Home » Modeling » EMF » instanceof for (dynamic) EObject
instanceof for (dynamic) EObject [message #504309] |
Thu, 17 December 2009 23:36  |
Hi all,
short story:
I must find out if a given dynamic EObject (model instance) is an
instance of a known EClassifier (model) previously generated via the
classic "EMF Generator Model" wizard from an XSD.
The particularity here is that the model instance (EObject) may come
from a model which comes from an XSD file which imports another XSD
which has the ComplexType to which am i trying to test the instanceof
against.
Unsuccessful attempts so far are like these (where TextArea is my known
ComplexType and eRef is the reference to my dynamic EObject) :
#1
CommonPackage.eINSTANCE.getTextArea().isInstance(eRef.getERe ferenceType());
#2
CommonPackage.eINSTANCE.getTextArea().isSuperTypeOf(eRef.get EReferenceType());
#3
CommonPackage.eINSTANCE.getTextArea().isInstance(eRef);
long story:
I've got an RCP app which allows my users to load XSD files and creates
ECore models from them. The app then allows the users to create model
instances from these generated ECores.
I've got some "special" XSDs in which i know some ComplexTypes a-priori
and hence i would like my app to behave in special way if a given model
instance is derived from any of these "special" ComplexTypes.
The users may perfectly import my "special" XSD files into their XSDs
and then construct ComplexTypes of their own which "subclass" my
I must recognize this type hierarchy via the "instanceof" operation
which i am trying to develop, such that i can tell if a given model
instance subclasses one of my "special" ComplexTypes.
much thanks & kind regards,
ARibeiro
Re: instanceof for (dynamic) EObject [message #504329 is a reply to message #504321] |
Fri, 18 December 2009 05:48   |
Hi Ed,
(as always, lots of thanks in advance)
comments inline.
On 18-12-2009 10:22, Ed Merks wrote:
> ARibeiro,
> Comments below.
> flai wrote:
>> Hi all,
>> short story:
> That sounds like a contradiction....
>> against.
>> known ComplexType and eRef is the reference to my dynamic EObject) :
>> #1
> Here you're at the wrong meta level.
>> #2
> This would work, but if you literally have a dynamic copy of
> CommonPackage, they simply aren't related in this way.
>> #3
> Here too you're at the wrong meta level.
> In no case will a dynamic instance ever be an instance of a generated
> classifier.
>> long story:
>> creates ECore models from them. The app then allows the users to
>> create model instances from these generated ECores.
>> a-priori and hence i would like my app to behave in special way if a
>> given model instance is derived from any of these "special" ComplexTypes.
> You'd have to make sure that the XSDEcoreBuilder uses those special
> generated Ecore instances rather than creating new dynamic versions of
> them.
How could I do this?
(I've got here your EMF book if you think there's a good example of this
case in it)
> They won't ever be instances of your generated type unless you ensure
> the Ecore model being used is really the generated one and not a dynamic
> copy of it.
How could i tell the generator to use my previously generated instance
instead of the dynamic one?
I though that having the same namespace in the schema would do this.
>> ARibeiro
Re: instanceof for (dynamic) EObject [message #504336 is a reply to message #504329] |
Fri, 18 December 2009 06:33   |
André,
If you look at XSDEcoreBuilder's getEPackage method you'll see how it
creates a new package if it doesn't find an existing package in
targetNamespaceToEPackageMap so you'd need to populate that map with
existing package instances.
André Ribeiro wrote:
> Hi Ed,
> comments inline.
>> ARibeiro,
>> Comments below.
>> flai wrote:
>>> Hi all,
>>> short story:
>>> against.
>>> #1
>>> #2
>>> #3
>> classifier.
>>> long story:
>>> ComplexTypes.
>> them.
> this case in it)
>> copy of it.
