Home » Archived » M2M (model-to-model transformation) » [ATL] Migration to Galileo
[ATL] Migration to Galileo [message #504305] Fri, 18 December 2009 04:14 Go to next message
I am migrating ATL transformations from Ganymede to Galileo.
In ours transformations we used these ATL classes to launch transformations programatically:
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel;
org.eclipse.m2m.atl.engine.AtlEMFModelHandler;
org.eclipse.m2m.atl.engine.AtlLauncher;
org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel;
Using the ATL plug-in wizard that ATL 3.1 provides, I have seen thtat transformations are implemented using:
org.eclipse.m2m.atl.core.ModelFactory;
org.eclipse.m2m.atl.core.emf.EMFExtractor;
org.eclipse.m2m.atl.core.emf.EMFInjector;
org.eclipse.m2m.atl.core.emf.EMFModelFactory;
org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
What should we do:
- Migrate code using org.eclipse.m2m.atl.engine.emfvm and org.eclipse.m2m.atl.core plug-ins to use EMFVMLauncher ?¿?
- Migrate code but to continue using
org.eclipse.m2m.atl.drivers.emf4atl and org.eclipse.m2m.atl.engine.vm to use AtlLauncher and ASMEMFModel ?¿?
Which is the difference in using EMFVMLauncher or AtlLauncher ?¿?
Thanks a lot !!!
Re: [ATL] Migration to Galileo [message #504520 is a reply to message #504305] Mon, 21 December 2009 03:23 Go to previous messageGo to next message
I have read in one post: "In ATL 3.0.x, it is recommended to use ATL EMF-vm, which is an improved
version of the ATL VM you were using." http://www.eclipse.org/forums/index.php?t=msg&th=159055& amp;start=0&S=87f3604973c372250a8d01021288af4b
So, I have migrated our code to use EMFVMLauncher, but testing them, with big models, I have obtained a VMException:
java.lang.ArrayIndexOutOfBoundsException: 100
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:430)
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:387)
it is trought by org.eclipse.m2m.atl.engine.emfvm.ASMOperation.java Class in line:
stack[fp++] = localVars[bytecode.getValue()];
where stack size = 100 and fp = 101
After that I have tried to use AtlLauncher, as we did before migration and it works fine.
Could it be a EMFVMLauncher bug or I am doing something wrong ?¿?
Thanks a lot
Re: [ATL] Migration to Galileo [message #504551 is a reply to message #504520] Mon, 21 December 2009 03:48 Go to previous messageGo to next message
--------------020802060800060105060504
I think you encountered that bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245891
It will be corrected for the 3.1 release (june 2010). At this time you
better have to stay with the RegularVM (in your case).
William
Miguel Ll a écrit :
> ion.java:430)
> ion.java:387)
> Class in line:
> and it works fine.
> Thanks a lot
Ne manquez pas notre prochaine formation ATL inter entreprises:
ATL - Paris - du 2 au 3 Décembre 2009
Pour plus de dates et pour le détail de cette formation:
http://www.obeo.fr/pages/formations/fr
Don't forget our next ATL training:
ATL - Paris - 2009 December from 2th to 3th
More dates and training program on:
name="william_piers.vcf"
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTAgNTMNCnVy bDpodHRwOi8v
d3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------020802060800060105060504--
Re: [ATL] Migration to Galileo [message #504886 is a reply to message #504551] Wed, 23 December 2009 00:44 Go to previous message
First of all, Merry Christmas !!!
Following with the ATL transformations migration I have a problem with EnumLiterals elements.
In Ganymed ATL version, ASMEMFModelElement class had the method asm2EMF() with this code:
else if (value instanceof ASMEnumLiteral) {
String name = ((ASMEnumLiteral)value).getName();
EClassifier type = ((EClass)((ASMEMFModelElement)getMetaobject()).object).getES tructuralFeature(propName).getEType();
ret = ((EEnum)type).getEEnumLiteral(name).getInstance();
In new Galileo ATL version, this code has been changed:
EClassifier type = ((EClass)((ASMEMFModelElement)getMetaobject()).object).getES tructuralFeature( propName).getEType();
//ret = ((EEnum)type).getEEnumLiteral(name).getInstance();
ret = ((EEnum)type).getEEnumLiteralByLiteral(name).getInstance();
As you can see, the method used now is getEEnumLiteralByLiteral() but the parameter is still the EEnumLiteral name.
I don't know why it has been changed but, a transformation that works fine in Ganymede it doesn't work with Galileo and the model and metamodel that I am using is the same.
Thanks for all !!!
Previous Topic:[ATL] e(Generic)SuperTypes
Next Topic:[ATL] unique lazy rules
Current Time: Fri Jul 25 23:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.26153 seconds
