Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to create button on runtime?
How to create button on runtime? [message #504525] Sun, 20 December 2009 23:28 Go to next message
hello everybody,
i try to make buttons via buttonlistener, how doesn't it work?
please help.
	public void createPartControl(Composite parent) {
		parent.setLayout(new GridLayout(1, false));
		GridData mainLayoutData = new GridData();
		mainLayoutData.widthHint=3000;
		mainLayoutData.grabExcessHorizontalSpace=true;
		final Composite mainContainer = new Composite(parent, SWT.BORDER);
		mainContainer.setLayoutData(mainLayoutData);
		mainContainer.setLayout(new GridLayout());
		GridData gameLayoutData = new GridData();
		gameLayoutData.widthHint=3000;
		gameLayoutData.heightHint=3000;
		gameLayoutData.grabExcessHorizontalSpace=true;
		gameLayoutData.grabExcessVerticalSpace=true;
		final Composite gameContainer = new Composite(parent, SWT.BORDER);
		gameContainer.setLayoutData(gameLayoutData);
		Button addCardButton = new Button(mainContainer, SWT.PUSH);
		addCardButton.addSelectionListener(new SelectionListener() {
			public void widgetSelected(SelectionEvent e) {
				new Button(gameContainer, SWT.PUSH);
			public void widgetDefaultSelected(SelectionEvent e) {
Re: How to create button on runtime? [message #504528 is a reply to message #504525] Sun, 20 December 2009 23:41 Go to previous messageGo to next message
p.s. i forget to set the Layout for gameContainer, but with this setting, it still doesn't work. are there any update problems?
Re: How to create button on runtime? [message #504565 is a reply to message #504528] Mon, 21 December 2009 09:31 Go to previous messageGo to next message
For the Button created in the the SelectionListener to be shown you need to
follow it with "gameContainer.layout()". Layouts only happen for free in
swt on resize.
Grant
"Chau" <d.chau1982@yahoo.de> wrote in message
news:hgnfse$4iu$1@build.eclipse.org...
Re: How to create button on runtime? [message #504611 is a reply to message #504525] Mon, 21 December 2009 13:35 Go to previous messageGo to next message
hi grant, can you please explain that exactly for me. i can't instance new buttons on the container. i have set the gameContainer a gridlayout...but nothing happens.
Re: How to create button on runtime? [message #504664 is a reply to message #504611] Mon, 21 December 2009 18:35 Go to previous messageGo to next message
He is saying that, after You create Your button, after You set the
GridLayout, just before You return, You should call
If You forget this crucial step Your container will *not* be repainted,
so no button will appear.
HiH
Mauro
Re: How to create button on runtime? [message #504687 is a reply to message #504525] Mon, 21 December 2009 22:14 Go to previous messageGo to next message
ok ir works, thanks a lot grant and mauro
Re: How to create button on runtime? [message #504733 is a reply to message #504525] Tue, 22 December 2009 01:11 Go to previous message
hi, now i have another question. if i dispose a control with the button in the gamecontainer, how can i instanciate new controlls in this container ?
Previous Topic:Automatic restart of crashed OLE Object
Next Topic:direct access to swt classes' fields
Current Time: Fri Jul 25 22:09:46 EDT 2025
Powered by FUDForum. Page generated in 1.19307 seconds
