Home » Archived » Buckminster » org.eclipse.buckminster.ant.AntBuilder
org.eclipse.buckminster.ant.AntBuilder [message #504559] Mon, 21 December 2009 04:26 Go to next message
Does anybody know, how to set the classpath for ant in the
<buildCommand> specification of the org.eclipse.buckminster.ant.AntBuilder?
I need to add following libraries
- aspectjrt.jar
- aspectjtools.jar
- myAspect (Folder)
Thanks for your answer,
Alain.
Re: org.eclipse.buckminster.ant.AntBuilder [message #504875 is a reply to message #504559] Wed, 23 December 2009 04:35 Go to previous messageGo to next message
I had a look at the "org.eclipse.buckminster.ant.AntBuilderConstants"
class (where can i find the source for that?) but I could not find a
constant which describes the possibility to extend the class path for ant.
Which classpath will be used by the buckminster-antbuilder?
Alain.
Re: org.eclipse.buckminster.ant.AntBuilder [message #504889 is a reply to message #504875] Wed, 23 December 2009 06:25 Go to previous messageGo to next message
Hi Alain,
The Buckminster ant builder uses the Eclipse Ant builder underneath, so everything that applies to the Eclipse ant
framework, also applies to the Buckminster ant builder.
Thomas Hallgren
On 2009-12-23 10:35, Alain Helfenstein wrote:
> Alain.
Re: org.eclipse.buckminster.ant.AntBuilder [message #504890 is a reply to message #504875] Wed, 23 December 2009 06:26 Go to previous messageGo to next message
In the Buckminster SVN.
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk
or more specificly:
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster.ant/src/java/org/eclipse/buck minster/ant/AntBuilderConstants.java
Thomas Hallgren
Re: org.eclipse.buckminster.ant.AntBuilder [message #505194 is a reply to message #504559] Mon, 28 December 2009 09:05 Go to previous message
One solution is, to use the <classpath> tag of ant itself.
<taskdef
resource="org/aspectj/tools/ant/taskdefs/aspectjTaskdefs.properties ">
<classpath>
<fileset dir="lib_aspectj">
<include name="*.jar"/>
</fileset>
</classpath>
</taskdef>
Regards, Alain.
Previous Topic:maven authentication issue
Next Topic:org.eclipse.buckminster.ant.AntBuilder <refresh.resource>
Current Time: Wed Jul 30 14:57:32 EDT 2025
Powered by FUDForum. Page generated in 0.04156 seconds
