fTqDu43szcnH8Tp9lqlVFink/raYcV+cgN/4xY+ZuAnGXEZ/GWj6NKg2OF7m yTDuVRugJPMr
BBpqCzs/wXn/dChkMr4faO4qJ+J4deHJ8QYf6viTnRcQw9pJGBVvD8oEqFEq UN0aArJbBSpj
jeaOQnmfx5CAbVqbBUQFRLINw78CE4GGHd3mOZgw2CNpWP+x5j9YK/wUeOpg tiMjYbJ2EksC
dc9LTSMIRWvEN9BsO1aRvQAvY4m2+TigX0qYgzWSMWFFsOIx5/d5xcF9fNyv ARhfRp4II5mL
GKQek5W9r754+713eiOjtr66k9q/Y04qoA+KfbCGE36QaWqr82/WINFjuUfo XHPifYS6lMnZ
Hr24GZwfFECppfDEYHfVo4ISY6ZnZbz+ZDtrI2JDgrAg5qc1f8dppV7IQIBB pZiJUeQeDwPI
vpfeLsmdkyWHiZY5kzTWucaQMNBFEUwqGf3h0tciOhATEJEu+qV+P/NjwINv Lu3epSpV95j0
5yRd4asFMjPHMETzHZSe+m3lfnGqRgq6JPELkrtEhDrFGTq2wo+8DlFagLLl m/dEz/zs960k
HeRAtqJvZZsOBeNnlIG+pcFU7aL83TbDEOcZa2RcWHTqiEjA8iarctXZNDUO bvi1fQCVTWjd
Z+yMSRQYNK3lP1Xd8jLONZ0nTRPlrLJlrn19AqzgQ2EB6SlerP7IU1FZpuS5 sq0Prt+JIQPO
ifiP3cwyyZtZjrmH8HazVY5JDcyZgfTScS2n0vkHmDLfJCZnHFcB5P9L/yoP jsVeFtJ8bVZr
jJuFe6ozpTXZkSZYv78e5Xbp6hWMXaW4tGsBL6dKXsERdyPnzdL8+HQuarS6 wI7M+UOABdST
C544Iv4hBAK8kTLkcipwmlDPfSZ9DzZa2DjtmzM3cPDXBDLeXvBKFkP391b2 bIFupjIP8S/c
5N37Trz+lm7Icj4IuvZoIB/L+hEkSpi1V+F8+YBkxS4WwexBM3G/wTQrqGBS uniZ8O8ddBLn
/w6Ui6MxbyS/Fz0QuCDzb9IMDEhO40jeiJifsC1ELeO+uzfZjb552EqboBPY rvVpE7kDgXEC
0RPjGfwuH53FRUDbjrand/6W7mz1nyO4B2Pqt5MZyWiM1AHOD7lm/P+ksmD9 iz7eJjR2HpXN
E9gyFrn0SeIlxfd/0uZmvY/EqMhYh3WJMiYQ2h4Jv5qOD5PkGaWcT+PxOB6o E3ucinv2HRz/
+YpZTWtofFH4FrG9z12GbykKOS6wBgnT6+FUxrKUQqbMUHLa9xVUxd2in94s /UTQ6RlnuP8v
Z3VHsIEcHMC5awEqxNgHu2nw3Ng+RUmAQizvv6yX3lq1ZQt83e3xt9GYRD5b dUlyhrIFBJbr
AQpNZVB8/piEAoC/iOjsjWuLMizYqRiPTTAID+/8Xu0MuiCUwicvkJcBPtm4 RyrXRpMMft7I
rB6KSyoL3dkyUyL2vD/NDmxEyDz3+x5Qt1b4jrCeCvRkEuh/MPOMlGmmm3tI +J4NUXwIUxI2
f1FU8OO9bnm+4Tb2tOxjk3Y/m6EGJ7B+KOWrhfS74oHAoqwaoGdKggnfEgvW 9rmh3vvi+kE0
fFA1tAChrnlxYe6xw5d8nFzorcOX8p7lhzXJhAb+Dd5PFD8BK54gu1ZXRMz6 F1lTpUtIPUtJ
buXdmwrjFSGD7YBiDkHZG18WDortLA9K06IATMWCyMlU5qS1tQgnbRim1J20 IghvFfSD0V58
LRZ7L2t1AwfsLaWBSbXefIIXLVeZL59MsvN78OgGPUSMLqW/TVV+HpChCtY0 HaK575vTvgYo
fx3dClZrQwOS648OipisEbBPNzZgvG1HqfSul5BR5EEEFJjVPrQbMdqewsDx ulQy6fFjuH2Y
P2qL27BZSZS2PkLVBGg4rEZrNm0NAGs9KEtdd0EIeK9O0t+MIrqxyyXuFSbP t3IU/4WOeA4E
FHLMIjgME00C5uFMSfanItT9bsgFTjyvdN1wSGXwZSm7GGWK2hF6CnwJk5B5 7JpmNP6nIMUW
