Home » Language IDEs » ServerTools (WTP) » Debugger (3.4.2) not stopping at breakpoints - known issue?
Debugger (3.4.2) not stopping at breakpoints - known issue? [message #504225] Thu, 17 December 2009 13:24 Go to next message
I noticed that when debugging a webapp with Tomcat on Eclipse 3.4.2 GanymedeSR2 the debugger fails to stop at breakpoints more often than not. I never experienced this problem in earlier versions.
Is this a know issue?
If it is a known issue, was it fixed in 3.4.2?
I realize that it might have been fixed on a later version, but I am stuck at 3.4.2 because our company unfortunately uses MKS Integrity 2009 for version control... and it doesn't play well with newer versions of Eclipse.
Re: Debugger (3.4.2) not stopping at breakpoints - known issue? [message #504301 is a reply to message #504225] Fri, 18 December 2009 03:44 Go to previous messageGo to next message
There is a known issue in Sun's 1.6.0_14 VM. If you are using that VM
then simply switch to 1.6.0_17.
Dani
> Thanks
Re: Debugger (3.4.2) not stopping at breakpoints - known issue? [message #504324 is a reply to message #504301] Fri, 18 December 2009 05:28 Go to previous messageGo to next message
1.6.0_16 should be ok, too.
Re: Debugger (3.4.2) not stopping at breakpoints - known issue? [message #504333 is a reply to message #504324] Fri, 18 December 2009 06:00 Go to previous messageGo to next message
Right, but if updating. why bother not to take the latest? ;-)
Dani.
Re: Debugger (3.4.2) not stopping at breakpoints - known issue? [message #504334 is a reply to message #504333] Fri, 18 December 2009 06:28 Go to previous messageGo to next message
You're right, I said just for completeness of information. :-)
Well, to be even more precise, the Sun JRE versions affected by this
problem are 1.6.0_14 and 1.6.0_15.
Mauro.
Re: Debugger (3.4.2) not stopping at breakpoints - known issue? [message #504380 is a reply to message #504225] Fri, 18 December 2009 10:27 Go to previous message
Thank you everybody. I am using 1.6.0_14, so that explains it to perfection. I will update to the latest.
Previous Topic:Eclipse, WTP, OSX, Tomcat, Tiles, JSP not found... deploy from Eclipse
Next Topic:WTP project 'cannot reference itself' error
Current Time: Sun Jul 27 09:41:28 EDT 2025
Powered by FUDForum. Page generated in 0.02756 seconds
