Home » Eclipse Projects » EclipseLink » NoSuchMethodException when using FetchType.Lazy and weaving
NoSuchMethodException when using FetchType.Lazy and weaving [message #501747] Thu, 03 December 2009 11:32 Go to next message
Dear all!
Once again I need your help! Rolling Eyes
I'm getting strange NoSuchMethodExceptions for all of my one-to-one and one-to-many relations. The problem goes away when I turn off weaving or when I use FetchType.EAGER. I generated the code with DALI to make sure I did not make any mistake.
Here are the exceptions:
Local Exception Stack:
Exception [EclipseLink-60] (Eclipse Persistence Services - 2.0.0.v20091121-r5847): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The method [_persistence_setdv_vh] or [_persistence_getdv_vh] is not defined in the object [ppd.model.entities.Vertrag].
Internal Exception: java.lang.NoSuchMethodException: ppd.model.entities.Vertrag._persistence_getdv_vh()
Mapping: org.eclipse.persistence.mappings.OneToOneMapping[dv]
Descriptor: RelationalDescriptor(ppd.model.entities.Vertrag --> [DatabaseTable(VERTRAG)])
	at org.eclipse.persistence.exceptions.DescriptorException.noSuchMethodWhileInitializingAttributesInMethodAccessor(DescriptorException.java:1152)
	at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.initializeAttributes(MethodAttributeAccessor.java:154)
	at org.eclipse.persistence.mappings.DatabaseMapping.preInitialize(DatabaseMapping.java:1208)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.preInitialize(ForeignReferenceMapping.java:804)
	at org.eclipse.persistence.mappings.ObjectReferenceMapping.preInitialize(ObjectReferenceMapping.java:940)
	at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3317)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:429)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:671)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:620)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:228)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:366)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:151)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:207)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:195)
	at ppd.datastore.MitarbeiterDAO.getListe(MitarbeiterDAO.java:30)
	at ppd.provider.PersonenProvider.getElements(PersonenProvider.java:15)
	at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:935)
	at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:692)
	at org.eclipse.jface.viewers.AbstractTableViewer.getRawChildren(AbstractTableViewer.java:1077)
	at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:869)
	at org.eclipse.jface.viewers.StructuredViewer.getSortedChildren(StructuredViewer.java:992)
	at org.eclipse.jface.viewers.AbstractTableViewer.internalRefreshAll(AbstractTableViewer.java:690)
	at org.eclipse.jface.viewers.AbstractTableViewer.internalRefresh(AbstractTableViewer.java:638)
	at org.eclipse.jface.viewers.AbstractTableViewer.internalRefresh(AbstractTableViewer.java:624)
	at org.eclipse.jface.viewers.AbstractTableViewer$2.run(AbstractTableViewer.java:579)
	at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1363)
	at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1326)
	at org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(AbstractTableViewer.java:577)
	at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:251)
	at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1601)
	at ppd.view.PersonSucheFrmView.createPartControl(PersonSucheFrmView.java:70)
	at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:371)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:230)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:594)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:312)
	at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:545)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:265)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:64)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:478)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1268)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1221)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1620)
	at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:659)
	at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:585)
	at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:569)
	at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:269)
	at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:930)
	at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2494)
	at org.eclipse.ui.internal.WorkbenchWindow$22.run(WorkbenchWindow.java:2933)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
	at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2914)
	at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:720)
	at org.eclipse.ui.internal.Workbench$18.runWithException(Workbench.java:1065)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
	at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync(UICallBackManager.java:115)
	at org.eclipse.swt.widgets.Display$2.run(Display.java:695)
	at org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler.runNonUIThreadWithFakeContext(UICallBackServiceHandler.java:460)
	at org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeContext(UICallBack.java:44)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:693)
	at org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExceptions(StartupThreading.java:55)
	at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Workbench.java:1061)
	at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Workbench.java:1888)
	at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbench.java:1824)
	at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWindow(WorkbenchConfigurer.java:188)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:790)
	at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1430)
	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:110)
	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1425)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2406)
	at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2295)
	at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:514)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:497)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
	at ppd.PersonEntryPoint.createUI(PersonEntryPoint.java:27)
	at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:92)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:231)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:119)
	at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NoSuchMethodException: ppd.model.entities.Vertrag._persistence_getdv_vh()
	at java.lang.Class.getDeclaredMethod(Class.java:1937)
	at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.findMethod(PrivilegedAccessHelper.java:61)
	at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getMethod(PrivilegedAccessHelper.java:228)
	at org.eclipse.persistence.internal.helper.Helper.getDeclaredMethod(Helper.java:1039)
	at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.initializeAttributes(MethodAttributeAccessor.java:145)
	... 85 more
Runtime Exceptions:
	at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.getMethodReturnType(PrivilegedAccessHelper.java:302)
	at org.eclipse.persistence.internal.descriptors.MethodAttributeAccessor.getGetMethodReturnType(MethodAttributeAccessor.java:105)
	at org.eclipse.persistence.mappings.ForeignReferenceMapping.validateBeforeInitialization(ForeignReferenceMapping.java:1505)
	at org.eclipse.persistence.descriptors.ClassDescriptor.validateBeforeInitialization(ClassDescriptor.java:5260)
	at org.eclipse.persistence.descriptors.ClassDescriptor.preInitialize(ClassDescriptor.java:3323)
I use M16. I tried the current RC1, but had some error so I switched back. I'd like to know if this is a bug or a misconfiguration. I use Eclipselink in a RAP-Project.
Thanks!
icon12.gif  Re: NoSuchMethodException when using FetchType.Lazy and weaving [message #501940 is a reply to message #501747] Fri, 04 December 2009 09:33 Go to previous messageGo to next message
Found the problem myself. If found out that the problem only occured when it was launched from within Eclipse. Running it standalone worked. To make it short:
In the launch configuration there was missing a VM parameter:
-Dosgi.framework.extensions=org.eclipse.persistence.jpa.equi nox.weaving
Without that parameter weaving will not work. This is a litte weaving pitfall Smile
Greetings to everybody who had the same problem
Re: NoSuchMethodException when using FetchType.Lazy and weaving [message #504561 is a reply to message #501940] Mon, 21 December 2009 09:32 Go to previous messageGo to next message
Dear i am getting the same error, and i added the VM argument but not effect. So can you tell how to disable runtime weaving and make it happen all on build time?
Re: NoSuchMethodException when using FetchType.Lazy and weaving [message #505306 is a reply to message #504561] Tue, 29 December 2009 03:16 Go to previous message
There is more than one way to do it. I put this in persistence.xml:
<property name="eclipselink.weaving" value="false"/>
You can also set this property in java of course.
HTH
[Updated on: Tue, 29 December 2009 08:16] by Moderator
Previous Topic:OSGI & JPA
Next Topic:JPA 2.0 BUG
Current Time: Wed Oct 15 15:18:00 EDT 2025
Powered by FUDForum. Page generated in 0.04834 seconds