eo2tykjF3vxu8ClxSjM3Kfb+9fWiHi/Z0YmWtg86NRJ4UhAE0zeXlNJS5/bQ 6Ks46cJj54U3
XpMRNKdBElDmoUB5j28h3/PYW5y5KdTQUid7AIMDkIhKfEHzDsXCi0rL2/h3 ZHnRIkFknzbB
ZQE8RdAxHJo+lJnhbi7+mVtFGLGRo9WntXKbXMp4t+WJI6Ip8z6OCKrnOxDs X/9i7GpHIRfa
8iexf2FWreVBpYoAgB2iINamQgM8SRymF6r9pZS23HYZyE6II7gPPmLeJB+5 VxFW40/x5qS8
8SBSEIJJXtJ/mJlhJwEpEIDuPQaFOSI2yHzqwDWcx/kK9lGBuOC2P01j/3RS ONH7mg+wjuLt
Yraube18TK46O8xe+x8kqK3oeou+cM/6REdvhZ6pB4uRSlgMc5mPG4wNZLhn 2o/hihNIOA+f
xfeGeRBGgdNHw52GK2TnaN5b4MMx2nbBRtjtWp2VVz668HbFLrwW3w05WHV2 YtyrWaSqVN6s
8Fch4vyHiW3V7sb35fV+3F5+ZnZB2oW/3B0VPM9seyT7omH+LxcSfJ8lRyik y2W6bye3ubS7
jAlkkDLgGQBQmbU0BjmrGQinBTUyIuvtum24jDPEDyfnmVrljvpm9iKrzEyJ puczdBhf0GqZ
bh0QG/1bRH0XHWb8zxExpPL0bFnK5tGQjk69lgDdVz9cz8X2ZoFwvEx6t9/f kjnxg5kkYDYY
9LIo3ip9M/n554kRY5rAWAKtjd0h4oIEMXWZygl7//jqHS/a/zsid/JnHtFt cPkVtBrRcZY4
kw4hzeninQGDoEei+tp9JltubqGsd98pISkzCzC0eSPqr44iaKO69XEF+5oe 72puxOJlRYA1
Uxhoz+xEKjvpRDTfp1MVGrwe1NEtsaN+jIDOQeqbNEBuviZO0OBAp7ZtxmLS VM5GI6R56dr1
32OBH8GY9Eb7oHzbIZqld6fJ+V/cUeCcJxv/TMEL9A69qrf9xeZamS/5Rm+K MArRf0mZCEh3
S3AasJD3KEBGHY5f+ENTPJSvcsDC6XqA7xcmexH0JOZ7+uAoaIM1RCfKPzir rQearF5Nyhc2
5j5xxe3m5f9eJil0MwpZZRoYb8fBBm1KhmDOhAZY5oUl0HEVYVJxMO9E/7sf Ht9vWCjfKqRT
xyL242JaoP3GDksy2f5VVz+m6t9BLikmOrW52f1zQ7Do2yjmtrKopgkeRdCJ c86HHfu2KRzP
gXkMrxhXTZsc/ofXdsNjcs0UHKIeSEBxb6upuB0IeW/uAZ3iONVSfcOGvvpw Ib+RUJJSTwli
9UH0iOKO3rVfrM3CwpN35L40WdSvgG9QXtjPHCNBnLslk/cPH8cDzIi2qEFP fLdwLijVS/ur
gOfIbjF5SqX/8prC9QkTpsSdyJTVuxtSZSG5P99kYjZkOiXLt2KGgZt54HN5 +DPPKwC8E7GQ
jYB8a3LIJS8TEA0cvjG28OT90ooQYpX/BDxfDZDTp8O9YxSHnNnnkjnZzGmN iBYPcqVm9YoL
xIpx5bKIyIZzx81ellIxrg4/IyFdc1V8sdFilhQX7nomj1A8YSLo4Yvp76/m rBKuooEZ0JOS
dFJAQHqJg/OXElY3VXW7SAiRxfjBfMYgP6FSTQQBqADG2hgJEJnyROgdRDrM 8CfWH7WgkikR
l2w1kNC0vpAZvDkmBow2PoUoPwriie34m3SowI5S0I8VUbxo5Rsf7fT7lnIG O/764dsZhoOb
AOax7cLAKYnGIUZrdBoukyVut5lLuZKYswutFw296AyLggkzv3F7Z7gH2r0d ymtD03CVv4h+
2BADJ+Wd4UOrRRRqN+SlSgjgnbKebXJi69exyxvunDHvkcyqoJ4BvTRSXztG N0oTtUGUDtJU
1ZQKsEk5m9BnmPlVGbs1B3I/o/Xj/KuOCj0/08c/3Ji4/wsDPz/yDiCvXUWg RQJWvFDxTT2h
cVzC3j+UPPet0d7Zs4Yy6TGZzkSq8Eoh5WoERsCjh0rYpUnvKTSdYkIlIPsc ayn3f+yBKYAc
IPpFv5GysrV5ZIjxe0/iXywfGCo3jfwAnOu/Vxjnb/DfZvcm7aqcF7TmwhJH WeXiJwjyOCXB