>>> ARibeiro
Re: instanceof for (dynamic) EObject [message #504572 is a reply to message #504336] |
Mon, 21 December 2009 09:56   |
Hi again Ed,
I've implemented your suggestion, but i still fail to understand why my
CommonPackage is creating *new EClasses* when i invoke the lines:
CommonPackage.eINSTANCE.getCheckList();
CommonPackage.eINSTANCE.getTextArea();
if i do
System.out.println(CommonPackage.eINSTANCE.getCheckList());
i get smth like:
org.eclipse.emf.ecore.impl.EClassImpl@40993028 (name: CheckList11)
(instanceClassName: null) (abstract: false, interface: false)
NOTE: the 11 after the name
(full source in
http://code.google.com/p/emf-generic-editor/source/browse/tr unk/com.rd.genericeditor/src/com/rd/emf/geneditor/view/edito rs/generic/binding/EmfSwtBindingFactory.java?r=6#148)
the *CommonPackage* should be already registered and should return
instances of my generated object, right? i really dont get it this time?!
thanks a lot,
André
On 18-12-2009 11:33, Ed Merks wrote:
> André,
>> Hi Ed,
>> comments inline.
>>> ARibeiro,
>>> Comments below.
>>> flai wrote:
>>>> Hi all,
>>>> short story:
>>>> against.
>>>> #1
>>>> #2
>>>> #3
>>> classifier.
>>>> long story:
>>>> ComplexTypes.
>>> them.
>> this case in it)
>>> copy of it.
>>>> ARibeiro
Re: instanceof for (dynamic) EObject [message #504608 is a reply to message #504572] |
Mon, 21 December 2009 08:26   |
André,
Set a breakpoint in the constructor for EPackage or where the nsURI is
set and what how the XSDEcoreBuilder gets to that point and creates a
clone of the model (and all the other places that get you there...
> Hi again Ed,
> my CommonPackage is creating *new EClasses* when i invoke the lines:
> if i do
> i get smth like:
> (full source in
I don't actually get the question. The CommonPackage's structure is
created when eINSTANCE is first access...
> thanks a lot,
> André
>> André,
>>> Hi Ed,
>>> comments inline.
>>>> ARibeiro,
>>>> Comments below.
>>>> flai wrote:
>>>>> Hi all,
>>>>> short story:
>>>>> against.
>>>>> #1
>>>>> #2
>>>>> #3
>>>> classifier.
>>>>> long story:
>>>>> ComplexTypes.
>>>> them.
>>> this case in it)
>>>> dynamic
>>>> copy of it.
>>>>> ARibeiro
Re: instanceof for (dynamic) EObject [message #507548 is a reply to message #504608] |
Wed, 13 January 2010 14:29   |
Hi again,
Perhaps you may shed a bit more of light over this problem ...
I've got the XSDEcoreBuilder running with options
xsdECoreBuilderOptions.put(XSDEcoreBuilder.OPTION_REUSE_REGI STERED_PACKAGES,
Boolean.TRUE);
and
xsdEcoreBuilder.getTargetNamespaceToEPackageMap().put(MyPack age.eNS_URI,
MyPackage.eINSTANCE);
but i am getting to the conclusion that XSDEcoreBuilder creates new
EClasses (of form ComplexType1, ComplexType11, ComplexType111, etc ..)
in XSDEcoreBuilder.resolveNameConflicts() due to the fact that it
already has (previously statically generated) EClassifiers with same
name in MyPackage.
Although i wanted it to use my existing EClassifiers in MyPackage, but
somehow it fails to do so ... do you have any idea why that might be
happening?
Much thanks in advance,
André
On 21-12-2009 18:14, Ed Merks wrote:
> André,
>> Hi again Ed,
>> if i do
>> i get smth like:
>> (full source in
>> time?!
>> thanks a lot,
>> André
>>> André,
>>>> Hi Ed,
>>>> comments inline.
>>>>> ARibeiro,
>>>>> Comments below.
>>>>> flai wrote:
>>>>>> Hi all,
>>>>>> short story:
>>>>>> instanceof
>>>>>> against.
>>>>>> #1
>>>>>> #2
>>>>>> #3
>>>>> classifier.
>>>>>> long story:
>>>>>> ComplexTypes.
>>>>> versions of
>>>>> them.
>>>> this case in it)
>>>>>> XSDs
>>>>> dynamic
>>>>> copy of it.
