Home » Modeling » EMF » Loading ecore model from a standalone java app
Loading ecore model from a standalone java app [message #504594] Mon, 21 December 2009 12:18 Go to next message
Hi.
I am trying to load the UML_21.ecore file from the eclipse emf source tree.
I can parse the metamodel successfully so far. However when i try to loop over the eClass obects in it i keep getting null when i try to get the superclass for the EModelElement.
The strange thing is the getEPackage is only null when i get to the EModelElement(only).
The Element class eClass.getEGenericSuperTypes() returns a single type (EmodelElement) but doing getEClassifier().getEPackage() on that type always returns null.
Here is the loop i use to go over the super types for each class.
for (superType : eClass.getEGenericSuperTypes ) {
superType.getEClassifier().getEPackage()
why am i getting null wheni do getEClassifier().getEPackage() on the EModelElement class only ?
The emf i am using is the libs that come with galileo. i copied the emf jar files.
Re: Loading ecore model from a standalone java app [message #504609 is a reply to message #504594] Mon, 21 December 2009 08:26 Go to previous messageGo to next message
Dameer,
Comments below.
Dameer Joog wrote:
> Hi.
> tree.
They've got online documentation for standalone use of UML.
It sounds like a broken proxy. Does EObject.eIsProxy return ttrue?
Likely you've missed an important registration step needed for
standalone. Are you following all the documented steps?
> emf jar files.
Re: Loading ecore model from a standalone java app [message #504610 is a reply to message #504609] Mon, 21 December 2009 13:33 Go to previous messageGo to next message
This is the code i scraped to do model loading
// Create a resource set to hold the resources.
ResourceSet resourceSet = new ResourceSetImpl();
Map<String, Object> options = resourceSet.getResourceFactoryRegistry()
.getExtensionToFactoryMap();
// options.put("xml", new XMLResourceFactoryImpl());
// Register the appropriate resource factory to handle all file
// extensions.
options.put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
// URI uri = file.isFile() ? URI.createFileURI(file.getAbsolutePath()):
// URI.createURI(args[0]);
URI uri = URI.createFileURI(resPath);
resource = resourceSet.getResource(uri, true);
System.out.println("Loaded " + uri);
Re: Loading ecore model from a standalone java app [message #504637 is a reply to message #504610] Mon, 21 December 2009 15:55 Go to previous messageGo to next message
This is the code i use to go over the supertypes
//EGenericType superType=null;
System.out.println(" class " + eClass.getName() +" {");
for (EGenericType superType : eClass.getEGenericSuperTypes()) {
//String typeName = getTypeName(superType, eClass);
EPackage currPackage = superType.getEClassifier().getEPackage();
if(currPackage==null){
System.out.println("eClass proxy:"+eClass.eIsProxy());
System.out.println("superType proxy:"+superType.eIsProxy());
System.out.println("classifier proxy:"+superType.getEClassifier().eIsProxy());
//System.out.println("Element:null");
}else {
The code above outputs :
[java] class Element {
[java] eClass proxy:false
[java] superType proxy:false
[java] classifier proxy:true
[java] }
Re: Loading ecore model from a standalone java app [message #504689 is a reply to message #504637] Tue, 22 December 2009 03:24 Go to previous messageGo to next message
Dameer,
Please look at the UML documentation for how to work with UML stand
alone; specialized registrations are required, not just the general EMF
ones. If it's not working, ask on the UML2 newsgroup about it.
> }else {
> [java] }
Re: Loading ecore model from a standalone java app [message #505514 is a reply to message #504689] Thu, 31 December 2009 05:52 Go to previous messageGo to next message
Hi Ed.
Now ... I think i am facing the same issue as http://www.openarchitectureware.org/forum/viewtopic.php?show topic=8392
I think that when its running standalone it is not able to find the Ecore.ecore file in the file path. So i maybe need to do this urimap prgaramatically. Ca you tell me what i will need to do this in java ?
Thanks a lot for all your help !
p.s.
i also asked the same question in the uml groups but i think this may not be related to UML.
http://www.eclipse.org/forums/index.php?t=msg&th=159800& amp;start=0&
Re: Loading ecore model from a standalone java app [message #505532 is a reply to message #505514] Thu, 31 December 2009 09:18 Go to previous messageGo to next message
Dameer,
What have you tried? What URI are you using to load the initial resource?
Dameer Joog wrote:
> Hi Ed.
> p.s.
Re: Loading ecore model from a standalone java app [message #505537 is a reply to message #505532] Thu, 31 December 2009 16:11 Go to previous messageGo to next message
Hi Ed.
I am using the latest emf that came with galileo btw.
This is the method i pasted before to load the initial resource its all in one method:
The app is standalone with emf jar files in the class path. I did not see more things that i need to perform the uri mapping.
Thanks.
Re: Loading ecore model from a standalone java app [message #505541 is a reply to message #505537] Thu, 31 December 2009 13:02 Go to previous messageGo to next message
Dameer,
Comments below.
Dameer Joog wrote:
> Hi Ed.
> all in one method:
Ecore resources should use EcoreResourceFactoryImpl.
What's the actual value of resPath? Where are you trying to load Ecore
resources from?
> Thanks.
Re: Loading ecore model from a standalone java app [message #505544 is a reply to message #505541] Thu, 31 December 2009 18:22 Go to previous messageGo to next message
I am loading the ecore file from src/test/UML_21.ecore and it is getting successfully loaded except that something is borked on the proxy *only* on a single class called ELement that derives from EmodelElement. All other classes are fine !
Since EmodelElemnt is in Ecore.ecore it has to find it .
Here is the modified code
EPackage.Registry reg1;
reg1 = resourceSet.getPackageRegistry();
reg1.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
XMIResourceFactoryImpl xmiFactory = new XMIResourceFactoryImpl();
EcoreResourceFactoryImpl ecoreFactory = new EcoreResourceFactoryImpl();
// extensions.
options.put("xmi", xmiFactory);
options.put("ecore", ecoreFactory);
Re: Loading ecore model from a standalone java app [message #505547 is a reply to message #504594] Thu, 31 December 2009 18:50 Go to previous messageGo to next message
I added :
File fullPath = getFullPath(resPath);
URI uri = URI.createFileURI(fullPath.getAbsolutePath());
And all seems to work ... thank you so much for all your help !
Re: Loading ecore model from a standalone java app [message #505556 is a reply to message #505544] Fri, 01 January 2010 10:09 Go to previous message
Dameer,
I see that resource references
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore so you'll need
to be able to load Ecore.ecore has well. You'll need to specify a URI
mapping from platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore to
wherever you put Ecore.ecore. It's located as source in
org.eclipse.emf.ecore/model/Ecore.ecore.
> // extensions.
Previous Topic:Is EMF suitable to implement key/keyref pairs?
Next Topic:Persistence of Multiplicity-Many Reference
Current Time: Fri Sep 19 01:08:53 EDT 2025
Powered by FUDForum. Page generated in 0.05244 seconds