zmIxuVpB24VJJyhqXy1xjHqFtGPPdYG8PoJmKyDPtU1v3WowTAvY42Sev51y Bap8xfGH08Cf
ysgyCQw0V/pOGWNuIr/J5mbzM0dogcM0/oe1KnazJh9ihLgIS2nKcZDXdukx rrbVAwOZ/1XQ
pS54vHwukLadkWNnIWgwh+YaZSPPxm01OcK6ekTXofk+bevcYO6fMUa/sK/C GgsT07T0sprN
0IbRduvyKSC/cRQfuQdlExexLicGfI7/oOdsP4tpjv7TLISZOwwCKtEXXT7A nOmlNsSFQGyb
bOTOxpPUpz23bTUWMN9+AfUYrKfNzuK409R4rr8Pm15Hhbq8bP2I693omZdA fW/y2oU6F267
rE5VNABM3EoUD1Ut+jkQ9lOl8hi5F1Z7y/Z2r9WY8eC96LZwMBdZv10v5VZs O1XWHvVFphGE
CaeTFRXg8KYEsDlNOuRRmrXZEjrxO8MDtgEfvOQAMk32RUtSKK59dLwdns6c cNsJK/IhHINw
9QGSyWdiE2ipvSJj/tdApjtejCs/xve2JOxrjvovIMv3btPOgTu5Qbaw0arA 75yz2n/kKC0G
7c4QJPlQN4fKk5DieyfD88UPEHcvba+3eeqALonO/P5sEp0/jAQiTBBG0vI5 izbK8sl+zZMV
KJSlxUgoM55u4DzJBoqDT3jw+BVhwCamxCtATNjV8CV0KVe5MBLdXuORH/SD 6ASQNDRpSgDH
f4Um81Is7Ax/WZKsC+l4cQiAYW04L9cq0gZxvRnwEaVQecoA40+2NGZTVPzS BhjgoO77Ivzu
rj8H+4HxTLOVQ6LZnKhdtFwbkEfEQaHRqw3b2EzICS7MdWSArwcVoTonNlBC XvI3bBq3dInX
5CNAx2eCIn8rRA6k6vbuLlRL+Nmf8O1Rcj46SwsR8SHM0yOabwdsQV7oeMyv streeGM6QZLC
EbOGVBpyoXad6lQTa6z7OszrjhAXsYCrSizD0OT0wn6EOa3SO/pYWQUIESI2 OKixT9ROH2JP
N9+eeQ47rN+VnFKFWAY1dvOR2K4t07Yz0SDYSKfKX07wUxSyorZsQLnC0efw 1IQF6qjUKVQr
aWybTlXOxVV25fQodzdI3aNEp63UAwike7FYMALqmOg7basmA+RuVYneMEHp CqLFJm1sTnw1
FoTAOaEbgVmqnzuEAMUkf9sJ0Sc+wpqgvo7pbtKDUEnBco0v4YR1e2iadcWo bBANulJzoEQS
ovXYZfjHua2hclhFaD/2kLxacoaSKWXU2+Bhv1/nxRk/+OO5b6I8n/fM/YVY cmDBOuJSn+jV
hof/h3aQWzGDMv2K1/sDrv7AEosqM9h4X2Qjf1wM2SSF3Hww3epbapGWYCxT fsbbEiaUkbrU
ZmXUPa1WxngRL1Tg+UZ3GWSbkp7xXwhGaYxhjiAIXUjt9JZ5E6vPVHxEHego 2w+BIf9sn3BH
xedTk9etIcfiJi7QSqxunZ2h0nwI7ve1LMYv+B9Cc+kXVzlPoOvDOzWk4AA6 iyo5aHnI4kWo
mjx34ag/Fp9w/tS4XNVpWeb2nXNWAXyVF5dBo9nkQQEiLLNuS8LCOhPMHy1i /cT5c1NbnMQw
8KACRFtt8qwpu80rRRUc5e+cvxLaVfxiLs+SHv9psAy78GyrvjAYZOhOwL9W 7o+rGPUReeNu
qEyXCQ8GtoWvLfB6L8o+1QFm2zZmopWBiZNU7qKyYufNpFAvSu41flrYvPAO j0j5J1t+c5TQ
YSXk18mzJ+oMYL4L0HwgZtjX4JfbtjyAsigJSQk43i37D3n2mL+E3fyQXcgc iovD7ZmzZa8T
Q6WpYw8BwsIkc+6JXPDIXY18GEhY2aoyWL57hhu2XeVdbiM4Py4QfWdr3G4H z6FewgUDqb3W
TEchzrqdFmQPAhJKXxAyG7+NkaZxCfmmyG4hrl5WbWN/gpDjlKWvA9GwS9or Xjg4erjZp/w1
qsTe35eJ70wdYwxDqdk7wzuli+hhJsnKEEuzb1ANAh+4pyOgwsVg6EHgJqnk uhph3yjWPsGN