>>>>>> ARibeiro
Re: instanceof for (dynamic) EObject [message #507814 is a reply to message #507562] |
Thu, 14 January 2010 13:24   |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
<title></title>
</head>
Ed Almighty!<br>
<br>
By analyzing the code that you suggested I found my 2 problems:<br>
1) I was building the options map, but i was not passing it to the
XSDEcoreBuilder (shame on me!)<br>
2) I was passing new BasicExtendedMetaData(new EPackageRegistryImpl())
to the XSDECoreBuilder constructor cause i copied it from the
XSDEcoreBuilder() (no-args constructor), instead of
EPackage.Registry.INSTANCE<br>
<br>
Now I moved on to a new challenge, which is to build an ecore model
from this XSD<br>
<a class="moz-txt-link-freetext" href="http://docs.oasis-open.org/emergency/cap/v1.2/CAP-v1.2.xsd">http://docs.oasis-open.org/emergency/cap/v1.2/CAP-v1.2.xsd</a> (OASIS
Common Alerting Protocol)<br>
which i sadly acknowledge is not possible ... probably due to the way
the way the schema is designed, i'll devote some time to understand why<br>
<br>
Thanks a lot for the help,<br>
André<br>
<br>
PS in your next visit to Portugal, drinks are on me ;)<br>
<br>
On 13-01-2010 20:31, Ed Merks wrote:
<blockquote cite="mid:hilai6$7k6$1@build.eclipse.org" type="cite">
André,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hil6vn$sbv$1@build.eclipse.org" type="cite">Hi
again, <br>
<br>
Perhaps you may shed a bit more of light over this problem ... <br>
<br>
I've got the XSDEcoreBuilder running with options <br>
Boolean.TRUE);
<br>
and <br>
<br>
<br>
name in MyPackage. <br>
</blockquote>
So it must be doing that here in computeEClass<br>
<blockquote><small> else if (reuseRegisteredPackages)</small><br>
<small> {</small><br>
<small> EClass eClass =
(EClass)extendedMetaData.getType(xsdComplexTypeDefinition.ge tTargetNamespace(),
xsdComplexTypeDefinition.getName());</small><br>
<small> if (eClass != null)</small><br>
<small> return eClass;</small><br>
<small> }</small><br>
<br>
<small> EClass eClass = EcoreFactory.eINSTANCE.createEClass();
<<<<<<</small><br >
<small> setAnnotations(eClass, xsdComplexTypeDefinition);</small><br>
</blockquote>
So that means the type isn't found in the extended metadata, which
leads me to wonder which XSDEcoreBuilder constructor you used.<br>
<blockquote cite="mid:hil6vn$sbv$1@build.eclipse.org" type="cite"><br>
happening? <br>
</blockquote>
I expect you want to use new BasicExtendedMetaData(new
EPackageRegistryImpl(EPackage.Registry.INSTANCE)) or even
ExtendedMetaData.INSTANCE in the constructor, but the latter will
update the global shared registry with the results of your builders, so
not something you'd want to do when running inside of an Eclipse
application that might be hosting other EMF clients).<br>
Much thanks in advance, <br>
André <br>
<br>
On 21-12-2009 18:14, Ed Merks wrote: <br>
<blockquote type="cite">André, <br>
<br>
clone of the model (and all the other places that get you there... <br>
<br>
<br>
André Ribeiro wrote: <br>
<blockquote type="cite">Hi again Ed, <br>
<br>
CommonPackage is creating *new EClasses* when i invoke the lines: <br>
<br>
CommonPackage.eINSTANCE.getCheckList(); <br>
CommonPackage.eINSTANCE.getTextArea(); <br>
<br>
if i do <br>
System.out.println(CommonPackage.eINSTANCE.getCheckList()); <br>
<br>
i get smth like: <br>
(instanceClassName: null) (abstract: false, interface: false) <br>
<br>
NOTE: the 11 after the name <br>
<br>
(full source in
<a moz-do-not-send="true" class="moz-txt-link-freetext"
href=" http://code.google.com/p/emf-generic-editor/source/browse/tr unk/com.rd.genericeditor/src/com/rd/emf/geneditor/view/edito rs/generic/binding/EmfSwtBindingFactory.java?r=6#148"> http://code.google.com/p/emf-generic-editor/source/browse/tr unk/com.rd.genericeditor/src/com/rd/emf/geneditor/view/edito rs/generic/binding/EmfSwtBindingFactory.java?r=6#148</a>)
