Home » Archived » M2M (model-to-model transformation) » [ATL] e(Generic)SuperTypes
[ATL] e(Generic)SuperTypes [message #504719] Tue, 22 December 2009 05:35 Go to next message
I'm working on a transformation which requires met to copy entire classes from one model to another. Since it is an ecore model, such a transformation would look as follows:
rule copyEClass{
	from
		a : MM!EClass
	to
		p : MM!EClass(
			abstract <- a.abstract,
			name <- a.name.debug(),
			eAnnotations <- a.eAnnotations,
			eGenericSuperTypes <- a.eGenericSuperTypes,
			eOperations <- a.eOperations,
			eStructuralFeatures <- a.eStructuralFeatures,
			eSuperTypes <- a.eSuperTypes.debug(),
			eTypeParameters <- a.eTypeParameters,
			instanceClassName <- a.instanceClassName,
			instanceTypeName <- a.instanceTypeName,
			interface <- a.interface
The problem now is that every inheritance relation gets copied twice, leading to classes looking like this:
<eClassifiers xsi:type="ecore:EClass" name="Container" eSuperTypes="/0/Component /0/Component">
This goes away by not copying either the eSuperTypes or the eGenericSuperTypes, but that seems a little blunt. So my question is, which one (if any) should I remove, what is common practice in this case, and what other solutions are there?
[Updated on: Tue, 22 December 2009 00:36] by Moderator
Re: [ATL] e(Generic)SuperClass [message #504747 is a reply to message #504719] Tue, 22 December 2009 07:29 Go to previous message
RJ a écrit :
> rule copyEClass{
> from
> a : MM!EClass
> to
> p : MM!EClass(
Looking at Ecore.ecore, it appears it is not a merge of both relations,
as the two properties have different types which do not subclass the other.
As the two relations represent/store distinct elements, you should let
them all, except if your models would never use generics.
Try with a model where some elements have the both (a super type and a
generic).
Notice that eGenericSuperTypes is a containment relation so those types
are contained by the EClass element which refers to them.
Previous Topic:[ATL] Character keeps 'disappearing'
Next Topic:[ATL] Migration to Galileo
Current Time: Fri Jul 25 22:21:15 EDT 2025
Powered by FUDForum. Page generated in 0.04902 seconds