1B2jXh35C6fvz3IEwXEX0dSPJ7LxBn0f7d1Ke5IwpIoJ/uCTUMqdsAWrI4In H4nfZrpxM1jR
YRpvXVYhAxA+tDGjm7YUvvxpjAJDskr7xUfYPDPN+LNfxK4oEcgi8lSVYEVm MG6EfWM2YCBa
VhwmjM+czOYIWpbQ0Bxib/hgMV1zCTkrYfFAoQZSrANlkeTouUVdh4XBM5CW 2DsMVJ8moEMk
f691mNOndkdxpeCHr5YW4nE8ADLv56pEN2B96nfr1+lAGmw7o5Kuct9CljHp 0EHenQ3jCIOV
elsvpFjtnGKyo/Dyv7bVYRz4fi/IHdqQg+rC+mI4U43UXDolXyiQdVC/EJwS +UY/eQxFcBjg
ij18uOCYEkvhg0ihNW+/xr2LYVWysipa1tZS3BlfsfvUwCCYuZ0P+EK7+ShH lS8VDPfWZkyB
kzHNG2kX5qGX7/IeXiZMXbV9Cn048jyeShZgMA5QQmVYoNOP0D808lQ8N3Y2 1asXruV/11AQ
zSs8Qg8px3d0Af6JDH/EIXARZGLvZ2CA/Qstc0xEriqA+cXTRASoKIJHGUwI BYkh1NdR3F95
TwsAvfqpMYOB+VV4CpbXee9++e3LX0/xAGuzQkfIWsJYvlBCP8UVVE/1yvUc pcHo2114ppI2
14IiTudALkxEUk+ZZnrWbKTQuyp3bjo4+OXPsJWSFvjV/WKeataJfIoqqxWL nmThfOFwvZJ0
nhfprWFv92nVqldvy+LaJ4cUTSFs8MbE9rlPitcMR8ULzI7zRpzN3SwT4ufw OnsIl1MR2ISV
NrfUcNXIxz/qtLY/hgSh5qM0mSzeQ0Lm9f3qTiXS3oLxQpqGpGA3kikaSr0G 6bOt0B0QoOJQ
GcNVFBGrSnmwRCgFL7xRMsoVfJYMTvwpxjz12xUHpVCI3Uy3+XRTMC9L11as ttT11R8w367l
Z7cggxxJQL5vTUgpWu5hMuRTWjx/ax0hQQkZZoc/zVhdp5Wr6II6Et4QY87j gSbETv1LJL2T
ivrVLRNXkxlo3atRmV6Z6jXG6o9PCP+jH3K5kY+C9WOLw1l1xj4TvB3Y06l2 Pq7Wl606xazn
ZjUDRCjz4gtG/n5TCmNIJf2CLnKYiFI781ST5kbxrXHDgKr6G6ZdRFaxg7K/ hhlshUTddD7A
I90dnaNdtlj0OvSCmZtQ9VyvDJ+EcDfiXyNitPZfAPAsym1mCKszB68j4pGM RgscuYQ/6bQW
4BTcMtsRspfvrnd9vJ1tBhV9R/JHedD2vZpDyeUo7JFbNo0yZh1VgB2mr9Rc MsxVIZT9hukj
DXIvymvzMHM7yNwjqL7IVLvQNs5Lo9XR4Qaft90Uba/55py3HHbWBXuxmKRU QGgHZXQqB7/9
OOtbGML3kjRmz+qT1yhrWcdNmaQs2Jy8do3EvZSjY/Bk1fKFfmLmuoPkY2z9 L804QJ0yFzIK
qim+QOIXxNoVN7pjbhH5vZeJt6P/Xew7yEbiLvwe4XmG0xatUP8xKcQhzjx1 Ile29BblFsfy
JEJyYwwmOelD5PPxwZ8fneoOzT7dh86/7KfMa99evdUqLZC4PQAZBAJVFd6s t72WEpDs5Dkp
EdCLgZRKcVJJUKJgGwk3Ee177l7YuISopRjdrbuX3KBOWemqSLv5zu+K18zk OBKcYo4CF/fm
FLtTemjAeZWhNlW90UUJv+IkoQIjbmprSdzrOSSTNkCwIvyDm48rPvsJLMw0 +avmXgl9rddz
+XkJT0jM+dla7aFjqXHqlbVf82ZE+17pLFzByolyMgSnf3s/xph/OGeqwjrM gE4sCqDI3Hnk
2Lewn0sGNqJgorLTQwYWXsuyJVZ0jJaFTc1iNiQIyTORVqENZFJmbm057mIE 9CGSjX7qtzhV
mdJYxqlN4jSVJao9WCH9mDbUW0T6Z4UJKNYZ4PpXqoeQ0vZEtlL3xBueobNe 8SX5csHQtqMk
aZaOvoKpFBCZFD3thW+VACU3cxNi5xyuW3SePWN/skEraPwzwfZ/VxuhYey3 EsZSmThZQkNn