<br>
<br>
time?! <br>
</blockquote>
created when eINSTANCE is first access... <br>
<blockquote type="cite"><br>
thanks a lot, <br>
André <br>
<br>
On 18-12-2009 11:33, Ed Merks wrote: <br>
<br>
If you look at XSDEcoreBuilder's getEPackage method you'll see how it <br>
creates a new package if it doesn't find an existing package in <br>
targetNamespaceToEPackageMap so you'd need to populate that map with <br>
existing package instances. <br>
<br>
<br>
<blockquote type="cite">Hi Ed, <br>
<br>
(as always, lots of thanks in advance) <br>
<br>
comments inline. <br>
<br>
On 18-12-2009 10:22, Ed Merks wrote: <br>
<blockquote type="cite">ARibeiro, <br>
<br>
Comments below. <br>
<br>
flai wrote: <br>
<blockquote type="cite">Hi all, <br>
<br>
short story: <br>
I must find out if a given dynamic EObject (model instance) is an <br>
instance of a known EClassifier (model) previously generated via the <br>
classic "EMF Generator Model" wizard from an XSD. <br>
</blockquote>
That sounds like a contradiction.... <br>
The particularity here is that the model instance (EObject) may come <br>
from a model which comes from an XSD file which imports another XSD <br>
which has the ComplexType to which am i trying to test the instanceof <br>
against. <br>
<br>
Unsuccessful attempts so far are like these (where TextArea is my <br>
known ComplexType and eRef is the reference to my dynamic EObject) : <br>
<br>
#1 <br>
<br>
<br>
<br>
</blockquote>
Here you're at the wrong meta level. <br>
#2 <br>
<br>
<br>
<br>
</blockquote>
This would work, but if you literally have a dynamic copy of <br>
CommonPackage, they simply aren't related in this way. <br>
#3 <br>
CommonPackage.eINSTANCE.getTextArea().isInstance(eRef); <br>
</blockquote>
Here too you're at the wrong meta level. <br>
<br>
In no case will a dynamic instance ever be an instance of a generated <br>
classifier. <br>
<br>
long story: <br>
I've got an RCP app which allows my users to load XSD files and <br>
creates ECore models from them. The app then allows the users to <br>
create model instances from these generated ECores. <br>
<br>
I've got some "special" XSDs in which i know some ComplexTypes <br>
a-priori and hence i would like my app to behave in special way if a <br>
given model instance is derived from any of these "special" <br>
ComplexTypes. <br>
</blockquote>
You'd have to make sure that the XSDEcoreBuilder uses those special <br>
generated Ecore instances rather than creating new dynamic versions of <br>
them. <br>
</blockquote>
How could I do this? <br>
(I've got here your EMF book if you think there's a good example of <br>
this case in it) <br>
The users may perfectly import my "special" XSD files into their XSDs <br>
and then construct ComplexTypes of their own which "subclass" my <br>
"special" ComplexTypes. <br>
<br>
I must recognize this type hierarchy via the "instanceof" operation <br>
which i am trying to develop, such that i can tell if a given model <br>
instance subclasses one of my "special" ComplexTypes. <br>
</blockquote>
They won't ever be instances of your generated type unless you ensure <br>
dynamic <br>
copy of it. <br>
</blockquote>
How could i tell the generator to use my previously generated instance <br>
instead of the dynamic one? <br>
<br>
I though that having the same namespace in the schema would do this. <br>
much thanks & kind regards, <br>
ARibeiro <br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
Current Time: Fri Jul 25 22:26:04 EDT 2025
Powered by FUDForum. Page generated in 0.06156 seconds
