Home » Modeling » M2T (model-to-text transformation) » Problems accessing to QVTO operations
icon9.gif  Problems accessing to QVTO operations [message #504316] Fri, 18 December 2009 05:04 Go to next message
Hello again!
First of all, I don't know if put this topic here or in thg GMF forum, because it affects to the GMF transformation using XPand templates and QVTO extensions...
I'm having problems when access to the operations of a QVTO extension. My XPand file looks like that:
«IMPORT 'http://www.eclipse.org/gmf/2009/GenModel'»
«IMPORT 'http://www.eclipse.org/emf/2002/GenModel'»
«EXTENSION gmf::EMFUtils»
«AROUND getDiagramVisualID FOR gmfgen::GenDiagram-»
	«EXPAND xpt::Common::generatedMemberComment»
	public static void myFunction() {
		«getReferencingObjects(self)»
«ENDAROUND»
The getReferencingObjects(EObject) is a function placed in a Class in the *gmf.codegen plugin, and is acessible because in the gmf plugin extensions is declared the following extension:
<extension point="org.eclipse.m2m.qvt.oml.javaBlackboxUnits">
    <unit name="EMFUtils" namespace="gmf">
       <library class="org.eclipse.gmf.internal.codegen.util.EMFUtils">
             <metamodel nsURI="http://www.eclipse.org/emf/2002/Ecore"/>
       </library>
    </unit>
</extension>
So I think all is well configured to access to this funtion in this class. I had seen examples in UML2 project, that access to gmf::GenModelUtils extension with the same way I'm doing, and it doesn't work for me... I'm desperate Sad
The error I get is:
Exception (Cannot find operation (getReferencingObjects(GenContainerBase)) for the type (null):in aspects::xpt::diagram::updater::DiagramUpdater, line 26) while generating code
Anybody know where I'm wrong???
Thanks in advance!
Marc
[Updated on: Fri, 18 December 2009 05:07] by Moderator
Re: Problems accessing to QVTO operations [message #504351 is a reply to message #504316] Fri, 18 December 2009 08:11 Go to previous message
Hi Marc,
since you're referring to GMF's modified version of Xpand.
It's best to ask at the GMF newsgroup (which I've CCed).
Sven
Marc schrieb:
> Hello again!
> QVTO extensions...
> «ENDAROUND»
> </library>
> </unit>
> </extension>
> work for me... I'm desperate :(
> Thanks in advance!
> Marc
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Previous Topic:QVTO helper fails
Next Topic:[XPAND] [MWE] 0.8.0 regression
Current Time: Sun Jul 20 23:38:09 EDT 2025
Powered by FUDForum. Page generated in 0.59116 seconds