JoUGaBiSDxxQ+yVg45yjuAoGD4l5BU3dapdBrcq0IFvpymS1fh0Xrc6r9FBV ccmye1Qbe9dU
OFiBST1pGFZPn3c6LmpLZ2q3o/rKPmVy54WDPqJvvNZw6vzKsBnnYqePnzL1 9dA2DkVQQvSy
o4T7zLVl5EeyyI65ejwLMYKGuCRExqBw3oQ3IMjgxhuc18cp8QH8rINgSPU3 /KFBVGRwJ0TN
o13ycGl+m1ho7qxdzDyv1PYVx/mhDh2Yi8mqds/hs5KubNZO8d5MsWRUjz7L sQzM9qByayo2
wRwbmLRElklplnm9N6qmIzS23q843sDyJ5pUUc+fwxdutbkztpwQJXRTH+aF SwZ6tVcmXbXM
j0szg5YQ0GHXzTGlmSrkLlkROWWoXGJHprjcvLzC9lXu04QitnYy+HjViTYU YsvkGcFhpcAW
NOQfprBWuMNZ89GTrRvivlhRyGDyVWManMgX2F0rj5n6aD//nKdId0+vDaCM blo3TSZ4Yz64
582JDLINalsiRIsHsO612fajzfUWiIYmSfznvtBGswL8ed79WySnoZbmXdgx syImVlpiEUpp
+XW2J1HBPJ6fneDk2/Y2pdg6kWImLCsCpxN6iiITQb5Vxe0Uuvk06TdxOruT zaDrHrcTe4ol
vFWps57KpWQVLPCH/tsD5GzeWCffOXPNmCW4oS/iS+N8m67TiakFZ1Cp7ObQ g8pcSZgcHzpj
yQRfvg2/QAMhzDCkL8rgoH3LX7fKrePXER855yCZhuGLm6NBa8MhxJ51zhMY cGUHJDkA+Cy/
kKM0bmZLFtNGJsVOg6Xm9JR++MdZn6hwXOL9NFFSAYhGxmE6OYqXufToyVWj p/3ebojTZ7Vb
aMICiqaen1OwbilDjKMEGhobc6PDve3KROCbS/MeE8hBJQ/NkLO3VVBJ84xs g/fPIRvKO6gL
9gcQBqAR9RbFEDGr/Af6HZbEKc3iDliPULpe50OOEg1VUizCX+vNEMwNOjhr njPTFfw2wUKj
PKyoIiKAxN26SEacqn7mFvGcBlONJPFvVFNbjsL3BtMQZlR/4LycUBi/UGFu 32GHIZNNdkY8
aQCb5PsUjby6bPfbY8WeD0dEIqv5V4N2JNDmfWO4yuLvOwXAXmetmuiE0yU8 bYdHYjRcRMVe
dwC6/+RFpJxAdJmoq/ZXSWSAxeW+XenAdWNjyuuVbJXgoi682nv6M3FiADgk IQfyL946+5if
UoDrGqbm9WqhGOI8KiTBg0xihjiRRkSFZQdSMNy0AeQjptQlAB0lU9UY2RDS kkQuFAWkwpuT
ukydPSlJWfxAosQ5Tp4uNg33SUULyyGlt23bedRe7ygS51dmMkVL94vM3Zjz z/zEtoLJXKB+
FxnQxWSjdaFs+iZPRsXzDOwEu9xL1N8ORYHtCF8MTWZea/NPYcNlSRl8DGan V/g+w/GtsEI8
se8zzx16YkMBziQRzz0s3DhWAYVygB8hqcEc4FWivfbmZQ+Xid07vujELtSt pCVZssGgksV+
Jq33C5CK8LrTnGazcOdAlSOAQvRsU3KDTKboal/09dFd7W6Dtn1MEljgsxQR 4WCikyZzNnss
ECMugpyq3YdjV4aKioWKRQz4HkcuJ3moKV3RtMn9bZ1WOICEQiMe9c3v4O/2 i1u/yatA6sdc
VldyUS++7Gbcg5EvlWfy10lgdpJdJ1u47bZ4smZQnD9IA7jfqpj3/ItaXkIY QQmk4R2HeXqn
mHojRHn5lVwCff1lV17lSZbrcysngr61JPUsEKcEhSG0opazCb3EwHvAnMgR ZT9ofjobCeyo
dLC2Iph9LLLJjyd3seWqva2m1cTiwNhYdHAuVPfJOjhnmLyL+w4r/t8k1wUo Q1cLlS2n5+Pq
wxkSh+e7h0sNUJ46YzVsfwpoxd5cPBVnKlDr2ceoOct1NKmzTxMAhE9R2D5c hntGjN9VsQGR
2f/VQs3dtXgYFWXjjbfqkjdhsyFSETc/rpVYxqyWlw5Te8PoQjQtCUwev/8E VgRUwcdONRxr
