Home » Language IDEs » PHP Development Tools (PDT) » PDT + XDEBUG + EASYPHP(See the variables of the function)
PDT + XDEBUG + EASYPHP [message #504600] Mon, 21 December 2009 07:45 Go to next message
This is my first post Embarrassed
I installed Eclipse PDT, Xdebug, and as a server EasyPHP. Everything works and I can (a little) Sad to use xdebug,
and I write to ask about help, I think, configuring xdebug.
In the code below:
<?php
function somma($a,$b,$c)
  $risultato = $a+$b+$c;
  return $risultato;
$x = 1;
$y=2;
$z=3;
echo $x." ".$y." ".$z ."<br />";
echo somma($x,$y,$z);
I can only see( In the windows variable) the value of variables $x,$y,$z but not value of variable $a,$b,$c.
For variable $a,$b,$c PDT in the windows write <uninitialized>
What can I do?
Thanks in advance
Re: PDT + XDEBUG + EASYPHP [message #504655 is a reply to message #504600] Mon, 21 December 2009 17:23 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
If you set a breakpoint on the return $risultato line and then execute
so that it breaks on that line do you get the values of $a, $b, $c ?
Dave Kelsey
On 21/12/09 12:45, MaxMax wrote:
> This is my first post :blush: I installed Eclipse PDT, Xdebug, and as a
> server EasyPHP. Everything works and I can (a little) :( to use xdebug,
> In the code below:
> <?php
> return $risultato;
> $x = 1;
> $y=2;
> $z=3;
> What can I do? Thanks in advance
Re: PDT + XDEBUG + EASYPHP [message #504709 is a reply to message #504655] Tue, 22 December 2009 04:55 Go to previous messageGo to next message
Eclipse User wrote on Mon, 21 December 2009 17:23
Dave Kelsey
Not even in this way I can see the values Sad
Re: PDT + XDEBUG + EASYPHP [message #504746 is a reply to message #504709] Tue, 22 December 2009 02:26 Go to previous messageGo to next message
what version of xdebug are you using in easyphp ? It sounds like an
issue with xdebug on the server side. You could get a log of what is
going on from xdebug, see
http://www.eclipse.org/pdt/documents/XDebugGuideForPDT2.0.pd f
for details.
Dave Kelsey
>> Dave Kelsey
> Not even in this way I can see the values :(
Re: PDT + XDEBUG + EASYPHP [message #504799 is a reply to message #504746] Tue, 22 December 2009 12:50 Go to previous messageGo to next message
I'll look the link you mention me and then I'll let you know.
Bye
Re: PDT + XDEBUG + EASYPHP [message #505068 is a reply to message #504799] Sat, 26 December 2009 04:07 Go to previous message
This bug is being reported as
0000467: In included files all variables remain <Uninitialized> - Mantis
http://bugs.xdebug.org/view.php?id=467
and 'resolved' module is in svn still...
Previous Topic:PHP v/s Java code formatter
Next Topic:Stop indentation on nested folder view - remote systems
Current Time: Thu Jul 24 21:53:37 EDT 2025
Powered by FUDForum. Page generated in 0.10458 seconds