/93rrIUmbNBx6BTt+saKP1vRrnOIbuLcDZwQv/jq6PUjN18OFoj3lJQ1xA+v NuVyI4WFsRyo
KBfzWg68ew3BSb+ITYr5IKj2RQmG9ZnNDQyp9G8lLO+44iouyQ9078ZSpj1P n4vxE2TWKxea
2/d/Hd2xdlio64+q9AsulKGCyc5rs1F4it/YkB2b0iRFItJ1VdFSL1By4avt FQ6xNl/9I3Wl
cQh3OknLeghm7c7MJv7Qt82peEcM3wRwdE8dMDuK5NpJ5+1yQV5thjO99wAA fNF1OxeGPOaH
pBMwtV1/UOPG3XB6Oxx6X7XegnASbTpBu2r+PqQr1SxO47OGxszNMP1HbOe/ FFsSC4jaQxUb
/dclJOlT/Xijv7YHI9j7ddo50CgF8C7sHPNE7kWQfEx9TJLVPzZmaAJwWctK khSS7Xeian9w
VsFWBFUH/LEP7fkiroYYWWWPaI/VAlTYS239/BXLgZajBfsWTd78nmesxDoa N0LPmq+Gd5n1
aFw/7DXzNhE+E3KXR5okZB4eYAL3Mf8d/q7xyRTWqFj9f6ew/ZeE1X9Gutq+ OrJabdVX6bVh
WFN0u5eyomsXAlWocGEwSFXqaDupvl/kTE7v8sLHY9c3pypk5LQVLQcLzhOa Ls8q8DTui4AT
z8UVDSUCP1DcgKxJSfzb6h7r2hmPM8t70LVCKiWOr08FfTNDlK495SKOssSB a+dPjT5x5/MQ
ZT2xFKWDF0pwKcJwJgOHUalF5mNokIK57IgSpdUCOxfpzXC4CPmyUe6O2JvS W+V4Ld4U4y1e
I00YPas9Wc1WESJVqY7pQA+si9Z89d+GXfGzq5VY4X7ZLPBccXsQJ3wlqt0m OgGl1fGtpHu0
mnrNJr1rGU525Tj+EWRoMToBg42fkioO60Qfv2sW10tFlP1bo3cdJ/znbo1s fPTPGjqeYdJl
gbCIuDpO2ONmr/wHJNnRINI+OnsSm/1p/2hI/1ot0MQXuqIj1f1qdodasE5D XC8U/Fy+b6R7
Jb06i8J7Sn6OyCZ8EKnz/Ja7MZYq+MhzRV25d3LQ6+Aynz65lurgk/Zu5iuk ULMGUdQF0hF+
03wWOJZ7m1ogTdojYfpviHQ2ZoXK1H00Vk3xrejAz099ydRNXe+osr1KHZcj G9RrFDYCf/ZN
f4wavHjaYcp9LDIQ9tQ6H8OmazndWFntrfsivwVn1X22qcVKTWMo46pSG4Zy 9K/qPY/AkUVw
qJXeRtfBBw45XqisHzOR67kQJScPv3f8jZzGIL6t2MASYXZNTjdGq8PFdBkY vDCWFzfdbHUp
RRUnv4ldH8p1Vihw7pxeCz2aDv0NSi9WpZNEY61eMr/6URP+KPItO8szGpoF nwXgPiNG/9VM
1W8LQqx49HBFYNvev+Sx2eu6biy8+67piUqb+5xe114eVsr4K3RZk8mrt800 jTHn2j2KmZNR
lJyibBlufnJOjaNIvD8TfhNKIQgP9RBtxGSTzbR5DfFEuCwrTv856EwYmdJp Dtv1NSolql87
yvzdYWNQe/bKKlW15Km3OiKJkMwTEujqd0pQvl9TV2+5AEQrWio7ScgtOEaV HSmu3E9YmQpj
1YoaHHj/ca4JahVPdVLfihl0wRA8whzWID5l2lxBA3pwj7EPuZp5bw18K1mU Y52sCpYRLRcf
aLWqWTcuSWbAw9Hsv4CIkbbtxgWz4MvjCSDpMCy6H7K90SYvPJJcX2K20gE5 pzwrOttLcJsN
TVLDwOo8WW527aE+Qlx5iQvFm7NeIa5iTZVv+EPzrLR0sLyDOfSQAd9BQ/3r SPv1AhZTPFRP
W8kiVkfSzzApkZrh+fA9Hfz8DLe1b+JHgtGRTpixzu+s4hv7v527QN8WkvNE 052onB8sr3fc
DSvubVXXcc0fpv7K1vefUGZrkNMiG8xeGgE2BZV8XUfrFIT1jganYqy9T19d +zuwBgzkKQFV
Ankqcu9PLUqkKTKfJFeXvQa4Dv1CwAstW4lQOQt+B25V1XzmU9Bf20cjxDV7 1RbauBjgsmoF
AfGtjOC8qk38LflDaccGTLifMnR3cvPTNgxMBORdnABVQIYps0Bnka1VOCFA O24bFQrzbQzg
Vvk5GjsOEwuJY6sHX29gtSmPU7XH6xintYt14yZ/ed4Sa1GIasaRDdAwQUpA llq9NnEgAuAW
vdEunJSDP18wT8+a/pD0pgTlr3zSI9FIAWL59ov4TJ5JCk6LZAcfpR3E/8hw l3Z8aqShOYst
MK5PA1gljyBZHVh/h75ekRKrkU+exgF0ULecVxb4WWK0PxKnz6T+B/S42syL b6txPqWdzJZl
4VxoZrIWJ1Iou4GR8D354gS+mGTkbOEbAA2hOWzyqfUL9sFGU8YblWFXyWfo AvM+yEZwtnc6
OvE5IbY0jcc78LyDhRrnkgkpmWtWMsGms++XTjrhgDbfjjEywlKKiAOBMRhk t5b1e/E2oXLE
LMTxN6eOqp2UV775VIK4PAxBRkllEi3uTm9Nt8KYHWXLMtqaxTKGvgijJVDe OE1GSX/rN4UJ
hBw8Z5JQmPLzYsiJSHlMuqWX+W9GbZ/L64QIejmqAg0TZo/MvZaiYRIKTEoa +i77P5w0/g9g
6Xu5OVWwR428db7gFyZqlufBTKIfdHBnVtEdhl941KgUJCcCt4zcITkX2NFt R4V4CZuZrEZ0
KAnF49dM+PtbAaSJgyX9bX5cQm+MS1HeKCmaPKOfJ5oNeU4WMKO1s++1LR8y PH5sc90U9RVM
RIEz0cwLU4rrkLkygP56gaZ6589FeCUYLQz3UtPoQCdqPCOLKVSrSoWzBUJd ATFL5PZx29aa
GA4Mdh2itIEVpKMEyfI6CIZFzZ0pafChT79medEnbnQ5XFwKLXQzTCGFvsJc Fhh9Lk6qEAXH
2ZYsZX2PQNZZFzquL72567vYuSFKmeh2TXTwG3Tz/4BUnxZwuC
Re: how to embed swt shell into native window [message #515037 is a reply to message #514986] Wed, 17 February 2010 09:32 Go to previous messageGo to next message
Daniel Krügler wrote on Wed, 17 February 2010 07:13
Daniel Krügler
i think we are talking about the opposite direction. I dont want to embed an external (win32 window) into a SWT Window. What I am trying to do is to embed a SWT Window into an external win32 Window. So, the win32 Window is now going to be the parent Window!
I have already tried the following: SWT.Window.handle = Win32.Window.handle, but it does not really work. And the same result when just replacing the handle from a Composite (not the whole Window)
Any Idea?
Thanks.
Re: how to embed swt shell into native window [message #515191 is a reply to message #515037] Wed, 17 February 2010 23:57 Go to previous messageGo to next message
Everything on windows is ultimatly a win32 window(correct me please if i am wrong)
So if you can embed a external win32 window into a SWT window using SWT WIN32 wrapper(OS)...
then why can not the other way around be done...
Embeding SWT window inside an external win32 window...
In SWT OS class the
public static final native int /*long*/ SetParent (int /*long*/ hWndChild, int /*long*/ hWndNewParent);
method is there which calls coresponding native win32 method....
The same method should be available in your win32 implimentaion(C++,.net,VB)
Hence i dont think there should be any problem...
Just analyse first how it is done in <WIN32 on SWT>...
and try to replicate it in <SWT on WIN32>...
Re: how to embed swt shell into native window [message #515505 is a reply to message #515037] Thu, 18 February 2010 23:28 Go to previous messageGo to next message
If you can embed WIN32 window inside SWT window....
Then why can not the other way be done....
Everything on windows is ultimately Win32 window(correct me if i am wrong)...
And since SWT is a wrapper around win32 library on windows...
hence what ever you can do in SWT should also be possible in other win32 librarys(C++,.net,VB etc)...
The SWT OS class native method
calls the underlying win32 library...
I think same method should be available in any win32 library(C++,.net,VB etc)...
[Updated on: Sat, 20 February 2010 00:49] by Moderator
Re: how to embed swt shell into native window [message #655168 is a reply to message #514990] Fri, 18 February 2011 09:37 Go to previous messageGo to next message
Could you please resend the pdf "swt_winctrl.pdf" (and maybe the example code too? The pdf seems not to be available anywhere.
Re: how to embed swt shell into native window [message #847370 is a reply to message #655168] Tue, 17 April 2012 04:30 Go to previous messageGo to next message
Hello everybody,
The article does not exist anymore. Do you still have the sample of code and/or the pdf ?
I do not find so much documentation about it...it would be very helpful !
Thank you in advance for your precious help Wink
Re: how to embed swt shell into native window [message #847413 is a reply to message #847370] Tue, 17 April 2012 05:22 Go to previous message
i'd be also curious Wink
Previous Topic:A table with two columns
Next Topic:SWT Canvas randomly expanding composite
Current Time: Mon Jul 21 01:25:54 EDT 2025
Powered by FUDForum. Page generated in 0.06090 seconds
